Страница 100 из 139 ПерваяПервая ... 509093949596979899100101102103104105106107110 ... ПоследняяПоследняя
Показано с 1,486 по 1,500 из 2084
Like Tree705Спасибо
Тема: Проект WSJT-X: моды JT65,JT9,WSPR,JT4,JTMS,MSHV - работа с тестовым софтом - часть 3
    30.04.2011
    Ростов-на-Дону
    4,402
    2850
    2596
    Lightbulb Проект WSJT-X: моды JT65,JT9,WSPR,JT4,JTMS,MSHV - работа с тестовым софтом - часть 3
    Продолжение обсуждения проекта.
    Предшествующие сообщения - в теме: https://forum.qrz.ru/377-jt65-jt9-ws...chast-2-a.html
    http://cq6l.ru ::
  2. #1486
    High Power Аватар для EW6BN
    15.08.2006
    48
    997
    282
    298
    Цитата Сообщение от UN8FR Посмотреть сообщение
    Насчет 750 Гц - заблуждение.
    Там явно есть допуск, походу +- 200-250 Гц, сдвиньтесь больше и декоды пропадут
  3. #1487
    18.01.2003
    Pavlodar (MO82lg)
    3,287
    506
    509
    Выложили новую сборку 240714 WSJT-X Improved.
  4. #1488
    Радиолюбитель
    17.12.2005
    nr Калининград
    2,662
    876
    808
    The "240714" code brings the following improvements:
    SuperFox messages are now sent out via UDP.
    When a "Super Hound" receives SuperFox messages, they are now also sent to PSK Reporter (provided PSK Reporter spotting is enabled).
    We should now get correct entries for the ALL.TXT file.
    Fixed a minor inconsistency with resetting the background color of the "Super Hound" label to red when unverified messages were received.
    Update to Hamlib_4.5_1024-07-12_SHA=8cc51f. In case of hamlib issues, please follow the usual procedure (Diagnostic Mode, etc.) and contact Mike W9MDB.
    And here is a brief progress report on the other known issues around our new SuperFox mode:
    Joe and Steve are on the trail of the problem why the "K8R verified" lines are so rarely displayed. The root cause seems to have been identified, and a solution is now being worked on.
    And of course we also try to evaluate the numerous audio files with the aim of improving decodability in the various situations. But that all takes a lot of time and effort, hi.
    We have not yet identified why we are still getting this "subprocess error at line 63 of sfox_demod.f90 ..." occasionally. However, it seems to happen only on some operating systems (especially macOS and RPi).
    So keep your fingers crossed and support us as much as you can.
    Important: Please refrain from reporting issues that are already known. We are currently drowning in a flood of emails.
    73 de DG2YCB,
    Uwe
    Код "240714" вносит следующие улучшения:
    Сообщения SuperFox теперь отправляются по протоколу UDP.
    Когда "Super Hound" получает сообщения SuperFox, они теперь также отправляются в PSK Reporter (при условии, что функция обнаружения PSK Reporter включена).
    Теперь мы должны получить правильные данные для файла ALL.TXT.
    Исправлена небольшая ошибка, связанная с изменением цвета фона надписи "Super Hound" на красный при получении непроверенных сообщений.
    Обновите до версии Hamlib_4.5_1024-07-12_SHA=8cc51f. В случае возникновения проблем с hamlib, пожалуйста, следуйте обычной процедуре (режим диагностики и т.д.) и свяжитесь с Майком W9MDB.
    А вот краткий отчет о ходе работы по другим известным проблемам, связанным с нашим новым режимом SuperFox:
    Джо и Стив работают над устранением проблемы, из-за которой так редко отображаются строки "Проверено K8R". Основная причина, по-видимому, выявлена, и в настоящее время ведется работа над решением.
    И, конечно, мы также стараемся оценивать многочисленные аудиофайлы с целью улучшения возможности расшифровки в различных ситуациях. Но все это отнимает много времени и усилий, привет.
    Мы еще не выяснили, почему мы все еще время от времени получаем сообщение об ошибке "ошибка подпроцесса в строке 63 sfox_demod.f90 ...". Однако, похоже, это происходит только в некоторых операционных системах (особенно в macOS и RPi).
    Так что держите пальцы скрещенными и поддерживайте нас, насколько это возможно.
    Важно: Пожалуйста, воздержитесь от сообщений о проблемах, о которых уже известно. В настоящее время мы тонем в потоке электронных писем.
