Кто распаковывал данный аппарат на передачу, интересует 40 метровый
диапазон.
диапазон.
Чтобы его раскрыть надо пол трансивера разобрать и отстегнуть полностью лицевую панель.Раскрывается до 7,5МГц.Цитата:
Сообщение от UT3GE
Icom IC-7800 (IC 7800 IC7800) General Coverage Transmit Mod
The IC-7800 can be modified for general coverage transmit(1.6 thru 54.0 MHZ) (Frequency Range and Specifications cannot be guaranteed after modification) by following the CAP/MARS directions below:
Remove top and bottom covers.
Remove 4 small screws holding front panel onto main chassis(2 per side).
Tilt up front panel(you may have to loosen and remove 2 connectors on lower left side of front panel) to expose the Logic Unit sitting vertically on the left side of the main chassis unit behind the front panel. You may find it easier to access the diodes by setting radio up on its right side.
Near the center of the Logic Unit (below and to the right of a processor chip) you will see 2 vertical rows of diodes / diode spaces. The bottom 4 diodes in each column are offset slightly to the right as pictured below. NONE OF THE DIODES IN THE RIGHT COLUMN ARE CHANGED!! The diodes in the left column must be configured exactly as shown below. This means that you may have to add or remove diodes in the left column depending on where you purchased your IC7800. USA radios are easy to modify as the only change is to remove D57. If you have to add diodes, try to use the ones that you had to remove(and make sure to install them in the correct direction-they ARE Surface Mount Devices):
LEFT RIGHT
D59 (no diode) 0 X (diode in)
D58 (diode in) X X (diode in)
D57 (no diode) 0 0 (no diode)
D56 (no diode) 0 X (diode in)
D55 (no diode) 0 - I forgot to note if there was a diode in this position.
D54(diode in) X 0 (no diode)
D53(diode in) X X (diode in)
D52(no diode) 0 X (diode in)
D51(diode in) X X (diode in)
Position the front panel unit back down into position in its proper place and then check to make certain that the connectors which connect to the front panel unit and to the logic unit are securely plugged in properly. Reinstall the 4 small front panel mounting screws(2 per side) and reinstall the bottom and top covers.
No radio reset is required. After this modification, there will be no band edge beeps if you had them turned on before, so be careful not to operate out of your band segment.
Enjoy your new General Coverage Transmit IC7800.
Блин.. лень.. а надо...
Это мы знаем, а вот какие диоды выпаять а какие впаять?
У меня № 0301033, все что нашел в интернете пишут
по разному. Имеется три варианта распаковки, а вот какой правильно?
Вот так то, а ты говориш переднею крышку снять.
Обнародуйте сие...Цитата:
Сообщение от UT3GE
RU3DNN
Павел сбасибо за отзыв, но вопрос остается открытым!!!
1 КОЛОНКА ham.dmz.ro service(mods.dk)
2 КОЛОНКА IC-7800 Modification/Service information Issued : May 27, 2004
3 КОЛОНКА UT3GE ЭТО КАК ОНИ НАХОДЯТСЯ В МОЕМ TX/RX
НЕ РАСПАКОВАННЫЙ ВАРИАНТ
<O X> <O X> <X X>
<X X> <O X> <X X>
<O O> <X X> <X X>
<O X> <O X> <X X>
<O -> <O X> <X ->
<X O> <O X> <X ->
<X X> <O X> <X X>
<O X> <O X> <X X>
<X X> <X X> <X X>
Может есть инфо какой диод и за что отвечает?
Да я понимаю, что вопрос открытый, а Айком закрытый.. :)
Будем ждать ответа.. А версия аппарата какая, американская?
Если крышка снята, то "методом исключения", у нас на гарантии пока - не вскрыть.
Знаете, мне СС говорил о шести диодах, вроде как, так и есть.
Спрашивайте на форуме Вам насоветуют.Есть Technical Information рассылаемая ICOM Distributors в которой есть Diode Matrix и для разных версий она разная.Обратитесь к продавцу у которого покупали и вопрос будет закрыт.Удачи.Цитата:
Сообщение от UT3GE
Да я так и понял надо обращатся к продавцу а иначе удачи не видать.
