04.01.2020, 11:17 #1531
- 29.11.2010
- пос. Птичное - теперь часть Москвы в 30 км к Юго-Западу от МКАД
- 2,298
- 1261
- 541
Интересное видео. Все уже должны знать, что пару месяцев назад в России введены в строй новые загоризонтные локаторы ПРО, что сразу стало создавать значительные помехи на радиолюбительских диапазонах.
О том как цифровая часть FTDX-101 борется с подобными помехами это видео.
Игорь RL5A
07.01.2020, 14:35 #1532
от IZ8FFA
After several reports of malfunctions of my FTDX 101D, the Italian importer (tnx Marco) proceeded to solve the problems. Now the radio is fine and I think that with the next firmware the small problems related to the display will disappear. I repeat that the receiver of this RTX is truly exceptional and the listening quality is superb.
Purchased in May, one of the first produced. Excellent receiver with very effective filters. Pleasant listening and overall I must say that the radio is also well done. But… .. several problems that even today, after more than 4 months of patient waiting, have not been solved. The negative judgments, all reported, there are the different problems related to the TFT screen with its functions. Even today it is not possible to use it with some programs such as the CW Skimmer. In CW mode, the panadapter is slow to display after the TX / RX switchover. Bump in the speaker during RX / TX switching in CW which makes it almost impossible to listen through headphones. In short, many small things to fix. But the reason why I leave a low mark is the unpleasant behavior by Yaesu. After spending over 3,300 euros for a radio that is not efficient, it doesn't seem polite to me. At this point we must wait until and if there is a remedy for the defects.
На ютьб есть подобный отзыв от любителя из SP. Это болезнь первой партии и к нам такие не поставляли, никто не жаловался?Последний раз редактировалось R5AE; 07.01.2020 в 14:50.
07.01.2020, 23:01 #1533
- 29.11.2010
- 2,298
- 1261
- 541
В первой партии - которая майская - по отзывам американцев - был косяк с ALC, который исправили. В Россию эти аппараты вроде не поставлялись. В остальном итальянец бредит - какой CW скиммер должен работать? Ему никто этого не обещал. Для всяких скиммеров есть в FTDX-101D выход на дополнительный SDR приемник. Который надо купить - если он хочет скиммер;-)
Я покупал трансивер в октябре, выпущен он в сентябре. Работает нормально. Но новую прошивку все равно - надеюсь некоторые доп опции программные может сделают.
Экран большой - хочется на нем побольше возможностей.Игорь RL5A
08.01.2020, 09:40 #1534
- 01.07.2002
- Владимир
- 7,791
- 3885
- 492
Тема почищена от последних сообщений коммерческого, таможенного и правового характера.
Их обсуждение предполагается в других разделах форума.
Надеюсь на понимание.
Здесь - про технические вопросы.73! Андрей VZ
08.01.2020, 14:25 #1535
Спасибо! Жаль, что нет усреднения ( как у 7610) слишком быстро скачет на панораме.
В QSK треск реле громкий, наверное, качественные, надежные реле поставили с большими зазорами.
by F6GYY
Superb transceiver with top ergonomics and a very selective receiver.. Menu and sub-menus are well organized . The different colors on the main and sub-receiver are a big help...
The selectivity of the receiver is at top level with the combination of the roofing filter and the automatic preselector ... ( driven variable capacitor...)...
Also less noise ...
The AMC function is not very clear... There is a direct interaction between AMC and ALC....on SSB...
It is not explained correctly in the manual...!!!
If the equalizer is correctly set , you are getting a superb modulation... The mike gain should be reduced....
Have set AMC at 55 , microphone gain at 35 and processing as follow :
at 5 dB....for locals....
at 18dB …for DX......
Yaesu SSM-75G Speaker Microphone ...modified (see text) ...
Settings of the internal equilizer :
Bandwidth 100 Hz to 2900 Hz
P PRMTRC EQ1 FREQ 400Hz, LEVEL -10, BWTH 5
P PRMTRC EQ2 FREQ 1400Hz, LEVEL +5, BWTH 6
P PRMTRC EQ3 FREQ 2700Hz, LEVEL +10, BWTH 10
Attention ! The liitle mike joined with the transceiver , SSM-75G is faulty... it is not sensitive at all...and the modulation is disastrous....
