Показано с 1 по 4 из 4
    11.11.2008
    Вопрос Как раскрыть ALINCO DX-70 ?
    КАК РАСКРЫТЬ ALINCO DX70 на передачу?????
    Без позывного Аватар для rus013
    20.04.2003
    Нижний Новгород
    51
    433
    27
    Ok, first an apology to all who sent msgs about these mods. Sorry for
    the delay in getting these out here.
    The Alinco DX-70 can be configured as follows:
    Extended TX, open the RX up to 35Mhz and down to 30 Khz, Open the VHF
    side from 45-60 Mhz RX/TX. All can be done quickly by , by removing or
    changing a series of chip-resistors located in the detatchable front face
    panel. This mod is a little tricky to perform, since it uses surface
    mount devices, so I TAKE NO RESPONSIBILITY IF YOU BREAK YOUR RIG.
    Alinco, further, in their mod sheet, warns that performing this mod
    incorrectly will NOT BE COVERED via warranty. At first, I tried using a
    Salami sized soldering iron--- take my word, get a good, very fine point
    iron of about 15 or 20 watts max! Make sure it is static guarded too.
    Ok...Here we go.
    1. disconnect power
    2. disconnect antenna
    3. remove control head, disconnect control cable
    4. remove 4 screws on back of control head,
    5 remove (unsnap is more like it) the control head back panel.
    6. THE MOD:
    Once you have the back panel removed, and using the big VFO knob as
    your guide (circuit board facing you, LCD display not facing you). The
    VFO knob should be on the left side. On the right side, in the lower
    right hand corner, you should see 2 distinct columns of chip resistors.
    On the board, they are NOT labeled, but I will draw the diagram below
    to help you. You cant miss these because there are 5 chip resistors in
    the left-hand row, and the right-hand row has 7 chip resistors. Above
    both rows is a solder-pad.
    a(: h(:
    g-
    i-
    b - j-
    c - k-
    d - l-
    e - m-
    f - n-
    Several chip resistors will be soldered in, depending on the model
    of your rig, and a solder pad is jumpered. Here are the mods per
    Alinco:
    a. 45-60 Mhz TX/RX - solder a 0ohm or jumper across location i
    b HF RX down to 30 Khz - remove the jumper m
    c. beyond just Mars Mod - TX/RX everywhere remove both jumpers c and e
    d. HF RX up to 35 MHZ - solder a bridge across pad a
    After performing the above mods, reassemble the unit.
    7. DONT FORGET to reset the microprocessor (with the radio off, hold
    the F button and simultaneously turn the power on.
    All memories are wiped out, but the new bands are opened.
    I've tried all mods with my Alinco rig and can confirm they work. I am
    able to pick up business band communication in the 46 Mhz range (FM), and
    cordless phones in 46/49 range. It TX's everywhere now too.
    I do not take responsibility if you perform this mod incorrectly, and I
    am not responsible for your operation practice if you choose to illegally
    transmit out of band.
    Thanks and again, sorry for such a delay in getting this out here.
    73 de Joe BV/N0IAT Taipei, TAIWAN (FORMOSA)
    На англицком но вроде всё понятно.
    Very High Power Аватар для UI8CM
    11.07.2009
    Нижний Тагил
    1,922
    398
    224
    Так она и так везде передаёт , и КВ и 6 м , и непрерывно весь диапазон .
    06.05.2008
    195
    17
    6
    Перевод.
    Alinco DX-70 могут быть раскрыты следующим образом:
    расширение TX, RX от 30 кГц до 35 МГц , открыт ОВЧ
    в полосе от 45-60 МГц RX/TX. Все может быть сделано быстро ,
    путем удаления или установки ряда чип резисторов,расположенных в торце передней съёмной передней панели. Эта операция немного мудреная,
    чтобы выполнять, поскольку используется поверхностный монтаж , так что Я не БЕРУ НИКАКУЮ ОТВЕТСТВЕННОСТЬ ЕСЛИ ВЫ ЛОМАЕТЕ ВАШУ ОСНАСТКУ.
    Alinco, кроме того, в их mod листа, предупреждает что при выполнении этого мод будет отказано в гарантии.
    Во-первых, использовать хорошо заточенный как карандаш небольшого размера паяльник 15 или 20 ватт Макс! Убедитесь, что он имеет защиту от статики.
    Хорошо...и так начнём.
    1. Отсоедините питание
    2. Отсоедините антенну
    3. Снимите блок управления, отключив кабель управления
    4. Отвинтите 4 винта на задней части блока управления,
    5 Снять крышку (освободить доступ) платы панели управления.
    6 Собственно модификация:
    Поверните блок управления к себе задом , и используйте большую ручку VFO как ориентир
    Расположите правильно блок управления (печатная плата, обращен к вам, ЖК-дисплей не виден вам). Ручка VFO должна находиться с левой стороны. На правой стороне, в нижнем
    правом углу, вы должны увидеть 2 отдельных колонки чип резисторов.
    На плате они не помечены, но я сделаю диаграмму ниже
    чтобы помочь вам. Вы легко разберётесь, потому что есть
    5 чип резисторов в колонке слева и
    7 чип резисторов в правой колонке.
    Выше обеих строк имеются перемычки из припоя.
    a(: h(:
    g-
    i-
    b - j-
    c - k-
    d - l-
    e - m-
    f - n-
    Несколько миниатюрных резисторов будут запаены в, в зависимости от модели вашей оснастки, и перемычки припоя.
    Вот пример Alinco:
    6.1.работа в полосе 45-60 Мгц TX/RX - паять 0ohm или перемычку через позицию i,
    6.2 расширение полосы RX вплоть до 30 Khz - удалить перемычку m
    6.3 Работа за пределами диапазонов Mod - TX/RX удалить премычки c и e
    6.4 расширение RX вплоть до 35 МГЦ - паять перемычку через панель a
    После выполнения вышеуказанных операций соберите устройство.
    7. Остаётся сбросить микропроцессор ( нажимая кнопку F и одновременно включать).
    Вся память будет стёрта, но новые полосы открыты.
    Я попробовал все модули с моей оснасткой Alinco и могу подтвердить их работу. Я принимаю связь в дипазоне 46 Мгц (ЧАСТ.МОД.), и радиотелефон в 46/49 дипазонов. TX везде теперь тоже.
    Я не беру ответственность если Вы выполняете этот модуль неправильно, и Я не ответственный за ваше действие практики если Вы решаете незаконно работать на передачу за пределом разрешённой полосы полосы.
    Спасибо и извините за задержку.
  1. Как раскрыть FT-450?
    от ленивец в разделе КВ аппаратура
    Последнее сообщение: 14.01.2010, 12:29
  2. Как раскрыть ALINCO DJ-496 ?
    от зенит в разделе УКВ: ALINCO
    Ответов: 9
    Последнее сообщение: 01.12.2006, 00:21
  3. Как раскрыть Alinco DR-130L ?
    от UT1ML в разделе DR-130/430
    Последнее сообщение: 05.09.2006, 09:47
  4. Как раскрыть ALINCO DJ-496 ?
    от SEMAN в разделе УКВ: ALINCO
    Последнее сообщение: 04.02.2006, 13:03
  5. Пмогите раскрыть ALINCO DJ-560
    от a000aa в разделе УКВ: ALINCO
    Последнее сообщение: 04.02.2004, 00:41
