Страница 48 из 76 ПерваяПервая ... 3841424344454647484950515253545558 ... ПоследняяПоследняя
Показано с 706 по 720 из 1135
Like Tree463Спасибо
Тема: LoTW
  1. #706
    Very High Power Аватар для VE3EUT
    21.11.2002
    East Gwillimbury, Ontario, CANADA
    2,460
    360
    282
    Немного обнадеживающей информации от KE3Z
    Despite ARRL's statements that LoTW and DXCC data are safe, it seems that some users are concerned that this may not be the case due to the time that it is taking to restore service.
    Perhaps it will ease some minds if I tell you that I know for certain that these data are safe. I know this because I personally assisted ARRL staff to get these data backed up to locations and systems that are in no way connected to ARRL's HQ or cloud systems. The LoTW data, for example, exists in multiple physical locations and cloud backup services. Such is also the case for the LoTW source code. In addition, I imported the LoTW data backup into a separate, new test database system to verify it. This took several days since the database is about 3 terabytes in size. (It's a LOT of data!)
    Getting the systems themselves back on-line is another matter, and I have no information to share about that as I'm not involved in the ongoing process of restoring them. ARRL has apparently made the decision, wisely in my view, not to bring any affected systems back into service until all parts of them can be vetted and secured. But the data itself is safe, and LoTW will definitely be back at some point.
    -- Jon
    Все ольше поводов для оптимизма, что данные не пропали
  2. #707
    модераптор Аватар для RX3X
    18.12.2002
    Калуга-Город Герой!!
    28,948
    17073
    1895
    Да штож такое-то..
    Опять языки выучить не успел..
    Чё там вкратце?
    ПыСы Коллеги, если вас не затруднит, когда даете тексты, по возможности, давайте и перевод.
    Спасибо.
  3. #708
    Standart Power Аватар для RW4WZ
    08.09.2013
    Ижевск, Удмуртская респ., Russia
    258
    118
    202
    Да штож такое-то..
    Чё там вкратце?
    Спасибо.
    Несмотря на заявления ARRL о том, что данные LoTW и DXCC безопасны, похоже, некоторые пользователи обеспокоены тем, что это может быть не так из-за времени, которое требуется для восстановления обслуживания.
    Возможно, некоторым станет легче, если я скажу вам, что точно знаю, что эти данные в безопасности. Я знаю это, потому что лично помогал сотрудникам ARRL выполнить резервное копирование этих данных в места и системы, которые никоим образом не связаны со штаб-квартирой ARRL или облачными системами. Например, данные LoTW существуют в нескольких физических местах и ​​в облачных службах резервного копирования. То же самое относится и к исходному коду LoTW. Кроме того, я импортировал резервную копию данных LoTW в отдельную новую тестовую систему баз данных, чтобы проверить ее. Это заняло несколько дней, поскольку размер базы данных составляет около 3 терабайт. (Это МНОГО данных!)
    Возобновить работу самих систем — это другой вопрос, и у меня нет информации, которой я мог бы поделиться по этому поводу, поскольку я не участвую в продолжающемся процессе их восстановления. ARRL, по-видимому, приняла мудрое, на мой взгляд, решение не возвращать в эксплуатацию какие-либо затронутые системы до тех пор, пока все их части не будут проверены и защищены. Но сами данные в безопасности, и LoTW обязательно вернется в какой-то момент.
  4. #709
    03.02.2006
    20,719
    10216
    5482
    Лучше всего с английского на русский переводит Яндекс -
    https://translate.yandex.ru/
  5. #710
    Big Gun
    28.11.2013
    6,131
    4064
    752
    Попробуйте https://www.deepl.com/ru/translator. На мой взгляд более корректен перевод.
