Hello friends! I get a lot of letters from non-Russian speaking radio Amateurs. Especially for you, I opened this topic. Here you can write in other languages besides Russian. There are other topics for Russian)))
Hi,
I encounter a problem when launching the software, I have the error message "can not load SpotsServer!" . I tried to find the solution but I can't.
Where is it possible to find more information on the operation of the software (for example the manual)
Your help would be greatly appreciated !
Chris F5CBQ
Вложение 246117
Welcome.
Quite a umber of hams here speak good English.
@F5CBQ Have you tried to run LOG under administrator rights?
Hello Alexei, RX4HX.
Thanks for opening this topic; Congratulations for the great work with the logHX.
I plan to move my logbook with 50,000 QSOs from the UR5EQF-Log to LogHX.
After importing the UR5EQF.adif file, I can't find a tool or option to update the "Callbook internal" on LogHX.
Thanks in advance for any help or guidance.
73 by py5ej, Pavanatti.
py5ej@hrdlog.net
Try this prerelease:
http://rx4hx.qrz.ru/files/loghx/prer..._build_529.exe
Now proplem fixed or not?
Here:
Вложение 246400
After:
Вложение 246401
Thanks for your help to updating LogHX's internal callbook, great result.
Following your guidance, the internal Callbook was updated, and added 25000 news Calls sign to internal callbook.
I run in administrator mode, turned off the antivirus, and it does not work :(
Вложение 246502
LogHX3Setup_build_529, in a simple process of importing/exporting an adif file, some CQ/ITU zones are modified by LogHX.
To test the file "IN original.adi" was imported to >> LogHX >> and the file exported was "OUT changed.adi".
Please see the following:
AA4M - DM42 - CQ/ITU 03/06 in > the LogHX export CQ/ITU 05/08
K6JDC - FM07VX- CQ/ITU 05/08 in > the LogHX export CQ/ITU 03/06
N7MDW - EM75XR- CQ/ITU 04/08 in > the LogHX export CQ/ITU 03/06
K5PDC - FM16TV- CQ 05/08 in > the LogHX export CQ 04/08
KV4AA - EN41VL- CQ/ITU 04/07 in > the LogHX export CQ/ITU/ ITU 05/08
I need help to config the LogHX for import/export an adif file to LogHX without changing the original (in case CQ/ITU).
Thanks for any help to config the logHX.
Not problem:
Вложение 246551
Hi Alexei,
Thanks for your prompt reply, I configured the import options for LogHX, as your recommendation, but the problem still exists.
I used the "IN original.adi" file in the attachment to my initial post to test.
When I import my complete log (50000 records), + - 5% of the records are exported with the CQ / ITU changed by LogHX.
I am looking for import options like "(not) Compute DXCC from callsign", available at UR5EQF Log.
73 of PY5EJ.
I found it in the LogHX folder. Is it correct ?
Вложение 246568
Fixed - now work well:
http://rx4hx.qrz.ru/files/loghx/prer..._build_530.exe
No - Ctrl+Alt+Del -> Task manager -> Look at StopMachineServer in working process.
Alexei, I hope to be in the correct folder
Вложение 246637
Hi Alexei.
With a new release, LogHX_530, my problem with CQ/ITU was solved.
Thanks for all,
73 de py5ej,
Pavanatti
Something is blocking the signal from SpotServer to Log.
It's may be inside Window antivirus - try insert log and spotserver to exception.
Here is russian:
https://forum.qrz.ru/377-jt65-jt9-ws...ml#post1650284
For help:
Run gpedit.msc, then
Вложение 246700
some news .... I installed gpedit successfully. I inserted exeptions but the problem is still present .... I installed a new antivirus (Avast) instead of windows antivirus. despite the installation of the new antivirus, I still have the problem .....
in the "time file spots" setup, the time life is 1 hour for the bandmap. in the radio1 bandmap, the time life spot is only 2/3 minutes. Why I can't increase the time life spot in the radio 1 bandmap? is it possible to highlight the spot in the radio bandmap ? Вложение 247854
Hi
I am looking at changing my QSO input box from what I have
Вложение 256204
to something like this to save space at the top of the box. Plus I like the colours to highlight the freq, band etc
Вложение 256206
I am new to this, secondary question, can I run loghx, wsjt and JT alert all at the same time? I have loghx and wsjt working OK but when I add in JT alert it doesn't work, I think due to UDP conflicts. I have tried various changes but cannot seem to fix it. I want JT alert to read my LogHx log.
I have been using LogHX as my main log program for the last few weeks.
Exporting my log from UCXLog to ADIF v.3, and importing into LogHX3, I realized that LogHX did not recognize deleted DXCC entities. Y2 calls signs from before oct 3 1990 are not recognized as DDR, OK calls signs before 1993 are not recognized as Czechoslovakia, and so on. It looks like all call signs are allocated to the current use of the prefix, and I cannot find any way to change that in LogHX.
This is no big deal as I do not count deleted countries and I have all the Europeans in the log anyway. But as my old PJ QSOs is wrongfully recognized as the today PJ-entities, the filtered cluster list in LogHX get messed up.
To fix this I have moved all the deleted entity QSOs to a separate log in the log database.
Is this the way to do it, or have I overlooked something?
(I do not read Russian, but I do read the Russian language forum using google translate)
73 de LB2EG Richard
(SunSDR2-DX, LogHX 3.541)
Вложение 256325
This is what I see. Without JTalert running the callsigns goto loghx, on 2333. with it running they don't. wsjt and jtlert on 2237
Alexei,
thanks for the clarification on the deleted entities. Time beeing I have found a OK solution exporting the deleted countries QSOs into a separate log book in the log database.
One more question:
Sometimes i run 3 active sessions of JTDX in parallel; Sunsdr2-DX RX1 and RX2 + a remote site. I understand that LogHX offers only one UDP port for simultaneous logging from JTDX/WSJT-X, and there is no option letting LogHX read a combined (with symlinks) ADIF log wsjtx_log.adi.
UCXlog that I have uses for many years can monitor changes in the wsjt_log.adi and import new qsos into the log.
I such a feature planned for LogHX?
I have as a quick fix solved the UDP conflicts by using Log4OM v2 as a middleware, as that program can read data from several UDP ports and forward the data to one port. I guess there may exist smaller programs than this 500 MB memory Hog to solve this matter. Anyway, the proxy system seems like av feasible feature exploring the capabilities in SunSDR (and Flex-6000 series) to control RX/TX on several slices with CAT control.
Is a UDP proxy feature planned for LogHX?
73 de LB2EG Richard
Thanks, all sorted, I hadn't quite got the UDP settings correct.
Can you help on the QSO entry design? I seem to not be able to edit it to how the example is and I like that example design.
Yes, this is not difficult to do. As soon as I solve the problem with the search on QRZ.COM - I'll do it.
Here:
Вложение 257424
Вложение 257440
Thanks, what I cannot get to happen is the infomation box to move from the top, to make it go on the right side of of the columns.
You use old version of log. Last version here (see links in header):
https://forum.qrz.ru/355-loghx-appar...izmeneniy.html
Last version:
http://rx4hx.qrz.ru/files/loghx/prer..._build_538.exe
LogHX also monitor changes in the wsjt_log.adi and import new qsos into the log, but this work when UDP function unchecked.
Write all JTDX QSO to one wsjt_log.adi file?
For all users LogHX: install new version of log -
http://rx4hx.qrz.ru/files/loghx/prer..._build_542.exe
here fixed problem with search call data in internet.
I can, unfortunately, not get this to work. I have disabled (checked off) the UPD port support in LogHX, and written the log path to the common wsjtx_log.adi file. But LogHX does not automatically import new qsos written to the ADIF-file. I the drop down "programs" list, I have checked "Use JTDX" and "External program used".
My set up window looks like this:
Вложение 257852
Using JTDX I have one setup folder for every RX in ... ... \AppData\Local\... ; one standard \JTDX and two defined with the --rig-name= extention when starting jtdx.exe. The common wsjtx_log.adi is located in a sub-folder i my user space document-folder, with symlinks pointing to it in the 3 jtdx folders. As stated in a previous post, this setup works fine using UCXlog. In the LogHX setup I have not filled in the path to the jtdx.exe. This to avoid starting and closing jtdx when restarting logHX etc.
An observation, running 3 Jtdx sessions using this setup, the QSO ENTRY window in LogHX receives QSO data from the JTDX session using the ordinary \AppData\Local\JTDX setup directory. This does not happen when running QSOs with the two other JTDX sessions.
Clearly, I must have overlooked something in the setup. I would be very happy to receive some advise on this.
I am using LogHX 3.542. and JTDX 2.1.0_rc149_32A
73 de LB2EG Richard
Problem fixed - try this version:
http://rx4hx.qrz.ru/files/loghx/prer..._build_543.exe
Uncheck "Use UDP", now log will be correct read QSO from wsjtx_log.adi.
I have a problem with program freeze uploading QSOs to LOTW, when web receipt window does not appear. LogHX stays then in limbo and i have to terminate the program with windows tools.
Вложение 260758
This is a time to time occurrence on in home shack and 2nd home shack. Using win10 1909 and (new) Edge as standard browser on both QTHs. Now at my 2nd home shack i use LogHX3 545.
Checking lotw.arrl.org, shows that the QSOs has been transferred, and the problem seems to be that LogHX is stuck waiting for a receipt on that.
Is there any way out of this other than terminate LogHX?
73 de LB2EG Richard
Вложение 260821
I am on the newest 525 SW now, still the same.
Also as many people use the IC7300 and tend to have recording audio on, I wonder if there could be a future feature to somehow log or link to an audio file of the QSO?
Yes, log waiting answer from LoTW server, when tq8 file send to LoTW server. But waiting for a timeout. Timeout is about 30-40 sec (Timeout set not log, timeout set windows).
Ok, I will think about how to solve this problem. But the problem of waiting for a response from the server is this problem windows, not log. Here is problem.
If I understand correctly: you can add any file to QSO here -
Вложение 261050
Hello friends ,
I need some guidance, to set the Capitalization in LogHX, to automatically write the first letter in upper case and the rest of the letters in lower case.
A feed back for versions 559 and 560, in these versions, I can't import any more .adif (upload) files exported from UR5EQF of size 57000 QSO.
When an attempt imports a small .adif with two QSOs, the process works, but a large file doesn't.
If an old version is reinstalled as 558, all working well, I use Windowns 7.
Thanks for any help, 73 de py5ej.
Pavanatti.
Aexei,
After version 555/555 automatic reading of wsjtx_log.adi does not work anymore. Only UDP works. This is also the case on 560.
73 de LB2EG
It's work only for Name and QTH fields in QSOEntry window:
Вложение 271406
Can you send to me adif file? rx4hx@mail.ru I check it.
... Correct e-mail.
I'll try to check it out today.
Now i check - all right.
Here:
Вложение 271434
I have just found my old .adif log from 20years ago and wanted to merge it into my existing log, however I don't want it to alter my DXCC as I am in a new QTH now, but I still want to be able to check the log quickly to see if we have had a QSO before.
So is there anyway to do this if I have my 2020 log open, for it to check the older log aswell?
If you had a callsign prior to this one, you have to create another log in LOGHX and import your old ADIF into that log.
If you have current callsign still, you can import your old ADIF into existed log and DXCC stats will be updated as well.
Thanks, well its the same callsign but different QTH.
So I wanted to restart the DXCC, but also still check the other old log for previous QSOs. As this week I worked 2 stations who told me we had worked over 20 years ago, so that got me interested to find the adif, which I got from eqsl.
So basically I have main log M0CGF but would like to cross reference the M0CGF1999-2003 log when searching for callsigns.
If you already created M0CGF1999-2003 log , you have to press RMK (right mouse knob) in any point of "Previous QSO" window and choose other existed log to search for QSO you made years ago.
You're welcome.
LOGHX is not depended on different QTHs :) anyway. So, you are able to create any other logs for different calls/qths as you wish.
Hello, Alexei,
Thanks for orientation, the file. Adit was sent.
Sorry, about Capitalization question, I wasn't clear;
In my logHX the "Begin QTH with the upper letter" was setting, and not solve my problem.
Please, think in following scenery:
New station, for example "EE100V", is not present on Internal Callbook, is a new one on logHX.
From QRZ.com came Name: 100 ANIVERSARY VALENCIA C.F.
and QTH: ESPAÑA
So far it's perfect.
Now editing, Name and QTH fields in QSOEntry window, the Capitalization not work automatically, and here was my question.
Thanks again for any suggestion.
73 de py5ej,
Pavanatti.
Excellent thanks so much! Just got that working!
Fixed:
https://forum.qrz.ru/355-loghx-appar...ml#post1717329
http://rx4hx.qrz.ru/files/loghx/prer..._build_562.exe
Yes - it' work only when name or QTH manually enter.
which letter should be capitalized if name is "100 ANIVERSARY VALENCIA C.F."?
Alexei, on the used example, a club station not involve a personal names, but In nearly all European and Latins languages, single-word proper nouns, including personal names, are capitalized as Name and QTH, that was the reason for the question.
Thanks so much for your attention to clear me that function to Capitalization Automatically the data from QRZ.com, Name and QTH fields in QSOEntry window, are not configurable, and it' work only when name or QTH are manually entered.
I did try the new version 562 with large.adi, exported from version 558, sorry, unfortunately the problem persists.
Perhaps the problem is with my local system.
I thank you for your work and promptness, please accept my thanks.
73 from py5ej.
Pavanatti.
Hello friends, RX4HX and RC3C.
In search of a solution, I adopted an action radical all was deleted, and a new installation was done, and to work fine, all field from "ADIF setup" now are in blank.
Alexei, in all old versions, until the version 558 the "ADIF setup" were :
[ConvertADIFField]
ADIFField1 = QSLMSG # ADDRESS
ADIFField2 = COMMENT # NOTES
ADIFField3 = STATE1 # USER1
ADIFField4 = STATE2 # USER2
ADIFField5 = STATE3 # USER3
[SetADIFField]
USER1 = STATE1
USER2 = STATE2
USER3 = STATE3
To summarize, the problem cannot be attributed to the size of large.adi, as reported, but perhaps due to the combination of fields assigned into "ADIF setup" together with the recent versions.
I appreciate the collaboration and the attention received.
73 from py5ej.
Pavanatti.
You right! Problem was here. Fixed:
http://rx4hx.qrz.ru/files/loghx/prer..._build_563.exe
P.S. Check Setup->ADIF setup - I changed here.
Hello!
Dear Alexei, with the new version 563 everything is back to normal, now it is possible to use the old ADIF setup.
Thanks and,
73 from py5ej,
Pavanatti.
When I work a station from the USA for example and I am using QRZ.com as the lookup, the log fills in the name and address but not the state and QSL information. I need to manually run "find from internet" for the date tag before it updates. Any ideas what I am missing?
Вложение 272421
All these do it.
sorted, found I have messed the State box on the QSO input field so it wasn't in line, State was linked to another field. So put it back to state and it works.
Hello again Alexei,
I understand that you are quite busy working on other parts of your log program these days. I do, however, hope that you will find time to make automatic reading of wsjtx_log.adi work again.
Using the test versions, i understand that the "Active calls for JT65/Jt9FT8... modes" window will read the frequency of RX1. In my setup using Sunsdr2-DX, I use RX2 for FT8/FT4, picking CW DX on RX1. I may have overlooked something in the setup, but otherwise it would be nice to have an option to direct the active calls window to the QRG of RX2.
73 de LB2EG Richard
I'm check this - all is ok! May be wrong path to wsjtx_log.adi in log setup for external programs?
How JTDX/WSJT-X work with SunSDR2?
May be two path:
1. JTDX use LogHX as virtual TS-870 - set number radio here:
Вложение 273152
2. LogHX use TCI and JTDX work with ExpertSDR as TS-480 (select COM port for second radio)
Hello Alexei,
I have two radios in home shack, SunSDR2-DX and Flex-6300. When using the Flexradio with loghx (build 575) i am trying to direct dxcluster spots to the SMARTSDR waterfall, using the N1MM UDP protocol. I can monitor the xml data sent from loghx to SmartsSDR via SmartCAT N1MM UDP port but no spots shows up on the waterfall. Using N1MM sending spots to SMARTSDR works ok.
Reading the Russian language loghx groups, I understand that you did some testing on this in December 2018, but I cannot find any info on success..
If this function is not working in loghx, I can assist on testing.
73 de LB2EG Richard
On N1MM website you will find the information here (spot data) https://n1mmwp.hamdocs.com/appendice...dp-broadcasts/
Comparing xml data sent from loghx to SmartSDR on UDP port 12061 to data from N1MM shows very little difference :
From LOGHX:
Вложение 276479
From N1MM:
Вложение 276480
73 de LB2EG Richard
Thanks for info!
Correct - try this version:
http://rx4hx.qrz.ru/files/loghx/prer..._build_576.exe
Still no success. Comparing the data, I see two differences, where N1MM has comma-separated double digit frequency entry, and loghx has single digit with period-separation.
Вложение 276485
73 de LB2EG Richard
Here only one digit:
May be problem here. Try this version with comma-separated (local delimiter):
Now, it is working!
Thank you!
Maybe later on it will be possible to filter and colour the spots according to log status, like in ExpertSDR?
Вложение 276604
Вложение 276605
73 de LB2EG Richard
Not problem!
From https://n1mmwp.hamdocs.com/appendice...dp-broadcasts/
color set here:
<status>single mult</status>
My variants compliance of colors:
double mult = new country
single mult = new country on band
dupe = also dupe.
Now colored:
Works nicely!
Вложение 276633
Would it be possible with not too much programming effort to add a function in setup excluding spots that otherwise would be marked as dupe beeing sent with UDP at all? This way one can choose only to show spots for needed entities in the waterfall.
A yes/no choice in setup, e.g. in the Broadcast data pane would be nice.
Вложение 276634
73 de LB2EG Richard
Hide dupe spots here:
Вложение 276654
Noted!
But unfortunately, it does not work on SmartSDR waterfall....
Вложение 276673
73 de LB2EG Richard
As shown in my earlier screenshot, the spots window in loghx shows filtered spots, but no filtering in SmartSDR waterfall. (LogHX only spot source for SmartSDR)
I will be out of home shack for some days, operating from my 2d. home shack with no Flex-radio. Only IC-7610 and Elad FDM-DUO.
73 de LB2EG Richard
Ok Richard, i'm understand! "Hide Dupe QSO" - it's for other: if you wkd with call, it will be not showed.
You have a different problem - same spots. I'm use trx SunDSR2 with program ExpertSDR, and ExpertSDR show only one spot for one call, it make this self. New spot delete old spot for call.
How it's done in N1MM? Or not done?
I can make so: if spot is in log spots base - it will be not send to UPD.
By the way: is spots on SmartSDR use "time life spots"? Or can manually delete spot?
Excluding spots from the UDP stream is the way to go, I guess.
As far as I can tell there is an age function in the N1MM UDP function that can define the spot "age" in smartSDR, but I am not sure how it works.
Most other apps that send spots to SmartSDR use the Flex-API. https://www.flexradio.com/api.
The N1MM option is the only straight forward UDP method.
The Flex radio spot function is described here: https://edge.flexradio.com/www/uploa...escription.pdf
73 de LB2EG Richard
Now via UDP sends only new spots:
http://rx4hx.qrz.ru/files/loghx/LogH..._build_577.exe
I am trying to export an ADIF file just containing 1 stations callsign for an OQRS request. I follow the export and type the callsign in I want, press enter and the callsign goes into the box above, but each export has zero entries. Am I missing something?
Also is the new QRZ function load straight into QRZ.com? I added my API key to LogHXbut it doesn't seen to go up automatically.
I have this paid membership version "QRZ XML Logbook Data".
Ah select via "space" excellent I learnt something today ;) :s11:
Thanks, I am having trouble with Profiles.
I go to Create profile and type in all the boxes for my 3 types, M0CGF, M0CGF/M, M0CGF/P. I cannot then select these profiles in the log via the select profile option. When I go to the select setup>profiles>select Active Profile, none of these are in the list shown. If I type the full name in Set>profiles>create it then appears but I cannot get it to put in the information in the log. For example I run M0CGF/M, but often different locations so I want a profile per location with different equipment and location references.