Но не ужели российские р-любители не распаковывали свои аппараты.
В России их на много больше нежели в Украине я имею ввиду владельцев IC-7800. Спасибо.:threaten:
RU3DNN
А что когда на гарантии то нельзя вскрывать?
Пломбы стоят что-ли?
Что то Павел ты не то говориш!!!!!!!!!!!:curtsey:
Да, пломбы стоят... Помимо гарантии самого Айком, год гарантии даёт фирма-продовец. Нет необходимости выкладывать фотографии этих пломб (:)). Дайте знать результат по "вскрытию пациента".
Виталий!
Распаковал?
73! UT7UV
ДА!
TX :
1.800000 - 1.999999
3.400000 - 4.099999
6.900000 - 10.499999
13.900000 - 14.499999
17.900000 - 18.499999
20.900000 - 21.499999
24.400000 - 25.099999
28.000000 - 29.999999
50.000000 - 54.000000
73! UT3GE
Это похоже на штатовкую версию, а не полное раскрытие.
GM!
Виталий спасибо!
А дай расположение диодов, плиз.
А то у меня европеец и я уже запутался.
73! UT7UV
TO: ES4RZ
Да это штатовский вариант, японцы
дали только такой вариант распаковки,
я к ним обратился с просьбой диапазона 7200 кгц,
так они мне дали вариант не полного раскрытия,
из серии "пошли дурака за бутылкой, он одну и принесет",
ну что просил то и получил. С другой стороны а что еще
нужно? СБишный бенд - поговорить с таксерами.:pogranichnik:
Хотелось бы напомнить, если кто пропустил, появились новые прошивки для IC 7800,
http://www.icom.co.jp/world/support/...irm/index.html
Поставил сегодня, версию 2.21 через карт-ридер, ушло минут 15 на установку, все работает.
Странно у меня почему то версия 2.30:sos:
С сайта Айком версию обновления 2.30 убрали.
Improved DSP filter shape selection function to work correctly when changing the operation mode.
Алексей, а реально это как почувствовали, есть разница, заметна? Стоит ли апдэйт того?
Почуствовать явно не удалось. Впрочем, я этого и ожидал, аппарат работал отменно с 2.11 перед апгрейдом. Процедура несложная на все ушло минут 15, главное было не ошибиться в некоторых действиях и питание обеспечить бесперебойное, пока происходит перепрограммирование. Записывал данные на карточку IC7800, через картридер подключенный к компьютеру. После запуска процедуры FIRM UP (в меню работы с карточкой трансивера CF CARD) трансивер перепрограммировал свои DSP приемников и TX DSP. Все делал по "родной" английской инструкции.
HI collegues!
У меня аппарат от июня 2004 года.
Ни разу не апгрейдировал.
А теперь вот дилер прислал новые платы с руффингом.
Можно ли поставить платы а потом уже апгрейдировать до последней версии?
73! RK1NA
И только так, сначала меняете платы, потом заливайте софт, каждую версию по нарастающей.
73! UT7UV
А кто-нибудь знает как раскрыть IC-7800 на передачу в непрерывном диапазоне?
Подскажите пожалуйста.
С уважением Сергей R3DX
Здравствуте Все.
У меня тр-р с 2005г., Ни разу не делал обновления, Хотелось -бы узнать, а какие
изменения происходят и как это можно почувствовать? а так-же насколько это
нужно.Давно подхожу к апдэйту, но никак не могу решиться, а так-же - обязательно-ли начинать обновления по нарастающей?
Владимир UA6CE
Видел только такое раскрытие:
Expansion Band Instruction for IC-7800 #03.
After you change diodes, frequency range will be changed as follows.
RX :
0.030000 - 60.000000
TX :
1.800000 - 1.999999
3.400000 - 4.099999
Even your customer would like to expand frequency, but sorry there is
no way to expand frequency more.
Владимир, а что по первой части, какие происходят изменения?
Александр, здравствуйте.
По первой части я хотел узнать что происходит по приёму, в DSP или иные
функциональные возможности трансивера, теперь более-менее прочитал в анотациях
по загрузки обновлений.Там написанно сухо, а хотелось -бы узнать мнение пользователей, их живые ощущения.