Open it ...carefully...and remove the plastic membran covering the electret element, having a 1 mm whole on it...
Done in 5-10 minutes and you will see the difference...!!! See Equalizer settings above...
Results : a very plaisant modulation, well balanced on the mediums and on the high pitched tones...
My personal comment: it is absolutely not necessary to buy a " studio microphone..." which costs a lot of money...maybe later on...
Other problems : not really, but the PA fan switches on a bit quickly ...even after 3 minutes on SSB...
Интересно, почему так быстро снизили цену, наверное, много жалоб, а допиливать прошивку долго и дорого, проще цену сбросить...Последний раз редактировалось R5AE; 08.01.2020 в 15:15.
Кто себе друзей не ищет, самому себе он враг (c)
ვინც მოყვარესა არ ეძებს იგი თავისა მტერია
08.01.2020, 16:16 #1536
- 19.01.2009
- 1,947
- 816
- 582
С модуляцией там надо повозиться - это правда, но это смотря, что хочется получить.
Я пробовал подключить несколько приличных микрофонов: AudioTechnica AT- 4033, Shure SM58 Beta, Beyerdynamic SHM-205, как через внешний преамп со своей эквализацией и обработкой, так и напрямую, но, пока, все таки, все равно, остановился на штатной мыльнице. В принципе она тоже неплохо работает. Вот с пластинкой внутри надо будет попробовать. Вообще мне казалось, что там внутри динамический микрофон, а не электретник , как пишет этот француз.
Думаю, что это, просто, "перетягивание одеяла" на перенасыщенном рынке. На сегодня, за эту цену с такими параметрами и возможностями альтернативы нет.UA3AIF
08.01.2020, 17:02 #1537
Да, раньше в основном были динамические, а тут микрофон и спикер/динамик в одном флаконе.
Интересно, после переделки, как будет работать VOX/AntiVOX? "Заводиться" не будет?
Как они с такими ценами вообще выживают, непонятно ... ведь там сложная механика VRF- это же не просто "чистый" сдр, где все делается на программном уровне... Хотя, учитывая стоимость работы японских программистов, и стоимость высокобитных процессоров, чтобы получить аналогичные параметры, может быть с такой схемотехникой и дешевле выходит)Последний раз редактировалось R5AE; 08.01.2020 в 17:40.
08.01.2020, 18:42 #1538
08.01.2020, 19:05 #1539
Вы его вскрывали? Таки, там нет динамика громкоговорителя ? Француз написал
Yaesu SS M-75G Speaker Microphone- таки обманул? динамика там нет...Sumimasen ("мне нет прощения" по японски )
https://www.manualslib.com/manual/15...page=16#manualПоследний раз редактировалось R5AE; 08.01.2020 в 19:27.
08.01.2020, 19:16 #1540
- 15.01.2009
- Новороссийск
- 324
- 393
- 350
08.01.2020, 21:56 #1541
- 19.01.2009
- 1,947
- 816
- 582
Я его два раза открывал, думал, может капсюль заменить. Но там нет никакого динамика. НО сам капсюль микрофона мне напомнил конструкцию наушников ТОН ( думаю помните) с похожей пластинкой.
Или это все можно как то использовать в режиме динамик/микрофон, но об этом нигде не написано в описании , или у пользователей в Европах какие то глюки по поводу этого трансивера - один ищет в нем скиммер и ему по ушам что то постоянно бьет, второй что то нашел необычного в микрофоне.
Все равно интересно. Для чего то они ее там поставили.
https://yandex.ru/video/preview?film...t=1578509754.1UA3AIF
08.01.2020, 21:59 #1542
- 07.06.2009
- Люберцы (Lyubertsy)
- 696
- 307
- 118
Последний раз редактировалось RA3FY; 08.01.2020 в 22:06.
73! RA3FY
Михаил
08.01.2020, 22:43 #1543
08.01.2020, 22:58 #1544
- 07.06.2009
- 696
- 307
- 118
08.01.2020, 22:58 #1545
