24.10.2023, 10:43 #16Standart Power
- 19.02.2019
- Минск
- 340
- 122
- 261
Уже потихоньку первые отзывы пошли.
A Dick Tracey wrist radio it’s not! Instead it’s a small-compact lightweight 5-band CW xcvr that’s guaranteed to make you smile! Toss it your jacket pocket and go for a stroll in the park, beach, apartment balcony, cruise ship/mm, family camping weekend, fishing canoe voyage, junior’s soccer meet, or you name the event/activity! I’ve been chasing SOTA or POTA operators every opportunity I get! In fact I’ve been using the KH1 with it’s 4’ whip exclusively with surprising results! Granted QRP takes some getting used with listening more and talking less. And using some acquired “working DX” strategy to snagged some QSOs.
Every since I got the KH1 I can’t stop thinking about where to take it next. Having the logging tray is nice but also having the LOG capture feature of “Continuous logging of CW TX text; 32 kb EEPROM holds hundreds of QSOs” if nothing else a great log validation tool for SOTA/POTA activator OP who’s in the hot seat and can easily make typos while logging. (Noted this feature isn’t in the firmware yet) Changing keyer speed GUI is brilliant one tap of the - (minus) button reduces your speed 2WPMs or one tap of the + (plus) button increases speed in 2WPM increments so on the fly you match your senders speed.
The minor CONs: Speaker is tiny thus audio in quiet room is sufficient audio but earbuds are recommended for outdoors especially at the beach with the pounding surf! I’m still getting used to the paddle and keying while holding KH1 vertically I’m sure it’s just a matter of muscle memory time doing it. The paddle has adjustable spacing but not the tension. I prefer light touch but that might not be wise for hand holding the radio. So I’m adjusting to KH1’s medium touch tension.Это не хендлик Дика Трейси! Вместо этого это малогабаритный, легкий 5-диапазонный CW-трансивер, который гарантированно заставит вас улыбнуться! Бросьте ее в карман куртки и отправляйтесь на прогулку в парк, на пляж, на балкон квартиры, на круизный лайнер, в семейный поход, на рыбалку на байдарке, на футбольный матч юниоров или на любое другое событие/мероприятие! Я гоняюсь за операторами SOTA или POTA при каждом удобном случае! На самом деле, я использую исключительно KH1 с 4' хлыстом и получаю удивительные результаты! Конечно, с QRP нужно приноровится, больше слушать и меньше говорить. И использовать приобретенную стратегию "работы на DX", чтобы получить несколько QSO.
С тех пор, как я получил KH1, я не перестаю думать о том, куда его применить в следующий раз. Наличие лотка для ведения журнала - это здорово, но и функция LOG capture, является отличным инструментом проверки журнала для SOTA/POTA активаторов, который в спешке может легко сделать опечатку при ведении журнала. (Замечу, что эта функция еще не включена в прошивку) Изменение скорости передачи в графическом интерфейсе осуществляется одним нажатием кнопки - (минус), что уменьшает скорость на 2 WPM, или одним нажатием кнопки + (плюс), что увеличивает скорость с шагом в 2 WPM, так что на лету вы подстраиваетесь под скорость вашего отправителя.
Небольшие минусы: Маленький динамик, поэтому в тихой комнате звук будет достаточным, но для использования на улице, особенно на пляже с шумом прибоя, рекомендуется использовать наушники!
Я все еще пытаюсь привыкнуть к ключу и нажатию весел при вертикальном положении KH1.Юрий
24.10.2023, 11:58 #17
24.10.2023, 17:23 #18Standart Power
- 19.02.2019
- Минск
- 340
- 122
- 261
Я почитал их ветки на qrz.com
Это для меня отдать за полурадио 1100ye ощутимая сумма для семейного бюджета.
Но когда ты инженер в штатах и получаешь от 7к$ в месяц, то выделить небольшую часть на игрушку не такая уже тяжелая задача. Некоторые гордятся тем, что Elecraft все делает в штатах, пусть и сильно дороже в Калифорнии, пусть и долго, но типо с их покупок местные получают ЗП и мед страховку. Потому рады, что в китае не собирают, пусть и было бы 300уе. Менталитет другой, да и ЗП тоже =)
Смеха ради, я в полях без стола всегда, стул редко беру, так как тоскать десяток км не очень хочется.
Для лога есть папка А5 с твердым основанием, потому лично я нахожу такую штуку полезной, когда это в радио встроенно =) особенно лог переданных сообщений.Юрий
13.03.2024, 16:45 #19Low Power
- 30.01.2015
- Сургут ХМАО-Югра
- 33
- 15
Нафиг а-тюнер, лучше бы диапазоны до 10 м. сделали.
15.02.2026, 10:20 #20Standart Power
- 24.09.2019
- Санкт-Петербург
- 36
- 193
- 74
- 27
По мне так KH1 уникальное устройство!
Пересмотрел кучу роликов по нему и кажется он действительно позволяет выйти в эфир практически с любой локации.
