Смотря ,какая скорость и какой фильтр у коллеги.Но стремиться надо!
лучше про это сразу забыть.
текущая активность только в OPERA:
21:14 136 SV8CS de SV8CS Op8 +2 dB in ZAKYNTHOS Isl.
21:14 136 SV8CS de RX3QFM Op8 2105 km -33 dB in KO91OO with 0.1w + Marconi"T"
21:14 136 SV8CS de SV8RV-2 Op8 7 km -29 dB in Zakynthos ( Zante) isl. with 0.1w
21:14 136 SV8CS de SV3DVO Op8 95 km -11 dB in Patra with 0.1w + Marconi"T"
20:59 136 SM6BHZ de G4WGT Op8 1013 km -29 dB in Chorley, IO83qo with 0.5ERPw + 2
20:59 136 SM6BHZ de SM2DJK Op8 815 km -18 dB in Umea with 0.5ERPw + 20 m Vert
20:59 136 SM6BHZ de F4DTL Op8 1182 km -23 dB in Paris France with 0.5ERPw + 20 m
20:59 136 SM6BHZ de RN3AGC Op8 1565 km -23 dB in Moscow with 0.5ERPw + 20 m Vert
20:59 136 SM6BHZ de RX3DHR Op8 1687 km -33 dB in Zaraysk . with 0.5ERPw + 20 m
20:59 136 SM6BHZ de F5WK Op8 1176 km -25 dB in JN18HP with 0.5ERPw + 20 m Vert
20:59 136 SM6BHZ de TF3HZ Op8 1935 km -33 dB in Reykjavik with 0.5ERPw + 20 m Ve
20:59 136 SM6BHZ de RX3QFM Op8 1867 km -23 dB in KO91OO with 0.5ERPw + 20 m Vert
20:59 136 SM6BHZ de LA4ANA Op8 259 km -7 dB in JO59CU with 0.5ERPw + 20 m Vert
20:49 136 SV3DVO de SV8CS Op8 95 km -16 dB in with 0.1w + Marconi T
20:40 136 SV3DVO de SV8CS Op8 95 km -16 dB in with 0.1w + Marconi T
20:34 136 SM6BHZ de RX3QFM Op8 1867 km -25 dB in KO91OO with 0.5ERPw + 20 m Vert
20:34 136 SM6BHZ de RX3DHR Op8 1687 km -29 dB in Zaraysk . with 0.5ERPw + 20 m
20:34 136 SM6BHZ de SM2DJK Op8 815 km -25 dB in Umea with 0.5ERPw + 20 m Vert
20:34 136 SM6BHZ de TF3HZ Op8 1935 km -22 dB in Reykjavik with 0.5ERPw + 20 m Ve
20:34 136 SM6BHZ de RN3AGC Op8 1565 km -26 dB in Moscow with 0.5ERPw + 20 m Vert
20:34 136 SM6BHZ de LA4ANA Op8 259 km -3 dB in JO59CU with 0.5ERPw + 20 m Vert
20:34 136 SM6BHZ de UZ2HZ Op8 1714 km -33 dB in KN69ra with 0.5ERPw + 20 m Vert
20:34 136 SM6BHZ de G4WGT Op8 1013 km -17 dB in Chorley, IO83qo with 0.5ERPw + 2
19:50 136 RX3QFM de RN3AGC Op8 489 km -24 dB in Moscow with 0.2w + 17m Umbrella
19:50 136 RX3QFM de RX3QFM Op8 0 km +4 dB in KO91OO with 0.2w + 17m Umbrella
19:50 136 RX3QFM de SM2DJK Op8 1759 km -18 dB in Umea with 0.2w + 17m Umbrella
19:50 136 RX3QFM de RX3DHR Op8 353 km -18 dB in Zaraysk . with 0.2w + 17m Umbr
19:50 136 RX3QFM de RW3ADB Op8 459 km -32 dB in Moscow KO85ro with 0.2w + 17m Um
19:49 136 RV3APM de RN3AGC Op8 102 km -27 dB in Moscow with 0.1w + INV-L
19:49 136 RV3APM de SM2DJK Op8 1230 km -34 dB in Umea with 0.1w + INV-L
17:20 136 RN3AGC de RV3APM Op8 102 km -9 dB in nr. Moscow
17:20 136 RN3AGC de RX3QFM Op8 -24 dB in KO91OO
17:20 136 RN3AGC de RX3DHR Op8 151 km -19 dB in Zaraysk .
17:20 136 RN3AGC de RW3ADB Op8 33 km -16 dB in Moscow KO85ro
и WSPR-15. скриншот с видом сигналов на водопаде.
антенны обычно много короче, чем длина волны, при согласовании катушкой на ней и антенне получается большое напряжение.
а ксв и не нужно. там его просто нет, как нету кабельной линии.
все и настраивают антенну в резонанс, кто неонкой, кто с помощью термопары. важен лишь максимально возможный ток в антенне.
