11.11.2022, 07:44 #1Администратор
- 30.04.2011
- Ростов-на-Дону
- 3,890
- 3023
- 2668
Проект WSJT-X: моды JT65,JT9,WSPR,JT4,JTMS,MSHV - работа с тестовым софтом - часть 3
Продолжение обсуждения проекта.
Предшествующие сообщения - в теме: https://forum.qrz.ru/377-jt65-jt9-ws...chast-2-a.htmlМодератор — деревянная палка с прокладкой из сукна, служащая для приглушения звука у пианино.
© RM6LA, Eugen. RnD, Russia.
:: RAFA XRRJ :: http://cq6l.ru ::
13.07.2024, 14:49 #1486
13.07.2024, 18:00 #1487Very High Power
- 18.01.2003
- Pavlodar (MO82lg)
- 4,708
- 793
- 665
Выложили новую сборку 240714 WSJT-X Improved.
Аркадий.
13.07.2024, 18:04 #1488Радиолюбитель
- 17.12.2005
- nr Калининград
- 2,949
- 1037
- 908
The "240714" code brings the following improvements:
SuperFox messages are now sent out via UDP.
When a "Super Hound" receives SuperFox messages, they are now also sent to PSK Reporter (provided PSK Reporter spotting is enabled).
We should now get correct entries for the ALL.TXT file.
Fixed a minor inconsistency with resetting the background color of the "Super Hound" label to red when unverified messages were received.
Update to Hamlib_4.5_1024-07-12_SHA=8cc51f. In case of hamlib issues, please follow the usual procedure (Diagnostic Mode, etc.) and contact Mike W9MDB.
And here is a brief progress report on the other known issues around our new SuperFox mode:
Joe and Steve are on the trail of the problem why the "K8R verified" lines are so rarely displayed. The root cause seems to have been identified, and a solution is now being worked on.
And of course we also try to evaluate the numerous audio files with the aim of improving decodability in the various situations. But that all takes a lot of time and effort, hi.
We have not yet identified why we are still getting this "subprocess error at line 63 of sfox_demod.f90 ..." occasionally. However, it seems to happen only on some operating systems (especially macOS and RPi).
So keep your fingers crossed and support us as much as you can.
Important: Please refrain from reporting issues that are already known. We are currently drowning in a flood of emails.
73 de DG2YCB,
Uwe
Код "240714" вносит следующие улучшения:
Сообщения SuperFox теперь отправляются по протоколу UDP.
Когда "Super Hound" получает сообщения SuperFox, они теперь также отправляются в PSK Reporter (при условии, что функция обнаружения PSK Reporter включена).
Теперь мы должны получить правильные данные для файла ALL.TXT.
Исправлена небольшая ошибка, связанная с изменением цвета фона надписи "Super Hound" на красный при получении непроверенных сообщений.
Обновите до версии Hamlib_4.5_1024-07-12_SHA=8cc51f. В случае возникновения проблем с hamlib, пожалуйста, следуйте обычной процедуре (режим диагностики и т.д.) и свяжитесь с Майком W9MDB.
А вот краткий отчет о ходе работы по другим известным проблемам, связанным с нашим новым режимом SuperFox:
Джо и Стив работают над устранением проблемы, из-за которой так редко отображаются строки "Проверено K8R". Основная причина, по-видимому, выявлена, и в настоящее время ведется работа над решением.
И, конечно, мы также стараемся оценивать многочисленные аудиофайлы с целью улучшения возможности расшифровки в различных ситуациях. Но все это отнимает много времени и усилий, привет.
Мы еще не выяснили, почему мы все еще время от времени получаем сообщение об ошибке "ошибка подпроцесса в строке 63 sfox_demod.f90 ...". Однако, похоже, это происходит только в некоторых операционных системах (особенно в macOS и RPi).
Так что держите пальцы скрещенными и поддерживайте нас, насколько это возможно.
