Показано с 1 по 7 из 7
Like Tree2Спасибо
  • 2 Размещено RW3DY
Тема: Осциллограф помогите собрать с нуля начинающему
    19.09.2015
    VT DSO-2A20E Hardware Specifications
    Oscilloscope Horizontal (Time) Axis
    Real Time Sampling Frequency (fs) Single Analog Channel
    200 MHz
    Single or Dual Analog Channels with or without 1-bit Digital Channel
    100 MHz, 50 MHz, 25 MHz, 20 MHz, 10 MHz, 5 MHz, 4 MHz,
    2 MHz, 1 MHz, 500 kHz, 400 kHz, 200 kHz, 100 kHz,
    50 kHz, 40 kHz, 20 kHz, 10 kHz, 5 kHz, 4 kHz, 2 kHz,
    1 kHz, 500 Hz, 400 Hz, 200 Hz, 100 Hz, 50 Hz, 40 Hz,
    20 Hz, 10 Hz, 5 Hz, 4 Hz, 2 Hz, 1 Hz
    Equivalent Sampling Frequency = [Real Time Sampling Frequency] × [Number of Frames Persisted]. Maximum 40 GHz, for repetitive signals whose maximum frequency is less than ¼ of the real time sampling frequency. Not valid for the case of post-trigger.
    Buffer Size Normal Frame Mode Analog Single Channel
    40000 samples (8 bits)
    20000 samples (16 bits)
    Dual Channels
    20000 samples / channel (8 bits, Non-ALT mode)
    10000 samples / channel (16 bits, Non-ALT mode)
    40000 samples / channel (8 bits, ALT mode)
    20000 samples / channel (16 bits, ALT mode)
    Digital 20000 samples (1 bit)
    Record Mode
    (Streaming Mode) Limited only by hard disk space available and maximum file size allowed by the operating system.
    Maximum sampling frequency for continuous streaming is computer speed and software setting dependent and typically 10 MHz (single channel, 8 bit) in Multi-Instrument.
    Roll Mode
    (Streaming Mode for Low Frequency Signals) Limited only by the computer memory available.
    Roll Mode is allowed when fs ≤ 1MHz and [Record Length] ≥ 4 × [Roll Width]. Maximum sampling frequency for continuous streaming is computer speed and software setting dependent.
    Sweep Time 5 ns ~ 500 s (Non-Streaming Mode)
    Sampling Frequency Accuracy ± 50 ppm
    Oscilloscope Vertical (Analog) Axes
    Number of Channels 2 (i.e. Ch. A and Ch. B)
    ADC Bit Resolution 10 Bits (can be reduced to 8 bits)
    Enhanced ADC Bit Resolution
    (available only when Sampling Frequency is less than 100 MHz) 16 Bits
    If this option is selected, the effective bit resolution increases from 10 bits to up to 16 bits as the sampling frequency goes down.
    (Assuming white noise in the signal)
    Sampling Frequency Effective Bit Resolution Sampling Frequency Effective Bit Resolution
    ≥ 100 MHz 10 Bits ≤ 25 MHz 11 Bits
    ≤ 6.25 MHz 12 Bits ≤ 1.563 MHz 13 Bits
    ≤ 391 kHz 14 Bits ≤ 97.7 kHz 15 Bits
    ≤ 24.4 kHz 16 Bits ≤ 6.10 kHz 16 Bits
    ≤ 1.526 kHz 16 Bits
    Bandwidth fs > 50 MHz 80 MHz
    fs ≤ 50 MHz 8 Bits No Effective Bit Resolution Enhancement 80 MHz
    Effective Bit Resolution Enhancement 15 ~ 25 MHz
    16 Bits Effective Bit Resolution Enhancement about 0.443 fs
    Voltage Measuring Range
    (Full Scale) ± 10 mV, ± 20 mV, ± 50 mV, ± 100 mV, ± 200 mV, ± 500 mV, ± 1 V, ± 2 V, ± 5 V, ± 10 V, ± 20 V, ± 50 V
    Max. Allowed Voltage ± 100 V (DC + AC peak), derated above 100kHz
    DC Accuracy ± 0.5%
    Coupling Type AC / DC
    Input Isolation No (Isolation can be achieved through a USB isolator)
    Terminal Type Referenced Single-Ended, BNC
    Input Impedance 1 MΩ , 15 pF
    Zero Calibration Through hardware. Individually done at factory, user adjustable
    Gain Calibration Through hardware. Individually done at factory, user adjustable
    Oscilloscope Vertical (Digital) Axis
    Number of Channels 1 (i.e. External Trigger Channel, 1-bit ADC)
    Bandwidth 140 MHz
    Threshold Resolution 11 mV
    Threshold Hysteresis 225 mV
    Threshold Range ± 20 V
    Max. Allowed Voltage ± 100V (DC + AC peak), derated above 100kHz
    Threshold DC Accuracy ± 1%
    Coupling Type DC
    Zero Calibration Through software. Individually done at factory.
