Now all good Alexei with V751 - tnx for the fix! ::p-up:
Very 73 - Steve G0UIH
Hi Alexei - tnx for the fix.
All good now in V751 :p-up:
Hello,
Since version 749, I have the followings problems:
- Very long statistics calculating time (10s max before, now 2 minutes)
- Synchronisation with lotw, eqsl or clublog is freezing
Same problems with 750 or 751
Hello,
With 752 version: no more long calculation of statistics!
Thanks
More on the issue I covered in my post in post #765.
I have prepared some screenshots to show the issue...
First, the Awards window with the desired font settings: font size set to 16
Вложение 350734
Then I close LogHX down, and restart it:Now you see all font sizes in that window have approximately doubled...
Вложение 350735
So I go through and reset the fonts to how they were, save the view, close and restart, fonts doubled again.
A similar thing is happening with the Band review window - this screenshot is with the desired font settings...
Вложение 350736
And then, after a closedown/restart - note the column header and the row size has increased, and I cant see a way to adjust those, so they carry on getting bigger with each restart...
Solution is to open a new Band Review window, configure it and close the other one down....
Вложение 350737
- - - Updated - - -
One more thing.. (sorry!!)
WW Locators window:
Selecting a time period returns no data despite there being data to show:
In this screenshot, 1/1/23 to 31/12/23 are selected, but the map is blank:
Вложение 350742
... but the data is there, because using the same pair of dates in the Awards window does return data:
Вложение 350743
Yes, it's bug! Thanks!
Fixed -
https://forum.qrz.ru/355-loghx-appar...ml#post2006303
What skin (name) do you use?
Hello,
I have just migrated my log to LOGHX. I have a problem.
I just made a QSO in FT8 and when WSJT-X UDP the QSO in LOGHX this strange
thing happened...
4348 QSOs were registered and the software froze! Can anyone help me to solve this problem?
Thanks,
73, Pierre VA2CZ
See the screen shot of my problem
https://u.pcloud.link/publink/show?c...eaiipIsyTU2Bck
Check in log - setup for WSJT-X - here -
Вложение 351082
may be here same ports for UDP and Rebroadcast UDP?
Also check setup for Net.
LOGHX v 3.0 build 754
HXCAT --> IC 7600v2
When LOGHX start send to transceiver command CI-V TRANSCEIVE OFF
also when I enter and exit from Radio setup.
I'm sure it didn't happen before, if we go back a few versions.
This is a problem for me that I have connect PC+AMPLIFIER+Externat SDR Receiver+SDR CONSOLE....all need CAT
CI-V Transceive
Each Icom radio can operate in one of two modes concerning the CI-V interface: CI-V Transceive on or off. What is this?
With CI-V Transceive set to on, two things happen:
the rigs transmits data automatically over the bus, whenever frequency or mode changes
the rig reacts to data sent over the bus which is adressed not only to it’s own adress but also to a special adress meaning “all rigs connected”
With CI-V Transceive set to off, the behaviour changes:
the rig does not send data automatically, when turning the dial or changing mode, the connected computer must request (poll) data
the rig reacts only to data sent to it’s specific adress, data sent to “ALL” is ignored.
The default setting is CI-V Transceive set to On.
This is useful when connecting a rig to an accessory like an amplifier which can read the CI-V data (and switch bands accordingly).
Also this mode is used to synchronize two radios all the time, maybe in a contest setup.
Another little problem,
I usually use tu set FREQ A from CAT,
Now not read freq A when I am in spit, but read Freq B
Thanks.
73 de IK2XDE Andrea
