Like Tree4983Спасибо
Тема: Лог от UR5EQF
    14.08.2006
    1,289
    1033
    670
    Лог от UR5EQF
    Часто задаваемые вопросы
    Важно для Windows 8 и выше
  2. #14236
    02.01.2010
    Semily
    122
    50
    89
    Цитата Сообщение от RV3DHC Посмотреть сообщение
    As I right understood you, the command [pmCW_U] doesn't work to switch radio into USB from CW mode, am I right?
    Not exactly... :-) You're not right, it is quite different.
    I can switch radio from any mode to any mode by Omnirig, only for switching radio from USB DATA to USB I must use some workaround, because if radio is in USB DATA then no commands labeled [pmSSB_U] are executed, ie. no commands labeled [pmSSB_U] are sent to radio. This is the true for UR5EQF logger. Alex's client for Omnirig can switch radio from any mode to any mode. I think Vladimir programmed some internal logic into Omnirig's interface, because this interface knows that radio is in USB mode already and it don't send "the same" message again (USB DATA is in fact USB with DATA flag only). And LSB DATA / LSB is similar.
    If I write hexa command for switching radio to USB under any other label then [pmSSB_U] (eg. [pmCW_U]), I can switch radio from USB DATA to USB by pressing CW button.
    I do not know how to write more clearly.
    You certainly admit that behaviour has nothing to do with something like USB driver.
    I closed communication with Alex by now, because Omnirig itself works.
    Thank you for your effort to help me.
    Mirek OK4FX
  3. #14237
    07.04.2002
    г.Москва, г.Троицк
    48
    9,497
    2569
    7700
    @OK4FX:
    Mirek, there is no any other internal logic interfaces for communication between Omni-Rig and Log. All CAT commands come through the Omni-Rig as well. So, Log uses standard Omni-Rig DLLs to get it through. As you know, when TRX's mode is LSB or USB the Log shows SSB in entry panel.
  4. #14238
    Standart Power Аватар для RV3YR
    16.03.2006
    Брянск
    249
    101
    891
    Цитата Сообщение от RA4PR Посмотреть сообщение
    После обновления с версии 3.25 до 3.27, не соединяется с eQSLcc, выдает:
    Цитата Сообщение от UR5EQF Посмотреть сообщение
    Уже раз десять отвечал на этот вопрос.
    Почитайте, что нового в версии 3.27.:
    Еще один такой вопрос и задавший кладет 10$ на развитие программы!!!
  5. #14239
    High Power Аватар для UT2UU
    06.02.2009
    Woodstock
    621
    303
    248
    Цитата Сообщение от UU6JJ Посмотреть сообщение
    Сообщение от RZ6HGG
    Я также присоединяюсь к этому пожеланию. Действительно шрифт азимута очень мелкий и приходится напрягать, зрение чтобы его разглядеть и понять куда надо повернуть антенну. А еще хорошо бы азимут и выделить каким-либо ярким цветом.
    И я присоединяюсь к этому пожеланию.
    UU6JJ Владимир
    И добавить еще азимут по длинному пути. Частенько работаю и приходится высчитывать.
  6. #14240
    Big Gun Аватар для RX4CD
    02.01.2009
    SA-43
    11,122
    5512
    2774
    Исчё 10 баксов.
  7. #14241
    05.07.2009
    Иваново
    272
    201
    37
    Разрешите представиться - RU3U !
    Приветствую Вас, коллеги!
    Разрешите представиться по случаю получения 4-х значного позывного RU3U взамен прежнего RU3UM.
    Надеюсь привыкнуть к нему Вам не составит большого труда.
    Если у кого-то из присутствующих есть неподтвержденные мною посредством бумажных QSL связи на RU3UM, прошу направить мне приватное сообщение (порядка тысячи бланков QSL остаётся в запасе).
    Карточки на новый callsign пока еще не заказаны. Всему своё время.
  8. #14242
    Standart Power Аватар для RA5ZB
    02.04.2010
    г.Шебекино, Белгородская обл. (BO-27)
    79
    105
    45
    84
    Поздравляю. Успехов в радиосвязи!