Thanks, that saves well now, in the columns but now trying to get QRZ to upload, seems the _m is an issue but I cannot see where this is referenced
Вложение 279095
Profile name use only for save profile-settings. It's all. I think - it's coincidence. May be call M0CGF/M not register on QRZ.COM?
Look here:
Вложение 279097
May be EXTENDED=M?
Its definately on QRZ.com, you can see the Logbook info I posted from QRZ.com in the photo.
Really strange.
What fills in the Empty part you point to? Is that generated from QRZ.com?
Вложение 279098Вложение 279100
Thanks, I posted in their forum aswell. Will let you know the answer.
I uploaded the adi after i exported it.
QRZ has completed the import processing of your logbook file.
File name: m0cgf_mobile.adi (25 records)
Destination Book(s):
"M0CGF/M" (276317)
Started on: Fri Oct 23 19:08:02 2020
Finished on: Fri Oct 23 19:08:03 2020
Import Results:
25 QSO's were inserted
0 duplicates were replaced
0 duplicates ignored
0 errors.
25 queued for confirmation checking
No luck on QRZ.com
https://forums.qrz.com/index.php?thr.../#post-5642838
maybe its my profiles?
When I select my mobile log in LogHX but I keep the operator as M0CGF it uploads to QRZ to my home log not mobile. If I choose profile M0CGF/M thats when I get the error message on the live upload window. So I think its something not set properly in my loghx.
also noticed a typo on the delete QSO. Shure - SureВложение 279909
Install new prerelease
http://rx4hx.qrz.ru/files/loghx/prer..._build_587.exe
What to do: run log with parametr /D=<NewDirForSetupFiles>
Create new icon for log like this:
Вложение 280003
Set name for new icon LogHX_Modile or other and run LogHX from new icon. Set QRZ.COM settings for /M call.
Now you have two loghx icons - for home and for mobile.
Thanks! Fixed!
Вложение 280037
In here? Not sure where it goes
Does this mean its the same loghx.exe running but it just looks at different data?
Also
is it easy to set up a new contest? Looking to enter this weekend, this comp https://www.ukeicc.com/DXcontestRules/rulesrussian.htm
Ok, good
But I have experience with this:
- I made 1 LOG for some callsigns
- my LOG I have databases for RC3C, RC3C/5 etc..
- If I need to use RC3C/5 (for example)
- I go to File -> Open New Log in database
Вложение 280085
- choose RC3C/5 and click Open
Вложение 280086
It's easy, Watson :)
Alexei,
I use LogHX3 with SunSDR2-DX and Flex-6300 (not at the same time, however).
Each radio has 2 CAT controlled Receivers, where I usually use RX2 (Radio2) for FT4/FT8 with JTDX (connected to LOGHX with UDP) and at the same time chasing CW DX using RX1 (Radio1).
In this setup the RX2 (Radio2) with JTDX is not marked as the "active" Radio in LogHX3.
The problem arises using the Active Calls window, where I cannot find any way to bind that to the radio that is "inactive" in LogHX, making the QSL status-colouring in the Active Calls Window follow the band on the active radio.
E.g. when chasing DX on Radio1 on 15 meter band, and monitoring the FT8 activity on 20 meters, the Active Calls Window shows QSL status on FT8 related to the 15 meter band, and not the 20 meter band:
Вложение 281861
Have I overlooked something in he LogHX3 setup, enabling the Active Calls Window QSL status colouring to follow the "inactive" Radio?
73 de LB2EG Richard
Can you have a look if there is a bug around QRZ look ups stopping working if you operator over the change of day, ie 23:59>>>>00:00. I do this often and it seems to not fill in once you hit midnight and I have to restart the program.
Вложение 282673
Started to get some leaks on closing a few times
580, I think it might have started when I installed the one for the mobile log. I couldn't get all that to work so maybe we now have a mix of data.
Ian
Install this version:
http://rx4hx.qrz.ru/files/loghx/prer..._build_589.exe
here memory leaks is fixed.
It's not good... I check problem.
Setup->Time life spots->
Вложение 282676
check it for only needed spots.
Alexei,Цитата:
Сообщение от RX4HX;
mea culpa!
I had overlooked the "show only colored spots" option. Works well.
I am also very happy with the show only coloured spots options in Cluster window, Bandmap windows and Active calls window.
I hope you will find time to make a choice between Radio1 and Radio2 in Active calls window.
73 de LB2EG Richard
There is very little time for log - many coworkers is sick.
But only for you :) -
http://rx4hx.qrz.ru/files/loghx/prer..._build_590.exe
now band in Active calls window will be from WSJT-X/JTDX. I think - it's right. Not need choice radio.
Try this version.
Вложение 283248
I am trying to get myrig and myant data to stay with each QSO, but I cannot get it to enter automatically on start like my profile callsign and Locator. I notice that entries from FT8 from UDP (gridtracker and wsjtx) have the myant and my rig data. So I think something is not right with my log set up.
Вложение 283299
This is my Profile that I am using. Still nothing appears. It was already using this profile, I haven't changed it since posting.
I cleared my profile.ini
it now looks like this
; Created at 21/11/20 16:18
[M0CGF]
Antenna=ZS6BKW
Call=M0CGF
County=
IOTA=
Locator=IO91WI
Name=Ian
Power=
QTH=Sanderstead, South London
SelfView=False
State=
Trcvr=IC-7300
UseGPS=False
User1=PSE QSL, Direct, Buro, LoTW, QRZ, Clublog, EQSL
User2=
User3=
WFF=
Actually it does not go in to the log also.
See the yellow highlights. The QSO's at the top I groupchanged the field before.
Вложение 283341
Try this version:
http://rx4hx.qrz.ru/files/loghx/prer..._build_593.exe
Is now ok?
now it writes the new info but now doesn't log mylocator Вложение 283592
also doesn't autofill from qrz anymore
Вложение 283593access error also on start. reloaded v589.
Thanks, I checked those setting and I have qrz.com ticked already.
Looking good!! Many thanks!
Hello,
LoTW Users.
How to setup the logHX, v.3.0 build 595, to retrieve LoTW confirmations (CFM QSO).
The program works well with e-QSL and Club Log, but I can't with LoTW, as explain the image to VE6 QSO:
Вложение 284122
73 de py5ej,
Pavanatti.
Do you setup LoTW login/password in LogHX?
Is any data downloaded from LoTW server? Look at Download folder, file - LoTWdl.adi
Hello,
Alexei.
To abandon the UR5 log, I am trying work only with LogHX.
Everything looks good, I can upload to LoTW, eQSL, ClubLog.
The problem is with QSL-CFM in the LoTW.
In the past, with UR5, I used the Oleg App (US-E-12) to do this job.
I did a double check login/password in LogHX, I think it is all OK, can did the upload to LoTW.
I don't find the file LoTWdl.adi.
To check, after did the upload to LoTW, e-QSL, and ClubLog, see image an exemple, the QSO in my log, uploaded to LoTW, and confirmation QSL (W0AQ).
Вложение 284247
Thanks for your attention, 73 de py5ej,
Pavanatti.
Main window - Utilites - Correct log - Correct time: round to seconds
Select it for all QSO and try again download and synchronize QSO's from LoTW.
Now is Ok or not?
Hello Alexei,
I did step by step the sugestion, but not work.
When download and synchronize, is possible see:
Вложение 284408
Maybe is an error file, but I can not find the file.
Thanks for your attention.
73 de py5ej,
Pavanatti.
Hello Alexei,
Hello Alexei,
In order to get more information about LoTW QSO-CFM, I did a download without synchronize to the file LoTWdl.adi, it is annexed as LoTWdl.txt.
As you can see is a file.html, to do Log on to Logbook of the World
I inform you that the 4 fields referring to LoTW are configured in LogHX
In case of the new one, where are setting?
73 de py5ej,
Pavanatti.
Hello, Alexei, and LogHX users.
Since the end of November 2020, I migrated from UR5EQF-log to LogHX, to facilitate the use, it was necessary to update the database of LogHX- build 603:
In C:\HAM\LogHX\LogHX\CountryData
File: country_district.dat_(PY+LU ver. PY5EJ -Dez20), file attached with fields updated >> Call, State, WAZ and ITUZ for Brazil and Argentina, as suggestion for review and eventual use;
In menu LogHX >> Utilities/Primary and secondary areas;
PY- Brazil (State list without special characters):
Вложение 288393
LU- Argentina (State list with reference into suffix):
Вложение 288394
To use the above information, it will be necessary to edit via LogHX menu >> Utilities/Primary and secondary areas and rename file attached to country_district.dat and replace the originals.
After review, please Alexei, consider to include the update to the next build.
Thanks to Alexei,
73 of py5ej,
Pavanatti.
Thank you very much! It's very good job!
But need little correction:
Brazil (Acre State (AC)): 11: 12: SA: -9.97: -67.81: 3.0: PY: 43: 108:
PT8{Z0123456789},PU8{ABCDEFGHIMNOPQRSTUVWXYZ0123456789};
and
Brazil (Amapa State (AP)): 11: 13: SA: 0.03: -51.06: 3.0: PY: 43: 108:
PQ8{Z0123456789},PU8{ABCDEFJKLMNOPQRSTUVWXYZ0123456789};
here same prefix PU8 - how determine - PU8AA is it "Acre State" or "Amapa State"?
And not need write {ABCDEFJKLMNOPQRSTUVWXYZ0123456789} - it's excludes simbols from call. If you mean any letter - right is "PU8" only.
Code simbols in .dat file:
* - any letter A-Z
$ - any numbarts 0-9
{} - exclude simbols fom call - example for JA calls:
Japan (Chugoku): 25: 45: AS: 34.87: 132.82: -9.0: JA: 143: 339:
J{TUWVXYZ0123456789}4;
JT, JU, J8 ets - it's not Japan.
Hello Alexei,
Thanks for your prompt feedback!
The PU8xxx, are the following allocation:
PU 8 AAA a CZZ AMAZONAS;
PU 8 DAA a FZZ RONDONIA;
PU 8 GAA a IZZ AMAPA;
PU 8 JAA a LZZ ACRE;
PU 8 MAA a OZZ MARANHAO;
PU 8 PAA a SZZ PIAUI;
PU 8 TAA a VZZ RORAIMA;
PU 8 WAA a YZZ PARA;
Attached are more information about Call allocation.
73 de py5ej,
Pavanatti.
@PY5EJ
May I add this into COUNTRY_USER.DAT file ?
TNX
Please test this version:
http://rx4hx.qrz.ru/files/loghx/prer..._build_604.exe
here add PY and LU areas to country_district.dat
and now for PY and LU will be field "State" auto-determine .
Hello,
Alexei, and Anton -RC3C.
Alexei, thanks for add PY and LU areas to country_district.dat, the auto filling for the state field, works fine, perfect.
The rules to commemoratives call (PY, ...), with two or more numbers, like py##xxx, are Federative and allocated to Brazil, not associate with state.
Example:
zv15cdr Brazil 15Th Anniversary;
zw30bf Brazil Thirtieth Bauernfest - German Festival;
zz100abcz Brazil 100 anos da ABCZ - Uberaba MG (PY4 state);
Anton, if still interest, in attached you find as I did to edit and setting PY and LU on (COUNTRY_USER.DAT)..
Please accept my thanks.
Merry Christmas, for all!
Hi,
Alexei.
Merry XMAS!
Feedback to country_district.dat build_604.
Please, look for LU#(Sulfix XP-XZ) Tierra del Fuego the state is TF (not FT).
73 de py5ej,
Pavanatti.
For Flora Fauna is it possible to match the reference exactly like on the wwff website, For example DLFF-0093 instead of DFFF-093? As I typed into the WFF field DLFF-0093 and it doesn't show it in the Award part. Is there anything I can help with getting the WWFF references up to date locally with me then send them you to save time?
Вложение 289737
Hi Alexei
I tried as you suggested regarding translating the User2 -> SOTA_REF for ADIF export but I can't get this to work. When I examine the ADIF export in ADIF Master the User1/User2 and User3 fields are populated, the transformation of User fields via the ADIF Setup page doesn't work for me. Maybe there is something else I should be doing.
I am exporting using the menu item File -> Export -> ADIF Format
Many thanks, Mark M0NOM
Вложение 289842
Вложение 289843
Fixed!
What version of log do you use? May be problem here - use this version:
Yes, you can itself correct WFF award.
But you must remember: DLFF-0093 is not equal DL-093! Set for QSO field WFF as in award format!
Hi Alexei
Yes, the 604 version works correctly, thank you, and seasons greetings.
Regards, Mark. M0NOM
Good evening everyone.
I found this problem in the "New qso Entry" window.
If I enter RX4HX, it correctly goes to read the fields on QRZ.COM (so I configured it), and then automatically inserts them in the registration window of the qso.
But if I enter RX4HX/p or RX4HX/m it does not read any data on QRZ.COM.
In this case it should read only the full name field (FName + Name) and the e-mail field, leaving the QTH, State, County, and WWLoc field blank
because being in portable or mobile I will have to enter other data (other place) provided by the correspondent.
I hope I was clear in the explanation.
Thanks for the attention
73 de IK2XDE Andrea.
Good evening,
sorry, I've been using LogHX (v3.0 build 604) for a few days,
the management of the awards not clear to me.
In the process of entering a qso, where I can enter the reference of the desired award .. ??
For example .... if I am in qso with DL8AAM, I would like to insert the appropriate DOK reference,
but in the window "qso entry" there is only the possibility to choose the IOTA (drop-down menu)
and WFF .... which seem does not work, there is no reference....no drop-down menu.
Thanks for the attention.
It's sets here -
Вложение 291265
Now info will be search only for RX4HX.
ok works, but the command works in reverse.
Thanks.
All Ok:
Not found without - Вложение 291371
Now found - Вложение 291372
Good evening,
but in the window "qso entry" there is only the possibility to choose the IOTA (drop-down menu...ok)
For the other award.....where I put the reference....??
You can setup QSOEntry window as you like - look here:
https://forum.qrz.ru/355-loghx-appar...ml#post1688916
you can set count visible fields and set fields name.
OK, but that's not my problem.
I have already put 10 lines and all fields.
The problem is that the IOTA field offers the drop-down menu with references
the WFF field does not offer any drop-down menus and no references.
And then if I wanted to put another award type RDA how do I put it .. ??
Thanks.
In the right part of the "qso entry" window I have activated the buttons,
how can I do to activate only some and not all ..?
I would like to use only the "find" button.
Among other things, I suggest separating the information
FIND CALL: QRZ.COM - QRZ.RU - HAMQTH - Clublog - EQSL
FIND MANAGERS: IK3QAR Site - QSLInfo.de - Local File Manager
FIND OTHER INFO: 425DXN - DXSUMMIT
So three different buttons for the three choices
Thanks.
73 de IK2XDE Andrea
Hello,
LogHX users.
How to configure logHX, v.3.0 build 606, to obtain FT4 (qsl confirmation), from LoTW (R) and eQSL (R).
For MODE: FT8, the LoTW, eQSL and ClubLog work well, and the LoTW (R), eQSL (R) and Clublog (R) fields, in to LogHX are correctly confirms;
However, for MODE: MFSK, SUBMODE: FT4, only Clublog can confirm the Clublog (R) field as OK.
From file download:
ClubLog dl: ... <MODE:3>FT4 ... > the Clublog(R) field confirms, as OK;
<MODE:3>FT8 ... > the Clublog(R) field confirms, as OK;
eQSL dl: ... <MODE:3>FT8 ... > the eQSL(R) field confirms, as OK;
<MODE:4>MFSK<SUBMODE:3>FT4 ... > the field eQSL(R), NOT confirms;
LoTW dl: ... <MODE:3>FT8 ... > the LoTW(R) field confirms, as OK;
<MODE:4>MFSK <SUBMODE:3>FT4 ... > the field LoTW(R) NOT confirms.
In the Setup LogHX , Mode Setup, I found the standard configurations as : Mode - FT4, ModeDXCC - DIGITAL, Report - (-10), and V as OK, SubMode - FT4, Mode - MFSK.
Thanks for any help, to setup the LogHX, and get the FT4, LoTW and eQSL confirmations.
Happy New Year!!
"Stay safe"
73 from py5ej,
Pavanatti.
Hello Alde,
I donwload and receive confirm from EQSL and LOTW without problem.
You must verify that you have qso correct in the log.
You must have MODE MFSK and SUBMODE FT4
Sure you will have MODE FT4 ....wrong....
About mode FT4:
you can use two variants:
- first, you use in log mode FT4, but import/export ADIF with this settings
Вложение 291497
- second variant - in log use mode MFSK, submode FT4 with settings for external program (from WSJTX/JTDX log get mode FT4)
Вложение 291498
I'm use first variant. I think - it's simple.
Good morning,
in the calculation of the DXCC statistics, if I choose DXCC MODE,
it only presents me the choice of CW - DIGITAL - PHONE
the MIXED mode is missing.
Hope it will be fixed in the next version.
Thanks.
FT4 (qsl confirmation) LoTW and eQSL, the first variant, to solve the problem.
Hello!
Alexei and Andrea.
My setup was incomplete, without definitions to "ADIF Mode => Log Mode ".
Following the Alexei suggestion, first variant :up:, all confirmations are working.
Thanks,
73 de py5ej.
??? Secect "DXCC mode" and check CW + DIGITAL + PHONE = MIXED!
Here is new release -
http://rx4hx.qrz.ru/files/loghx/prer..._build_607.exe
today I will post it officially.
Of course, but please add MIXED in the menù.
Вложение 291615
Attached you will find some useful information
to update the country-district file for all users.
Thanks in advance.
73 de IK2XDE Andrea
Ok! Now i'm understand :) But isn't that it?
Вложение 291621
Thanks! I'll add it to country-district!
Ok...Here some other update for country-district.
73 de IK2XDE Andrea
Вложение 291629
Can I help Alexey to make presented here district list by @IK2XDE?
Yes ...of course no problem.....!
This files was for all ham.
Please for CANADA add also the provinces prefix
Canada
(NS) NOVA SCOTIA
(QC) QUEBEC
(ON) ONTARIO
(MB) MANITOBA
(SK) SASKATCHEWAN
(AB) ALBERTA
(BC) BRITISH COLUMBIA
(NW) NORTWESTERN TERRITORIES
(NB) NEW BRUNSWICK
(NF) NEWFOUNDLAND/LABRADOR
(NT) NUNAVUT
(YT) YUKON
(PE) PRINCE EDWARD ISLAND
73 de IK2XDE Andrea
OK.
I just asked Alexey himself for that :D
BTW, TNX FOR QSO
Вложение 291632
Alexey can you please add in the Award section (AWARD-->SELECT AWARD)
WAC - Worked All Continents
WAS - Worked American States
and also for DXCC please add "COUNT DELET ENTITIES"
(select or unselect flag).....I have in my log some old qso
with some delete entities.....and I whant to see that.
I think that some others users have the same problem.
Thanks in advance.
Continue my tests with LogHX v 3.0 buid 607
First, I have configured
"Setup LogHX" -> "Callbook" -> "Internet Database" -> "Insert data from QRZ.COM".
This works well and correctly with new QSOs for stations never worked.
But if I insert a QSO with a station already worked,
the old data from the log are taken by default,
those inserted in the previous QSO.
Personally I prefer to always have updated and new data, taken from qrz.com,
the correspondent may have changed qth in the meantime.
So the ideal would be to add the possibility to choose ....
whether to keep the old data or to force and always update with new data.
This is chosen by the user by putting a small flag "always update data".
I hope this option is easy ... and of interest to all users.
- In the "Correct log data" menu I would like to have the function for
update all the data (complete) by downloading them directly from QRZ.COM
(obviously only for the selected QSOs and not for the entire log).
This could be useful after converting a contest log,
therefore without the corresponding data,
or during the log maintenance phase, only for some selected QSOs.
Thanks for attention.
73 de IK2XDE Andrea
Of course :)
About WAC award - i'll add in new release few new fields in log, and awadr WAC will be available.
