Right mouse click - menu - "Select time period"
Same in previous QSO window.
I can do that but can you have 2 windows? one showing this month and one showing all time - both showing at the same time??
Now - not. Only one window. But I need to think about it. Maybe is good idea - to make a separate window for each statistic.
Hi Alexei,
Couple of things now I've fixed my login problems on here.
I posted in the past about the fonts in the Awards window doubling in size after restarting the program, when using a theme or skin for the main program.
i have found that it actually happens if the Awards window is actually closed and re-opened, and not just when the program is closed down and restarted.
I was also thinking as a suggestion, that the configuration of the Awards window could be loaded/saved in a similar manner to that of the Band Review windows.
Finally (for now!) I am finding the sound output selection on the DX spots alarm (Setup.. General Setup.. Color setup for Country Status) is changed if another sound device is connected or reconnected. For example, I plug in a Midi device I use to control my SDR software, and LogHX changes the output device to the Midi device I just plugged in (undesired behaviour)
Any way of making the selected sound output device "stick" ?
Any idea what httpgeterror - error code 87, error message : The parameter is incorrect. its from the spotmachineserver.exe
Log version?
768
Try this test version -
http://rx4hx.qrz.ru/files/loghx/test..._build_770.exe
sorry been away with work, says 404 error on the download
Now download last release 770 -
http://rx4hx.qrz.ru/files/loghx/LogH..._build_770.exe
Hello all,
today morning my friend CT1EHK Carlos did upgrade of logHX3 to 770 version.
He is facing the following situation:
Вложение 362936
He is able to run logHX3 when he chooses OK but he is afraid that something is not going well, Alex can you check what's wrong here ?
Best 73 all.
CT1DRB/OK8RB
David Quental
Hello Dear Alexei.
I need help sorting the QSLR(S)_Date columns after removing (30-12-1899).
Вложение 362945
Thanks in advance for any guidance, 73 from py5ej.
