VE3LYC/KL7 7004 UP1 NOW
Да, еще бы услышать как-то.
А пока только присутствие.
P.S. VK5CE во время своего австралийского турне по островам, в ОБП, цекулял часами в пустоту.
А Цезарь наверно с дороги, еще не отошел.
Будем надеяться.
Правда. По истечение гигантского времени не загрузить логи в клублог для автозачета. В голову лезет мысль о коммерческой составляющей (у меня отмечена безуспешная отправка к UA9OBA SASE na-150, 233) или отсутствие желания вбить бумажный лог, ну или, извините..- я не знаю.
Спасибо Михаилу за его труд :p-up:
Новости от товарища Цезаря.
18 March 2019 - 22:00 UTC
A blew the second and last set of fuses I had, but with Adrian's remote assistance, I was able to fix the amplifier for the time being. Let's home that those power surges won't be that much of a problem, otherwise this is extremely annoying.
I sat on 20 m for a couple of hours, but didn't make many QSOs. The noise level is S2-3, not stellar, but not that bad. However, I cannot copy any stations anywhere on the bands, except for those calling me. If you copy me, it's not a guarantee that I will be able to copy you! I'm still studying the actual propagation conditions. Got a couple of NA stations in the log, a VE3VEE on 30 m and VE7QTC on 20 m. I'll continue to call on 20 for a little longer, but I will eventually move to 30 m. There is plenty of shifting ice in the Bering Strait, so the locals told me that this is something the polar bears like, and they may come in and go out at any time, hi. Since the heaviest noise level is on 40 m, I may keep using 30 m through the night, since if I'll change it to 40 m and the band isn't good, I'll have to go back again and move the antenna to 30 m. I only made two QSOs on 40 m this morning, so 30 m has been so far the best operating band right now.
18 March 2019 - 16:30 UTC
Made it to the island very late in the day. After organizing everything I was able to run some 30 m in the night. The noise level was high, S7, but after midnight dropped a bit, to S4-5. The 30 m conditions appeared to vanish, I wanted to move to 40 m, but the blizzard was too strong, and I decided against going out. This morning I moved to 40 m, but the noise level is very high, S9. I made a couple of contacts, after which the amplifier died on me. I tested everything possible, and my guess is that there must have been a power surge. I have spare fuses, but if this happens again, I won't be able to use it anymore.
I will move to 20 m at 17 UTC, starting in CW first. I'm still testing conditions, but the noise level seems always very high. Many stations I calling fast, making virtually impossible to pull out their callsigns, because of the polar propagation conditions. I'll keep going.
Перевод машинный.
18 марта 2019 - 22:00 по Гринвичу
A взорвал второй и последний комплект предохранителей, которые у меня были, но с удаленной помощью Адриана я смогла починить усилитель на некоторое время. Давайте вернемся к тому, что эти скачки мощности не будут такой большой проблемой, иначе это очень раздражает.
Я сидел на 20 м в течение нескольких часов, но не сделал много QSOs. Уровень шума S2-3, не звездный, но не настолько плохой. Тем не менее, я не могу копировать какие-либо станции в любом месте на полосах, за исключением тех, кто звонит мне. Если вы копируете меня, это не гарантия, что я смогу скопировать вас! Я все еще изучаю условия распространения. Получил пару станций NA в журнале, VE3VEE на 30 м и VE7QTC на 20 м. Я буду продолжать звонить на 20 еще немного, но в конечном итоге я перееду на 30 м. В Беринговом проливе много движущегося льда, поэтому местные жители сказали мне, что это то, что нравится белым медведям, и они могут войти и выйти в любое время, привет. Поскольку самый сильный уровень шума находится на 40 м, я могу продолжать использовать 30 м в течение ночи, так как если я изменю его на 40 м, а полоса не будет хорошей, мне придется вернуться и переместить антенну на 30 м. Я сделал только два QSOs на 40 m сегодня утром, поэтому 30 m до сих пор была лучшей рабочей группой прямо сейчас.
