Привожу краткую информацию (это очень предварительно):
ICOM IC-7000
l IF DSP
Twin-PBT and other DSP controlled noise reduction features from higher-end models are
incorporated. Also, no optional filters are required.
l High 35W* of output power in the UHF band
*Final specification still tentative.
l 2.5 inch color TFT LCD display
l Ultra high +0.5ppm frequency stability specification
l 508 memory channels
500 memory channels, 6 program channel and 2 call channels
l Voice recorder, clock and log memory functions built-in
l Completely new controller design.
Modern and up-to-date design reflects current trends in product design and has a ‘family’
resemblance to bigger base station models.
l Dial rotation is selectable from free spin or spin with a click sound
l Smallest dimensions in its class
RF unit is planned to be 20mm shorter in length than current IC-706MK2G.
l Large, clearly labeled large backlit function keys for user-friendly operation
l Multiple scanning modes
Program/Priority/Memory channel/Selected memory channel/Auto memory write.
l 10-keypad hand microphone supplied as standard
l Controller separation capability retained for flexible installation
l The IC-7000 will retain many other features from the IC-706 series
