Thanks for your help to updating LogHX's internal callbook, great result.
Following your guidance, the internal Callbook was updated, and added 25000 news Calls sign to internal callbook.
I run in administrator mode, turned off the antivirus, and it does not work :(
Вложение 246502
LogHX3Setup_build_529, in a simple process of importing/exporting an adif file, some CQ/ITU zones are modified by LogHX.
To test the file "IN original.adi" was imported to >> LogHX >> and the file exported was "OUT changed.adi".
Please see the following:
AA4M - DM42 - CQ/ITU 03/06 in > the LogHX export CQ/ITU 05/08
K6JDC - FM07VX- CQ/ITU 05/08 in > the LogHX export CQ/ITU 03/06
N7MDW - EM75XR- CQ/ITU 04/08 in > the LogHX export CQ/ITU 03/06
K5PDC - FM16TV- CQ 05/08 in > the LogHX export CQ 04/08
KV4AA - EN41VL- CQ/ITU 04/07 in > the LogHX export CQ/ITU/ ITU 05/08
I need help to config the LogHX for import/export an adif file to LogHX without changing the original (in case CQ/ITU).
Thanks for any help to config the logHX.
Not problem:
Вложение 246551
Hi Alexei,
Thanks for your prompt reply, I configured the import options for LogHX, as your recommendation, but the problem still exists.
I used the "IN original.adi" file in the attachment to my initial post to test.
When I import my complete log (50000 records), + - 5% of the records are exported with the CQ / ITU changed by LogHX.
I am looking for import options like "(not) Compute DXCC from callsign", available at UR5EQF Log.
73 of PY5EJ.
I found it in the LogHX folder. Is it correct ?
Вложение 246568
Fixed - now work well:
http://rx4hx.qrz.ru/files/loghx/prer..._build_530.exe
No - Ctrl+Alt+Del -> Task manager -> Look at StopMachineServer in working process.
Alexei, I hope to be in the correct folder
Вложение 246637
Hi Alexei.
With a new release, LogHX_530, my problem with CQ/ITU was solved.
Thanks for all,
73 de py5ej,
Pavanatti
Something is blocking the signal from SpotServer to Log.
It's may be inside Window antivirus - try insert log and spotserver to exception.
Here is russian:
https://forum.qrz.ru/377-jt65-jt9-ws...ml#post1650284
For help:
Run gpedit.msc, then
Вложение 246700
some news .... I installed gpedit successfully. I inserted exeptions but the problem is still present .... I installed a new antivirus (Avast) instead of windows antivirus. despite the installation of the new antivirus, I still have the problem .....
in the "time file spots" setup, the time life is 1 hour for the bandmap. in the radio1 bandmap, the time life spot is only 2/3 minutes. Why I can't increase the time life spot in the radio 1 bandmap? is it possible to highlight the spot in the radio bandmap ? Вложение 247854
Hi
I am looking at changing my QSO input box from what I have
Вложение 256204
to something like this to save space at the top of the box. Plus I like the colours to highlight the freq, band etc
Вложение 256206
I am new to this, secondary question, can I run loghx, wsjt and JT alert all at the same time? I have loghx and wsjt working OK but when I add in JT alert it doesn't work, I think due to UDP conflicts. I have tried various changes but cannot seem to fix it. I want JT alert to read my LogHx log.
