30.01.2007, 20:39 #1QRP
- 08.03.2006
- 26
Владельцам IC-7800
Кто распаковывал данный аппарат на передачу, интересует 40 метровый
диапазон.
30.01.2007, 20:44 #2Без позывного
- 01.01.2005
- 35
- 18
Чтобы его раскрыть надо пол трансивера разобрать и отстегнуть полностью лицевую панель.Раскрывается до 7,5МГц.
Сообщение от UT3GE
30.01.2007, 20:58 #3КолхозНик
- 24.11.2005
- Поле в лесу
- 3,552
- 2197
- 653
Icom IC-7800 (IC 7800 IC7800) General Coverage Transmit Mod
The IC-7800 can be modified for general coverage transmit(1.6 thru 54.0 MHZ) (Frequency Range and Specifications cannot be guaranteed after modification) by following the CAP/MARS directions below:
Remove top and bottom covers.
Remove 4 small screws holding front panel onto main chassis(2 per side).
Tilt up front panel(you may have to loosen and remove 2 connectors on lower left side of front panel) to expose the Logic Unit sitting vertically on the left side of the main chassis unit behind the front panel. You may find it easier to access the diodes by setting radio up on its right side.
Near the center of the Logic Unit (below and to the right of a processor chip) you will see 2 vertical rows of diodes / diode spaces. The bottom 4 diodes in each column are offset slightly to the right as pictured below. NONE OF THE DIODES IN THE RIGHT COLUMN ARE CHANGED!! The diodes in the left column must be configured exactly as shown below. This means that you may have to add or remove diodes in the left column depending on where you purchased your IC7800. USA radios are easy to modify as the only change is to remove D57. If you have to add diodes, try to use the ones that you had to remove(and make sure to install them in the correct direction-they ARE Surface Mount Devices):
LEFT RIGHT
D59 (no diode) 0 X (diode in)
D58 (diode in) X X (diode in)
D57 (no diode) 0 0 (no diode)
D56 (no diode) 0 X (diode in)
D55 (no diode) 0 - I forgot to note if there was a diode in this position.
D54(diode in) X 0 (no diode)
D53(diode in) X X (diode in)
D52(no diode) 0 X (diode in)
D51(diode in) X X (diode in)
Position the front panel unit back down into position in its proper place and then check to make certain that the connectors which connect to the front panel unit and to the logic unit are securely plugged in properly. Reinstall the 4 small front panel mounting screws(2 per side) and reinstall the bottom and top covers.
No radio reset is required. After this modification, there will be no band edge beeps if you had them turned on before, so be careful not to operate out of your band segment.
Enjoy your new General Coverage Transmit IC7800.
Блин.. лень.. а надо...73! Павел ru3dnn.ru
30.01.2007, 21:05 #4QRP
- 08.03.2006
- 26
Владельцам IC-7800 (ONLY)
Это мы знаем, а вот какие диоды выпаять а какие впаять?
У меня № 0301033, все что нашел в интернете пишут
по разному. Имеется три варианта распаковки, а вот какой правильно?
Вот так то, а ты говориш переднею крышку снять.
30.01.2007, 21:10 #5КолхозНик
- 24.11.2005
- Поле в лесу
- 3,552
- 2197
- 653
Обнародуйте сие...
Сообщение от UT3GE
73! Павел ru3dnn.ru
30.01.2007, 21:34 #6QRP
- 08.03.2006
- 26
RU3DNN
Павел сбасибо за отзыв, но вопрос остается открытым!!!
1 КОЛОНКА ham.dmz.ro service(mods.dk)
2 КОЛОНКА IC-7800 Modification/Service information Issued : May 27, 2004
3 КОЛОНКА UT3GE ЭТО КАК ОНИ НАХОДЯТСЯ В МОЕМ TX/RX
НЕ РАСПАКОВАННЫЙ ВАРИАНТ
<O X> <O X> <X X>
<X X> <O X> <X X>
<O O> <X X> <X X>
<O X> <O X> <X X>
<O -> <O X> <X ->
<X O> <O X> <X ->
<X X> <O X> <X X>
<O X> <O X> <X X>
<X X> <X X> <X X>
Может есть инфо какой диод и за что отвечает?
30.01.2007, 22:17 #7КолхозНик
- 24.11.2005
- Поле в лесу
- 3,552
- 2197
- 653
Да я понимаю, что вопрос открытый, а Айком закрытый..
Будем ждать ответа.. А версия аппарата какая, американская?
Если крышка снята, то "методом исключения", у нас на гарантии пока - не вскрыть.
Знаете, мне СС говорил о шести диодах, вроде как, так и есть.Последний раз редактировалось RU3DNN; 30.01.2007 в 22:19.
73! Павел ru3dnn.ru
30.01.2007, 22:46 #8Без позывного
- 01.01.2005
- 35
- 18
Спрашивайте на форуме Вам насоветуют.Есть Technical Information рассылаемая ICOM Distributors в которой есть Diode Matrix и для разных версий она разная.Обратитесь к продавцу у которого покупали и вопрос будет закрыт.Удачи.
Сообщение от UT3GE
30.01.2007, 23:10 #9QRP
- 08.03.2006
- 26
Да я так и понял надо обращатся к продавцу а иначе удачи не видать.
Но не ужели российские р-любители не распаковывали свои аппараты.
В России их на много больше нежели в Украине я имею ввиду владельцев IC-7800. Спасибо.
RU3DNN
А что когда на гарантии то нельзя вскрывать?
Пломбы стоят что-ли?
Что то Павел ты не то говориш!!!!!!!!!!!
31.01.2007, 09:58 #10КолхозНик
- 24.11.2005
- Поле в лесу
- 3,552
- 2197
- 653
Да, пломбы стоят... Помимо гарантии самого Айком, год гарантии даёт фирма-продовец. Нет необходимости выкладывать фотографии этих пломб (
). Дайте знать результат по "вскрытию пациента".
73! Павел ru3dnn.ru
04.03.2007, 19:43 #11High Power
- 30.12.2003
- Kyiv
- 545
- 204
- 84
Виталий!
Распаковал?
73! UT7UV
05.03.2007, 01:30 #12QRP
- 08.03.2006
- 26
ДА!
TX :
1.800000 - 1.999999
3.400000 - 4.099999
6.900000 - 10.499999
13.900000 - 14.499999
17.900000 - 18.499999
20.900000 - 21.499999
24.400000 - 25.099999
28.000000 - 29.999999
50.000000 - 54.000000
73! UT3GE
05.03.2007, 04:29 #13Малоактивен
- 18.05.2003
- Sillamae
- 78
- 11,867
- 3809
- 2101
Это похоже на штатовкую версию, а не полное раскрытие.
Владимир
https://www.qrz.com/db/ES4RZ
05.03.2007, 09:51 #14High Power
- 30.12.2003
- Kyiv
- 545
- 204
- 84
GM!
Виталий спасибо!
А дай расположение диодов, плиз.
А то у меня европеец и я уже запутался.
73! UT7UV
06.03.2007, 20:03 #15QRP
- 08.03.2006
- 26
TO: ES4RZ
Да это штатовский вариант, японцы
дали только такой вариант распаковки,
я к ним обратился с просьбой диапазона 7200 кгц,
так они мне дали вариант не полного раскрытия,
из серии "пошли дурака за бутылкой, он одну и принесет",
ну что просил то и получил. С другой стороны а что еще
нужно? СБишный бенд - поговорить с таксерами.
2Спасибо