  5. #1489
    15.03.2012
    г.Данков
    1,019
    209
    поставил эту версию и решил позвать на 14092 ...зовущих не видно,ответил сразу
  6. #1490
    Very High Power Аватар для UA1WA
    03.04.2007
    Псков, Россия, PS-01,RC-051
    1,200
    378
    980
    21091 только что сработал с K8R, ответил с 3го вызова. RR73 получил, но особого чувства удовлетворения как то не получил, будем ждать когда SuperFox появится в JTDX. Вcем Удачи, DX!
  7. #1491
    02.04.2007
    п.Подлесный
    3,820
    908
    305
    нет...не совсем...+\- ставил 600 декодирует....400 уже нет...1000 так же нет
  8. #1492
    03.02.2006
    18,636
    8938
    4739
    Крайне не удобно, что в WSJT-X/JTDX убрали функцию "Автосохранения QSO". От "автоматов" это не спасет все равно, но неудобство добавляет.
  9. #1493
    03.02.2006
    18,636
    8938
    4739
    Цитата Сообщение от EW6BN Посмотреть сообщение
    полный отстой этот SuperFox для DX
    Основное достоинство SuperFox - сила сигнала не делится пропорционально количеству потоков. Так что по идее должно быть лучше. Но время покажет.
  10. #1494
    15.08.2006
    48
    997
    282
    298
    Так -13 ниже декода не видел, ушами слышно.
    Уж лучше пусть делится по потокам до -20...-21
    Вообще Olivia, Contestia, ROS хорошо работали, но тут видимо в эту полосу много информации загнали, отсюда и падение уровня
  11. #1495
    18.01.2003
    Pavlodar (MO82lg)
    3,287
    506
    509
    Я сейчас с ними на 12м сработал, дали +01 мне, а я их декодировал от -14. Ниже уже все...
    В WSJT-Z эта функция есть, но в последних версиях не работает. В версии 2.5.4-1.22 еще работает!
    Автор похоже забил на этот мод...
  12. #1496
    26.11.2003
    1,311
    446
    Удалось таки принять на 24911,76. Была даже попытка QSO, но RR73 не получил.
    Уровень отображается от -9. Декодируются в среднем 2 из 3 циклов, хотя на водопаде есть и "дудки" слышны чётко. Кратковременная помеха и никакого декода.
    Самый низкий рапорт лисе -16.
    Непонятно:
    Почему не в каждом цикле присутствует сообщение "K8R verified"?
    Количество сообщений в ответе от 4 до 9, чаще 6. Я не всегда декодирую все 9 возможных или K8R так и отвечает? Частичное декодирование в SF возможно?
  13. #1497
    07.12.2008
    Тамбов и окрестности
    2,954
    1185
    2179
    Авторы написали, что режим ещё сырой, будут дорабатывать.
  14. #1498
    05.04.2004
    Антрацит, LU06
    304
    91
    25
    Похоже это предел, ниже не декодируется, во всяком случае ниже у меня не получилось.
  15. #1499
    15.03.2012
    г.Данков
    1,019
    209
    24911 +774 k8r щас отработал,минуты 3 звал.....ант 10м провод и 70вт
    сделал ниже 200гц,потом выше 300гц относительно 774-декода нет...а искать точно где граница декода не стал,ибо хоть и все декоды но слабо идет,на водопаде не видно его,только журчание слышно
    ниже 100 и выше 200, относительно 774 ,декод был нормальный
  16. #1500
    03.02.2006
    18,636
    8938
    4739
    Мда. Прескорбно! Тогда уж действительно - лучше пусть делится по потокам!
    Но думаю тут все быстро встанет на свои места - понятно что в теории одно, а на практике часто получается другое.
    Сам факт -14 ни о чем не говорит, если пытаетесь сравнивать с рапортами JTDX - формула расчета рапортов разная, и это ерунда. Главное, чтоб реальная чувствительность была хорошая.
    Мда. Первое впечатление крайне отрицательное - вижу K8R 18095 очень ярко, а декодирование идет через раз! Обычным F/H проблем бы не было.
  1. Ответов: 2451
    Последнее сообщение: 11.11.2022, 07:49
  2. JT65/JT9 - имейте совесть, когда в "цифре" работаете!
    Ответов: 65
  3. Рамочная антенна с соотношением сторон 1:3
    от RV9UDO в разделе Антенны КВ
    Ответов: 79
    Последнее сообщение: 21.11.2017, 08:12
  4. Рамочная антенна с соотношением сторон 1:3
    от UR7HCX в разделе Антенны КВ
    Ответов: 37
    Последнее сообщение: 21.09.2016, 18:10
  5. Новая мода JT65