You can add this award youself... Sorry - now i'm busy - write about this letter. But short - add new award via: Award window - menu Select award - here.
Can some one who use FLGDIGI and LogHX help me please.
I am trying to set up logging for PSK31 and RTTY via FLDIGI. I have FLDIGI selected in the digital mode set up and the program run location also correct. But when I open the digi window I get the attached view. Only the text window, no FLdig waterfall or freq display, but in the bottom toolbar I see Fldigi but its not hiding anywhere behind any windows. I have tried uninstalling fldigi and I updated to v607 LogHX.
Вложение 292263
Yes, I verify,
Log field "INFO" = ADIF tag "NOTES"
So I thinks is better rename filed as the adif tag NOTES.....:s7:
ADIF tag "COMMENT" not exist any fild in the log.
Other filed in the log that I verify with adif, was QSLS
QSLS YES = ADIF tag <QSL_SENT:1> Y
QSLS NO = ADIF tag <QSL_SENT:1> N
But here NOT EXIST "IGNORED" = ADIF tag <QSL_SENT:1> I
FIELD "PrintQueue" = N
is the same of "QSL NOT NEED" FIELD "PrintQueue" = N ...... so ..... QSLS I (ignored)
I think is better use QSLS field with full compatible ADIF tag.
73 de IK2XDE Andrea
Here:
Вложение 292338
Now you can export log field Info to ADIF tag COMMENT.
Hello!
To contribute, follow my current setup of coutry_district.dat and more information.
HNY, and 73 de py5ej.
Stay safe.
Hi,
Anton.
As you can see from the attached files, the information is similar, but with a structure, and additional data,
to allow "auto-determine State", when added to country_district.dat, except for the Chile area.
The "XX - Call Distribution (Country).txt" files, also contain information for editing the "Primary and secondary areas" fields in LogHX.
Canada - Code adding, and some CQ and UTI zones have been corrected.
For testing, it will be necessary to replace the original file with country_district_(PY5EJ-2021-01).dat.
73 de py5ej.
Many thanks! Added! Please, check it:
http://rx4hx.qrz.ru/files/loghx/prer..._build_608.exe
Hello, I use V3.0 build 608. I use CWGet V2.37 registered, i can not start this from LogHX i have Error CWGet not found.
73 Pat
Hi Alexei,
Thanks for the info works now.
COUNTRY ERROR
C31CT was ANDORRA and not Uruguay
Вложение 293438
Hi,
Andrea and Anton.
In attention, I solved with the "country_district.dat (15jan21)" find in attached, for analyze and test,
If want test, please, rename and replace the file original.
Thanks.
73 de py5ej.
OK. I'll take a try this one. TNX
Tried.. C31CT now defined as Andorra
Вложение 293450
seems it works now with PY5EJ's correction
Thanks Alde, now all is correct.
73 de IK2XDE Andrea
Hello,
someone works the drop-down menu in the WFF field.
As in IOTA, if I double-click the drop-down menu that
offers me the IOTA references for the selected country opens.
Nothing appears in the WFF field.
Вложение 293504
Вложение 293505
Andrea,
Please, check WFF field equals to WFF. It has to be. If not, you have to change it to WFF.
1) Click 1 time LKM (Left key mouse) on WFF field
2) click RKM (right key mouse)
3) In opened menu use "Set log field"
Вложение 293512
4) In small window check if WFF equals to WFF like as my example
Вложение 293513
5) Change the field if no equal to WFF
6) LKM on [V] Field: options
7) choose the right log Field name to set
Вложение 293514
8) When choice is done, then click OK
if you need to change the name of log field, just change manually field "Field caption:" by typing text, then choose right Field log name to equal (see 6-7-8 units above)
Hope it helps
There is no WFF territory list in LogHX at all, Andrea.
Hello,
Yes, WFF field was correct
Вложение 293522
and as you can see, in the award section we have a lot of WFF award for some country
in example I use 9AFF.
Вложение 293523
so after this, in WFF field we should find 9AFF reference in the drop-down menu like in the IOTA.
Andrea
Alexey, Andrea and Anton.
In attached on to "country_district.dat (17jan21)" there is a complement for VK country, and new data for BY country, all info is for analyze and test.
To test, please, rename and replace the file original.
Thanks.
73 de py5ej.
Stay save.
Thanks Alde,
I will test it as soon as possible.
In this moment I focus my test on the award,
but I can't get the drop-down menu working on the other fields,
only on the iota it works. (in the qso entry windows)
I cannot choose the reference of the 9AFF (for example) from the menu,
but I can only enter it manually.
73 de IK2XDE Andrea
Hi Andrea!
For 9AFF and other programs (User5 for example)
Вложение 293837 Вложение 293839
Hello Niclolay,
thanks for your answer,
but I think you are wrong.
Is not necessary to use USER5 field.
Reference was in WFF field.
Вложение 293846
So you can insert reference for 9AFF award in the WFF field
Вложение 293847
And you can find your qso, with WFF field with 9AFF reference
Вложение 293848
And also you can find qsl in 9AFF award statistic.
Вложение 293849
The problem that I write was that in the QSO entry windows,
for IOTA field we have a drop-down menu that
present all IOTA reference valid for this call......
This function NOT work for WFF field.
Thanks.
73 de IK2XDE Andrea
MULTIPLE LOG with MULTIPLE CALSIGN......How to setup...??
Can someone explain me how to setup multiple log with multiple callsign.
My situation was:
Log: IK2XDE - Operator: IK2XDE Andrea
Log: IK2XDF - Operator: IK2XDF Gianpaolo (my brother)
Log: IQ2LZ - Operator: IK2XDE+IK2XDF+IK2ZJR....and other (club station call)
All log have different QTH and different login and password for LOTW/EQSL/HRDLOG...ecc..
I think the way was create 3 different DATABASE, and inside 3 different LOG (one for call)
Where I put all different config for LOTW/EQSL/HRDLOG...eccc...
Thanks.
IK2XDE Andrea
Previus QSOs windows
If in QSO ENtry window i type HG5OG, in the previus qso i find HG5OG and also HG5OGI
But that is wrong......HG5OGI was different call station.
I think this is a little bug.
Вложение 294494
For use log fom many callisgn:
https://forum.qrz.ru/355-loghx-appar...ml#post1765426
Run log with parametr - /D=<Folder name with ini-files> like:
LogHX3.exe /D=IQ2LZ
Easy way - make icons for each call on desctop. When you run LogHX3.exe /D=IQ2LZ first time - all ini-files will be copy on C:\LogHX\IQ2LZ folder (if log was installed in C:\LogHX). And now you can setup log for IQ2LZ with itself paramerts.
Create new log-base for each call.
Look here:
Вложение 294506
OK,
it would be more practical to switch from one log to another without having to exit the program.
Binding the directory with all the INI files to the log and call.
However, the idea of having separate directories for each call is great.
I tried /D=IK2XDE and it works, created the directory and copied the files.
At the start, however, does NOT connect the cluster via telnet.
If I run the program without /D=IK2XDE the telnet works fine.
73 de IK2XDE Andrea
Hello Alexey (RX4HX), and LogHX users!
For analysis, testing, and possible inclusion in future LogHX distributions, I present, attached, the file "CountryFile HC+HK+OA 2021-01-24.zip".
In addition to the previous suggestions, information was included for HC (Ecuador), HK (Colombia) and OA (Peru).
To test, please rename and replace the original file.
73 from py5ej,
Pavanatti.
Stay save.
About the Band / Mode Statistic
Currently showing two values (qso worked) + (qso confirmed)
You could please evaluate the possibility of putting the choice of single view (only qso worked) or the double one (worked + confirmed).
To be able to change the sort of "mode" columns.
It would also be nice to be able to export it to excel.
Thanks.
IK2XDE Andrea.
Hello,
there is something wrong in the cluster windows.
Вложение 295323
Вложение 295324
In example you can view differece beetwen telnet windows and cluster windows.
I think problem was when find caracter < > in the spot comment.
73 de IK2XDE Andrea
Check for dupe qso (in General setup)
In the log I would like to find this function very convenient.
Do not send the qsl for the same call/band/mode (QSO DUPE).
Field PrintQueue "N"
So in the qso entry windows, if I type a call already contact in the same band and mode,
the flag "N" is automatically put in the "PrintQueue" field.
Of course I can change the field before saving the qso,
but automatically "N" is set.
"check for dupe qso" function could also be activated when I import an adif,
perhaps after a contest, where I import in my log many stations already contact
several times in previous contests.
When I import the qso from an adif after contest,
if the qso is already present in my log (same call/band/mode),
"N" is automatically put in the PrintQueue field.
Of course this function is a personal choice,
which everyone can activate or deactivate in the general setup.
Вложение 295538
Thanks for reading.
Вложение 296891
Strange, been running fine for 1 year.
LogHX + Gridtracker + WSJT-X
Nothing changed but now it will not log into LogHX
The only way I can get it to work is if I use the main udp server value in LogHX but then gridtracker doesn't work.
I used to have it set up like
WSJT >>>> main UDP to Gridtracker
WSJT >>>> 2nd UDP to LogHX
If I type in the wsjt callsign box it would appear in the log entry box in loghx, now nothing. Many reboots. I even updated to 611 loghx and 2.30 wsjt but still the same issue.
Wonder why my system doesn't work
Try this version
http://rx4hx.qrz.ru/files/loghx/prer..._build_611.exe
All settings is right...
Hello Andrea,
Where can I download build 612 ?
73 Pat
Now you can choose:
Вложение 297649
http://rx4hx.qrz.ru/files/loghx/prer..._build_612.exe
I cannot find it but is there a field I can export to Excel that shows the CONTINENT of the station (ie Europe, NA, SA,OC,AF). Just need a field I can do some calculations on.
I find a little problem with BANDMAP
Вложение 297680
Вложение 297681
Hello,
Displays the information in the Radio 1 screen from qrz but not in the QRZ.COM screen from the LogHX use now buid 612.
We all know that 340 countries are currently valid for DXCC purposes.
Many of us, however, will probably log some QSOs with deleted entities,
made in the past, and therefore valid.
Qso that maybe we have regularly accredited for the award,
and rightly we want to keep track and visibility.
For this I ask if it is possible to integrate the DXCC statistics with these deleted entities,
of course with a choice flag, where I can select WITH or WITHOUT "DELETED ENTITIES".
Full list with all info here: http://www.arrl.org/files/file/DXCC/...nt_Deleted.txt
I personally have qso with these deleted entities:
Netherlands Antilles Is.
St. Marte-Saba & St. Eustatius Is.
Malyj Visosotsky Is.
All qso made in the past, when they are valid,
and regularly accredited for the DXCC.
I am not sure I can help in this case , if Alexey could understand your request
But
1) Menu - Utilities - Non standard Calls
Вложение 298364
2) Non standard calls window
Вложение 298365
3) Press "Insert" and Add needed prefix with dates of its availability
Second way, I am thinking, is
1) add deleted territories to country_user.dat file
2) When log started , Press Ctrl-C
3) Select deleted prefix for needed QSO
@RX4HX , your turn :)
Any ideas? I haveset USER3 to CONT but it doesn't seem to pull in any data. I cannot see continent as a standard grid header to add? Just want to display AF,AS,EU,OC,NA,SA etc in a field.
Hello,
With build 614, on START, I receive this error...!!
Вложение 298634
I return back with build 613....all is ok.
Thanks.
73 de IK2XDE Andrea
I’m not sure, but I found and fix same error. Please, check it:
http://rx4hx.qrz.ru/files/loghx/prer..._build_614.exe
Thanks....all work fine now....!!
No error on start and
also deleted countries in DXCC Award work very well and easy to setup.
Now I am using build 615
everything seems to work .... but I will continue my tests.
Now that we can count deleted countries in DXCC,
the graphic part should be improved,
highlighted those deleted,
and putting the selection Count deleted countries YES or NOT.
Вложение 298726
Thanks.
IK2XDE Andrea.
If I right understand, it's this:
Вложение 298757
Uncheck "DXCC mode"?
Menu UTILITY - STATISTIC - BAND MODE STATISTIC
ONLY WORKED
ONLY CONFIRMED
ALL
73 de IK2XDE Andrea
Вложение 298888
Change column position.
Change font dimensione.
Thanks.
About modes position: set mode position here - replace row with modes in Setup->Mode setup
Вложение 299017
About wkd/cfm - please wait :)
I try with build 618 to setup a contest.....but NO result.
Вложение 299062
Menu SETUP CONTEST --> CONTEST
No possible to select any listed contest
ONLY GENERAL CONTEST
Вложение 299063
Menu CONTEST
Open Contest
> EMPTY <
Only General Contest in the list
Вложение 299064
File menu - NOT OPEN (not work)
73 de IK2XDE Andrea
OK with buil 619 I try to setup a contest (ARRL-INT-DX-CW)
first view I have some observation.
Вложение 299130
EXCH received (STATE) ....was NOT SAVE IN THE LOG (OK in "ContestNRreceive" field)
MULTIPLIER Windows, show only worked multipliers, my opinion is better view ALL multipliers,
probabily in RED color (NOT WORKED) - BLUE color (WORKED).
In the SCORE windows, please add also DUPE count.
And also please not write "AREA" but I think is better "MULTI"
Some other observation...next days....I will continue my test.
73 de IK2XDE Andrea
Contest mode - universal for all contests. Log do not know, that in this contest Exch is State.
Yes, it will be done.
It is ok!
It is mult-name: exapmle for CQWW:
Вложение 299220
Try CW PADDLE with TCI and my SunSDR2DX (today build 619)
Sending macros in cw ....ok.....but seem that "speed" "letter delay" and other
they don't work, they have no effect on speed.
To change speed work only BreakIn menu (EESDR version 1.3.1 update 8)
Also SET NUMBER STYLE (T12345678NT)....NOT work.
73 de IK2XDE Andrea
Running today build 619.
I have setup
RADIO1 - ICOM IC-7600 - (HXCat Interface)
RADIO2 - SunSDR2DX - TCI
BandMap work perfect with radio1 (ICOM) but when I change to Radio2 (SunSDR - TCI)
BandMap not change, stay on Radio1 and NOT WORK.
All other CAT - PTT ecc... work fine.
- Button Panels (band Map).
If I change band cick on button panels, all ok....radio change band.
If I change band from radio, BandMap change correct, but YELOW button NOT change.
For apply number style - use {}:
09{09}
will send
09TN
Select SunSDR2 receiver here:
Вложение 299249
May be problem with Bandmap setup (Setup-Bandmap - do you making any changes here?)
@IK2XDE
Andrea, I am highly recommending to use special Contest Software for contesting instead of contest module in LOG.
Вложение 299318
THIS FUNCTION DO NOT WORK WITH TCI (SunSDR2DX)
But work perfectly with ICOM IC-7600 via (HXCAT Interface)
Вложение 299321
THIS FUNCTION DO NOT WORK WITH TCI (SunSDR2DX) and also with IC7600 via HXCAT
Вложение 299325
Radio 2 - SunSDR2DX was configured correct
Вложение 299326
QSO Entry windows work with no problem with TCI CAT
Вложение 299324
But BandMap DO NOT change beetwen Radio1 (Icom) and Radio2 (SunSDR)
Bandmap stay loked on radio1 and NOT change on radio 2
73 de IK2XDE Andrea
Log have two bandmaps window - for Radio1 and Radio2:
Вложение 299334
What is macros text? This function works only for macros.
OK, I will try it tomorrow evening,
I think that 2 Bandmap was for SO2R (2 VFO)
but when I am as SO1R (1 VFO), only one Bandmap work and switch radio1/radio2
.....OK....I will try.....
Thanks.
[TX]cfm 599 tu[RX]
Speed cpm / Letter Delay / Dash/Dot Delay (NOT WORK with TCI)
But work with HXCAT with ICOM IC-7600.
73 de IK2XDE Andrea
Operation after contest.
After contest I usualy import ADIF from contest (N1MM+) to LOGHX.
I hope to have this function useful to many other users soon.
>> UTILITY <<
Update data of selected qso from qrz.com
With this function, all QSOs imported after the contest can be updated with all the data (fields)
downloaded from qrz.com ..... obviously with paid access.
Thanks in advance.
Using build 627 .....and find this utility:
UTILITY --> FIND INFO --> FOROM INTERNET -->QRZ.COM
This is what i am looking for.......great...!!
......but.... NOT update LOCATOR ...and NOT update QTH (only partial) ONLY ADDR1 field and not ADDR2 field.
Please correct it.
Thanks in advance.
IMPORT ADIF....!!
FILE --> Import Adif
Can you please add date filter (from date - to date)
Thanks.
You can make it via filter:
Вложение 301527
... Hmmm, but it is for export, not for import. Do you need time filter for _IMPORT_?
Ok!
External programs for LogHX
In the new version of the log, the ability to get / insert data into the log from / to an external program will be added. Will be able to make external utilities for the log. If any want to write your own utility for the log , you are welcome! :)
Yes thanks....need date and time filter (FROM DATE <TO> DATE) and (FROM DATE and TIME <TO> DATE and TIME)
In the file menu,
we can find LOTW - EQSL and CLUBLOG,
HRDLOG is missing....!!
Please add also HRDLOG for (upload, download and synchronize).
In the clublog when we upload our log ..... please add the choice
MERGE into EXISTING LOG.....or......CLEAR LOG before UPDATE (CLEAR OPTION)
Вложение 301594
For all online log, LOTW, EQSL, CLUGLOG and HRDLOG,
please add the choice for UPLOAD
CREATE FILE TO SEND MANUALLY via web interface.
(Create file but not send automatically via LogHX)
Thanks in advance.
Andrea,
you can manually upload QSO to HRDLOG using this
Вложение 301596
Click right mouse key, in menu use "Send QSO to hRDLOg.net"
YES....but work only for single qso (only single selected qso)
I ask a full procedure like eqsl or clublog
(UPLOAD-DOWNLOAD and SYNCHRONIZE)
I think the problem comes from the fact that in the log we do not find the HrdS and HrdR field
Thanks for attentions.
@IK2XDE HRDLOg was optional functionality as I know.
Let's see what Alexey replies
I have verified and confirm that the HRDLOG fields are missing in the log.
I therefore ask Alexei to add these fields to better manage the sending of QSOs on HRDLOG,
as he has done for EQSL, CLUBLOG and LOTW.
Another request is to add the PRINTQUEUE field in the QSO manually entry / edit windows.
This field is missing.
I have my view for using WSJTX set up using the normal colours but I want to run the dark mode using the "wsjtx --stylesheet :/qdarkstyle/style.qss" on a desktop short but, when I point the wsjtx location at the shortcut it doesn't work. Any ideas how to auto run the dark mode from the view?
It is a window appeared when QSO uploading to HRDLog.net
like this
1) Selecting the QSO (for example KC1LAG)
Вложение 301624
2) See the proof of uploading
Вложение 301625
Look here:
Вложение 301669
write here:
This is for live use, when you send a qso, you see the confirmation message.
But not when maintaining and checking the log.
There is no way to see if a qso has already been sent in the past.
Thanks.
Problem with LOTW and EQSL and clublog synchronize.
Using build 627 (start log (/D=IK2XDE) because I have a lot of log.
When I select sinchronize download log and chose the file that will be /LOGHX/IK2XDE/DOWNLOAD directory....
and pres GO.....whean I press GO ......everything crashes, even windows ... and I'm forced to restart the pc.
Nessun messaggio di errore.
In these years I have tried several logs, I think that an interesting function when we synchronize the log with eqsl,
is to download the images of the qsl and save them linked to the qso.
It would be useful to download the eqsl images and save them in the photo field of each qso.
Yes! I'm fix this problem!
Prerelease 629:
https://forum.qrz.ru/355-loghx-appar...ml#post1787917
Sorry, but nothing change for me.
Running buil 629 - (Windows 10pro - I7 9700k - 32GbRam)
Starting log /D=IK2XDE
When I try to synchronize LOTW download log, windows freeze.
I just send you my log and adif file, try LOTW and also EQSL same problem.