Важно: Пожалуйста, воздержитесь от сообщений о проблемах, о которых уже известно. В настоящее время мы тонем в потоке электронных писем.73! Валентин UD2F ex: RU2FM
SunSDR2 + PA 100w + verticals (40, 20-10m), Inv L (160-80m)
13.07.2024, 19:20 #1489Very High Power
- 15.03.2012
- г.Данков
- 1,432
- 269
- 97
поставил эту версию и решил позвать на 14092 ...зовущих не видно,ответил сразу
13.07.2024, 20:58 #1490Very High Power
- 03.04.2007
- Псков, Россия, PS-01,RC-051
- 1,291
- 395
- 1032
21091 только что сработал с K8R, ответил с 3го вызова. RR73 получил, но особого чувства удовлетворения как то не получил, будем ждать когда SuperFox появится в JTDX. Вcем Удачи, DX!
Сергей (UA1WA)
14.07.2024, 09:05 #1491погулять вышел...
- 02.04.2007
- п.Подлесный
- 4,101
- 984
- 311
14.07.2024, 10:43 #1492Координатор темы
- 03.02.2006
- 53
- 20,659
- 10166
- 5459
Крайне не удобно, что в WSJT-X/JTDX убрали функцию "Автосохранения QSO". От "автоматов" это не спасет все равно, но неудобство добавляет.
Ant.: UW4HW, Pwr.: ~500 Wtts
14.07.2024, 13:58 #1493Координатор темы
- 03.02.2006
- 53
- 20,659
- 10166
- 5459
14.07.2024, 14:00 #1494
14.07.2024, 14:19 #1495Very High Power
- 18.01.2003
- Pavlodar (MO82lg)
- 4,708
- 793
- 665
14.07.2024, 15:58 #1496Мастер - Ломастер
- 26.11.2003
- 1,536
- 515
Удалось таки принять на 24911,76. Была даже попытка QSO, но RR73 не получил.
Уровень отображается от -9. Декодируются в среднем 2 из 3 циклов, хотя на водопаде есть и "дудки" слышны чётко. Кратковременная помеха и никакого декода.
Самый низкий рапорт лисе -16.
Непонятно:
Почему не в каждом цикле присутствует сообщение "K8R verified"?
Количество сообщений в ответе от 4 до 9, чаще 6. Я не всегда декодирую все 9 возможных или K8R так и отвечает? Частичное декодирование в SF возможно?Юрий RX3ASP
14.07.2024, 16:09 #1497Very High Power
- 07.12.2008
- д. Старчики Знаменский р-н Тамбовской обл.
- 3,141
- 1260
- 2247
Авторы написали, что режим ещё сырой, будут дорабатывать.
73! Сергей (UA3RMB)
14.07.2024, 16:28 #1498Standart Power
- 05.04.2004
- Антрацит, LU06
- 374
- 149
- 37
14.07.2024, 16:35 #1499Very High Power
- 15.03.2012
- г.Данков
- 1,432
- 269
- 97
24911 +774 k8r щас отработал,минуты 3 звал.....ант 10м провод и 70вт
сделал ниже 200гц,потом выше 300гц относительно 774-декода нет...а искать точно где граница декода не стал,ибо хоть и все декоды но слабо идет,на водопаде не видно его,только журчание слышно
ниже 100 и выше 200, относительно 774 ,декод был нормальный
14.07.2024, 17:51 #1500Координатор темы
- 03.02.2006
- 53
- 20,659
- 10166
- 5459
Мда. Прескорбно! Тогда уж действительно - лучше пусть делится по потокам!
Но думаю тут все быстро встанет на свои места - понятно что в теории одно, а на практике часто получается другое.
Сам факт -14 ни о чем не говорит, если пытаетесь сравнивать с рапортами JTDX - формула расчета рапортов разная, и это ерунда. Главное, чтоб реальная чувствительность была хорошая.
Мда. Первое впечатление крайне отрицательное - вижу K8R 18095 очень ярко, а декодирование идет через раз! Обычным F/H проблем бы не было.73 de RX4HX, Alexei, http://rx4hx.qrz.ru
959Спасибо
