07.02.2014, 12:47 #16КолхозНик
- 24.11.2005
- Поле в лесу
- 3,559
- 2208
- 654
Вышло обновление V2.0.22
В нём:
- Wednesday MinTest Cabrillo output fixed according to the rules. (TNX RZ3AZ/UA5C)
- QTC network synhronization didn't worked properly for WAE RTTY contest.
- New contest supported: WRTC 2014.
- New option available: Commands->Live score->Use UDP broadcast. If checked, score will be broadcasted to selected IP address/port instead of making post via http, as requested by WRTC 2014 committee.
- OK/OM DX Cabrillo fixed according to format requested by contest robot.
- WWPMC contest config check was broken. Fixed. (TNX 9A4CD)
- Multiplier check routine from recinfo field was broken and call wasn't added to bandmap when received from dxcluster. Fixed.
- NAQP rcvd field expanded to support longer names. (TNX W9PA)
- NAQP config fixed by the rules. (TNX W9PA)
- Network time server was creating time info packets with local time info, instead of UTC. Fixed now.
- Regex processing routing had bug when processing RCVD field under some conditions. Fixed now. (TNX IK2NCJ)
- New contest supported: BALKAN HF CONTEST.
- New contest supported: Tesla Memorial HF CW Contest.
- Marconi Memorial HF CW Contest config file changed according to the new contest rules. (TNX IK6BAK)
- Multiplier count for NA Sprint contest fixed according to the rules. (TNX W9PA)
- Added prefill database for NA Sprint. (TNX W9PA)73! Павел ru3dnn.ru
07.02.2014, 14:08 #17Радиолюбитель
- 17.12.2005
- nr Калининград
- 2,959
- 1040
- 913
Может кто подскажет, как прописываются множители в конфигах ? Пытался разобраться на готовых файлах, не получилось...
Пока автор не сделал (хотя в "обещалках" есть), хотелось бы довести до нужной кондиции конфиг под УКВ тесты типа NAC (и т.п.), Пока только загвоздка с множителем за новый квадрат.73! Валентин UD2F ex: RU2FM
SunSDR2 + PA 100w + verticals (40, 20-10m), Inv L (160-80m)
07.02.2014, 14:30 #18КолхозНик
- 24.11.2005
- Поле в лесу
- 3,559
- 2208
- 654
Пока на эти вопросы сам автор не отвечает.. Вероятно, готовит подробное описание процедуры.
Валентин, посмотрите содержимое файла EUVUS.txt (по умолчанию C:\Program Files (x86)\DXLog.net\Contest). На его основе, подбирая YES\NO (обдуманно) можно сделать требуемый файл под свои условия. Или же, на английском языке отправить положение Крису и ждать нового релиза.73! Павел ru3dnn.ru
07.02.2014, 15:02 #19Радиолюбитель
- 17.12.2005
- nr Калининград
- 2,959
- 1040
- 913
Понятно Павел. Спасибо, попробую.
С Крисом на эту тему уже общался давно на форуме, он обещал сделать и в очереди это пожелание есть...
Если не получится сделать самому - то будем ждать.73! Валентин UD2F ex: RU2FM
08.02.2014, 09:06 #20КолхозНик
- 24.11.2005
- Поле в лесу
- 3,559
- 2208
- 654
и оно появилось - Contest definition, о чём Крис в рефлекторе написал We are working on documentation, hopefully it will be ready in next couple of days. There are 292 different parameters which can be customized in the config file, so it will take some time.
73! Павел ru3dnn.ru
10.02.2014, 23:24 #21Silent Key
- 18.01.2011
- Матвеев Курган
- 1,667
- 191
- 526
Пытался установить на двух компах. Выдает такое сообщение и кабздец))) Че делать?
Геннадий RU7L ex RN6MT, RA6LDY, EZ6LBB
11.02.2014, 11:40 #22Радиолюбитель
- 17.12.2005
- nr Калининград
- 2,959
- 1040
- 913
То, что пишет
) Установить Microsoft .NET Framework 4.0 (скачать с сайта Майкрософт)
11.02.2014, 12:33 #23КолхозНик
- 24.11.2005
- Поле в лесу
- 3,559
- 2208
- 654
Для установки программы понадобиться установить полную версию Microsoft.NET Framework 4.0. Скачать её можно с сайта Microsoft. Мне понадобилось, несмотря на то, что Windows-7 регулярно обновляется. Уже после установки NET Framework 4.0, желательно выполнить обновление. Как правило, приползёт 4 новых.
73! Павел ru3dnn.ru
11.02.2014, 13:11 #24Silent Key
- 18.01.2011
- Матвеев Курган
- 1,667
- 191
- 526
Спасибо за ответ Валентин и Павел. Я понял, что требуется установить. Но ворде как была установлена поумолчанию. Хорошо, ща скачаю и поставлю.
21.02.2014, 08:47 #25КолхозНик
- 24.11.2005
- Поле в лесу
- 3,559
- 2208
- 654
Вышло обновление V2.0.23
В нём:
- Digital modes recognition from bandplan when spot is received from DXC fixed. (TNX W9PA)
- Worked prefixes window was broken under some circumstances. Fixed. (TNX W8AKS)
- New rules for EA RTTY and EA PSK63 contest implemented. (TNX EA4ZK)
- Bandmap editor implemented. Check Bandmap properties in radio 1 or radio 2.
There are 10 different bandmaps available, default one which comes with installation and 9 which can be saved by user.
- Check partials and Check N+1 display order is changed now. N+1 algorithm is fixed.
This windows now shows data first in following order:
1. already worked calls, but not dupe
2. dupe calls
3. all other calls
In each of these three groups, callsigns are sorted alphabetically.
- SCP is now rewritten to optimize performance. Regex queries removed.
- Cabrillo "LOCATION" tag added for ARRL contests.
- Databases for YU and E7 local contests are refreshed now. (TNX YU7RL)
- Live score auto posting setting is now remembered in dxn file and restored when file is opened.73! Павел ru3dnn.ru
28.02.2014, 23:41 #26Радиолюбитель
- 17.12.2005
- nr Калининград
- 2,959
- 1040
- 913
Подскажите, не могу найти, как внести связь в лог с CW режиме без передачи макросов (не нажимая Enter в ESM).
К примеру в N1MM это можно сделать через Cntrl-Enter. А здесь ?73! Валентин UD2F ex: RU2FM
03.03.2014, 13:10 #27КолхозНик
- 24.11.2005
- Поле в лесу
- 3,559
- 2208
- 654
Пропишите под одной из F-кнопок $LOGQSO, тогда при ESM (Enter Sends Message) содержимое строки упадёт в лог и макрос никакой не будет передаваться.
73! Павел ru3dnn.ru
14.03.2014, 16:33 #28
27.03.2014, 07:33 #29КолхозНик
- 24.11.2005
- Поле в лесу
- 3,559
- 2208
- 654
Вышло обновление v2.0.25
Анонс версии.73! Павел ru3dnn.ru
14.04.2014, 09:58 #30
299Спасибо
