- 14.08.2006
- 1,289
- 1033
- 670
Лог от UR5EQF
Часто задаваемые вопросы
Важно для Windows 8 и выше
26.10.2010, 01:34 #14236Standart Power
- 02.01.2010
- Semily
- 122
- 89
Not exactly... :-) You're not right, it is quite different.
I can switch radio from any mode to any mode by Omnirig, only for switching radio from USB DATA to USB I must use some workaround, because if radio is in USB DATA then no commands labeled [pmSSB_U] are executed, ie. no commands labeled [pmSSB_U] are sent to radio. This is the true for UR5EQF logger. Alex's client for Omnirig can switch radio from any mode to any mode. I think Vladimir programmed some internal logic into Omnirig's interface, because this interface knows that radio is in USB mode already and it don't send "the same" message again (USB DATA is in fact USB with DATA flag only). And LSB DATA / LSB is similar.
If I write hexa command for switching radio to USB under any other label then [pmSSB_U] (eg. [pmCW_U]), I can switch radio from USB DATA to USB by pressing CW button.
I do not know how to write more clearly.
You certainly admit that behaviour has nothing to do with something like USB driver.
I closed communication with Alex by now, because Omnirig itself works.
Thank you for your effort to help me.
Mirek OK4FXMirek OK4FX, OK1-36292
26.10.2010, 11:54 #14237Пользователь Linux
- 07.04.2002
- г.Москва, г.Троицк
- 49
- 9,497
- 2569
- 7704
@OK4FX:
Mirek, there is no any other internal logic interfaces for communication between Omni-Rig and Log. All CAT commands come through the Omni-Rig as well. So, Log uses standard Omni-Rig DLLs to get it through. As you know, when TRX's mode is LSB or USB the Log shows SSB in entry panel.
26.10.2010, 15:38 #14238
26.10.2010, 16:53 #14239
26.10.2010, 17:50 #14240
26.10.2010, 22:32 #14241Standart Power
- 05.07.2009
- Иваново
- 272
- 201
- 37
Разрешите представиться - RU3U !
Приветствую Вас, коллеги!
Разрешите представиться по случаю получения 4-х значного позывного RU3U взамен прежнего RU3UM.
Надеюсь привыкнуть к нему Вам не составит большого труда.
Если у кого-то из присутствующих есть неподтвержденные мною посредством бумажных QSL связи на RU3UM, прошу направить мне приватное сообщение (порядка тысячи бланков QSL остаётся в запасе).
Карточки на новый callsign пока еще не заказаны. Всему своё время.Владимир, de RU3U
27.10.2010, 00:39 #14242
27.10.2010, 08:02 #14243Very High Power
- 12.08.2006
- Рязань
- 2,629
- 882
- 290
http://www.omskair.ru/index.php/-qrzru/296--rz3cc
Лучше и не сказать, да простит меня почтенная публика.73! Владимир (RC2SC)
27.10.2010, 09:47 #14244High Power
- 23.12.2006
- Екатеринбург
- 79
- 668
- 177
- 383
Приветствую,коллеги, и прошу помощи, если кто-нибудь с подобным сталкивался!
В результате моих не совсем правильных действий по разгону троянов, у меня перестал запускаться лог.
Более того - при открывании лога, когда уже всё вроде бы подходит к концу, комп уходит на перезагрузку!
Откат на более раннее состояние компа почему-то не получается.
Все другие программы работают нормально.
Было примерно так - запустил сдуру какую-то программу (типа по активации аккаунта Одноклассников).При её установке произошла перезагрузка компа, а лог при этом был (кажется) запущен. Обычно он (лог) и не даёт возможности выключить комп, когда он открыт, а тут это произошло.
И с тех пор, со вчерашнего дня, началось - пытаюсь включить лог - начинается перезагрузка компа.
Что делать???73!Олег
27.10.2010, 10:12 #14245Silent Key
- 28.05.2002
- Чебоксары, CU-02
- 4,198
- 3112
- 642
Похоже, вирус остался... для лечения можно попробовать CureIt! - http://www.freedrweb.com/cureit/ ... а потом еще и пройтись утилитой AVZ - http://z-oleg.com/secur/avz/index.php , очень помогает, только нужно уметь правильно пользоваться... впрочем, небольшой хелп там есть...
27.10.2010, 10:22 #14246SK
- 24.06.2008
- Пролетарск, Ростовская обл., Россия
- 813
- 205
- 8299
Я тоже пытался на днях восстановить вход на одноклассники и сдуру рубанул не ту ветку реестра, пришлось накатывать систему поверх, вчера только все восстановил. Сергей Вам правильно советует, пробежаться утилитой DRWEB и AVZ, но если это не может, то зайдите на сайт касперского, там есть утилиты по удалению троянов, конечно желательно знать какой вирус у Вас "поселился" и выбрать именно под него лекарство. Удачи!
Павел. 73! RCWC # 18
27.10.2010, 12:05 #14247Very High Power
- 12.08.2006
- Рязань
- 2,629
- 882
- 290
http://www.esetnod32.ru/.download/ot...rojan_remover/
Бесплатные утилиты для удаления вирусов, троянских программ (trojan winlock, trojan win32, trojan packed) и иного вредоносного ПО (spyware).73! Владимир (RC2SC)
27.10.2010, 13:46 #14248
27.10.2010, 21:58 #14249Standart Power
- 05.07.2009
- Иваново
- 272
- 201
- 37
To RA9XQ
Понимаю, что данная конференция не место для обсуждения темы коротких позывных. Но!
В эфире я с 1978 года. Да с коллективки, да, не мог я иметь индивидуальную радиостанцию, у каждого своя дорога в жизни, у меня наблюдательский позывной был в активном пользовании 15 лет. Телеграф освоил в 1977 году, в SSB провожу связи на английском, немецком, украинском языке. Имею диплом инженера по эксплуатации средств связи. В эфире не матерюсь, сигналом своим спектр "не гажу".
Если Вы хотите сказать, что я получил короткий позывной огульно и "для понта" - Вы ошибаетесь! То же самое готов сказать и уважаемому Г. Шульгину. И кому угодно!
Готов выслушать извинения.
73! Владимир, de RU3U.Владимир, de RU3U
27.10.2010, 22:49 #14250Standart Power
- 31.03.2009
- Зуяково
- 78
- 111
- 22
- 46
4983Спасибо
