I remember that. But there is no way to do this yet.
I agree, this is a necessary function. I will do it in the next release.
Hi Alex, I understand that this is not easy to implement.
The solution could be to bypass the problem,
using "RADIO MACROS" supplied with Esdr3 v 1.0.8 and working perfectly.
At this point, as for the bandmap 1 and 2,
when you switch FROM radio1 (es. ICOM)
to RADIO 2 SunSDR2 radio via TCI,
"CW paddle windows" and "Voice windows" are automatically closed,
and the external program "RADIO MACROS" opens.
Perhaps it is useless to waste time implementing it,
since the original RADIO MACROS program powered by Expert works perfectly.
Thanks for your efforts
73 de IK2XDE Andrea.
I worry about adding awards where the first and only criterion is the district (County, Okres in Czech). But the program needs State - but we have no states, only Counties (Okresy). Many OK/OM stations indicate on servers (eg Hamqth) County character code - mine is GBL. What with it? Can County be added as the first criterion? And would it be possible to import a database of OK/OM callsigns with County codes?
Thank you for the info.
73 Josef OK2WO
It's wrong! Look here - https://adif.org/314/ADIF_314.htm
Enumeration for Country Code 503 (Czech Republic)
Code Primary Administrative Subdivision
Southern Moravia (Jihomoravský kraj)
GBL Blansko
By ADIF standart - GBL is Primary Administrative Subdivision - for log - State.
Oh yes - ADIF specifications - I did not know it, sorry. Thank you for clearing. I was looking in LogHX (live example):
Вложение 358199
Next I was looking to Hamqth XML (example on web) - there is <district> as our OKRES (STATE by ADIF) code:
Вложение 358200
That is a referred problem, probably.
73 all the best, Josef OK2WO
I do not see ? ? ? as Mode, but now (since I changed to vers. 762) the Mode is not taken from MSHV. It is a big issue, FT8, MSK, FSK, Q65 QSOs are RTTY or SSB by the band !
Returned to 758.
Pse QRX! Will be fixed in new release.
Hi,
Upgraded to 762 and changed "Call" font size and type at "Find" search.
Wher can I set these parameters? TU
73 Steve HA9PP
Вложение 358482
Now you can not change font for field Call (Find call), but if need - I can make it.
Today I test MSHV with log (I use JTDX for FT8). I can not found problem.
Explain - where ??? In QSOEntry window?
Pse printsrceen!
[QUOTE=RX4HX;2041645]Now you can not change font for field Call (Find call), but if need - I can make it.
I have returned to 761, so PSE check this part of program and make correction if possible. TU
73 Steve HA9PP