If I run log in normal mode (NO /D=IK2XDE) all work fine....!!!
- OTHER QUESTION
Using "QSO MANUAL ENTRY" it does not take data from qrz.com
Using "QSO MANUAL ENTRY" the "Printqueue" field is missing (please add it)
Thanks for your continued efforts to improve the software
73 de IK2XDE Andrea
To be more precise, the search on qrz.com does not work correctly,
it is the third possibility, even if in the setup I have activated only one choice.
I have only configured the search on QRZ.COM
Вложение 302036
But first look on QRZ.RU ........ and get error.
Вложение 302037
then it looks for HAM.QTH and gets an error
Вложение 302038
Only as a last resort (3) search on QRZ.COM and enter the data correctly.
73 de IK2XDE Andrea
QRZ.RU window open or checked this menu:
Вложение 302249
Same for HamQTH.
Done - prerelease 630
https://forum.qrz.ru/355-loghx-appar...ml#post1399067
And check again
Now is ok or not?
OK.......Printqueue in the "QSO MANUAL ENTRY" windows work well......thanks...!!
Problem with search info on qrz.com....in "QSO MANUAL ENTRY" was that if i press button
on the right of the call, search start in all of three callbook QRZ.RU -> HAMQTH -> and finaly QRZ.COM
with error result....of course....because was not configured....
But If I select only QRZ.COM......should only search on qrz.com
Unfortunately synchronize with lotw and eqsl still doesn't work.
As soon as I press GO windows freezes.
Please note that only if I start /D=IK2XDE
If I start in normal mode, all work whit no problem.
Thanks.
73 de IK2XDE Andrea
Вложение 302259
Another observation, although having entered the fields in setup, RTX, ANTENNA and POWER
are not copied in the QSO entry window.
Вложение 302261
For QSOManuallyEntry set search servers here:
Вложение 302262
It's very strange. Whan is on screen, when log is freezes?
Yes....I run as administrator......!!
Hm... It's mystery for me :)
I'm check with you log/setup - not problem. Something block work of log.
Well, after countless tests looking for the solution, I found what is blocking windows.
"SHOW NEW COUNTRY"
if I select this function everything stops as soon as I press "GO",
if I don't select this function, everything works correctly.
I have successfully syncronized over 100,000 qsos on lotw and eqsl with no problems.
So the problem is "SHOW NEW COUNTRY" in the syncronize windows.
Вложение 302763
This function in my opinion i very important,
very often we have problems with the internet line, with the server busy,
especially during the weekends and after the contests.
It is therefore very useful to be able to create the log to be sent,
and then send it later, via the web and not automatically.
Oppure per esempio io preferisco usare per LOTW il software TQSL separatamente.
Grazie per l'attenzione.
Hello Alexei,
Using build 631
In the "QSO MANUALLY ENTRY" now you add e drop down menu for "Print Queue" field.....welll....work fine.
But you are missing "N" QSL NOT NEED please add it....
Вложение 302827
Thanks.
Many thanks Andrea! This is a big help for me! In new version I'll make here new functional.
How about variant - checkbox "Send manually" in upload window?
About LoTW: here create ADIF or tq8 file for manually upload?
Look new prerelease 632 for new work of Print Queue here:
https://forum.qrz.ru/355-loghx-appar...ml#post1792469
Yes, for EQSL and CLUBLOG
checkbox "CREATE ADIF TO SEND MANUALLY"
if checked, loghx only create an adif file, to be send manually via
web interface.
Same checkbox here.
Create ADIF file to be send manually with TQSL,
then users sign file with TQSL and send to lotw server.
Thanks.
Ok, using build 632
Вложение 302840
Please here add this choice "QSL NOT NEED" = PritQueue field = "N"
Thanks in advance.
73 de IK2XDE Andrea
A simple solution would be to create a TXT file similar to NotFoundRecord_Lotw
containing:
"New COUNTRY CONFIRMED" and
"NEW QSO CONFIRMED"
so after synchronization we can see the result.
OK....try build 633
works perfectly .... thanks .... !!
With build 633 works perfectly .... thanks .... !!
Well all work fine for me with build 633
In this section it remains for you to fix HRDLOG.
Without upsetting the program, it is enough that it puts UPLOAD
with these possibilities:
ALL QSO
SELECTED QSO
NOT SEND QSO
manually upload to server (only create ADIF)
To do this I think it is necessary to add in the log the field "HrdlogS" (Yes or No)
to know which qso's have already been sent or not to the server.
Thanks for the excellent work you are doing, and the constant commitment.
In the next few days I will ask you again for the management of the local database of managers.
73 of IK2XDE Andrea
I seem to be getting this error a lot recently in 631 Вложение 303021
What decimal separator do you use? What skin do you use (may be "broken" skin)?
About new fields in log: i'm waiting "Russian Lotw" - http://Hamlog.online :) for add fields for this QSL. I hope it will be soon. :)
Вложение 303032 and black box.asz
To M0CGF: what decimal separator here:
Вложение 303103
The same as your photo shows.
Using build 634
I try to setup "Digital Mode Windows" using RTTY.
Radio was IC-7600 mode RTTY (not USB or LSB) using FSK
So I will configure MTTY to TX with EXTFSK64.
Problem was that when I start "Digital Mode Windows" Radio go on SSB....
How can I configure to stay on RTTY....??
I find that if I disable CAT (setting NO RADIO) all work fine.
SO I think that HXCATinterface when find DIGI MODE change tu USB (using AFSK)
but I whant to stay in RTTY using FSK.
Two variants -
Вложение 303425
Uncheck Use SSB or check Not change TRX mode.
Well, everything works perfectly.....!!
Sorry but there are still some configurations / settings that I don't know.
Have you thought about how to update the management
of the managers on the local database ... ??
In the "SET FILTER WINDOW"
"Use Costum Filed" section,
Freq field was missed....please ad it....
I know that there is band filter,
but is different search for 20m qsl or for 14,260 qso.
Please add all log field here.....hi...
Thanks in advance.
is that strictly needed?
If the IK3QAR and QRZ COM/RU services are included, there is no matter to update local QSLM database. Also, there is a tool in menu to see NG8K contest callsign activity/QSLm information.
I believe everyone update it manually for their needs, I do that here.
Hello Alexey,
the problem described in message 223 persists even with build 634.
about message 273 I hope you will consider this implementation.
(eqsl download QSL immage and put it in photo field)
Hello
SET FREQ FOR BUTTON was correct,
problem when a change band, (CHANGE BAD FROM RADIO)
CAT change band in the qso entry windows, and the band map but....
bold fond change with band so....like in example 40m (BOLD FONT)
but yellow button background NOT hcange band...stay on old band. (17m in example)
If I change band press bandmap button all is ok...!!
Using VOICE WINDOWS with LogHX 3.0 build 636
Вложение 304242
If I setup button as in image, I receive error....file NOT FOUND
Вложение 304241
But if I remove [TX] and [RX] file was found and play by logHX regularly
I think there is some problem with TX command.....that include [TX] and [RX] in the file path name.
Please confirm that TX command FOR VOICE WINDOWS will be send via PTT COM SET for MMVARI (AFSK)
Вложение 304243
If yes...please add description for PTT for MMVARI and VOICE (AFSK)
Thanks.
Yes....with no macros, file will play regularly,
but radio NOT go in TX.....PTT not work....!!
I think PTT is the same of MMVARI......right.....???
73 de IK2XDE Andrea
Well....I have a problem.
I use different radio for CW and for SSB and DIGI.
On SSB and DIGI I use ICOM IC-7600 ACC1 connector wired to COM7 (no CW-KEY connector)
PTT was on COM7 (DTR) work correct with MMVARI in AFSK mode
FSK was on COM7 (RTS) work correct with MTTY in FSK mode (with external FSK)
No CW port was configured. (NO CABLE)
Just put in the RADIO SETUP window the choice of PTT line for the voice keyer.
VOICE PTT --> like CW PTT....or like MMVARI PTT
In fact the voice is transmitted through the sound blaster as for the psk31 in AFSK.
I hope it is possible, I await your confirmation.
Thank you.
73 de IK2XDE Andrea
Well, I think - this is right:
Вложение 304376
when you use Voice macros, MMVari is not work and COM7 is free.
Yes, if I use only one radio, but CW/PTT set on COM5,
was connect to the second radio IC-7600
(Yes I have two ICOM IC-7600) that work simultaneously. (of course with filter and different antenna....hi..)
COM 2 for CAT
COM 5 for CW on IC-7600 (1)
COM 7 for SSB and DIGI on IC-7600 (2)
all configured as RADIO1
on RADIO2 I have SunSDR2DX with TCI
My station was Multi TX and Multi Operator
IK2XDE Andrea and my brother IK2XDF Gianpaolo
Hello, using LogHX v3.0 build 636
Start log with /D=IK2XDE
Select view template,
show template in C:/LOGHX/Views and not template in C:/LOGHX/IK2XDE/Views
I thinks correct is: if I start with /D=IK2XDE will show template in C:/LOGHX/IK2XDE/Views
I thinks correct is: if I start with /D=IQ2LZ will show template in C:/LOGHX/IQ2LZ/Views
I thinks correct is: if I start with /D=IK2XDF will show template in C:/LOGHX/IK2XDF/Views
All operators can have different display choices based on the operating mode and personal choices.
SAVE TEMPLATE work correct and save template in the correct directory, but Select template show always default directory.
Upload QSO to Clublog/Lotw/Eqsl
If I select new function "Manually upload to server"...all work fine....!
but at this point I think another step is needed.
After creating the adif file ..... before closing the window .... the choice should be presented:
Mark exported qso as SENT...... YES or NO
Infact now, all qso exported to adif, was NOT marked as send.
Thanks.
In this regard, it would be enough to have a separate configuration for the voice.
CW / PPT
MMVARI / PTT
VOICE / PTT
surely other colleagues will have different configurations
73 de IK2XDE Andrea
Hi, who knows when the 705 will be supported for a CatHX configuration ?
When I'm using LogHX with Win4IcomSuite and CWskimmer with Omnirig (The only way for cwskimmer), I,m not able to configure the IC-705 in LogHX with Omnirig (I have a violation). To bypass this issue I use the last version of Flrig that support the IC-705 for LogHX but it is not optimum. I have some trouble durng the initialization of LogHX and Flrig. After some time it works but it is not very friendly :s11:
73s Christian F8GHE
- - - Updated - - -
Hi, who knows when the Icom IC-705 will be supported for a CatHX configuration ?
73s Christian F8GHE
First about CatHX INI-Files:
CatHX use INI-files from OmniRig - you can copy to /Rigs folder INI-file from OmniRig.
Second - about IC-705: you can self create INI-file for 705, if you have documentation for CAT of 705. Or send to me documentation for 705, and I'll make INI-file.
Yes Andrea, You're right! I'll fix it.
Alexei,
First about CatHX INI-Files: Thanks for the advise. I did it and more than 130 files was updated and added on release 634 and my problem solved :s7:
Second - about IC-705: The INI-file for IC-705 is included in this last Omnirig INI-file Updated 2021-04-15. It could be a good idea to update rigs in your release of your GREAT software :s7:
Thanks very much for your help and your work
73s Christian F8GHE
In the adif file sent to clublog, the DXCC field is missing.
This field is not mandatory, but it is essential to avoid reporting errors in the log,
especially for ambiguous calls for example with special calls like GB5xxx
which have various exceptions for ENGLAND-SCOTLAND and WALES ..... just for example.
I think it is appropriate to put this field in the file to be uploaded to Clublog, Eqsl and Lotw.
Thanks.
73 de IK2XDE Andrea
Problem with folders fixed - please check:
https://forum.qrz.ru/355-loghx-appar...ml#post1801176
Fixed also.
This problem persists even with the latest version 641.
The yellow background does not follow the band, as does the bold lettering.
The cat and the band map work correctly both
with CATHX than with TCI without problems.
Thanks.
Surely other colleagues will appreciate this possibility
Also ... for example.... in N1MM +,
I can configure CW on one port and PTT on another different port.
Thanks.
The problem occurs on any band, both with CATHX and IC-7600 and with TCI and SUNSDR2Dx.
When I change bands, the yellow button stays on the initial band,
but the bold text follows the cat correctly, the bandmap also changes bands correctly.
The problem is only the yellow background color.
Thanks.
Try also with build 644,
of course same problem.
Test with clublog, without DXCC field, a lot of ambiguous calls like GB5xxx
create an error report because the country is not recognized.
(This call was used for England-Scotland-Wales)
Test also send adif to HRDLOG without DXCC field,
qso added to log without flag, because country was not recognized.
Please fix this (add DXCC field in the adif)
Thanks.
73 de IK2XDE Andrea
ONLY FOR REPORT.
In the build 644 yellow background now is orange,
yes follow the band with cat, but not delete (clear) previus band.
I think you will work again on it.
Thanks.
But in my log was registered correct.
Thanks.
https://clublog.freshdesk.com/suppor...-club-log-use-
Here is a list of the ADIF fields Club Log uses:
QSO_DATE
TIME_ON
TIME_OFF (this is stored independently and used for log matching as well as ADIF exports)
QSLRDATE
QSLSDATE
CALL
OPERATOR
MODE
BAND
BAND_RX
FREQ
QSL_RCVD
LOTW_QSL_RCVD
QSL_SENT
DXCC
PROP_MODE
CREDIT_GRANTED
RST_SENT
RST_RCVD
NOTES
GRIDSQUARE [note that this is only set if the Club Log user sets a locator on Settings > Locators, and it is not stored per QSO]
How does Club Log determine DXCC status?
Identifying DXCC entities correctly is an important feature of Club Log, so let's take a moment to explain the philosophy.
Club Log primarily uses details of allocated prefixes dating back to 1945 to map callsigns in uploaded logs to the corresponding DXCC entities. Maintaining the prefix data, plus a number of changes and known exceptions within defined date ranges, is a painstaking task undertaken voluntarily by Alan, 5B4AHJ.
If you upload an ADIF log that claims a particular DXCC entity for a QSO (in the ADIF COUNTRY or DXCC field) but Club Log maps the call to a different entity, an error will be generated when the log is imported into the database. Other problems, such as unknown prefixes, also generate errors. At the end of the log import process, an error report will be emailed to you and copied to Alan.
It is not unusual to discover from the Club Log error reports that you have worked new countries or filled additional band-slots, and most of us find it immensely satisfying to know that our logs and DXCC records are accurate. We hope that you will go through any error reports you receive, fixing busted calls and obvious country errors in your log and then re-upload your corrected log to Club Log.
I am using build 644 with satisfaction,
surely there are still some things to improve, in my opinion, but we are getting closer .... hi ...
My tests this week focused on the cluster.
The cluster I use is: ik2xde.ddns.net:8000
To check the differences I used PUTTY for the telnet connection.
For example, I noticed that in the telnet window, many lines are cut / deleted especially
at the beginning of the connection, all the lines sent by the cluster are not displayed.
In my opinion this is a mistake, often in that part there are important warnings for users,
or instructions for use, for filters, for skimmers or other.
In my opinion all lines should be displayed.
For example, if I send the SH/U command (to view the users connected to the cluster),
only the first line is shown, the others are cut off.
- The ALARMS window, once the call to be monitored has been set,
show only the latest spots, one line only for each mode or band.
In my opinion it would be better to see all the spots of that call,
to have a better situation.
Or in any case being able to choose whether to see only one line, or all.
- Favorite Spots.
This function is not clear to me, I did not understand what it is for, and how it can be configured.
Thanks for your attention, I hope that my observations will help everyone to improve this software.
Now you can use different port for CW and PTT:
https://forum.qrz.ru/355-loghx-appar...ml#post1806384
Alse add ADIF fields for export QSO to LoTW, eQSL, Clublog
Thanks, now with buil 645 work great.....PTT and CW on different port.......thanks....!!
Sorry, with buil 645 I NOT found DXCC field in the clublog/eqsl/hrdlog adif file.
SORRY THIS MOD NOT WORK
<< NEW >>
Now orange band button change band correctly in the bandmap.....thanks....!!
<< NEW >>
The VOICE WINDOWS not resize the button key (NOT ENLARGE the button)
Вложение 306217
Thanks.
Thank you very much Andrea!
Your comments are very helpful in working on log!
I'll fix it soon!
Yes.....with build 647 VOICE WINDOWS resize button key....now work fine.
With build 647 I NOT find DXCC adif field in the clublog upload file, please remember to do this.
Please remember also my post N. 329 about Telnet cluster.
Thanks for your good job.
About EQSL image.
I just download from eqsl all my 65000 qsl image,
all image are stored in a directory, C:\Users\LOG\Pictures\IK2XDE-EQSL
Вложение 306626
As you can see in the example, all immage,
All qsl use this format file name: CALL_DATE_TIME_BAND_MODE.png
I try to import a single file image in the PHOTO field of the log, and all work fine,
but, import manualy 65000 file take a long time.
Can you please add and automatic integration of the file....??
For example, if I push show photo (on selected qso)
automatic verify if file exist in the declared directory, and show it.
No importing all immage, no importing link or other, only verifiy the file ...and if exist show it.
I hope this change is possible....!!
Well, thanks you for your work.
- With build 648 in the cluster telnet windows, all the string are showed, all seem to work correct now....thanks...!!
- With build 648 in the cluglog adif, was added DXCC adif field, well....tested, and all work fine.......thanks...!!
- With build 648 we have now a problem with separete COM configuratio of PTT and CW
with buil 647 work great, but now if i setup a different port, CW work on the same port of PTT.
I think you will have to verify something here....!!
Thanks for your effort.
Made some other test,
with build 648 .....PTT/CW separate COM port work fine.....!!
This is my config "RADIO 1" SETUP ( 2 x IC-7600 )
Вложение 306799
Вложение 306798
IC-7600 N.1
PTT for Voice Key on COM7
MMVARI for AFSK digi like PSK31/63 on COM3
IC-7600 N.2
CW for CW KEY on COM5
MMTTY for FSK RTTY with EXTFSK64 on COM4
SunSDR2DX
On "Radio 2" I have setup TCI with SunSDR2DX
no problem with TCI....no problem with SDC.....!!
73 de IK2XDE Andrea
With build 649
there is a small problem with the CW macro window.
When I press "TUNE" there is no way to stop the transmission,
if I press "ESC" it doesn't work, I have to send a macro and then it stops.
Before (buil 647) it was turned off by pressing "ESC" or again press "TUNE"
Thanks.
Try this version:
http://rx4hx.qrz.ru/files/loghx/prer..._build_650.exe
Is now ok?
YES.....!!
from my side, i have done some tests,
and everything seems to work correctly now.
73 de IK2XDE Andrea
Andrea!
Test also this version:
http://rx4hx.qrz.ru/files/loghx/test..._build_651.exe
Is Ok?
With this version (build 651)
RADIO1
HXCAT with IC-7600 work fine... !!
Separate COM port.....work fine...!!
PTT on COM 7....work fine....!!
CW on COM 5.....work fine....!!
CW macros.....work fine....!!
Voice key switch radio in tx (PTT) and play the selected file......work fine....!!
RADIO2
TCI with SunSDR2dx
CAT via TCI work fne....!!
CW macro via TCI work fine.....!!
.....but....
Voice key with TCI.....NOT WORK...... (TCI does not switch the radio in TX)
All others like cluster, statistic, award, ecc.... seems to work fine.
Hello,
any news about msg #335 (EQSL image)
will it be possible to implement this function .. ??
Thanks.
This function is of little interest. I don't plan to do it yet. In the near future, I plan to automatically call in FT8/FT4.
I use eQSL Show by IZ0ROQ
You can find it here: https://www.iz0roq.com/i-miei-programmi/
Infact I suggest to import only the link of the photo, in the photo field of the log.
importing images would burden the log unnecessarily.
73 de IK2XDE Andrea
Hello,
Can somebody help me, how to recreate RDA Award statistic in LogHX3, please?
It is showing false and/or missing datas.
TU 73 Egon
- - - Updated - - -
Вложение 309620
Вложение 309621
Вложение 309622
Вложение 309623
Hello Alexei,
RDA KI-15 just one of the missing RDA on the statistic.