в случае такой длинной антенны, как у вас, напряжение не будет сильно большим. на коротких антеннах 15-20м запросто может получится и 100 кВ на антенне. поэтому дуги, растекание и прошивание любой разумной изоляции на дв нормальное дело. а так же отгорание слоистых материалов типа текстолита.
Фото внутренностей не нашел, есть описание и схема. Принцип её работы по моему описан во 2-ой части Ротхаммеля - в статье электрически малые антенны. В 2012 г. во время экспедиции 3D2C на miniWhip принимали их на 160 м на 599 CW. Антенна чувствительна к электрическим полям, желательно поднять её над крышей метров на 5-10 на диэлектрической мачте.
Как прочитать ( раскодировать) этот сигнал?
Это цифра - поэтому декодирование не визаульное, а из соответствующего софта
Визуально "расшифровываются" QRSS, DFCW, HELL
QRSS - читаются как обычный CW - точки-тире
DFCW - также, но визуально это выглядит как 2 ряда точек на разных частотах. Тире обычно выше, а точки - ниже по частоте (более экономичный по времени чем QRSS, но тяжелее для PA)
Можно потренироваться маяки в EU DX окне подсказка: самый жирный DK7FC
Это картинка с граббера YO/4X1RF
HELL - из точек формируется обычный текст - обычно на английском
..ну и непонятно какой диапазон и частоты - старайтесь или в правой части через Setup/Calibration указывать, или пишите какая частота справа чему соответствует
Представление о текущей активности (прошедшая ночь) на 136 можно почерпнуть из Активность на 136кГц 19-20 сентября
Цветом выделены WSPR-15 Op32(Opera32) Op8(Opera8)
Это только лучшие рапорты по модам
Во второй части подборки лучшие QRB по модам
Лучшие QSO (2way & 1way) ЗДЕСЬ правда данные на 30 апреля 2013
Граббер в KN28iv
EU окно
https://www.dropbox.com/s/y6brizddb31zgfi/EU.bmp
TA окно
https://www.dropbox.com/s/vrw0nu9je4z3l62/TA.bmp
Обновление каждые 30 минут
Игорь, а вы точно уверены, что это сигнал?
У нас иногда "сигналы" могут быть сформированны чем угодно- внеполоской дальних, иногда очень далёких навигационных передатчиков, в народе зовётся бэдлайн от англ badline, импульсными преобразователями, соседскими зарядниками и ИБП.
Чтобы обнаружить действительно чейто сигнал- надо быть в курсе об активности, знать точную частоту его передатчика и безусловно, в режиме CW(NDB) можно увидать только соседей за 30-50 км от себя.
вот, в QRSS-10 уже иногда видно достаточно далеко, от 100 до 3000км в зависимости от энергетики станции и качества прохождения.
На какой частоте в тот момент у вас стояло радио? Какой режим был включен? USB?
да, еще по поводу согласовения.
на картинке Сергея ХГН видно, что в разрыв катушки с выхода передатчика включена лампочка накаливания. чем больше антенный ток- тем более ярко она сияет.
это, как говорится на безрыбье, тем у кого нету термоприбора.
Анатолий UA4WPF говорил, что использовал кусочек проволоки нихромовой, которую после настройки изымал из цепи или закорачивал.
при исключении лампочки, те, кто пользовался сим методом замечали некоторую небольшую разницу в настройке вариометра с лампочкой и без.
ДВ сезон набирает обороты, ночи становятся длиннее.
Поздравление первому передачику из Украины - Андрею - UW8SN
Отличные декоды в Европе
04:14 136 UW8SM de G0KTN Op32 1937 km -34 dB F:13% in Bath, UK IO81 with 0.2w +
04:14 136 UW8SM de SV8CS Op32 1280 km -21 dB F:9% in Zante Island with 0.2w +
04:14 136 UW8SM de SM2DJK Op32 1686 km -15 dB F:1%_End in Umea with 0.2w +
04:14 136 UW8SM de G4WGT Op32 1958 km -24 dB F:14% in Chorley, IO83qo with 0.2w +
01:33 136 RN3AGC de G4WGT Op32 2552 km -35 dB F:5% in Chorley, IO83qo
01:33 136 RN3AGC de SM2DJK Op32 1309 km -17 dB F:0% in Umea
01:33 136 RN3AGC de RW3ADB Op32 33 km -12 dB F:0% in Moscow KO85ro
00:33 136 RN3AGC de SV8CS Op32 2373 km -39 dB F:12% in Zante Island
00:33 136 RN3AGC de SM2DJK Op32 1309 km -15 dB F:0% in Umea
00:33 136 RN3AGC de RW3ADB Op32 33 km -12 dB F:0% in Moscow KO85ro
DK7FC отметился на граббере JA8SCD/1
Сегодня 01.02.2014 RC4HAA с 19-00 до 21-00 будет работать в режиме маяка на 137700 кГц. Рапорта приветствуются
TX потребляет 17В на 20А, антенна-луч 100м, CW, 137700, маяк включили
