Alexei,
Not recognized any difference. 763 still smaller.
73 Steve HA9PP
Вложение 358504
Вложение 358505
Alexei,
73 Steve HA9PP
Вложение 358504
Вложение 358505
Strange! Here -
Вложение 358516
older and new version - same font now!
What skin do you use?
Log from MSHV:
Вложение 358527
Log window:
Вложение 358528
My skin setting is
Вложение 358699
Still UDP Multicast working on this new version build 765?
Fixed problem with UDP Multicast -
http://rx4hx.qrz.ru/files/loghx/LogH..._build_766.exe
Hello,
starting with version 765, and later 766 and 767, there are problems opening the local file managers.
versions 763 and 764 work correctly.
Thanks.
73 de IK2XDE Andrea
Fixed - try this:
http://rx4hx.qrz.ru/files/loghx/test..._build_767.exe
ICOM IC-7600
With version 767 [ something changed in the management of the cat when transmitting in split.
Now, even if I set FREQA, it always reads the frequency FREQB, the one where I transmit in split.
Instead it should remain FRQA where I receive the dx station.
V763 work fine with cat.
Thanks for your attention
73 de IK2XDE Andrea
Fixed, please test -
If you select FREQA or FREQB - Вложение 360119
you can not use second VFO for split mode.
Hi Alexey,
ICOM IC-7600 does not have two separate vfos.
when in split mode,
the VFOA (FreqA) is fixed on the receive frequency, (red arrow on the bandmap) (in the log as RX FREQ)
the VFOB (FreqB) you move it to the desired transmit frequency.
(blue arrow on the bandmap) (in the log as TX FREQ)
Please check, until version 763 everything worked fine.
73 de IK2XDE Andrea