When I made a new one, it is written in but sometimes not. I don't know why.
Thank you for your help!
73 Egon
Yes, something is wrong!
Check state and county fields for KI-15: may be "space" after KI or 15?
If you don't find the problem - send to me you log base (rx4hx@mail.ru)
I found problem with R8WB/M and KI-15: R8WB defined as Asiatic Russia (UA9), and KI is Europen Russia (UA).
For solve this problem change country for R8WB/M in log (Ctrl+С or menu Change country for current station)
Hello Alexei,
I’ll investigate further what’s wrong with the others.
Thank you very much for your help!
I received this error message but could not interpret it.
The KI-15 problem is solved!
Вложение 309626
I read in the Russian section of the forum that you are planning some changes to the log.
Please remember the HRDLOGS (send) field
73 de IK2XDE Andrea
Others info about file format in my msg #335
We need HRDLOGS to know if qso was upload to hrdlog server.
For HRDLOGR i do not know if we can download an adif with all confirmed qso like eqsl or clublog.
73 de IK2XDE Andrea
Hi Alexei,
I am using LogHX (build 660) with JTDX and Gridtracker.
To keep control over Gridtracker (memory/prosessor usage) i have Gridtracker on a Rasperry PI on the same LAN as my shack PC. As the UDP forward function in LogHX (setup for external programs) does not allow portforwarding to another PC (am i wrong?), I have enabled multicast in JTDX. UDP packets from JTDX are now received by Gridtracker on the Raspberry pi, and forwarded by Gridtracker to the listening port on LogHX on shack PC. This works Ok, but it is a one way stream that does not allow any action to JTDX coming from LogHX.
Is it a big task for you to expand the UDP forward function in LogHX "setup for external programs" to allow portforwarding to another pc/ip-adress (or to expand LogHX to send and receive UDP using Multicast)?
73 de LB2EG Richard
Hello Alexei,
Are you planning to built in any kind of RDA synchronization (or just check/uncheck fields), as like LoTW, eQSL, Clublog, etc? I can't control what I uploaded and downloaded as worked/confirmed QSO/QSL.
Thank you,
73 Egon
Correct - check settings for rebroadcast and try again:
http://rx4hx.qrz.ru/files/loghx/prer..._build_662.exe
Alexei,
I would be great if you would prepare just two fields into database for future use, like for LoTW, eQSL, etc. I would use it for "hand" synchronisation with any source from Hamlog, mydx.eu, cfmrda. I have confirmed QSOs now only from the LoTW in my log, which is just less than half of my confirmed QSOs. And in the future, when will be any server, LogHX can "continue" the synchronisation.
73 Egon
New release 663:
Вложение 311229
Alexei,
You are awesome! Thank you very much! Red arrows are perfect! (rel. 663) But... I found "something" again! :s6:
As a RDA collector, I use RDA Award window very often and if I click on any RDA, only an empty window appears and to open this empty window, I have to click four! Two mouse click do nothing. Photos attached. Rel. 660 works fine, two click is enough as normally.
Greetings, Egon
Вложение 311236Вложение 311237
PS: build 662 do the same.
Yes, it's mistake! Thank you for your comment!
Fixed. Release reload:
http://rx4hx.qrz.ru/files/loghx/LogH..._build_663.exe
Hello,
running v 3.0 build 665
no correct display new START/END command.
Вложение 311657
Вложение 311656
73 de IK2XDE Andrea
Hello, as posted with image, in my msg. 380
Skyns: Acryl.asz
Styles: Luna
Hello,
any news about this ....??
Hello,
using Sunsdr2DX,
there is no problem if using ESDR2 with TCI 1.4
but please verify that ESDR3 A0.8 work with TCI 1.5
and the ESDR3 A0.9 work with TCI 1.6.
So in the next feature you must updare TCI with 1.6 version.
There is some little difference.
Thanks in advance for your effort.
Hi Andrea,
I have been using ESDR3 with LogHX and it works ok for me for everyday work. The only "annoyance" i have found is that klicking on spots on ESDR3 panadapter does not fill the QSO window in LogHX. But according to UT4LW this function is not fully implemented in ESDR3 yet. I am, however, no advanced user, only CW and digimode work with JTDX and MSHV. So if Alexei want to wait until ESDR3 matures until implementing different TCI log on for ESDR2 and ESDR3, I can wait.
73 de LB2EG Richard
Hello Richard,
Yes, TCI 1.6 work with ESDR A0.9.
So this not necessary for now, but I think in the future, we need to verify loghx and update to TCI 1.6.
I confirm that for now....with alpha version....is not necessary.....we are wait for a new ESDR 3 version soon (I hope....hi)
In the clublog when we upload our log ..... immediatily, (not manualy)
please add the choice MERGE into EXISTING LOG.....or......CLEAR LOG before UPDATE (CLEAR OPTION)
Normaly when we send ALL QSO - will be CLEAR OPTION
Normaly when we send NOT SEND QSO - will be MERGED
You can find info about CLEAR option here:
https://clublog.freshdesk.com/suppor...-into-club-log
I find also that actualy, adif file that we send to clublog,
not contain field QSL_RCVD and LOTW_RCVD
This false the clublog DXCC statistic, because not contain, if qso was confirmed or not.
So please add QSL_RCVD and LOTW_RCVD field to adif to send.
you can find other info about this here:
https://clublog.freshdesk.com/suppor...tch-my-logger-
Thanks in advance.
Just a few polite requests and a question.
- in "Radio1" window : when I inserted a callsign from a webpage, sometimes there were 1 or 2 spaces left at the beginning of the callsign, so I couldn’t find it in the log. Would you do that to cut off the blank parts in front of and behind the callsign, please !?
- in "QSO manually/edit" window : there are some fields where I can't paste text with the "Control-V" method, just with the mouse, using the "Menu / Paste". For example: Via, Locator fields. The RSTs, Name, QTH, WFF are OK. (cut of spaces as well?)
- Do you plan to use the new "HamlogR / S" in QSL status and statistic as well as on LoTW, eQSL, Clublog?
The new "QSO manually / Edit" window is very nice! Congratulations to your nice work and the many new things you do! The program is better and better every time, really a pleasure to use it!
Thanks for all Alexei!
73 Egon
Thank you again Alexei!
Well... Most of the time (99%) I usually paste from these websites as I mainly hunt for RDAs : tnxqso, cfmrda, mydx. Sometimes I copy 1-2 spaces front or behind the callsign. :s7: I just insert and do not push the Enter key and checking the result in the "Previous QSOs" window.
73 Egon
Are these fields in the SW as I don't see where they are but they are in the adif from my tablet log
for example
<QSO_DATE:8:d>20211029<TIME_ON:4>1435<TIME_OFF:4>1436<CALL:6>YO6FNF<NA ME:5>David<RST_RCVD:2>59<RST_SENT:2>59<BAND:3>20m<FREQ:6>14.272<MODE:3 >SSB<SUBMODE:3>USB<MY_GRIDSQUARE:6>JO00dr<COMMENT:0><OPERATOR:7>M0CG F/M<STATION_CALLSIGN:7>M0CGF/M<MY_SIG:4>WWFF<MY_SIG_INFO:8>GFF-0018<SIG_INFO:9>yoff-0125<STX:2>15<eor>
Вложение 315157
For import from you tablet log WFF field, use this settings:
Вложение 315163
Pse QRX new version!
Hello,
I can't get it to work I have this message ORZ.COM.
My subscription for QRZ.COM is still ok until 03/04/2022.
73 Pat – ON3CQ
Вложение 315966
Hi,
I am using two instances of LogHX (678) to achieve independent operation of ESDR RX1 and RX2, enabling me to use JTDX on RX2 while chasing CW DX on RX1.
This setup works well, but with one annoyance. When klicking on spots in the ESDR panorama on RX1, it also changes the QRG on RX2 (et vice versa). This only happens when klicking on a spot in panorama. Changing from ESDR2 to ESDR3 does not matter.
I use the Net Setup in LogHX.
Вложение 317657
Anyone?
73 de LB2EG Richard
Need prinscreen setup of TCI in log. Here:
Вложение 317686
Do you use Radio 1 for ESDR RX1 and Radio 2 for ESDR RX2? I think problem is here.
Hi Alexei,
Yesterday i put the latest ESDR3 0.11.0 (v.28.12.21) in use with LogHX. Using the spot function LogHX populates ESDR3 panorama with spots as usual, but clicking on spots did not result in change of QRG or an entry in LogHX QSO window.
The same problem with SDC even in Linux.
Reporting this on EESDR Github bugtracker, the EE programmer closed the report as no EESDR bug, stating this was a LogHX or SDC problem. https://github.com/ExpertSDR3/Expert...KER/issues/189
Testing again today, clicking on the FIRST spot from either SDC or LOGHX changes the QRG, but not when clikcing on the subsequent spots.
73 de LB2EG Richard
- - - Updated - - -
EE programmer has reconsidered and accepted this as a ESDR3 bug...
73 de LB2EG Richard
anyone having issues uploading logs to EQSL and LOTW in 2022? I am getting No Match on eqsl_user/eqsl_pswd for date 20220102 00:01.
i checked my eqsl and the call is valid from march 2020 to 2035.
Ian
BANDMAP dont show all spot receiving from telnet.
Show only not worked call.
I forgot where is function to set/unset this.
Thanks
It's here:
Вложение 321684
P.S. I'm very sorry for not answer of you e-mail. Please wait - i'm work of manager base!
Alexei,
I recently started using LogHX together with the SunSDR2 DX and V3 0.12.1 via TCI.
He always takes my RX 1 TCI for my Log entry can I open a 2nd log entry for RX 2.
How can I have my RX2 tracked via TCI to also be able to log via RX2.
Is there is a way tu use double RX and double log entry.
73 Pat
Yes - it's here:
Вложение 322027
Thanks Alexei,
Now it works, it is also possible to use 2 open QSO Entry for Radio 1 & 2.
Вложение 322058
73 Pat
- - - Updated - - -
When I use RX1 on 10.136 DIGU for FT8 with JTDX, then I can't change RX2 on 40M, it stays on DIGU.
When I click LSB it goes back to DIGU.
73 Pat
Вложение 322059
It's been a while since I wrote, today we are at version 3.0 build 686
Here are some observations:
The awardsbase.mdb file which is normally found in the ... /LOGHX/AWARDS directory
It is not copied to the directory .... /LOGHX/IK2XDE/AWARDS
if I start the software with the command LogHX3.exe /D=IK2XDE
It would be useful if LOGHX automatically proposes the update of the CTY.DAT file
when and if available.
https://www.country-files.com/big-cty/
or a button is created to automatically search and update this file
Regarding the offline file managers, I think it is useless to ask the management,
I know you are working on it ... I hope to see it soon in the next version.
73 de IK2XDE Andrea
ik2xde@gmail.com
Hello,
obviously what you wrote, is the procedure we have done up to now,:p-up:
but an automatism, without waiting for a new software release, would be very welcome.
When the software starts, as it checks if there is a new release,
in the same way it could check if there is a new version of the CTY.DAT file
We will be very grateful to you Alexey
Hello,
I'm in JN37AH (Est of France near Besançon), when I plot on maps spots from my own local skimmer, it's like I'm in the south of america. My station setup seems correct. What I could forget ?
Вложение 323602
7"s Christian F8GHE
My General Setup
Вложение 323604
It's correct when I connect the Spot machine to the RBN (With the telnet protocol).
Not clear for me! I have to do more tests for more details in my request !!
73s Christian F8GHE
Yes.
Alexei knows that I am available for every need,
I have already made myself available to him several times.
We hope he take this into consideration too.
Here all work fine with buil 686.
73 de IK2XDE Andrea
In log check you locator -
Вложение 323665
is here ok?
Yes this setup seems correct but I have to check to configure the Localhost Spot-Machine to spots my CWskimmer-srv output (It seems the origin of issue)Вложение 323725
I just find my mistake !! It was the Localhost setup Вложение 323739
Alexei,
Here are just 2 small syntax errors in the LocalHost configuration window of the spotmachine
- Log in promt => Login prompt
- Replay => Login prompt answer
Вложение 324033
73s Christian F8GHE
Hello everyone,
Who can explain this setup ? I don't understand it :s9:
Вложение 324047
73s Christian F8GHE
If you want get spots from WW DX cluster, you can self sets parsing for this ww-page or use two ww dx cluster (OH2AQ or DXSCAPE), parsing of which is already in the log:
Вложение 324103
For select OH2AQ or DXScape - double-click on red line.
Hi Alexei,
"parsing of which is already in the log:" : You mean that the parsing is applied on all new spots and also those that are already in the LogHX log ?
73s Christian F8GHE
- - - Updated - - -
Hi Alexei, now it's ok in LogHX V3.0 build 688. Thanks very much !
73s Christian F8GHE
- - - Updated - - -
Hello,
Here are 3 questions about Spot-Machine setup and 2 minor syntax errors :
1. What is the use of the Login suffix for the Telnet setup ?
2. How is the assignment of automatic login scripts 1 or 2 to each telnet sessions done ?
3. It seems that only adress IP 127.0.0.1 is recognized in the Localhost setup ? Not possible to set IP 192.168.xx.yy !
Вложение 324311
To connect to the same telnet-server from several logs use suffix. You will be connecting as F8GHE-1, F8GHE-2, etc.
You can't do that now. But this is the right remark. Will do.
It is possible to use IP 192.168.xx.yy. Is here problem?
Hello,
Is it possible to open a log screen for Radio 2 also.
73 Pat
Yes it seems not working with the local IP
Вложение 324441
Ask for a confirmation about Spot-Machine connection.
Do you want to mean Disconnect/Reconnect instead Connect/Reconnect ?
Вложение 324442
I would like to have these screens for radio 1 & 2 that you shouldn't switch.
Вложение 324467
73 Pat
Hi Alexei, we'll test that thanks for the info.
Hi Alexey,
after two years and 120000 qso, I still have some observations to make.
Of course, only for the purpose of improving this beautiful software for all users.
Only you can tell us if these improvements can be made and for that we thank you in advance.
UTILITIES -> STATISTICS -> BAND/MODE STATISTIC
In this statistic it would be nice to add the ability to analyze the complete log
or filter it by date (FULL LOG or From date -> To date)
I would like to see the same possibility in the award statistics, such as DXCC etc ....
Complete management of HRDlog field <HRDLOGS> and <HRDLOGR> fields currently not managed.
Some automatisms would be convenient in the manual entry window of the QSOs.
For example when I type the QSO start date, it should automatically change the end QSO date as well,
and the same thing for the QSO start and end time.
The same thing when I enter the RX frequency,
it should automatically propose the same TX frequency.
However, always leaving the possibility to modify them .... obviously
Last question, if I start the program with this command:
LOGHX3.EXE / D = IK2XDE
can I open a second instance of the software
LOGHX3.EXE / D = IK2XDF
And use two logs at the same time .... Multi Operators station.... ??
Of course with different radio....different CAT and CW COM PORT setup....MULTI TX??
As you know, we are two brothers.
In order not to be pointed out as the one who always asks and does nothing,
I remind you of my availability to help you manage, maintain and update the local file manager
and the cty.dat file, making them always available to all users.
Question on EQSL uploads, for this month I operate as MQ0CGF. I have set up EQSL and created a new log in LogHX. I cannot seem to get the MQ0 log to sync with EQSL. Anything I have missed in the set up?
Have you changed eQSL data in LOG settings - callsign/QTH/password ?
Вложение 324699
each time you wanna get data from eQSL for certain of your callsigns, you have to change settings, then take data from service.
OK got it, does this information save between different logs, as I a ton of /p locations at EQSL and each has its own location and profile?
Hello,
I have a questions about the CreateBackup utility :
1. Is there a way to memorize the default destination folder. It's always C:/ and I would like to set D:/LogHX-backup/ ?
2. Is it possible to specify the destination folder from CLI ? I would like to schedule an automatic "Backup-Task" with the Windows Task scheduler ?
Вложение 324862
73 Christian F8GHE
Hello,
I would like to know if someone has already noticed a loss of synchronization of the frequency
between equipment and softwares of a setup like describe on the picture ?
This observation is only true when using FLDIGI by making rapid frequency changes.
I never observe this issue when using :
- WSJT-X
- FLDIGI with a slow variation of frequency (On IC-7300 or LogHX or Win4Icom or FLDIGI)
Note : The 7300.xml file for FLDIGI is the up2date version.Вложение 324961
73s Christian F8GHE
How get freq LogHX?
Pse print screen of Radio setup in log.
Hello Alexei,
Thank you for supporting us with new features!
I had a strange issue with LoTW download a long time ago. The "QSL QSO after"'s date is constant since 09.20.2021, I have to modify it at every LoTW downloding. See picture.
Вложение 324972
Build 689 :
I have problems with the new telnet section. b688 handle it perfectly but I realized malfunctions with the same setup in b689:
- Telnet1: I use dx.hu for Telnet1, it is not asking from me any password, just a login name. In b688 it is OK but b689 is inserting my password from the "Script for Telnet" window and it is causes an error, dx.hu says "Invalid command". It is not a big problem, just I noticed it for you.
- Telnet2: I use HamAlert. In b688 it is handle login/password from "Scripts for Telnet" window but b689 can not handle it just asking login and password again and again. I tried it with and without auto login but no success.
- Telnet3: I inserted in "Telnet server setup" window the "Localhost 127.0.0.1" but it does not work because it is using the Telnet2's HamAlert telnet setup (!!!) which is NOT checked in the list of "Telnet server setup" window at all.
I missing Localhost because I intesively using SDC.
What could be wrong in my setup? HELP PSE! :)
Thank you in advance, Egon / HA3MN
PS: Really enjoyed to meet you "personaly" for the first time on 10m/FT8! :)
Yes, it's mistake! Autologin is not turn off! Will be fixed!
Is here port set right? Did I understand correctly that telnet 1 and telnet 2 use localhost?
I was wrong! Autologin turn off correctly:
Вложение 324975
Please, reload picture.
Alexei,
Autologin turn off is working for Telnet1, your picture is clearly shows the solution.
Investigating my other problems, I will write again.
73 Egon / HA3MN
Alexei,
I sent an email to your qrz.com address.
73 Egon
Any idea, please?
73 Egon / HA3MN
Вложение 325021
I know what the problem is. Is here checked?
Вложение 325025
I think - yes, here is checked!
And you use "View" - therefore, the date is not saved.
Uncheck here or not use "View" when upload QSO.
Thank you Alexei!
It was checked!
I unchecked and now it is remember the downloading date!
I wouldn't have thought of that... :)
73 Egon
- - - Updated - - -
Hello Alexei,
I can't tell you more clearly, sorry.
Build 689 :
- Telnet1: NOW OK!
*** I tried it with and without auto login but no success. ***
Вложение 325027
- Telnet3:
- I inserted in "Telnet server setup" window the "Localhost 127.0.0.1 port 7373" for SDC but it does not work.
Вложение 325028 Вложение 325029
*** It is using the Telnet2's HamAlert telnet setup! ***
HamAlert's setup is NOT exist in the list of "Telnet server setup" window at all when I setup for Telnet3.
Try new prerelease
https://forum.qrz.ru/355-loghx-appar...ml#post1886596
and look list selected hosts. I think several hosts have been selected.
Running b690 but nothing changed. :( Same situations.
Checked only one in telnet2 and telnet3 as you see on the photos.
Вложение 325033 Вложение 325034
.... and I repeat again : Telnet3 is using Telnet2 setup, NOT the Telnet3/localhost setup!
If I go to "Cluster" window and choose "Telnet3", I see Hamalert's setup as I sent photos about it in my last message.
With vers. 690 and 691 crash on start,
Вложение 325057
NOT FOUND any STYLES in setup. (only Windows...NOT others)
Вложение 325058
73 de IK2XDE Andrea.
Alexei,
b691: Telnet2 window is totally empty, Telnet1, Telnet3 are OK.
b688: Telnet1, Telnet2, Localhost are perfect.
Yes, I confirm an issue with the skin colors.