  9. #14243
    Very High Power Аватар для RC2SC
    12.08.2006
    Рязань
    2,629
    882
    290
    http://www.omskair.ru/index.php/-qrzru/296--rz3cc
    Лучше и не сказать, да простит меня почтенная публика.
  10. #14244
    High Power Аватар для RW9CC
    23.12.2006
    Екатеринбург
    79
    668
    177
    383
    Приветствую,коллеги, и прошу помощи, если кто-нибудь с подобным сталкивался!
    В результате моих не совсем правильных действий по разгону троянов, у меня перестал запускаться лог.
    Более того - при открывании лога, когда уже всё вроде бы подходит к концу, комп уходит на перезагрузку!
    Откат на более раннее состояние компа почему-то не получается.
    Все другие программы работают нормально.
    Было примерно так - запустил сдуру какую-то программу (типа по активации аккаунта Одноклассников).При её установке произошла перезагрузка компа, а лог при этом был (кажется) запущен. Обычно он (лог) и не даёт возможности выключить комп, когда он открыт, а тут это произошло.
    И с тех пор, со вчерашнего дня, началось - пытаюсь включить лог - начинается перезагрузка компа.
    Что делать???
  11. #14245
    Silent Key Аватар для RM4Y
    28.05.2002
    Чебоксары, CU-02
    4,198
    3112
    642
    Похоже, вирус остался... для лечения можно попробовать CureIt! - http://www.freedrweb.com/cureit/ ... а потом еще и пройтись утилитой AVZ - http://z-oleg.com/secur/avz/index.php , очень помогает, только нужно уметь правильно пользоваться... впрочем, небольшой хелп там есть...
  12. #14246
    SK
    24.06.2008
    Пролетарск, Ростовская обл., Россия
    813
    205
    8299
    Я тоже пытался на днях восстановить вход на одноклассники и сдуру рубанул не ту ветку реестра, пришлось накатывать систему поверх, вчера только все восстановил. Сергей Вам правильно советует, пробежаться утилитой DRWEB и AVZ, но если это не может, то зайдите на сайт касперского, там есть утилиты по удалению троянов, конечно желательно знать какой вирус у Вас "поселился" и выбрать именно под него лекарство. Удачи!
  13. #14247
    12.08.2006
    Рязань
    2,629
    882
    290
    http://www.esetnod32.ru/.download/ot...rojan_remover/
    Бесплатные утилиты для удаления вирусов, троянских программ (trojan winlock, trojan win32, trojan packed) и иного вредоносного ПО (spyware).
  14. #14248
    High Power Аватар для RA1OHX
    13.05.2009
    Каргополь
    609
    235
    382
    На будущее советую сделать снимок системы с помощью программы Acronis - востанавливает систему за несколько минут
  15. #14249
    05.07.2009
    Иваново
    272
    201
    37
    To RA9XQ
    Понимаю, что данная конференция не место для обсуждения темы коротких позывных. Но!
    В эфире я с 1978 года. Да с коллективки, да, не мог я иметь индивидуальную радиостанцию, у каждого своя дорога в жизни, у меня наблюдательский позывной был в активном пользовании 15 лет. Телеграф освоил в 1977 году, в SSB провожу связи на английском, немецком, украинском языке. Имею диплом инженера по эксплуатации средств связи. В эфире не матерюсь, сигналом своим спектр "не гажу".
    Если Вы хотите сказать, что я получил короткий позывной огульно и "для понта" - Вы ошибаетесь! То же самое готов сказать и уважаемому Г. Шульгину. И кому угодно!
    Готов выслушать извинения.
    73! Владимир, de RU3U.
  16. #14250
    31.03.2009
    Зуяково
    78
    111
    22
    46
    Он перед Вами уже извинился.
    Последний раз редактировалось RX9WX; 27.10.2010 в 23:05. Причина: Ошибка в авторе цитаты
    Михаил (RX9WX)
Обратные ссылки (?)
    21.05.2013, 16:51
  2. UR5EQF Log
    21.05.2013, 06:55
  1. Ответов: 6
    от RX3AOE в разделе APRS
Метки этой темы
