Изменения к версии PowerSDR 2.7.2 от KE9NS - Rev T8 от 24.06.2016 года.
ссылка - PowerSDR - Flex5000
Добавлено:
06/24/16 T8: Add: PowerMate directly into PowerSDR (instead of using an external program). See Setup->General->User Interface->Active to activate PowerMate for changing frequency (currently based on the Tune Step). You can adjust the speed. Tap Knob to cycle through Tune steps: 100hz, 250hz,500hz,1khz
If RIT is Enabled, the Knob changes the RIT value (Tap to Zero the RIT)
Also decided to just include DJConsole instead of compiling a seperate version with and without it.
к версии T7:
06/15/16 T7: Add: Allow SWR in all modes instead of just Tune (for the 3000,5000)
06/12/16 T7: Fix MUT button function when using TUN button (caused by me reducing the TUN volume when in MONitor mode)
06/09/16 T7: remove space beteween meter and digital value. Update SWL.csv
06/08/16 T7: remove lines around meters and frequency. Lets see what happens.
06/05/16 T7: Fix: Allow RX2 meter on low res 1366 x 768 displays, but you must also activate "Auto-Hide the taskbar" to get maximum available vertical pixels available. Right click on the task bar ->properties->Auto-hide the taskbar.