  6. #711
    High Power Аватар для EW2GI
    13.04.2009
    Минск, Марьина Горка
    889
    417
    277
    А последний абзац - ... ну который опустили. )
    "LoTW вновь проснется с тем же ужасным пользовательским интерфейсом, который был у него, когда он впервые стал общедоступным в 2003 году. Возможно, руководство ARRL узнает из этого «инцидента», что в эпоху социальных сетей оно продолжает плохо управлять LoTW и связанными с ним системами вознаграждений ( DXCC, VUCC, WAS) подрывает доверие к организации как среди существующих, так и среди потенциальных членов. Для организации, пытающейся обратить вспять сокращение числа членов, это нехорошо!"
    de AA6YQ
  7. #712
    High Power Аватар для RT2O
    24.03.2012
    59
    659
    873
    352
    Не барское это дело . Перевод в онлайн переводчике
  8. #713
    Модератор
    18.01.2003
    Кишинёв
    4,574
    2044
    8853
    Вроде как это не от KE3Z. Да и смысловой нагрузки для простых пользователей - ноль.
    Вопрос когда запустят и в каком виде. Про данные конечно радует, хотя и без этого сомневался, что проект такого уровня не бэкапится в пару-тройку независимых мест.
  9. #714
    21.11.2002
    2,460
    360
    282
    Этот вопрос нас всех волнует, но то, что периодически проскакивает информация, что бэкапы есть - это радует. На счет интерфейса, который не менялся с 2003го, мое личное мнение что не нужно трогать то, что работает. Он конечно убогий, но делает все что надо. А кому нужны отчеты и статистика, могут выгрузить свои QSL в тот же Logger32 и развлекаться с этим локально.
  10. #715
    Модератор
    18.01.2003
    Кишинёв
    4,574
    2044
    8853
    Он конечно убогий
    Скорее уж выдержанно-консервативный. Полезности всякие рюшечки, свистелки и куча апплетов с модными яркими градиентами ему не добавят, а аналитика вообще не его задача, совершенно согласен с
  11. #716
    21.11.2002
    2,460
    360
    282
    Что можно было бы добавить - это responsive design, bootstrap или нечто аналогичное чтобы нормально выглядел интерфейс и на мобильном телефоне
  12. #717
    03.02.2006
    20,719
    10216
    5482
    данные не пропали
    У меня сегодня вспомнилась история 12 летней (а может и большей) давности: топовые DX-мены (на 160 метров) обнаружили в своих рядах некий позывной, который работой на 160 метров замечен не был. При выяснении обстоятельств выяснилось, что все подтверждения на 160 метров сделаны через LoTW. Когда стали разбираться, выяснилось, что товарищ как то умудрился хакнуть LoTW и подтвердить себе липовые QSO. Тогда эту историю замяли и особо не афишировали, связи аннулировали. Вот возникает мысль - что, если проблема в том, что база не сломана, но в нее допустим достаточно долго заливали от имени ДХ липовые QSO? Это бы очень хорошо объяснило тот факт, что систему так долго не запускают.
  13. #718
    14.11.2012
    Таганрог
    2,354
    1627
    425
    А позывной его не помнится ?
  14. #719
    21.11.2002
    2,460
    360
    282
    Хакнуть можно практически любую систему, думаю, был бы бюджет и желание. Но тут вижу несоизмеримость усилий и полученного результата. Фейковый DXCC как результат? Ну это не серьезно, это как украсть шахматы в доме престарелых IMHO. У меня нет объяснения, почему долго не запускают. Но у меня есть уверенность, что после того, как систему запустят мы узнаем правду рано или поздно, эта инфа будет слита, у меня уверенность почти 100%
  15. #720
    Very High Power Аватар для RX0TX
    16.12.2007
    Черемхово, Иркутская обл.
    1,998
    544
    1284
    Думаю на сайте есть некие персональные данные. На сколько они полны - вопрос. Тем не менее как вариант, и\или спортивный интерес
  1. LOTW: регистрация
    от UN7GCE в разделе Аппаратные журналы
    Ответов: 3147
    Последнее сообщение: 08.04.2026, 18:16
  2. Помогите с LOTW
    от UA4NAL в разделе QSL
    Ответов: 717
    Последнее сообщение: 11.03.2026, 10:17
  3. У LoTW свои часы???
    от EX8AB в разделе Юмор и отдых
    Последнее сообщение: 12.06.2007, 15:30