    Gain Calibration Through software. Individually done at factory.
    Oscilloscope Trigger
    Trigger Detection Method Digital
    Trigger Source Ch. A, Ch. B, EXT, ALT
    Trigger Mode Auto, Normal, Single, Slow
    Trigger Edge Rising, Falling
    Trigger Level Adjustable within full scale
    Pre-Trigger -100% ~ 0% of Record Length
    Post-Trigger 0 ~ 100% of Record Length
    Trigger Frequency Rejection Nil: No Rejection
    HFR: High Frequency Rejection, cut off at 0.11fs
    NR0: Noise Rejection, hysteresis = 1% of half of full scale
    NR1: Noise Rejection, hysteresis = 2% of half of full scale
    NR2: Noise Rejection, hysteresis = 4% of half of full scale
    NR3: Noise Rejection, hysteresis = 8% of half of full scale
    NR4: Noise Rejection, hysteresis = 16% of half of full scale
    HN0: HFR + NR0
    HN1: HFR + NR1
    HN2: HFR + NR2
    HN3: HFR + NR3
    HN4: HFR + NR4
    HNX: selectable HFR + adjustable hysteresis = 0% ~ 25% of half of full scale
    Note: The specified hysteresis may be modified internally to ensure [Trigger Level (%)] – [Hysteresis (%)] ≥ -100% at rising edge, or [Trigger Level (%)] + [Hysteresis (%)] ≤ 100%] at falling edge.
    Oscilloscope Dynamic Performance (Typical)
    THD fs=100 kHz, f=1 kHz, from 2nd to 20th order, full-scale input:
    8 bits (without bit resolution enhancement): ≤ -55 dB
    8 bits (with bit resolution enhancement): ≤ -56 dB
    16 bits: ≤ -69 dB
    IMD (250 Hz + 8 kHz, 4:1) fs=100 kHz, from 2nd to 3rd order, full-scale input:
    8 bits (without bit resolution enhancement): ≤ -51 dB
    8 bits (with bit resolution enhancement): ≤ -52 dB
    16 bits: ≤ -59 dB
    IMD (19 kHz +20 kHz, 1:1) fs=100 kHz, 2nd order only, full-scale input:
    8 bits (without bit resolution enhancement): ≤ -65 dB
    8 bits (with bit resolution enhancement): ≤ -65 dB
    16 bits: ≤ -78 dB
    SFDR fs=100 kHz, f=1 kHz, full-scale input:
    8 bits (without bit resolution enhancement): ≥ 61 dB
    8 bits (with bit resolution enhancement): ≥ 61 dB
    16 bits: ≥ 62 dB
    Crosstalk ≤ -45 dB (at the same voltage measuring range for full bandwidth)
    Noise For voltage measuring ranges ± 50 mV and above:
    8 bits (without bit resolution enhancement): ≤ ± 3 counts (± 1%)
    8 bits (with bit resolution enhancement, fs =100 kHz): ≤ ± 2 counts (± 0.8%)
    16 bits (fs =100 kHz): ≤ ± 0.3 8-bit count (± 0.1%)
    For voltage measuring ranges ± 10 mV and ± 20 mV:
    8 bits (without bit resolution enhancement): ≤ ± 15 counts (± 6%)
    8 bits (with bit resolution enhancement, fs =100 kHz): ≤ ± 9 counts (± 4%)
    16 bits (fs =100 kHz): ≤ ± 1 8-bit count (± 0.4%)
    Signal Generator General
    Coupling Type DC
    Output Isolation No
    Output Impedance 50 Ω
    Overvoltage Protection ± 35 V
    Signal Generator -Analog (when Signal Generator is running)
    Output Voltage Range ± 2 V, adjustable
    DAC Bit Resolution 12 Bits
    Output Sampling Frequency (fs) DDS Mode
    200 MHz, 100 MHz, 50 MHz
