Вероятно точного в природе нет но вот небольшой
(based on IARU region 1).
BPSK31, QPSK31, BPSK125, QPSK125 (USB)
1838, 3580, 7035, 10140, 14070, 18100, 21080, 24920, 28070, 28120, 50000, 144000 (144605 in France and 144144 in Italy).
PSK10, PSKFEC31, PSK63F + DIGISSTV "Run", PSKAM10/31/50 (USB)
Except PSK220F, These modes are QRP transmissions. They are used very little.
I propose to focus calls at the following frequencies and times:
* 14075 Khz (AF around 1000 Hz) at 17h00 UTC,
* 10148 kHz (AF around 1000 Hz) at 22h00 UTC,
* 144620 hHz (AF around 1000 Hz), at 20h00 UTC.
PSK220F + DIGISSTV "Run" (USB)
* 14075 Khz (AF around 1000 Hz), at 17h00 UTC if few traffic,
* 10148 kHz (AF around 1000 Hz), at 22h00 UTC if few traffic.
* 144620 hHz (AF around 1000 Hz), at 20h00 UTC if few traffic.
BPSK63 and QPSK63 (USB)
14072.5 - 14080 Khz. It is recommended to use fixed frequencies multiple of 100 Hz: 14072.5, 14072.6, 14072.7...
For that, the user sets his transceiver on 14072 Khz in USB and operates on 500, 600, 700,..., 2400 or 2500 Hz...
on the spectrum indicator.
CHIP (64/128) (USB)
7090 (for USA), 14077 and 14110 KHz
CCW (USB)
For CCW which is a mode close to CW, the following frequencies are suggested:
1844, 3561, 7031, 10107, 14061, 21061, 24907, 28061 Khz (QRP frequencies + 1KHz).
CCW-FSK (USB)
The following frequencies are suggested:
3590, 7043, 10143, 14075 Khz (CQ calls in 24 wpm).
For North America, it is proposed:
3575, 7075, 10137, 14075, 18105, 21075, 24905, 28075 Khz.
MFSK16, MFSK8, THROB, THROBX, DominoF, DominoEX (USB)
1838, 3580, 7037, 10147, 14080, 18105, 21080, 24929, 28080 Khz
Note: for SSTV in MFSK16, in general, it is not authorized to transmit a mix of text and pictures
because the authorized frequencies, for these modes (MFSK16 / SSTV), are different.
The MFSK8, DominoF, DominoEX and THROBX modes are QRP transmissions. They are very little used.
I propose to focus calls in the same conditions as for PSK10, PSKFEC31, PSK63F, PSKAM10/31/50 modes (see above).
OLIVIA (USB)
With an AF frequency of 1000 Hz, frequency displayed on the transceiver:
7038.5, 14104.5, 14105.5, 14106.5, 14107.5, 14108.5 (call frequency), 18102.5, 18103.5, 18104.5, 21129.5 KHz
CONTESTIA and RTTYM (USB)
For 1000 Hz bandwidth sub-modes, with an AF frequency of 1000 Hz, frequency displayed on the transceiver:
14103.5 Khz
For 500 and 250 Hz bandwidth: 7039.5, 14075.5 Khz
VOICE (USB en HF, FM en VHF) New Digi moda
3590, 7043, 10148, 14075, 144620 Khz with an AF frequency of 1000 Hz.
* 14074 Khz (AF at 1000 Hz), at 17h00 UTC if few traffic,
* 10148 kHz (AF at 1000 Hz), at 22h00 UTC if few traffic.
PAX (USB in HF, FM in VHF)
3590, 7043, 10148, 14075, 144620 Khz.
PAX2 (USB in HF, FM in VHF)
3610, 7042, 14112, 18112, 21112, 24932, 28302, 144620 Khz.
MT63 (USB)
1822, 1838, 3580, 3590, 3635, 7035, 7037, 10140, 10145, 14106, 14109, 14114, 18100, 18105, 21130, 24925, 28130 Khz
RTTY 45 bauds (50 and 75 bauds) (Ham), ASCII 110 bauds (Ham) and PACTOR 1 (USB)
1838-1842, 3580-3600, 7035-7045, 10140-10150, 14070-14099, 18100-18109, 21080-21120, 24920-24929, 28050-28150,
50100-50500, 144600, 144800-144990
AMTOR ARQ or FEC (Ham) (USB, sometimes LSB)
Same frequencies as for RTTY 45 bauds (Ham), in particular around 14075 KHz.
PACKET 300 bauds + APRS + DIGISSTV "Run" (USB)
3590-3600 (QSO), 10150 LSB (APRS), 14090-14099 (QSO), 14101-14112 (BBS), 14105 (APRS), 18102 (APRS), 21100-21120 (QSO), 21113 (APRS), 28120-28150 KHz (QSO)
For the pictures transmission in DIGISSTV, I propose to focus calls on 14090 Khz USB (AF around 1000 Hz), at 17h00 UTC if few traffic.
PACKET 1200 bauds + APRS + DIGISSTV "Run" (FM)
29250 (APRS), 144800 (APRS)
BBS can be found around 145000 Khz (QRG examples: 144900, 144925 and 144950 KHz).
For the pictures transmission in DIGISSTV, I propose to focus calls on 144630 kHz at 20h00 UTC if few traffic.
MIL-STD-188-141A ("141A") (USB)
Some ALE frequencies: 3617, 7040.5, 14109.5, 21117.5 KHz
FELD HELL, PSK HELL, FM HELL and HELL 80 (USB)
3580, 7035, 10135, 14063,14076,21063 and 28063 KHz
SSTV
3730 (LSB), 7035 (LSB), 14230 (USB), 21340 (USB), 28680 (USB), 144500 (FM)
HF Fax (Ham) (USB)
3730-3740, 7035-7045, 14230, 21340, 28680, 50550, 144700 KHz