С Уваж. Владимир
Владимир!
Заметные изменения в работе DSP были только в первых версиях, улучшалась его работа (реально было слышно более "мягкий" звук и избирательность), далее просто дабавлялись некоторые функции и все. Также во второй прошивке пофиксили "дерганье" стрелки С-метра, а так уже и не вспомню больше, давно уже было :)
73! Саша UT7UV
Владимир, прошло примерно 10 дней как я инсталлировал новые ПО , могу сказать, что фильтрация в режиме CW при переходе от версии 2.11 к 2.21 улучшилась. Это стало заметно при работе на приеме в достаточно узкой полосе от 500 до 300 Гц. Сигнал стал мягче, лучше звучит, настройка комфортной ширины полосы субъективно стала более комфортной.
Здравствуйте.
Спасибо за информацию. Уменя стоит версия 1.22, если судить по отражению на экране монитора во время включения внизу справа.
С Уваж. Владимир
1.22 относительно свежая версия, так что не переживайте :)
А какая сейчас новая? :)
7700 перепрошил один раз, помоему больше апдэйты не выпускались для 7700
http://www.icom.co.jp/world/support/...irm/index.html Сегодня вышла...
Серега привет!
Знаю как и уже многим раскрыл! Есть нюансы при расборке перед раскрытием, звони помогу! Кстати когда собирал инфу по раскрытию, спасибо UT7UV помог инфой ну а дальше нет, мозги и руки. По поводу установки обновлений. Я настоятельно рекомендую их устанавливать. Ставить надо самую последнюю, смысла в последовательной установки всех версий нет никакого. Процедура примитивная, простая. Польза огромная.Перед началом не забудьте сохранить все свои настройки на флешку что бы в дальнейшем после апдейта их восстановить. Главные изменения в работе DSP. Ну и скажем баг который я заметил при работе сплитом был устранен только в 2.30. Установив 2.30 заметил некоторые улучшения по приему, например по другому работает NR. Просто если все нюансы описывать надо много времени. При выходе каждого обновления косоглазые указывают только то что не заметить просто нельзя. Кто ставил и замечал, что при каждом обновлении полностью перепрошивается софт. На яхе есть форум на который я подписан так там очень активно все нюансы обсасывают.
С уважением! RT5A
Сегодня 31.01.11 повторно вышла исправленная версия 2.30 для 7800! Я пока не ставил обновленную! Всем удачного апдейта.
С уважением RT5A, 73!
Таки лучше последовательно версии обновлять, или можно сразу крайнею устанавливать? Какие впечатления от обновления?
К вопросу как лучше я уже писаал пост выше. А теперь про 2.30 и про повторную установку. В первый день выхода 2.30 я скачал и установил. Затем через два дня эта прошивка исчезла с их сайта и появилась 31.01 под тем же номером 2.30. На форуме 7800 про это подробно описывалось, одной из причин была проблема у америкосов с их 5 Мгц диапазоном. Я снова скачал новую версию и начал устанавливать поверх 2.30 старой, в итоге загрузка прошла но не обновилась, пишет выкл. и вкл. Аппарат просто включился как обычно с 2.30! Для чистоты эксперимента я откатился на версию 2.21 а затем залил новую 2.30 все прошло успешно. Я уже писал что чуть по другому работает NR, небольшой баг со сплитом устранен, при вкл. DIGI SEL немного изменились уровни сигналов. Всем удачи!
На яхе форуме 7800 чел выложил цены на сегодня в USA!
Забавно! Наши еще плюс 2 тыс. просят! ЗАБАВНО!
Gigaparts $11,999.00
Universal Radio $12,499.99
AES $9999.99
HRO $11,799.95
Texas Towers $11,969.99
Ham Station $11,000.00
Ham City $11,839.95
R and L $12,299.95
С уважением!
73! RT5A
Уважаемые владельцы, не подскажите можно ли управлять аппаратом (САТ) через стандартный COM-порт компьютера без преобразования уровней каким-нибудь шнурком на RS232-разъем трансивера? Никакой подробной информации в мануале не нашел ((. Заранее спасибо.
