Вышло обновление V2.0.22
В нём:
- Wednesday MinTest Cabrillo output fixed according to the rules. (TNX RZ3AZ/UA5C)
- QTC network synhronization didn't worked properly for WAE RTTY contest.
- New contest supported: WRTC 2014.
- New option available: Commands->Live score->Use UDP broadcast. If checked, score will be broadcasted to selected IP address/port instead of making post via http, as requested by WRTC 2014 committee.
- OK/OM DX Cabrillo fixed according to format requested by contest robot.
- WWPMC contest config check was broken. Fixed. (TNX 9A4CD)
- Multiplier check routine from recinfo field was broken and call wasn't added to bandmap when received from dxcluster. Fixed.
- NAQP rcvd field expanded to support longer names. (TNX W9PA)
- NAQP config fixed by the rules. (TNX W9PA)
- Network time server was creating time info packets with local time info, instead of UTC. Fixed now.
- Regex processing routing had bug when processing RCVD field under some conditions. Fixed now. (TNX IK2NCJ)
- New contest supported: BALKAN HF CONTEST.
- New contest supported: Tesla Memorial HF CW Contest.
- Marconi Memorial HF CW Contest config file changed according to the new contest rules. (TNX IK6BAK)
- Multiplier count for NA Sprint contest fixed according to the rules. (TNX W9PA)
- Added prefill database for NA Sprint. (TNX W9PA)