Not possible to save a modified default blue color (C6DDE7) in the "Log Windows" or "Previous QSO" with the Grid Color setup .
73s Christian F8GHE
- - - Updated - - -
No problems with build 686 that I just test !
73s Christian F8GHE
Fixed - reload this version:
http://rx4hx.qrz.ru/files/loghx/prer..._build_691.exe
Alexei,
Can you put a "COPY" button in the "QSO manually entry/edit" window, which is copy ALL details of the original window?
It would be very useful when there are more than one RDA. It would be copied all to a new window and needed just overwrite the State/Country fileds.
Thank you in advance, 73 Egon
Alexei,
Just inform you about b692 : Telnet1, Telnet3 are OK. Telnet2 still only a empty window.
Is there any info source about updating? What did you updated in prerelease version?
I know the Whatnews.txt but there is nothing any about prerelease(s).
Thank you!
Here is ok -
Вложение 325223
I've made a lot of changes to the internal workings of the log. I will wait 10-15 days, and if there are no comments, I will release.
Hello,
With the last buid 692
- issue with styles list corrected
- but issue with Grid colors not solved : The default grid color on "Log Windows" and "Previous QSO windows" modified automatically from white to blue color (C6DDE7) after update from build 686 to 692. And it is not possible to change this default bue color.
73s Christian F8GHE
Alexei,
Installed 692 again. I did a lot of research and figured out what was causing the problem at me in the Telnet2 window.
If something is in TelnetScripts2 (TelnetScripts2.hx), than Telnet2 window does not work.
I tried with a few server from Server#2's list and with EMPTY Scripts#2 all servers are working,
including HamAlert (hamalert.prg / 7300) which I inserted in the LogHX/Setup Machine window.
If I inserting just only ONE line (or TWO) into Scripts#2 (like login: and my call), Telnet2 window does NOTHING.
Pushing (Connect) Telnet2 button, nothing happen.
I tried to replace TelnetScrips2.hx from a older backup (b688 and older) but nothing...
I gave up... :)
Sincerely, Egon
PS: Telnet1, Telnet3 are fine.
I have no more time now but soonly I will try to change Telnet3 <-> Telnet2 details. Maybe...
Alexei,
b692:
I just finished the investigation with interesting results.
I put "hamalert.org/7300" setup to Telnet1,2,3.
Of course, during the test I checked the tested Telnet, unchecked the other two.
- Telnet1 is 100% OK, working fine with Scripts1 (two lines are in it, login: and password: )
- Telnet2 is not working IF there is something in Sricpt2
- Telnet3 is the same as Telnet2
I tried dx.hu/9000 server in Telnet1, 2, 3 with one line in the scripts1, 2, 3.
All OK!
No idea...
- - - Updated - - -
UPDATE:
Ignore the following two lines above :
"I tried dx.hu/9000 server in Telnet1, 2, 3 with one line in the scripts1, 2, 3.
All OK!
Sorry but it is not true!
У меня hamalert работает только если в ручную логин и пароль вводить
How get freq LogHX => Good question, and I don't know exactly but for me (Not sure) it is the same way that WSJT-X . It work perfectly with WSJT-X but with FLDIGI frequencey must be modify slowly. I tried to increased VSP speed from 19200 to 38400 and it is the same.
Here is the setup
Вложение 325343
73s Christian F8GHE
b693 = b692 on Telnets.
b694 = b693 = b692 on Telnets.
Telnet1: All OK! dx.hu/9000, hamalert.org/7300, 127.0.0.1/7373 works fine WITH scripts.
Telnet2: With scripts do nothing. Without scripts (empty scripts) I can login manually.
Telnet3: same as Telnet2
b695 on Telnets is same as before.
Hi Alexei, Have you looked to code a macro or other method able of adjusting the CW speed to that of a CW spot from a cluster ? Another setting could be a default CW speed.
73s Christian F8GHE
- - - Updated - - -
Hello, for me there is an issue with the Telnet1 Script with these error messages 1 and 2Вложение 325687
Alexei,
Thank you in advance!
It is would be very useful when a /P or /M station works from 2-3-4 rayons (RDAs).
No any option to logging all RDA at once, must be line by line for correct info in Award window.
I would just click on the "Copy" button and reedit just the next RDA in State/Country fields.
The "Insert" button is helps a bit but missing datas.
PS: Telnets are OK, thank you for your effort!
At me Telnet1, Telnet2 with script(s), Telnet3 without script(s).
Alexei,
Is it possibele when I logging a QSO with split, then logging the RX frequency not the TX frequency?
For me, more important to see/know/remember where I HEARD the other station.
Вложение 325799
Saved TX and RX freq. Do you have any problems here?
Alexei,
"Is it possibele when I logging a QSO with split, then logging the RX frequency not the TX frequency?
Возможно ли, когда я регистрирую разделенное QSO, а затем записываю частоту RX, а не частоту TX?
Для меня важнее видеть/знать/запоминать, где Я УСЛЫШАЛ другую станцию. (Google translate)"
Maybe I did not say clearly, sorry.
Вложение 325808
I worked with R7AB/P on 14.066 but LOG shows 14.067, my TX split frequency (up +1).
I would like to see 14.066 in the log, where R7AB/P was.
Rigth mouse click - Grid setup -Columns setup - check here:
Вложение 325812
Alexei,
Thank you for info!
I just used "Freq" and not "Freq RX" for logging!
It was so simple soluton! My fault... :)
- - - Updated - - -
Alexei,
The life is more complicated! :D
"Freq RX" is not rounded number as "Freq" but the worst is "Freq RX" is not exist in the past so no frequency in old QSOs.
I'm back to "Freq" and living with this situation. Not a big problem.
Alexei,
Is this utility manages the Soviet prefixes as well? (Before June 12, 1991)
It's here:
Вложение 325826
Вложение 325827
Alexei,
You think about everything.
You always impresses me! :)
It is a pleasure to cooperate with you.
I love LogHX :p-up: :s11:
Thank you for your effort!
73 Egon
Alexei,
I found a few things... :s7:
- DXCC Award has a unnecessary line : ZD4. It is appears in Excel list as "-ZD4" as well.
- RDA Award : I had a lot of QSOs (133) with Komi (KO) but in RDA Award the KOs are totally empty. All KO in the log belongs to DXCC=UA.
Same with Perm (PM). 241 QSOs. Just a few QSOs are "Wrkd" in RDA Award list. These QSOs are belongs to DXCC=UA9 (RM8G, R9GB, R9FM).
Greetings, Egon
Alexei,
Sorry for my english, you misunderstood me again... :)
ALL 9X and 9F are UA in the log but in RDA AWARD window no any 9X or 9F QSO/QSL!
Вложение 326183 Вложение 326184
Вложение 326185 Вложение 326186
... and what about ZD4 in DXCC Award windows and in Excel as well?
Вложение 326187 Вложение 326188
Thank you!
Alexei,
Sorry for my very BAD english, you misunderstood me again...
I DO NOT talk about I NEED ZD4 in the DXCC list or in DXCC Award in the LogHX program!
I talk about a unnecessary line in LogHX/DXCC Award window.
In MY LogHX / DXCC Award there is a ZD4 line. See the picture.
If I save it to Excel (from LogHX) it is exists as "-ZD4" as well. I'm talk about this!
I can not tell you more clearly, I'm sorry...
Вложение 326189
PS: In the CTY.DAT there is no ZD4 of course. Where it come from than...
Egon, I just checked my DXCC settings , and i should say I dont have ZD4 (deleted Prefix) on it
Here is a screenshot below
Вложение 326190
Hello Anton,
Thank you for info, the problem is on my side but I can't resolve it.
I don't know where it come from. I did not touch any (country) files in LogHX.
I found "ZD4" only in \LogHX\CountryData\country_deleted.dat
73 Egon
You're welcome.
- But, can you check files:
- CTY.DAT
- COUNTRY_USER.DAT
- COUNTRY_DISTRICT.DAT
- If there is a sign with ZD4 prefix existed still?
- And, have you updated CTY.DAT from last version - 30.06.2022 ?
- Have you checked ZD4 prefix in DXCC award settings inside the LOG?
I am thinking you have box-checked on ZD4 in DXCC award on your side. I haven't
Вложение 326199
Hello Anton,
Your HELP was the solution! Thank you!
Before :
Вложение 326207
After ZD4 unchecked :
Вложение 326208
I also recommended the LogHX program to my friend,
he also installed it and he also had ZD4 in DXCC!
In the brand new installation! Hmmm...
Thank you for your HELP Anton!
73, Egon
Hello,
The "Spot Machine" Icon is missing in the "Utilities" menu after the upgrade from Build696 to the Build 697.
No issue after the downgrade from Build 697 to Build 696.
I didn't try a new ugrade to Build 697.
73 Christian F8GHE
Yes, now here -
Вложение 326294
Hello,
the Number Style on CW window does not work for me. Number 9 is still 9, not N. Any idea? 73 Josef
It's for button macros. F1..F12.
Sri I dont understand. I have this possibility for styles:
https://prnt.sc/9FFbiPDN6QQY
and it cannot be changed.
Have you some example of your setting?
TNX reading and reaction, Josef OK2WO
I don't understand problem. Write macros for button like this -
Вложение 326663
and RST will be send with number style.
Super. All is clear. It works perfectly. Thank you for the help - I did not find it on online help pages. 73 GL Josef OK2WO
Hello,
I found by chance in the Forum new Macros for CW/Digital: [RX: <DOAFTERRX>]
<DOAFTERRX> - Letter:
S - SAVE, C - Clear TX Window, F- Focus to QSOentry window.
Macros Example: [RX: SCF], [RX: S], [RX: SC]
Question: Why is it not listed optionally in "Rig Control" menu?
73 Josef OK2WO
Hamlib Error during RADIO1 setup
I would like to use Hamlib for the setup of my Radio ICOM IC-705 but :
1. When I select Hamlib on the Radio Setup, I received this Error message : "Error Start Hamlib"
2. In the Hamlib setup the IC-705 is missing in the list
3. Hamlib files in the folder Hamlib seem very old (2014). How to update them ?
Вложение 326696
I tried to installed the last version Hamlib 4.4 but it is the same.
This setuo is not clear for me :s9:
73s Christian F8GHE
Hi Christian, I have installed a new Hamlib on PC and thereafter copied the files to the Hamlib subdirectory under LogHX. Works, but I still get the Hamlib error message on LogHX start up. Choosing Hamlib from the radio drop down menu makes it all work, though.
73 de LB2EG Richard
Download files from here -
https://github.com/Hamlib/Hamlib/releases/tag/4.4
hamlib-w32-4.4.zip - for WIndows 32
hamlib-w64-4.4.zip - for WIndows 64
Here is test release of LogHX with new Hamlib 4.4:
http://rx4hx.qrz.ru/files/loghx/test..._build_699.exe
Hamlib check trx connection! Turn on trx before log run! And if you use IC-705, you must select IC-705 only, otherwise there will be an error! Now IC-705 present:
Вложение 326699
Hi Alexei and Richard,
Thanks very much for your help. Now LogHX is ready with Hamlib 4.4 :p-up: and I'm able to select IC-705 !
73's Christian F8GHE
- - - Updated - - -
- - - Updated - - -
Hi Richard, Thanks very much. Now all is OK with the last LogHX build 699. Last Hamlib 4.4 is inside LogHX :p-up:
73s Christian F8GHE
Sri does not work for me: vers. 699, FT-991 connected (works OK with Omnirig with the same settings). Still "Error start hamlib" - any idea? 73 Josef OK2WO
I have just updated to 700 and I am getting 2 entries into the log when I press enter. One entry has all the details from qrz, the other is a new line with just the callsign,date and time.
When I try and delete, it asks to update the dxcc statistics, then it creates another qso line.
thanks the issue is why is it adding 2 qso's then ont deleting them without adding another back in? i reverted to an older release now and its not happening.
Check here - Setup - Net setup -
Вложение 327048
I think problem here!
I use LogHX + MSHV in my second QTH with FT-847 transceiver. Due to the specific properties of the transceiver, it is necessary to use a separate COM port, connected to the Data in/out terminal for modulation and PTT. (I also use USB interface SCU-17 but this is not important at this point.)
However, it is important that I have to manually close this COM port before running MSVH (this port is normally used for PTT/CW).
Question: Would it be possible to add "Close PTT/CW port" to be added to MSHV settings (or other external programs)?
Note: For FT-847 and digital modes, PTT via CAT cannot be used (TX modulation would not pass).
Thank you for reading, 73 Josef OK2WO
Yes. Use "View" for MSHV like here:
Вложение 327975
CAT setup will be saved in view file.
Hi Alexei,
As you are working on CW, I hope you remember my request :s7:
It was about a way (Macro or button, ..?) to set the CW speed identical as our contact .
73s and have a nice day
Christian F8GHE
I have just installed the ERC rotator control in my yaesu 450DC. All works using the Easy rotor control software. Com 6, Yaesu GS232A 9600,. I have tried using the Yaesu option and the universalcom port in Loghx and tick auto rotation to spot, but nothing turn when using HX. It certainly opens COM6 as when I try to open ERC while I have HX openwith a rotor connected it says COM6 in use. So I am not sure what is missing?
Вложение 328627
Вложение 328628
Doesn't work either way if I click the auto to spot
Вложение 328629
Logger32 it works with these settings
; Created at 22/09/2022 19:10:30
[RotorSetup]
AutoRotation=True
BaudRate=5
ByteSize=3
COMPort=COM6
COMPort_Command=
Correction=0
DTRControl=False
Parity=0
RTSControl=False
RotorType=1
StopBits=0
To M0CGF:
I remember about you problem, pse QRX! I will deal with your problem in the very near future.
Try this version:
http://rx4hx.qrz.ru/files/loghx/prer..._build_705.exe
Check "Auto rotation to spot" or click here:
Вложение 329092
deleted
Hi Alexei
I had the ERC guy remote into my set up today to check a few things, he found the following, I made the change to 14400 and it works OK.
"I tested the rotor function in LogHX.
The command-syntax for GS232 is correct but I found the bug in LogHX: The Baudrate chosen in SETUP – ROTOR SETUP is wrong.
If you choose 9600 Baud the real Baudrate is 4800
If you choose 14400 Baud the real Baudrate is 9600
If you choose 19200 Baud the real Baudrate is 14400"
Hi Alexei,
Do you think that it could be possible to add MULTIPSK from F6CTE (index) as an LogHX external program ?
73s Christian F8GHE
Thank you for help! Yes, problem is here - fixed. Try now:
http://rx4hx.qrz.ru/files/loghx/prer..._build_706.exe
I can't promise that it will be fast. But I will try to do it.
Hi,
Who can explain to me how FLDIGI communicates with LogHX?
Here is the diagram of my system
73s Christian F8GHE
Вложение 330196
Search in Google: fldigi xml-rpc
Example:
Fldigi Users Manual: Xmlrpc Control
Is it possible to listen an UDP broadcast with LogHX (For example QSOs broadcasted by DXLOG on the UDP port 12060 of the localhost) ?
I think that it should be possible with the Spot-machine but I'm not able to configure it :s9:
73s Christian F8GHE
I would like to know if it is possible to connect LogHX to the UDP Broadcast QSOs or SPOTs Output from DXLOG ?
DXLOG is able to Broadcast QSO or SPOTs to UDP. It is possible to select N1MM format for QSO.
I was able to connect this UDP output to Log4OM with the Inbound Communicator of Log4OM and I would like to do the same with LogHX.
Вложение 330425
It's here:
Вложение 330462
After setup DXLOG.NET for Broadcasting, it works with Log4OM but not with LogHX.
Maybe my LogHX setup is not correct ? I checked on TAB Broadcast data /Received (N1MM format) / Radio, Contact and Spots on port 12060 (Same as on your ScreenShot)
And now when I close LogHX, I received this UDP error message.
Вложение 330566
Here are my setup for DXLOG and LogHX
Вложение 330601
Вложение 330602
I progress very slowly like a cat :s7:
Now my "radio UDP" setup between LogHX and DXLOG is working :p-up:
But spot and contacts need more investigation
Here is the status of my UDP setup
- Radio is OK
- Contacts and Spot are KO
Вложение 330650
Here are print screens of DXLOG and LogHX
Вложение 330652
73s Christian F8GHE
Hello Christian!
Thank you so much for the very detailed information! I found the error and corrected it. Try this test version -
... deleted!
Re-setup ports for Broadcast!
Update: new release
https://forum.qrz.ru/355-loghx-appar...ml#post1912284
Alexei, the pleasure is mine. I really like LogHX and it's me who thanks you for all your work and the time spent for LogHX.
I'm sorry but it seems the same for me with the new build_707 except the disappearance of the UDP error :p-up:
After re-setup of UDP port 13063
=> Everything is OK with Radio (Same on previous version 706)
=> But Contacts and Spots from DXLOG not seen on LogHX (Same on previous version 706)
Please confirm that Contacts or Spots could be seen in the QSO-Entry window ?
73s Christian F8GHE
Setup of DXLOG and LogHX right? Look at print screen:
Now use one port for radio, spots and contacts!
After a good night everything is working :s10:
(Check setup and Restart DXLOG and LogHX)
Thanks very much and have a nice sunday !
73s Christian F8GHE
Вложение 330724
I am looking at putting my World Castles Awards in the log, esp the English castle awards.
I've got the basic reference numbers, I wonder if its possible to get the actual name in there also?
Also for 1 QSO where they have multiple references, how can we get the log to recognise this? I have given User7 to WCA references in my log, it reads great for only one reference, but for multi refs it doesn't, could it be read by comma seperated values?
Вложение 331801Вложение 331802Вложение 331803
Thanks Alexei for the quick reply. Yes I am going through all my logs just tieing up the references from the e-log on the castles site and correcting the G. I haven't really looked at using the awards properly yet. My next target is getting FLdigi and CW set up properly as I am getting back into CW and want to try PSK31 again.
Spelling update under "Utilites" should be "Utilities" and then "Advancent Search" should be "Advanced Search"
"Non Standart callsign" should be "Non Standard Callsign"
Hi Alexey, as always thanks for your constant work to update the log.
Unfortunately with version 708 and 709 we lost the automatic sending of QSOs on clublog.
Back to 707 everything works fine, I also tested other logs and there doesn't seem to be a problem from clublog,
so the problem seems to be LogHX with automatic clublog disabled.
(in fact in the general setup the checkbox for automatic sending has disappeared).... is it a mistake.....?
Is there some reason unknown to us...??
It's a shame was one of the great features of this log.
Thanks for answer.
73 de IK2XDE Andrea
[QUOTE=F8GHE;1912424]After a good night everything is working :s10:
73s Christian F8GHE
Hi, here i a very simple Howto to connect LogHX to DXLog.
ATTACH=CONFIG]332573[/ATTACH]
Вложение 332571
73s Christian F8GHE
- - - Updated - - -
[QUOTE=F8GHE;1920566]With the correct file :s7:
Вложение 332574
Hi, here it's an update (V2) with some corrections of a very simple Howto to connect LogHX to DXLog.
Вложение 332637
I'm sorry I can't help you, but I couldn't find any news about it.
Sending real time QSOs was essential for the proper functioning of live streams
whose instructions can be found here: https://clublog.freshdesk.com/suppor...g-live-streams
In fact if you continue to use the 707 version everything works correctly, without errors like other logs,
I don't receive errors and reports from clublog.
I don't see why LogHX should disable this feature when all other logs use it without any problem.
Try to enable real time automatic sending again, and see if the clublog authors report the bug or the problem.
Thank you.
Hi, I also regret this feature :s9:
With the last Prerelease version 712 is the "Automatic send" to ClubLog OK like with the previous release version 707 ?
73s Christian F8GHE
- - - Updated - - -
It seems that LogHx is not in this list of softwares that support QSOs upload in realtime to ClubLog:
https://clublog.freshdesk.com/suppor...ltime-uploads-
from this page https://clublog.freshdesk.com/suppor...g-live-streams
Maybe could be add ?
73s Christian F8GHE
Unfortunately even with version 714, automatic upload is disabled.
I hope Alexey will quickly fix this important function.