    DDS Mode or Streaming Mode
    20 MHz, 10 MHz, 5 MHz, 2 MHz, 1 MHz, 500 kHz, 200 kHz, 100 kHz, 50 kHz, 20 kHz, 10 kHz, 5 kHz
    Output Sampling Frequency Accuracy ± 50 ppm
    Bandwidth DC ~ 60 MHz
    Output Signal Frequency 0 ~ ½ of output sampling frequency
    Rise Time (10% ~ 90%) < 5.8 ns
    DC Offset Range Full output voltage range
    DC Accuracy ± 0.2% of full scale
    Waveform DDS Mode* Sine, Rectangle (duty cycle adjustable), Triangle, Saw Tooth,
    White Noise, MLS (length = 263-1), User Configurable Waveform Library (Arbitrary), Musical Scale
    Streaming Mode* Sine, Rectangle (duty cycle adjustable), Triangle, Saw Tooth,
    White Noise, Pink Noise, MultiTones, MLS (127~16777215), DTMF, User Configurable Waveform Library (Arbitrary), Musical Scale
    Signal Frequency Resolution
    DDS Mode <0.05 Hz (fs = 200 MHz)
    <0.000001 Hz (fs = 5 kHz)
    Streaming Mode Virtually infinitesimal
    Buffer Size DDS Mode Without interpolation: 1024 samples
    With interpolation: 1024 × 65536 = 67108864 samples
    (Note: interpolation is only available when fs <= 3.125 MHz)
    Streaming Mode Virtually unlimited
    Frequency Sweep DDS Mode Supports linear sweep of all types of repetitive waveforms.
    Sweep speed range: 1/32768 × fs2 / 232 ~ 65535 × fs2 / 232
    (e.g. 284 Hz/s ~ 610 GHz/s when fs = 200 MHz)
    Streaming Mode Supports linear and logarithmic sweep of all types of repetitive waveforms.
    Sweep speed range: unlimited
    Amplitude Sweep DDS Mode Supports linear sweep of all types of waveforms.
    Sweep speed range: 1/32768 × fs / (232 –1) ~ 65535 × fs / (232 –1)
    (e.g. 0.000142 %/s ~ 305171 %/s when fs = 200 MHz)
    Streaming Mode Supports linear and logarithmic sweep of all types of waveforms.
    Duration (Signal Length) Resolution DDS Mode 1/fs or 1µs, whichever is greater
    Streaming Mode 1/fs
    THD ≤ -60 dB
    (fs = 2 MHz, f = 1 kHz, from 2nd to 20th order, full-scale output)
    SFDR ≥ 65 dB
    (fs = 2 MHz, f = 1 kHz, full-scale output)
    *DDS mode consumes almost no computer CPU time while streaming mode consumes a lot. Maximum sampling frequency for continuous streaming is computer speed and software setting dependent and typically 10 MHz in Multi-Instrument. More advanced functions are provided via Multi-Instrument software under streaming mode. Please refer to Multi-Instrument software manual for details.
    Signal Generator - Digital (when Signal Generator is not running)
    Voltage Range -1.65 ~ 1.65 V, not adjustable
    Output Signal Frequency Accuracy ± 50 ppm
    Bandwidth 60 MHz
    Waveform Square Signal Frequency 25 MHz / N, (N=1, 2, 3, ….25000)
    MLS Sampling Frequency 25 MHz / N, (N=1, 2, 3, ….25000)
    General
    Interface USB 2.0 High Speed / USB 1.1 Full Speed / USB Isolator
    Device Category in Multi-Instrument ADC Device VT DAQ 1
    DAC Device VT DAO 1
    Firmware Upgradable Yes
    Power Bus powered by USB port, no external power source required.
