"-" - Deleted country. Got here by mistake.
For edit award use Awards window ->
Вложение 343236
Yes, it's problem.... Ok, I will think about how to fix the problem.
Вложение 343236
Thank you Alexei, all sorted :p-up:
Hello Alexei,
(How) Can I rename User11-20 fields' name in Setup/QSL Status or somewhere. I would like to see it in Award window / QSL method window. To rename in the Log window is OK but it does not help.
Thank you for your answer!
73 Egon / HA3MN
Thank you Alexei!
In the log window I will see the renamed field, OK.
In the QSL method window it stays as User11 but I KNOW User11 is what I want to see in log. So it is OK!
Hi Alexei...
Suggestion: - in the WW Locators map - would it be possible to be able to navigate around the fields by using arrow keys or buttons (up/down/left/right) instead of having to double-click to go back to the world map and select another field? In other words, to go from IO to JO, just click right. Would improve the useability of this window.
Cheers!
Hello Alexei,
Sorry to remember you but you did not say anything about that:
#659
07.06.2023, 09:41
Thank you,
73 Egon / HA3MN
Hello Egon!
For Radio - use this checkbox for save Radio setup in View
Вложение 344315
For Rotor - not problem! Will be done!
Alexei, hi!
Feedback.
Here with Windows 10, Intel i7, and JTDX 160rc2, the time synchronization function does not work in the latest versions of LogHX v.3.0 build 734 and 735. I went back to version 733 and everything works normally.
73 from py5ej,
Pavanatti.
Is there a way of having two seperate configuration files/setups? The scenario is my normal call is M0SDB however I now have a second call for contesting, M3O.
All my contesting will therefore be logged under M3O and I have another LoTW tSQL for it, QRZ page etc so I need to be able to configure LogHX to use those details when contesting. I have set up a new database for M3O however things like the LoTW settings, QRZ settings etc are shared with overall with M0SDB and ideally I would have two separate configuration files that would load with the connected database.
There are ways of overcoming this but they are not ideal.
Many thanks as always for any help
de Danny M0SDB/M3O
By the way - check here:
Вложение 344621
Setup->Default
for set system time log must be have administrator right.