Many other software works fine...how did they fix it...?
Let's try to contact the clublog manager to verify the problem..??
Alexey thank you in advance for the time you will spend on this.
Thanks.
73 de IK2XDE Andrea
LogHX don't use Club Log Live Stream uploads. Like here -
But log can use this URL to upload QSO in realtime:
Вложение 333397
Ok! I restore realtime uploads.
... Done -
http://rx4hx.qrz.ru/files/loghx/prer..._build_714.exe
Happy New Year all!
Looking for advice from you users on the CW set up in LogHx.
At the moment, I have only used for normal logging and with WSJTX, I have different views to suit each.
I did have it working a long time ago with PSK31 but my set up has changed and I am still trying to get it to work, I think its an FLDigi issue.
My main question is using CW windows for Morse code. I am getting back into CW so both my sending and recieving are slow! So I am looking at creating a view to decode CW and maybe have the keyer enabled but I really plan to use my paddle again. Is there a good set up for CW that anyone can share that I could try?
Thanks!
Hello, Dear Alexei - RX4HX
Best wishes for a Happy New Year to you and all group members.
Report on version 3.0 build from 708 to 715 (on previous builds including 707 was normal).
Randomly when I try to edit a QSO, the PC crashes, to restart it you have to turn off the power.
I use Windows 7 Ultimate Service Pack 1, Intel i7-3770 CPU @ 3.40GHz, 64Bits.
Вложение 333501
73 and Happy New Year for all, from py5ej;
Pavanatti.
Here need more info. How are you trying to edit a QSO? [/QUOTE]
Hello, Dear Alexei, thank you for your prompt reply.
To edit a QSO, I double-click on the desired QSO, in the normal case I get the editing window, but randomly, in versions 708-715, instead of the editing window I get the timer icon and nothing else is possible to do.
Вложение 333522
73 de py5ej;
Pavanatti.
Hello, Dear Alexei.
Thank you very much for your attention.
At your request, I will describe the sequence:
In the main Log window, "Log PY5EJ.base:C:\ ... Log PY5EJ.lhx2" I select the desired QSO, with a single click, the line turns blue.
Then double click on that (blue) line to start editing;
In versions 707 and earlier, I always get the "QSO entry/manual editing" window, and everything works fine.
In versions 708-715, sometimes I don't get the "QSO entry/manual editing" window, as expected; instead, I get the timer icon, which stays there forever;
The crash is always random, and when it happens, is after double-click on the main Log window, "Log PY5EJ.base:C:\ ... Log PY5EJ.lhx2", on selected QSO (blue line) under versions 708-715.
HNY and 73 from py5ej,
Try new prerelease -
http://rx4hx.qrz.ru/files/loghx/prer..._build_716.exe
Any changes?
Hello, Dear Alexei.
Thank you for your attention.
Using prerelease 716, the problem for editing, "manual QSO entry/editing", still exists.
With differences:
Sometimes (random), after double-clicking on the desired QSO, I don't get the window "manual QSO entry/editing" as expected, instead the editing function becomes available from this point.
Apparently, everything goes on normally with the editing function disabled, (the timer icon does not appear, and the system does not crash, as it did in versions 708-715).
I am still testing with prerelease 716.
Thanks for your assistance.
Strong 73 from py5ej;
Pavanatti.
Report on version 3.0 build from 707 to 716 (on previous builds was normal).
When starting the program, when the loading window opens,
and load these modules:
Loading Country.dat - successfully
DataModule created - successfully
DataBase Opened - successfully
MainFrom Created - successfully
Setup Cat: Only CW/PTT
CWForm created - successfully
at this point the loading seems to stop for 2-3 minutes, then resumes regularly and opens all the other modules
Begin Open PrevQSO
Prev QSO was opened - successfully
...ecc....
...ecc....
From my tests this problem occurs only if I use a computer with 3 monitors, where I normally load it on the second monitor.
If instead I use the log on a computer with only one monitor, the problem disappears and the loading is fluid and fast.
So I think the slowdown is due to using multiple monitors, ...as de loghx stops to think where to place the windows.
Alexey as always thanks for your attention I hope you can solve this problem.
73 de IK2XDE Andrea
ABOUT CTY.DAT
when and if new file will be available.
or new button to check it automatically.
We know that we can update it manually, when we want, but automatically is better......hi...!!
Thanks in advance.
73 de IK2XDE Andrea
For more information - what does "editing function available" mean?
It's not good!
Please download and install again 716 version
I add here info for loading.
After "CWForm created - successfully" must be other strings. This will help me localize the problem.
I certainly thought about it. But there is a zip file with with various name: bigcty-20230104.zip
Problem is here.
OK instal and test new build 716
GridForm created - successfully
Try load log database
Log database opened - successfully
QSOEntry created - successfully
Begin Open PrevQSO
Begin open BandMap
BandMap was opened - successfully
Begin open Cluster
Cluster was opened - successfully
Begin open WorkedConfirmed
WorkedConfirmed was opened - successfully
Begin open QRZ.COM
QRZ.COm was opened - successfully
Start external programs
ON SINGLE MONITOR COMPUTER - ALL WORK FINE
ON 3 MONITOR COMPUTER - We have this problem only on first start, If I close the log and restart, no problem.
If I turn off computer , than restart computer and restart log...same problem....slow load at first start.
My log was with 130.000 qso....but I don't think this is the problem.
Some index corrupted...??
Hope in your solution.
73 de IK2XDE Andrea
If this will help:
Remember I run the log on the second monitor, not on the first monitor (pricipal)
And remember that I run log with this string: ...\LogHX\LogHX3.exe" /D=IK2XDE
73 de IK2XDE Andrea
[QUOTE=RX4HX;1926134]For more information - what does "editing function available" mean?
Sorry, Alexei for my mistake, I meant to say UNAVAILABLE;
The correct being "Instead, the editing function becomes unavailable", (nothing happens if you try a double click).
73 de py5ej,
Pavanatti.
May be QSOManuallyEntry widow opened beyond the boundaries of the screen.
What to do: try Shift + dbl click - for open window in left-top position of screen.
There is only one action between these lines - opened log in log database. I don't think the monitor can somehow influence this.
Try copy database file to another computer and try opened.
130.000 - is not problem! 100%!
Yes...just try,
on another computer, with single monitor, no problem, log start fast and fluid.
The problem appeared after the build 706, with the build 704 everything is ok.
PC - I7 9700k - 64Gb Ram - 1Tb SSD
If i return on build 704 all work fine.
Thanks
Hello, Dear Alexei.
The unavailability problem, described, disappeared after restarting the program.
I am using build 716, and no longer have problems to edit a QSO (double-click > QSOManuallyEntry), now everything looks normal.
Please consider including in the Utilities > Find info ... > From the Internet >" HamRadio Outlet", address (https://www.hamradio.com/tools.cfm).
Thank you for your help and congratulations on a beautiful and useful LOG program.
Thanks,
73 de py5ej,
Pavanatti.
At the end of the year I decided to make some statistics of my log,
and I encountered this problem in managing the WAE Award (Worked All Europe - DARC Award)
https://www.darc.de/en/der-club/refe...-country-list/
The problem is the recognition of these 4 entities valid for WAE but not for DXCC
4U1V - United Nations Vienna - ( DXCC 206 - Austria)
GM/S - Shetland Is. - (DXCC 279 - Scotland)
JW/B - Bear Is. - (DXCC 259 - Svalbard)
TA1 - European Turkey - (DXCC 390 - Turkey)
For these entities, unfortunately the diploma searches in the COUNTRY field, and finds what is foreseen for DXCC,
so for example 4U1VIC who operate from Vienna was considered as Austria and not as United Nation Vienna.
Same thing goes for JW9JKA who operate from Bear Is. but was considered as Svalbard....etc.....
What can we do to fix this problem...??
Thanks for help.
Thanks for info, also 4U1A was in my log,....same problem....for WAE
But of course OLD qso with 4U1VIC are currently valid for the award.
73 de IK2XDE Andrea
ik2xde@gmail.com
You must manually set country -
Вложение 333810
Hello,
unfortunately this is not the solution.
With CTRL+C I will change DXCC country, that is not the same of WAE country.
Вложение 333823
Вложение 333829
Вложение 333824
WAE award search in the Country field, and does not find UN Vienna, but will find OE - Austria DXCC 206
and for this he will count the valid QSO as Austria and not as Unitited Nation in Vienna.
Вложение 333825
Вложение 333828
Same problem with JW9JKA from Bear Is. EU-027
In the field country we will find JW - Svalbard DXCC 259
so in the WAE award will count like Svalbard Is. JW and not JW/B Bear Is.
I hope I have explained the problem well.
73 de IK2XDE Andrea
Ok i tried, but nothing changed, i completely disabled the skins, and i also tried to select others, but nothing changes.
This loading pause occurs on the first start.
Then if I go out and come back, at the new start everything works fine.
All this always and only on the PC with multiple monitors.
73 de IK2XDE Andrea
Hi, I'm currently testing (again) the ARS-USB rotator control (Az only) from EA4TX:
Everything work perfectly when I use ARS-USB through PSTRotator.
But it is not the same:
1. When I try to configure ARS-USB in direct connect to the serial COMx port in YAESU emulation without ARSVCOM.
- It works (Az is sent to the ARS-USB) but I observe after the second or the third character (Depend of LogHX config) of the Callsign input two clicks in the relay
of the control box per character sent (It's like a ARS-USB reset for each new character sent). AZ sent is correct and rotation OK.
- I didn’t find how to control rotor start as possible with DXLog (ALT+F12 or CTRL+F12) or PSTRotator (Option: Confim Imported Data)
(Automatic starting of the rotor is problematic because not necessarily desired).
When I don't check "Auto rotation to QSO entry Call" in config, I don't know how to start the rotation.
2. When I tried to configure ARS-USB as EA4TXARS in LogHX, I received an error message "Can not open link ARSWIN !".
I tried to install ARSWIN but it doesn't work on my x64 OS and ARSVCOM is not recognized.
Am I doing something wrong?
73s Christian F8GHE
- - - Updated - - -
Вложение 334347
Вложение 334348
73s Christian F8GHE
If I understand correctly, you want to start the rotation manually.
It's here - by keys:
Вложение 334350
or by mouse -
Вложение 334351
I'll correct this problem!
I checked. LogHX uses an old version of the EA4TX program. Install last version of EA4TX ARSVCOM and configure LogHX like Swisslog - select Yaesu rotor in LogHX.
https://ea4tx.com/en/faqs/ars-usb-fa...etup/swisslog/
Hi Cristian
I want to draw your attention to one problem when controlling the rotator from LogHX. In your picture of the rotator setup, I see that you have two antennas on one rotator (10M, 2M). I use 4bander 40,20,15 and 10M on one rotator with PSTRotor. When I configured it like you (40M,20M,15M,10M) the rotator only worked on the first band (40M). The rotator did not work on the other bands. I had to configure each band separately. Then it worked. You might have the same problem. On 10M the rotator will work for you as Alexey wrote, but on 2M the hint (Rotor connected!....) will not appear and the rotor does not work.
Вложение 334362
Vlado OM3BY
Hi Vlado, with the last build 717, I didn't meet this issu. I'm able to control all bands set on the same line with a "Rotor Type" = PSTROTOR or YAESU and in Manual or Automatic control.
May be Alexei solved this issu previously !?
73s Christian F8GHE
- - - Updated - - -
Hi Alexei, Thanks very much. Now, everything works perfectly :s7:
Note: A hotkey to "stop" the rotation of the motor could be very useful. This would allow to overcome ARSVCOM or PSTROTATOR to do that.
73s Christian F8GHE
Hi Christian
The only problem was in what format Band was written. If you wrote it as in the menu, it did not work correctly (40M, 20M...with a space). If you wrote Band without space (40M,20M...) everything worked correctly. Alexei already fixed it in 718.
Вложение 334441
Stopping the rotator would be a very nice feature. :up:
Vlado OM3BY
Again about award section.
After updating some awards, including the WFF,
I found this small problem, the references are sorted only on the first field (country)
and cannot be sorted by reference number. (see pictures)
Вложение 334704 Вложение 334705 Вложение 334706
I think it's more convenient to be able to choose the order,
if sorted by country or by reference, personally I prefer by reference.
Thanks for the attention
73 de IK2XDE Andrea
Hello,
the problem occurs with all versions.
The awards are simply sorted only with the first field (country) and it is not possible to sort them with the second field (reference).
I've personally updated and added several new awards, and they all have the same problem.
It's a small problem, which I hope Alexey will be able to solve in the next version.
Thank you.
Hello,
I am testing my new IC-7100 with my logs. The tcvr has a USB connection but only for CAT, no RTS or DTR is supported on the virtual COM port. It seems the only other USB / COM port could be used for CW keying.
But - I am testing it with my contest SW Tucnak (Czech made) where Hamlib (last version) is used. Voala - CW keying works via CAT perfectly. There is of course the option "CW via CAT".
Could be the same option added to LogHX radio setting?
Thanks and 73 de Josef OK2WO
CW via CAT - it's CW via CAT-command. Write macros -
Вложение 335256
Sri, it is not what I mean. Excuse for my bad description of the problem. There is no option "CW via CAT" - I was playing with FLDigi where it is. Tucnak has the option "Hamlib" for CW keying:
Вложение 335321
I read on Hamlib documentation: rigctl has the command b which is "send_morse" character. A little problem is that speed cannot be controlled from a log but must be controlled by radio (no problem with IC-7100). ESC function for breaking preprogrammed macros works well. The rig poll interval should be short, 100 ms is OK.
Вложение 335322
Josef OK2WO
Please, test this version:
http://rx4hx.qrz.ru/files/loghx/test..._build_719.exe
Set CW here -
Вложение 335366
Tested - CW works OK, but after keying up MHz are missing:
Вложение 335475
73 Josef OK2WO
With the latest build file version 719,
at the start he asks me to insert the call. (....\LogHX\LogHX3.exe" /D=IK2XDE )
Вложение 335615
clicking on ok, presents general setup, where my call is already inserted.
then click ok, everything works fine.
73 de IK2XDE Andrea
Hello Josef!
What to do:
- run only LogHX and select as CAT - CatHX. Setup CAT for you Trx. Set "PTT via CAT"
- Menu Setup->Test CAT window.
- CW window -> press RX/TX button for TX, wait 3 sec and press RX/TX button for RX.
- close Test CAT window. When window coluses, will be created txt-file with command from TRX.
Save this file and sen to me. Tnx!
All are arranged by you, but the TX switch on CW windows works for a very short time only. I tried the TUNE switch ON / 3 sec / OFF, file is here: Вложение 335649
Hi Alexei, Do you plan to add this Hotkey Ctrl+ESC (or Ctrl+Alt+ESC) in your next build720 ?
(I would like to validate it with the EA4TX ARS-USB of my old friend because for his simplification I prefer not to installed PstRotator for him. With one less software, it will be easier for him :s7:)
73s Christian F8GHE
Unckeck here -
Вложение 335664
But now it 's enough -
all is Ok!
Question - when you Trx set to TX, LogHX show freq from Trx?
Yes, everything is ready for this.
New file here with RX/TX working ((renamed to .txt):Вложение 335673
Frequency indicator is OK if TX (all digits).
73 Josef
I found problem - please, test this version:
http://rx4hx.qrz.ru/files/loghx/test..._build_720.exe
The build tested - CW via hamlib works OK. There are some limitations (IC-7100 specific):
- it can send up to 29 chars only (incl. spaces)
- speed and CW chars settings must be controlled in radio
AutoCQ in LogHX works OK.
Anyway, the best solution for IC-7100 CW is to use the additional USB port with USB/RS232 convertor.
Thank you Alex for your perfect work. 73 GL Josef
Hi,
Here is a small Howto to setup LogHX with a rotor controler ARS-USB from EA4TX with and without PstRotatorAz. It wrote in French but if you think that coukd be usefull for community, I can translate it in English.
73s Christian F8GHE
Hello,
I just installed LogHX 7.19 on a new PC with Win11 and I'm not able to modify the font size of the "setup menu", the icons and the clock size. My font size is so small, that I can't read menu :s9: After multiples tests, I don't know if it is a Window11 or a LogHX parameter.
Who can help me ?
Вложение 336637
73s Christian F8GHE
For change clock size - replace files in folder Skins\Default\0.jpg...9.jpg and R.jpg to another. You can find these files on the internet.
The rest cannot be changed yet.
Thanks very much Alexei.
Ok for the clock size and about the unchangeable font size of the "General Setup" menu but here are some remarks about it:
- I never met this type of tiny font size with Win7 or Win10 and my friend F1DJY who use Win11 doesn't meet this type of problem.
- When I try to change the default font size of Win11, the font size of the "Genral Setup" menu always stays the same.
Questions:
- Is it the default font size of Win11 that used for this menu of LogHX or is it a setting in an .ini file?
- May be, I have to reset and create new .ini files ?
73s Christian F8GHE
Hello,
I find this little problem,
all CW spot from skimmer EA8/DF4UE-#
carry a letter C in the bandmap
I think it is due to the very long call.
If possible, check the alignment correction
Вложение 337090Вложение 337091
Thanks for your work
73 de IK2XDE Andrea
LOGHX v. 3.0 build 723
startin log with ....\LogHX\LogHX3.exe /D=IK2XDE
Do NOT read last view template.
I must select my view template that I save and load it.
LOG NOT save LAST view template as default.
73 de IK2XDE Andrea
Yes, it's new function: if "View" selected in profile or here
Вложение 337280
open selected "View", else - last opened "View".
Hello Alexei,
Updated to 723 and I got a error message when I click in Award:RDA window. 722 is OK.
Вложение 337351
Can't close any windows, I have to kill the process and restart the program.
TU 73 Egon / HA3MN
PS: I tried Award:DXCC, same error.
Is there a solution? I am using EESDR V3 with 2 RX open.
I use RX1 for SSB and RX2 for JTDX.
Problem when I start JTDX, RX1 also goes into DIGU.
I use both RX1 and RX2 over TCI, see photo setup.
73 Pat
Вложение 338033
Hello,
from vers. 725 I have serious problems with views. F.e. my main view is FT8 where should be No Radio and external program is MSHV (Freq and Mode are marked as from MSHV). If I save this view and open again, the Hamlib is marked as ON (why?) together with No Radio, the mode on radio is changed from USB-D to RTTY-R (why??) and MSHV is started up (it is not wanted in settings). If I want to stop MSHV temporarily, no matter if from LogHX panel or from MSHV directly (f.e. I need to make quick CW QSO) both programs are stopped and started again with the same problems (loop?).
No problem with previous versions.
Any idea?
Josef OK2WOВложение 338164
Solved.
I had to change the views setting and restart several times - now it is OK. Sorry for the note. 73 Josef OK2WO
Sri boys, with the testing of MMVARI functions I accidentally closed Macros panel. What it can be added back? Thanks for help. Josef OK2WO
You can not 100% сlose macros panel.
Look at here:
Вложение 339059
Pull mouse here.
Or -
LogHX\INI\loghx_view.ini - section [DigitalForm] -
MacrosPanel_Height=100 - set here 100.
TNX!
Hello,
does exist some help (how-to) for the setting of the new contest (if DLL does not exists) ?
For example VHF Reg. 1 CW/SSB contests, or local activity contests, where are QSO nr, WW loc and special exchange (QTH, name) are sent...
I tried to make macros but [myloc], [myqth] etc. do not work...
73 Josef OK2WO
This is in the plans. I hope I'll do it soon. :s10:
Hello Alexei,
Is it my problem only or others have this too?
I started with eQSL a few weeks ago and when I downloaded eQSLs in LogHX the confirmed eQSLs not checked at all. All goes to the "Sent (eQSLS)". LoTW works fine but eQSL do this problem at me.
Thank you for help!
Is here checked?
Вложение 339463
You must download only CFM eQSL - ADIF from eQSL have not field "eQSL CFM"!
Thank you Alexei! This method is works! 73 Egon
Hi Alexei,
Is there any possibility that you can mount Azimuth Map LogHX via PstRotator. That you can use it to operate beam.