RK3TD
Можно.
Вы хотите купить Icom 7800? У меня знакомый хочет продать, если есть интерес пишите в л/с дам его контакты.
Коллеги, подскажите работает ли функция VOX в режиме USB-D?
Более конкретно: срабатывает VOX от сигнала, подаваемого на ACC1 или на S/PDIF?
А то что-то у меня не работает(((
Принес домой IC-7800. Пытаюсь сделать программный update.
В трансивере стоит версия 2.15.
Это достаточно старая версия firmware.
Несколько вопросов:
1. Можно ли сразу накатить последнюю, например 3.10, или надо промежуточные устанавливать?
2. Для прошивки приобрел Compact Flash card 32 GB kingston. Трансивер ее объявил не форматированной
(хотя она читается компом как FAT32) и предложил переформатировать. После моего согласия - пытался переформатировать
карту, но завершил с ошибкой - после этого карта не читается.
Кто нибудь знает - какого размера допустимо использовать в IC-7800 эти карты? Может 32 GB - это много.
Или форматировать как то надо по-особенному?
Предполагаю что 32 GB это реальный перебор.
И в мануале ничего по этому вопросу нет.
У меня стоит 256 мб и никаких проблем , попробуйте не более 2 GB.
По прошивке не знаю , сам не обновлял.
Уже с 3.00 достался , и пока все устраивает.
Поэтому не собираюсь обновлять.
(но думаю что можно ставить сразу любую версию прошивки , без всяких промежуточных).
В данном случае именно на 3. версию прошивки и надо перейти.
Согласитесь - это существенные плюсы.
Из за этого стоит заморачиваться.
В розничной продаже вокруг нас в основном CF 16 - 32 Gb.
Меньше 1 Gb - просто раритет :-)
Попробую прошиться до 3 версии через LAN.
Другого варианта не вижу.
После прошивки 3 версии в трансивере появится порт USB для флешек.
Тогда проблема с CF CARD старого образца сама собой должна отпасть.
Firmware Updates / Software Downloads | Support | Icom Inc
Три раза "пере прошивал" свой ic 7300 с базовой версии ,проблем "0" проще не бывает , а чем отличается прошить ic7800. Интересно ....... это просто поговорить?
Вложение 188078
P.S.Два раза "пере прошивал " бывший Yaesu ,а уж Kenwood уже и не помню то ли 12 то ли 13 раз.Наглядно видно разницу!
Отличие в том, что нельзя прошить IC-7800 с прошивкой 2.4 с USB флешки или кабеля RS-232.
Если прошить в него версию 3.0 и далее, то потом можно и с USB флешек прошиваться.
Я так только с Compact Flash или по сети LAN.
Вот я тут и пробовал с Compact flash прошивку загрузить. Да только похоже, с размером перебрал.
Вот такие вот пляски с бубном.:s10:
Все. Решил проблему с CF Card.
Попросил у знакомого на денек карту на 128 mB.
Она без проблем заработала с IC-7800 под прошивкой 2.40
Я на нее сохранил старые установки трансивера.
После этого на не на компьютере записал пошивку 3.30
Вставил в трансивер и... без проблем перепрошился.
Теперь в трансивере красивый водопад, USB HUB и еще куча всяких ништяков.
После всего этого без особой надежды решил попробовать воткнуть в трансивер
свою супер CF CARD на 32 Gb (с которой ничего не мог сделать) и о чудо...
Она завелась, определилась на все свои 32 GB и отлично себя чувствует.
Новая прошивка оказывается еще и поддерживает карты больших размеров.
На карточку я тут же записал несколько QSO из эфира. Все отлично записалось и сохранилось.
Так что кардридер в трансивере неплохой. Просто изначально прошивку не допилили под такие карты.
А может и нужды не было в те годы. Это сейчас 32 Gb никого не удивишь.
А где взяли v.3.30. ?
Вот тут последняя v.3.10 - Firmware Updates / Software Downloads | Support | Icom Inc
Вложение 188126
Если не секрет , поделитесь ссылкой.
Заранее tks !
Включился режим USB-D1, что это и как вернуть просто USB?
Решено.