    Power Consumption Max. 2.5W
    Dimensions 145 mm (L) × 108 mm (W) × 26 mm (H), anodized aluminum case
    System Requirement Windows XP, Vista, 7, 8 or above, 32 bit or 64 bit
    Operating Temperature 0° C ~50° C
    4. P6100 Oscilloscope Probe Hardware Specifications
    Attenuation Ratio × 1, × 10
    Bandwidth DC ~ 100 MHz (× 10), DC ~ 6 MHz (× 1)
    Input Impedance 1 MΩ (× 1, with VT DSO connected)
    10 MΩ (× 10, with VT DSO connected)
    Input Capacitance 18.5 pF ~ 22.5 pF (× 10), 85 pF ~ 120 pF (× 1)
    Input Capacitance Compensation Range 10 ~ 30 pF
    Length 1.2 m
    Accessories include: a 12 cm snap-on rotating ground lead, a sprung hook, two marker rings, a probe compensation adjustment tool, two probe tip caps.
    ВИДЕЛ НА САЙТЕ http://www.virtins.com/VT-DSO-2A20E.shtml
    ХОТЕЛОСЬ БЫ ПОХОЖЕЕ ИЗ ПОДРУЧНЫХ ДЕТАЛЕЙ
    08.09.2015
    Владивосток, Совгавань, возможны другие варианты
    144
    32
    Very High Power Аватар для R9AAA
    03.09.2006
    Челябинск, Россия
    45
    2,363
    1797
    6514
    200 МГц полоса, цифровой и еще начинающему.... о_О Осилите такие платки паять (Hantek DSO1102B)?
    Поверьте - купить готовый значительно дешевле и проще.
    Big Gun Аватар для RX4CD
    02.01.2009
    SA-43
    11,122
    5512
    2774
    Цитата Сообщение от pyriy Посмотреть сообщение
    ВИДЕЛ НА САЙТЕ VT DSO-2A20E: PC based USB 10~16Bit 200MSPS 80MHz Oscilloscope, Spectrum Analyzer, 12-bit 200MSPS 60MHz AWG Signal Generator | Virtins Technology
    Вы в своем уме? Трезвый?!!
    10.07.2012
    Мытищи
    1,202
    1955
    646
    Сергей! Да это прикол, только пока не понял зачем, ну подождем развития событий, а так-то - клиникой пахнет...
    Пишу так потому что имею опыт попыток ремонта DSO (4 канала, 6 ГГц), всей толпой рассматривали плату входных усилителей, от которых запашок пошел, а народ, надо заметить неглупый. Так вот, монтаж там четырехслойный, даже Кейсайт не стал ковыряться, плата только под замену.
    Very High Power Аватар для RV4AI
    08.03.2012
    76
    1,625
    1068
    348
    Только детская наивность, коррелирующая с количеством сообщений или же, с другой стороны, тонкое чувство юмора, совмещенное с желанием флудинга, поясняет якобы "хотелки" топикстартера. Коллега, ЭТО надо покупать... 73!
    10.02.2006
    Истра, Мос.обл.
    7,605
    3764
    8642
    Закрыто.
  1. Помогите начинающему
    от UR5DKA в разделе Общие вопросы
    Последнее сообщение: 08.06.2006, 18:07
  2. Помогите начинающему
    от z014 в разделе КВ аппаратура
    Последнее сообщение: 30.11.2004, 13:45
  3. Помогите начинающему
    от вфт_лщ в разделе Компьютеры и сети
    Ответов: 13
    Последнее сообщение: 13.02.2004, 17:10
  4. Помогите начинающему
    от Igi в разделе Беседка. Для любителей поговорить.
    Последнее сообщение: 21.05.2003, 01:07
  5. Помогите начинающему
    от Igi в разделе Общие вопросы
    Ответов: 27
    Последнее сообщение: 02.05.2003, 22:44