18 марта 2019 года - 16:30 по Гринвичу
Добрался до острова очень поздно. После организации всего я смог пробежать около 30 м ночью. Уровень шума был высоким, S7, но после полуночи немного снизился, до S4-5. 30 м условия, казалось, исчезли, я хотел перейти на 40 м, но метель была слишком сильной, и я решил не выходить. Сегодня утром я переехал на 40 м, но уровень шума очень высокий, S9. Я сделал пару контактов, после чего усилитель умер на меня. Я проверил все возможное, и я предполагаю, что должен был быть скачок напряжения. У меня есть запасные предохранители, но если это повторится, я больше не смогу их использовать.
Я перейду на 20 м в 17 UTC, начиная с CW. Я все еще тестирую условия, но уровень шума кажется всегда очень высоким. Многие станции я вызываю быстро, что делает практически невозможным вытащить их позывные из-за условий полярного распространения. Я продолжу.
Проблемы у него с шумами, и УМом.
Сейчас у на на 14008 up!!!!
Как уже сообщал ранее Андрей EU7A, QSL за NA-150 рассылает N7RO. Почему лог за эту экспедицию не выложен в автозачет - не понятно. Логи за более ранние и более поздние экспедиции KL7RRC уже давно есть на Club Log QSO Mathes, в том числе и за NA-233 - KL7RRC/P/2009. Если нужна бумажная QSL за NA-233, то можно так же попробовать получить ее через N7RO.
VE3LYC/KL7 услышал на 20 ке ,тихо, но читаемо, но он дает только вызов,видимо у него в qth всё же много помех.
NA-081 VE7ACN/VE1, NA-127 VA7XW/VE1, NA-014 VE7ACN/VE9
Послезавтра ни свет, ни заря двигаем в аэропорт. Самолёт в 6.30 утра, пока планировал и сращивал всю поездку, кончились билеты по приемлемой цене на более поздние рейсы. А бизнес-классом канадским пенсионерам пока не получается летать :s9:
Плохие новости: на пятницу 22 марта, на день прибытия, по прогнозу дождь и ветрище, до 20 м/с. Посему, Спайдера, в лучшем случае, удастся собрать и оставить лежать на земле до улучшения погоды, что должно произойти в воскресенье.
Хорошие новости: сегодня решил проблему 40/80 м из одного штыря с автотюнером. Потому что штырь вертикальный и по дождю поставится, делов немного, а непромокаемые штаны и куртка уже в чемодане. Как запасной вариант, едут с нами Inverted V на 20-30-40 м, поэтому, пропустил провод для 80 м Inverted L внутри 12-метрового Spiderpole, снаружи привязал изолентой по одному лучу от инверторов на 30 и 40 м. Резонансы на 40 и 30 м уплыли куда-то вниз из-за близости длинного провода на 80 м, но это уже не имеет никакого значения, потому что стали строиться все диапазоны с автотюнером, и если по дороге законы физики и аппаратура останутся в том же состоянии, то бегать на улицу переключать диапазоны больше не придётся. КСВ по прибору усилителя SPE 1,3K-FA на полной мощности: 80 м - 1,28; 40 м - 1,23; 30 м - 1,19; 20 м - 1,31; 17 м - 1,49; 15 м - 1,35.
P.S. Погода сегодня в Ванкувере бьёт все рекорды. +22 градуса, солнце светит.... А в VE1 ещё и снег обещают.
А тут похоже шансы не велики. Пока не слышал ничего. Посмотрел по карте, там как раз поселок за горой 200-400м для меня, если Цезарь что-то вокруг горы или на горе не придумает. Не случайно я и предыдущую активность с этого острова не услышал.
Азия/Европа/Океания отработают с таким QTH.
Только что на 10106.0! Идёт хорошо, но звал долго, и отвечает далеко не все зовущим. Видимо, действительно проблемы с RX...
[QUOTE=KJ6MBW;1569039.....
Азия/Европа/Океания отработают с таким QTH.[/QUOTE]
Будем надеяться, пока его не слышно совсем.
VE3LYC/KL7 10.106 7.00 Z
слышно хорошо
