Hello Alexei;
I encountered a problem installing version 754, see below:
Вложение 351161
Thanks for your attention, 73 from py5ej.
Hello Alexei;
Вложение 351161
Is here path to Flrig.exe OK?
Вложение 351184
Hello Alexei,
I found this situation on filtering QSOs with date(s) and a custom field.
Вложение 351210
73 Egon
Thanks! Yes, it's mistake! Will be fixed!
Fixed -
http://rx4hx.qrz.ru/files/loghx/LogH..._build_754.exe
Hello Alexei,
Sorry but I forgot to say in my last message, I use 754!
What do I do wrong?
Вложение 351213
73 Egon
- - - Updated - - -
Вложение 351216
But this is OK!
DateQSO>=#01/01/2024# and DateQSO<=#02/02/2024# and Country="UA"
or
DateQSO>=#01/01/2024# and DateQSO<=#02/02/2024# and Country LIKE "UA"
73 Egon
Hello Alexei,
Thank you for the info, YES it works now!
But I had to reinstall v754 again. My 754 was updated by
the automatic update but it does not work! Hmmm...
I downloaded LogHX3Setup_build_754.exe from your website
and reinstalled it and NOW it works!
Thanks again!
73 Egon
Hello Alex,
tell me something about it,
every time I start loghx, it sends TRANSCEIVE OFF via CAT, and I have to manually go into the radio menu and re-enable TRANSCEIVE ON.
It's inconvenient to have to change it all the time.
Another little problem,
I usually use tu set FREQ A from CAT,
Now not read freq A when I am in split, but read Freq B
Thanks.
73 de IK2XDE Andrea
I'm use INI-files for Radio from OmniRig.
Now I check file IC-7600v2.ini for you Radio and found this:
; Icom IC-7600 ver. 2.00 firmware command set
; IC-7600v2 File created by Bob Wilson, N6TV, n6tv@arrl.net
; Tested by: N6TV @ KE1B & HRO Sunnyvale, CA
; Updated by N6TV 2019-03-23:
; - Comment out compound CI-V commands under pmVfoAA, pmVfoAB, pmVfoBA, and
; pmVfoBB because Icom firmware doesn't handle them consistently.
; - Removed pmFreq as recommended when both pmFreqA and pmFreqB are available.
; initialize
[INIT1]
;Turn CI-V transceive OFF
Command=FEFE7AE0.1A050097.00.FD
ReplyLength=16
Validate=FEFE7AE01A05009700FD.FEFEE07AFBFD
[INIT2]
;disable RS-232C decode, use CI-V
Command=FEFE7AE0.1A050098.00.FD
ReplyLength=16
Validate=FEFE7AE01A05009800FD.FEFEE07AFBFD
[INIT3]
;set CW normal to lower sideband
Command=FEFE7AE0.1A050089.00.FD
ReplyLength=16
Validate=FEFE7AE01A05008900FD.FEFEE07AFBFD
Try delete section [INIT1] from file IC-7600v2.ini (LogHX\Rigs\IC-7600v2.ini)
I think this should help.
Do you use CatHX? If yes then in log - Setup - Test CAT window- then set split ON/Off, close Test CAT window and send file with CAT info to me.
Yes this is the problem,
now problem solved I just put ; before
So initialize ignore/skip this line.
[INIT1]
;Command=FEFE7AE0.1A050097.00.FD
;ReplyLength=16
;Validate=FEFE7AE01A05009700FD.FEFEE07AFBFD
OK I send you personl mail with file.
73 de IK2XDE Andrea
Hi Alex,
I no longer remember how to disable auto reconnection to the cluster.
After sending "bye" to the cluster, loghx automatically reconnects.
I would like to disable the function.
Thank you.
73 de IK2XDE Andrea.
Ok, I tried your solution, but something is wrong.
with ALT+D disconnect telnet correctly.
But if I send the command via telnet
[DISCONNECT] - disconnect from telnet (command provided in the telnet macros)
loghx freezes. and blocks the system.
On the contrary, if I send the manual command "bye" via telnet,
telnet disconnects from the cluster and then reconnects automatically.
So I think you will have to adjust the macro command
[DISCONNECT] = ALT+D
so we can create the macro button in the telnet window to disconnect from the cluster.
Thanks for the attention.
73 of IK2XDE Andrea
Quick question and apologies if I am missing something - is there a QSO timer built in? I am working towards various CW awards that require QSO's over a certain length and I want to be able to start and stop a timer and for this to log the start and end time of a QSO.
I have tried doing this manually and when I set the start time the end time mirrors the start time and greys out so I cannot edit it. Plus I sometimes forget to note the start and end time so a timer would be useful.
Many thanks and vy 73 Danny M0SDB
