07.02.2023, 10:07 #1
Землетрясение в Турции и Сирии
Коллеги делюсь полученной информацией с разных источников:
6/February/2023
Feb 6, 2023 · Emergency Comms · Greg, G0DUB
A 7.8 Magnitude earthquake hit Türkiye and Syria at 01:17UTC on 6th February leading to a large loss of life and many casualties. Aftershocks continue in the area with another large 7.5 magnitude event happening at 10:24UTC affecting the response. The emergency communications group of TRAC will be involved in the response activities, primarily expected to be on VHF/UHF but they do also use 3.777 and 7.092MHz as needed. Radio Amateurs are requested to give way to any emergency traffic around those frequencies.
Aziz Sasa TA1E the President of TRAC has stated that Turkey has asked for assistance from the international community and notes that if SAR Groups intend to come for assistance they should contact the Embassies of Turkiye in their countries. He also says that SAR groups should be advised to have at least one Ham Radio operator in their team and/or the facilities to program their radios.
This is a devastating event for the area but please remember that it is easy for ports and airports to be blocked with unrequested supplies so only materials formally requested by the relief agencies should be dispatched and only to named destinations or they are likely to be blocked from import.
https://audio.com/dx-world/28540
Написал письмо Aziz Sasa TA1E с предложением при необходимости пользоваться нашими автоматическими базовыми станциями на КВ (шлюзами) для передачи электронных писем адресатам с мест, где отсутствует интернет и покрытия сотовой связи.
07.02.2023, 10:23 #2Администратор
- 30.04.2011
- Ростов-на-Дону
- 3,890
- 3023
- 2668
Если хотите получить какой-либо отклик на свой пост - прикладывайте, хотя-бы, автоматический перевод из любого онлайн-переводчика, например Яндекса:
А ещё лучше англоязычный оригинал давать в форме ссылки, а выкладывать сразу перевод.6/Февраль/2023
6 февраля 2023 года · Экстренная связь · Грег, G0DUB
Землетрясение магнитудой 7,8 произошло в Турции и Сирии 6 февраля в 01:17 по Гринвичу, что привело к большим человеческим жертвам. Подземные толчки продолжаются в этом районе, и еще одно крупное событие магнитудой 7,5 произошло в 10:24 UTC, повлияв на реакцию. В мероприятиях по реагированию будет задействована группа экстренной связи TRAC, которая, как ожидается, в основном будет работать на УКВ/ УВЧ, но при необходимости они также используют 3,777 и 7,092 МГц. Радиолюбителей просят уступить дорогу любому аварийному трафику вокруг этих частот.
Азиз Саса ТА1Е, президент TRAC, заявил, что Турция обратилась за помощью к международному сообществу, и отмечает, что если группы SAR намерены обратиться за помощью, они должны связаться с посольствами Турции в своих странах. Он также говорит, что группам SAR следует рекомендовать иметь в своей команде по крайней мере одного оператора радиолюбительской связи и/или средства для программирования своих радиостанций.
Это разрушительное событие для региона, но, пожалуйста, помните, что порты и аэропорты легко могут быть заблокированы из-за неиспользованных поставок, поэтому следует отправлять только материалы, официально запрошенные учреждениями по оказанию помощи, и только в указанные пункты назначения, иначе их, скорее всего, запретят импортировать.Модератор — деревянная палка с прокладкой из сукна, служащая для приглушения звука у пианино.
© RM6LA, Eugen. RnD, Russia.
:: RAFA XRRJ :: http://cq6l.ru ::
07.02.2023, 13:04 #3
7 февраля 2023г.
⚡️ Появились новые данные по жертвам землетрясения в Турции: погиб 3381 человек, ранены 20436
Первая группа спасателей МЧС России, прибывших ночью 7 февраля в Турцию, достигла места своей дислокации в наиболее пострадавшей от землетрясения провинции Кахраманмараш и скоро приступит к поисково-спасательным работам на месте.
Как передает корреспондент ТАСС, спасатели, преодолев по горным дорогам 200 км из Аданы, прибыла в город Мараш. Они будут дислоцироваться на базе турецкого AFAB, являющегося аналогом российского МЧС.73! de RW3AH
07.02.2023, 13:13 #4High Power
- 17.03.2016
- Вологда/Vologda
- 971
- 362
- 223
Интересно, а еще кто-то, кроме Российских МЧС, на помощь туркам поехал?
73 de R1SA! (Игорь)
Умные с лица мы, а в душе как дети,
Встанем на пути – не обойдешь.
Слова не схоронишь, в драку полезешь,
Совесть да костяшки обдерешь.
07.02.2023, 13:25 #5Standart Power
- 17.08.2007
- Cоветская Гавань
- 327
- 197
- 127
07.02.2023, 14:04 #6High Power
- 11.01.2011
- Almaty_MN83JD
- 75
- 697
- 436
- 472
Последний раз редактировалось UN3G; 07.02.2023 в 14:08.
73! Валерий UN3G ex UN3Z, RL7GD, RX7GBD, UL7GBD
08.02.2023, 09:00 #7
Указанные частоты при проведении ПСР:
1.855 lsb
3.777 lsb
7.092 lsb
14.270 usb
21.270 usb
24.955 usb
28.540 usb
Шлюз ID2043, QTH МО, переведен на номинал 7.175 usb, HFPager, поддержка эл. почты
08.02.2023, 17:10 #8High Power
- 26.01.2009
- Тамбов
- 71
- 884
- 146
- 372
Там особо и не поможешь .
72 часа .
МЧС России есть где быть полезнее .Игорь (UA3RGF)
08.02.2023, 17:30 #9
08.02.2023, 17:33 #10
08.02.2023, 18:43 #11
08.02.2023, 18:59 #12Р.любитель
- 05.02.2007
- Вологда
- 71
- 7,642
- 10536
- 7089
Президент Турции обьявил неск. часов назад, что число погибших превысило 8,5 тысяч человек. Раненых порядка 50-ти тыс.
Спасатели там отовсюду, включая Армению и даже Афганистан. https://www.1tv.ru/news/2023-02-08/4...urtsii_i_sirii
В Сирии тоже много погибших
Включил телик, "Россия-24". Как раз показывают спасенных через несколько суток. Повезло кому-то, даже целым семьямПоследний раз редактировалось UA1QV; 08.02.2023 в 19:04.
73! Михаил -
08.02.2023, 20:44 #13Р.любитель
- 05.02.2007
- Вологда
- 71
- 7,642
- 10536
- 7089
Посмотрел еще раз новости. Свежие. "Лучше один раз увидеть" ныне актуальнее "услышать" и "прочитать". Что подумалось... а нафиг уже КВ связь не нужна. Технологии далеко вперед ушли. Даже ЧМ-болтушки накоротке если. У всех мобильники, со всеми вытекающими. Если связь обвалится - проще вышку с ретранслятором и автономным питанием поставить оперативно.
73! Михаил -
08.02.2023, 22:32 #14Very High Power
- 18.09.2009
- все время в экспедициях
- 4,124
- 1504
- 956
Да и вряд ли вышки мобильной связи все упадут от землетрясения. И запас автономноного питания у них есть.
Олег RU2FB
08.02.2023, 22:50 #15Big Gun
- 20.09.2005
- 79
- 8,283
- 3864
- 3486
Безусловно людей надо спасать, но что то всё только о Турции, а Сирия .... это другое?
Евгений.
Практика - критерий истины.
В эфире практикую с 1966 г.
105Спасибо