Цена конечно на полный набор очень кусачая, учитывая что это CW only
Но эта штука не даёт мне покоя)))
Наверное без раздумий заменял свой KX2 на KH1
02.04.2026, 19:17 #21Standart Power
- 24.09.2019
- Санкт-Петербург
- 36
- 193
- 74
- 27
Ну что же....я получил наконец Elecraft KH1, за что огромное спасибо Сергею UA3MLU!
Не уверен, но возможно я первый владелец этой радиостанции в России
Будем изучать и пробовать работу в эфире с балконов/парков/скверов)))
Могу делиться впечатлениями в этой ветке....если кому-нибудь это интересно конечно.
DE R1BBG
02.04.2026, 20:51 #22Standart Power
- 09.02.2021
- 426
- 95
- 48
03.04.2026, 03:17 #23
03.04.2026, 11:48 #24Standart Power
- 24.09.2019
- Санкт-Петербург
- 36
- 193
- 74
- 27
В общем первое впечатление конечно же: оно не стоит столько!
Реально консервная банка, как и все элики, имхо))
Однозначно - на ощупь и выглядит относительно крепко и прочно.
Я приобрел комплект без "лотка для пива"
и без внутреннего модуля зарядки АКБ. Ну и само собой без самой АКБ, но последнее не является большой проблемой, так как это обычная сборка из 3х18650 литиевых банок с DC штекером 5.5мм.
Лоток необходим, ИМХО, только для работы "с руки", но это можно решить имея знакомство с опытным 3D-моделистом
Верхняя и нижняя части, а также клипсы для крепления телескопической антенны в "походном" положении явно напечатаны на 3D принтере. Пластик кажется вполне прочным. Штатный манипулятор с первого взгляда не внушает доверия, но это обманчиво! У меня не возникло с ним каких то фатальных проблем и после небольшой подстройки хода/зазора до 18wpm вполне нормально с него кодируются
Тракт не шумный, есть ATT с ослаблением на 10 и 30дБ. Приемник - ничего выдающегося, супергет с одной ПЧ...но повторюсь, что фишка этого аппарата не в каких-либо топовых характеристиках, а в том, что это реально ручное КВ-радио!! Кажется ещё полосовые фильтры перестраиваются электронно, варикапами. В мануале описана процедура улучшения чувствительности, если надо SWL погреть уши вне р/л участков. Клёвая фича электронный логгер переданных сообщений, содержимое которого выгружается в комп, имеет метки по дате и времени. То есть если вы владеете приемом в "голову" , то вести лог по сути вообще не нужно
(у меня пока проблемы с этим и мне нужен "лоток для пива"
) Ну и первое QSO сегодня на 20ке с G4RCG с рапортами 579/579 на балконную антенну.
В общем пока такие мысли...прикрепил фото рядом с переноской ID52 для визуального понимания габаритов этого малыша
03.04.2026, 13:51 #25Very High Power
- 18.06.2004
- Курган
- 4,939
- 3832
Один плюс этого радио-популяризация CW.
Никакого SSB и СМС.
QMX+, не?
Или хотелось именно такой форм-фактор?73! Андрей aka Модест Петрович. Не член и не многочлен никаких клубов.
03.04.2026, 13:55 #26Standart Power
- 09.02.2021
- 426
- 95
- 48
03.04.2026, 15:22 #27Standart Power
- 24.09.2019
- Санкт-Петербург
- 36
- 193
- 74
- 27
Можно было бы скользить в разы дешевле, но прям очень хотелось пощупать эту железку!
Прям с того момента, когда начал заниматься Морзе
Вес не более 400гр и по сути все, что нужно для работы, присоединяется к корпусу радио.
Тюнер на борту есть, 4x4 Г-контур, диапазон L от 0.35 до 5.25uH, диапазон C от 60 до 420pF.
И первое QSO с балкона на штырьевую антенну с R4AY! Валентин проходил очень крепко, что не удивительно - 700вт и 2 элемента видимо на меня.
Во время QSO пару раз залипал ключ, или руки крюки....в общем мне понравилось.
Из куска пластика быстро смастерил временную штуковину для бумажного лога.
03.04.2026, 16:18 #28Standart Power
- 09.02.2021
- 426
- 95
- 48
03.04.2026, 16:31 #29
03.04.2026, 16:44 #30Standart Power
- 24.09.2019
- Санкт-Петербург
- 36
- 193
- 74
- 27
Я даже больше скажу )))), у меня он был и целый год с ним где только не таскался. Но тут меня затянул телеграф и вот.
Несравнимые девайсы...500MP это не телеграфный трансивер и работать с руки удобно лишь в ТЛФ режимах.
Разочарование пока только лишь в том, что пришлось избавиться от стоящих девайсов ради приобретения этого RIG.
Повторюсь, что приобретая этот RIG надо понимать, что ты точно хочешь работать с руки откуда попало.
При этом ничего не мешает его использовать с нормальной антенной где-нибудь сидя на пеньке
Хотел ещё добавить по тюнеру: опция ATU подразумевает под собой не только плату самого ATU, но и верхнюю часть корпуса с болтиком под штырь, доп катушкой для согласования короткого штыря на 20/17/15м с движковым переключателем отводов этой доп катушки.
32Спасибо
