Цитата:
Первоначальное сообщение от Игорь UN7GM
Пока до QST дело не дошло, вот еще один страдалец. Не иначе, как происки агентов Icom+Kenwood :-).
Date: Sat, 18 Jun 2005 04:15:15 -0000
Subject: No Output Power !!
I received my 9000D 2 days ago (#47) and just started getting
comfortable with the rig and its menu setting. I completely EQ'd the audio with great reports with the 3 qsos I had. Then, this evening during a qso on 75M, running class A and low SWR, the display screen shut off and went completely white and then the power dropped to about 1 to 2 watts !! I switched to VFO B and it has same problem.
I have reset the microprocessor twice, and I reset the menu
twice....no power....I let the rig set for 1/2 hour....no power.... I
also shut the rear power switch on the back...then turned it on and then turned on the front power switch and the display went into a boot up but still no power. I felt the rear of the transmitter and it was just warm....no appearance of a heat problem.
During the first day, I had to turn the rig on twice in succession
before the display would come on. But, on the second day, it only took the initial turn on and it would display.
Another problem I noted yesterday.....the power indicated on the meter is not correct in ssb mode...indicates about 75 watts while my bird wattmeter indicates 200....all other modes report correctly.
Дело не в происках Айкомвудовцев. Скорей всего, индикатор умной машинки показал бедняге среднюю мощность (в SSB она намного меньше пиковой!), а как сделать, чтоб показал пиковую --- тот не сообразил. И умная машинка не дала ему голосовыми связками накачать так, чтоб средняя до пиковой дотянула :) Вот на чего у супермашинки мозгов не хватило --- объяснить незадачливому юзеру, в чём тот не прав :)