73 Pat
Hello Alexei,
Is there a possibility to do the manager database update.
73 Pat
There is no nessesary, b'coz we have QRZcom/QRZru/IK3QAR and other services to get QSL route to callsign.
Here I do it manually If i have a time to do.
Recently I did update it POBEDA-78 memorial within.
This is the syntax of manager file to update database correctly:
File Structure qslmanager.txt (or another txt file) to import into LOG
-----------------------BEGIN-----------------------
<3 spaces>02-may-22
RP77A<7 spaces>RZ1OA
RP77KO<7 spaces>RA3VE
ON8X<7 spaces>ON8XXX
DK0XXX<7 spaces>DA4XXX
-----------------------/BEGIN----------------------
---begin-- & ---/begin--- you have to delete.
Hope it will help you in any cases for manual update.
About managers - best way to find managers for Stations:
Вложение 340299
Hello Alexei,
There is a new LogHX fan because I installed LogHX to a very good friend of mine. :s7:
Everything works fine, just only one thing we don't know...
How to control the PTT in VoiceHX window? [TX] [RX] commands does not do it.
With VOX or using MOX the messages are transmitting, no problem.
In Logger32's DVK window there was a COM port to control PTT.
He has microHAM 2R+ and FTdx5000.
Thank you for your help in advance!
73 Egon / HA3MN
Hello/Privet Alexei, Pat, Andrea
Another option is to use OK1RR's QSL Managers Database. Martin OK1RR updates this database every month. But he uses a different .txt file format than Alexei in LogHX. It is possible to modify this file as needed by LogHX. It would be better if Alexei made it possible to import a .txt file from OK1RR to LogHX. Would it be possible Alexei?
https://ok1rr.com/downloads/qsl-managers-database/
Vlado OM3BY
I'm doing an import from a text file to manager database. But how to take into account the start date and the end date if they are not provided? After all, there may be different managers for same station at different times? How to log data from the OK1RR database when the start and end dates are not specified?
Hello Alexei,
Is it possible to save Radio1/Radio2 setup and Rotor1/Rotor2 setup into the "Views"?
My friend has two radios, one for HF and one for VHF but HF/VHF antennas are using the same rotor (there is only one rotor).
I made to him two "Views" to change radios/rotor(s). One for HF and one for VHF but when he is using the "Select view" menu and select the "HF" view or the "VHF" view,
the "Views" does not load the informations for which radio and rotor are belongs to the given "Views" because the LogHX does not save these informations.
Are we do something wrong?
Thank you again for your help in advance!
73 Egon / HA3MN
PS: There is an other friend of mine... I installed LogHX to him as well.
He said, LogHX is much better than his old log program, you made so GOOD program! :)
He loves it so much!
Dear Alexei,
I hope this email finds you well. I am writing to inquire about the availability of UDP Multicast support in LogHX and its potential inclusion in future releases.
As an operator who frequently utilizes applications such as WSJT-X and JTDX, I have come to appreciate the convenience and functionality provided by UDP Multicasting. It enables multiple applications running on the same PC to interact with WSJT-X using a shared UDP IP Address and Port. This capability proves particularly valuable when using programs like GridTracker and JTAlert in conjunction with LogHX.
However, upon my exploration of LogHX, I could not find any options or settings related to UDP Multicasting. Hence, I wanted to confirm if LogHX currently lacks support for this feature. If so, I kindly request you to consider implementing UDP Multicast support in future releases of LogHX. This enhancement would greatly enhance the interoperability and versatility of the LogHX application.
For reference, the versions of the applications I am currently using are as follows:
LogHX v3.0 build 730
JTDX v2.2.160-rc2 HF
WSJT-X v2.6.1 6b6d74
To provide an example, I have outlined below the necessary configuration settings for enabling Multicast UDP in WSJT-X:
1. Navigate to the Reporting tab in the WSJT-X Settings dialog.
2. Under the UDP Server group of controls, set the UDP Server: address field to a valid IP address within the 224.0.0.1 through 224.0.0.255 or 239.0.0.0 through 239.255.255.255 address range. The default value of 224.0.0.1 is commonly used.
3. Keep the default value of 2237 for the UDP Server port number: field.
4. From the Outgoing interfaces: drop-down listbox, select the loopback_n option. You may choose to select all available interfaces.
5. Set the Multicast TTL: field value to 1.
6. Ensure that the checkboxes for Accept UDP requests, Notify on accepted UDP request, and Accepted UDP request restores window are selected.
For visual reference, you can consult the following image from (https://support.hamradiodeluxe.com/s...multicasting):
I sincerely appreciate your attention to this matter. Introducing UDP Multicast support in LogHX would greatly enhance its compatibility and utility in multi-application environments. Thank you for considering my request, and I look forward to any updates or feedback you may provide.
73, PY5XT (Eleandro)
Hello Eleandro!
Thank you for the interesting information.
I did not know about UDP Multicast support in WSJT-X. Is it new function? I'm use JTDX, JTDX don't support Multicast UDP.
I will study this question and add UPD Multicast in LogHX. This is a necessary function.
Hi Alexei,
In did JTDX doesn't have multicast yet, but WSJTX as far as I could find in internet has Multicast capabilities since 2020 last quarter, mainly to be able to comunicate with external logs and JTAlert on raspberry-pi.
Anyway, I didn't tested JTDX but as soon it works with WSJTX/LogHX I go for a request on JTDX :)
All the best, thanks for reply. Be safe
Hi there
I am a new user and really like LogHX - great work and just what I was looking for. I did use Log4OM however that just runs so slowly even on powerful PC's.
2 questions though. I have it setup to upload to LoTW automatically when I close the software down however I get a pop up box telling me TQSL is trying to run in administrator mode. It then gives me the option to run anyway however I would like it just to work. How do I stop this - do I have a setting wrong?
Second is a suggestion for bulk selecting QSO's. Would it be possible to select the first QSO you want to manage and then scroll down to the last QSO you want to manage and shift-left mouse click to select all those QSO's. The reaqson is sometimes I import a contest log of several hundred QSO's and want to do a QRZ lookup on all of them and pressing space to select each one takes a lot of time. Being able to just shift-left click would be much quicker in this example.
73 de Danny M0SDB
Set LogHX right here -
Вложение 342984
You can't do that now. But it's a good idea. I will do it in the next version. Now you can select the necessary QSO through the filter, then menu "Select...->Select all QSO".
Many thanks for your help Alexei - I think I have it working now and thank you for looking to implement my QSO selection suggestion.
73 de Danny M0SDB
Hi Alexej, thank you for a beautiful piece of software, I like LogHX, from my point of view it's the best logger I've ever seen.
Please, allow a question:
My rig is SunSDR2 DX, connected by TCI bus. Everything works OK so far, the only problem is that CW paddle app (a part of LogHX):
a) inserts very long spaces between letters (much longer than set in CW paddle settings), when input from keyboard (but interletter space is OK when input by F1 - F10 macro)
b) the speed of CW changes spontaneously, when trying manually to set other when default value (100) - it can be seen, how the value of CW speed spontaneusly and randomly changes from 40 to 150 cpm
Any idea, please? Thank you so much
Zdeno
Good evening Alexei,
Recently found your software, I have to say it's the most flexible logging program I've ever seen, in terms of user and display configurability. Congratulatuions!
Couple of things - in many parts of Europe, 4m (70Mhz) is an allocation these days. Is it a user option to add 4m support or are the bands "hard wired" into the software?
Secondly.. the Awards window I am finding very hard to read, because the fonts (it looks like) are a fixed size and using a high resolution monitor (even a 42-incher) makes the print very small.
Can this be made bigger/user definable as so many of the other windows are? This applies to the table (Wkd/Cfm) and the band numerical summary on the right hand side.
Also a zebra effect on the awards table would help follow the lines across.
Speaking of the Awards window.. right click then "Minimize view" does indeed minimise the window, but there doesnt seem to be an option to undo the minimize and the content of the window is lost.
The only way I could fix it was to copy over the loghx.ini from a virgin install on another machine.. I couldnt find the line in the .ini to change.
Thanks again for an excellent package.
Hello Zdeno!
If you use CW via TCI, then yes: not intended CW for sending from keyboard.
Set CAT via TCI and CW via COM-port for sending CW via keyboard.
I will contact the developer of SunSDR2 and I'll figure out how to solve this problem. I don't like CW via TCI.
I will check this problem tomorrow. I use SunSDR2.
Hello Jim!
Thank you for redirecting questions to the forum.
About add bands/modes/etc — use «Insert» key for add new line in tabe, Ctrl+Delete keys for delete
line in tabe. Or for add new line in table — go to last line and press «Down arrow» button.
In general, almost everything can be customized in LogHX.
A new version will be released tomorrow - font for the Awards window can be changed, problem with "Minimize view" will be fixed!
Thanks for the updated version Alexei - the select bulk QSO's works perfectly and I have got LoTW uploading automatically now as well. Very pleased with my choice of using LogHX :)
Thanks for the updated build, Andrei. much better for my old eyes!
Any way of increasing / user defining this part of the window? Have to lean forward so my nose is almost touching the screen to read it :s10:
Вложение 343123
Hi Alexei
I have been testing the click-select and on further testing it does not quite behave. If I select the first record and then scroll down to find the last record the first record becomes de-selected straightaway so I can only bulk select a group of QSOs if they are all displayed in the window at the same time. If I want to select say 200 from a contest I cannot do this.
I don't know if this is an easy fix?
Thanks again
Danny M0SDB
Does anyone else get this on the countries list in the DXCC table?:
I was wondering where the "341st country" was coming from....
How does one get rid of the "-ZD4" ??
Вложение 343225
"-" - Deleted country. Got here by mistake.
For edit award use Awards window ->
Вложение 343236
Yes, it's problem.... Ok, I will think about how to fix the problem.
Thank you Alexei, all sorted :p-up:
Hello Alexei,
(How) Can I rename User11-20 fields' name in Setup/QSL Status or somewhere. I would like to see it in Award window / QSL method window. To rename in the Log window is OK but it does not help.
Thank you for your answer!
73 Egon / HA3MN
Thank you Alexei!
In the log window I will see the renamed field, OK.
In the QSL method window it stays as User11 but I KNOW User11 is what I want to see in log. So it is OK!
Hi Alexei...
Suggestion: - in the WW Locators map - would it be possible to be able to navigate around the fields by using arrow keys or buttons (up/down/left/right) instead of having to double-click to go back to the world map and select another field? In other words, to go from IO to JO, just click right. Would improve the useability of this window.
Cheers!
Hello Alexei,
Sorry to remember you but you did not say anything about that:
#659
07.06.2023, 09:41
Thank you,
73 Egon / HA3MN
Hello Egon!
For Radio - use this checkbox for save Radio setup in View
Вложение 344315
For Rotor - not problem! Will be done!
Alexei, hi!
Feedback.
Here with Windows 10, Intel i7, and JTDX 160rc2, the time synchronization function does not work in the latest versions of LogHX v.3.0 build 734 and 735. I went back to version 733 and everything works normally.
73 from py5ej,
Pavanatti.
Is there a way of having two seperate configuration files/setups? The scenario is my normal call is M0SDB however I now have a second call for contesting, M3O.
All my contesting will therefore be logged under M3O and I have another LoTW tSQL for it, QRZ page etc so I need to be able to configure LogHX to use those details when contesting. I have set up a new database for M3O however things like the LoTW settings, QRZ settings etc are shared with overall with M0SDB and ideally I would have two separate configuration files that would load with the connected database.
There are ways of overcoming this but they are not ideal.
Many thanks as always for any help
de Danny M0SDB/M3O
By the way - check here:
Вложение 344621
Setup->Default
for set system time log must be have administrator right.
After setting the administrator right, in the latest versions (734 and 735), everything works normally.
Thanks for your help, 73 from py5ej.
Really easy this question I am sure. Which is the option to preview the image and other information from QRZ.com. I have closed it accidentally and just remember the name of the window to select.
73 de Danny M0SDB
I have found it again - Right click on the QSO input window then 'Find...'/Find call on QRZ.com' :)
Alexei, I trust you're doing well.
I've come across a question regarding the RADIO SETUP > RADIO 1 > HAMLIB > Setup in our beloved logbook. While exploring the menus, especially the radio control settings, I noticed a screen where we can configure RADIO 1 or 2. There's an option labeled "HAMLIB" specifically for setting up a "NETWORK CONNECTED RADIO." I'm curious about how this is supposed to function; does it relate to Hamlib TCP rig control daemon RIGCTLD?
Вложение 345304
The question is the Radio Setup/HamLib/Network connected radio (PICTURE LEFT SIDE) the same thing as in JTDX HamLib NET Rigctl (PICTURE RIGHT SIDE)?
For context, the rigctld program is a NEW Hamlib rig control daemon ready for testing that handles client requests via TCP sockets. This allows multiple user programs to share one radio.
In my scenario I've successfully got my older radios (TS440S and IC718) running smoothly using RIGCTLD in conjunction with either JTDX/WSJT-X. Of course it took some time to figure out, but with a simple command line, I can switch the CAT Control between radios and control them seamlessly.
Just as reference I'm sharing the batch file I'm currently using for Hamlib TCP rig control:
Batch File for IC-718
I create a batch file and use the NSSM (Non-Sucking Service Manager) to create it as a Windows Service so I can launch it with windows InitializationКод:@echo off
del D:\Ham\HamLib\log.txt
rem ----------------------------------------------------------------
rem D:\Ham\HamLib\hamlib-w64-4.5.5\bin\rigctld.exe -m 3013 -r COM1 -s 9600 -c 0x5E --set-conf="dtr_state=ON" -p COM7 -P DTR
rem -m 3013 << Seleciona o modelo ICOM IC-718
rem -r COM1 << Porta COM a ser utilizada no CI-V
rem -s 9600 << Set serial speed to 9600 baud
rem -c 0x5E << CI-V address to communicate with the rig
rem --set-conf="dtr_state=ON" << ON turns on DTR, OFF turns it off, Unset disables it
rem -t 4533 << Change the termination network port for text protocol when using the
rem -p COM7 << Use as the file name of the Push-To-Talk device using a device file
rem -P DTR << Use of Push-To-Talk device
rem -vv << Set verbose mode, cumulative upt to 4 Vs
rem -L << List all config parameters for the radio defined with
rem -Z << Enable time stamps for the debug messages
D:\Ham\HamLib\hamlib-w64-4.5.5\bin\rigctld.exe -m 3013 -r COM1 -s 9600 -c 0x5E --set-conf="dtr_state=ON" --set-conf="ptt_share=1" -t 4533 -p COM7 -P DTR -vv -Z -L >> D:\Ham\HamLib\log.txt
I'd appreciate any insights or guidance you can provide on the HAMLIB option in the logbook setup.
Hello,
I cannot to add 70 MHz (4m) band to General Setup (OLEdB error). Can you help?
73 Josef OK2WO
Здравствуйте! Появилась такая проблема, на данный момент работает версия 732, в новых релизах программы (по 737) перестала корректно закрываться программа sdruno, которая запускается одновременно с Loghx3 через установки для внешних программ. Подскажите, пожалуйста, в чем может быть дело и как исправить, до 732 версии все было хорошо.
Вложение 345366
Hey Alexei,
I wanted to share some additional information about using Hamlib Net now with FLDIGI, and you can check out the attachment for more details.
Вложение 345684
For instance, I've successfully run JTDX, WSJT-X, and FLDIGI simultaneously, with all programs having access to RADIO CAT. It's worth noting that this might not be feasible with every program open at the same time, but in certain contexts, it's definitely doable.
Feel free to explore and let me know if you have any questions!
» UTILITIES -> FIND MANAGER (NOT INSERT MANAGER)
NOT WORK with "CURRENT QSO"
NOT WORK with "ALL QSO"
NOT WORK with "SELECTED QSO"
Please Alexei verify, this work only, if find a single manager,
but if find a multiple manager, for example, with different year,
the utilities don't insert the manager, they move on (skip), it should insert the most recent one instead
73 de IK2XDE Andrea
Must be fixed, please check -
https://forum.qrz.ru/355-loghx-appar...ml#post1988066
Unfortunately it doesn't work,
it inserts the manager only if it finds a single result,
if it finds multiple managers with different years,
it does not insert anything, skips the QSO and moves on to the next one.
In this case it should choose the one with the most recent date, and insert it.
Thanks.
73 de IK2XDE Andrea
Yes. If for station found only one manager - insert anyway.
If found many managers - check date interval. If not found valid date interval - manager is not set.
... Well, as variant:
first - check for valid begin and end date
if not found - check for valid begin or end date
if not found again - insert last manager.
Yes I think this is the best solutions.
It will work correct.
Please verify also manual insert, I just send you a video of the problem,
when we push insert, DO NOT CHECK the call of qso.....so insert a manager
to any qso without verify the call.
Thanks.
Wait for new prerelease.
73 de IK2XDE Andrea
Test this version -
http://rx4hx.qrz.ru/files/loghx/test..._build_739.exe
Well.....done...!!
Now UTILITIES --->> FIND MANAGER.....work great...!!
I will make some other test...but seems al is ok.
Persist the problem with manual enter.
if i am on a qso with no manager in the database,
and I push insert, DO NOT CHECK the call of qso.....and insert any manager
How do we change the CQ Zone iun the log?
VO2NS comes up as Zone 5, but is Zone 2 and cant see where to change it. Thanks.
- - - Updated - - -
Disregard. Found it.
While I'm here... Bandscan window (using the horizontal one) - Changing the font size doesnt seem to change the font size of coloured spots.. the uncoloured ones do change but coloured spots remain rather small.
The Band review windows (really handy feature, this, by the way!) One can change the fonts but the line size stays the same... increase the font too much and the lines get cut off at the top and bottom. If you need, I can provide a screenshot for both issues after the weekend is done.
Cheers.
Unckeck here:
Вложение 346434
Hmmm... Yes, it's wrong! Will be fixed in next release!
Thanks. That worked!
Thought I'd toggled that option yesterday, obviously not. Thanks fopr the tip and quick response
I might be mistaken, but I thought there was a means of saving all received DX spots to a file, but I can't find it.
1. Is there such a feature in LogHX, and
2. If there isn't, would that be easy to add, perhaps saving to a text or CSV file, with a new file being started each day, or month?
It's useful to have an archive for propagation. I also use old spots for goign through older SDR IQ recordings.
There are some loggings progs that allow the archiving of spots.. but I have found that VE7CC cluster software that I use to supply spots has an archiver, so I have enabled that.
Hello Alex,
I hope that in the next and upcoming version you will fix this bug.
In the ver. 739 of 14/11 unfortunately I see that it is not yet correct.
Persist the problem with manual enter from MANAGER local database.
If i am on a qso with no manager in the database,
and I push "INSERT" in the manager windows,
Just send you a video, I don't know if you've seen it.
Always many thanks for all the work you are doing.
73 de IK2XDE Andrea
Hi Alexey, hope you are all fine.
I have a feature request to AutoCall in JT window, of course if it is possible to implement, it is better to draw then explain, currently we have this screen:
Вложение 347822
my request is to have the capabilitie to focus on unworked CQ Zones, WPX and GridLocators something like this "really bad MSPAINT job" :s6:
Вложение 347823
Justifying my request, some times I already worked a country but still didn't have an uncomon zone from this country, or an special event callsign with a different callsign WPX, or the GridLocator is complete new or maybe rare. This feature could be interesting to complete my personal archivements or goals, in special when we talk about JTs modes.
Thats for now, let me know if you understood or need more clarification.
All the best 73 PY5XT - Eleandro
Hello Eleandro!
Now LogHX use only one pre-calculated statistic - DXCC. But yes, there are many requests to add statistic by Zone, WWLoc, WPX, State, County... Maybe something else :)
I am currently working on this issue. I plan to add option for user to choose many pre-calculated statistic. I am currently finishing work on a new version of the log. Adding new statistics will be the next step.
OK Alexei, for me that sounds a good plan. :s11:
Just to you be aware, in the future of course if possible read the CQ DX Marathon (https://dxmarathon.com). I'm participating not in the top tear, but having fun in participating.
Basiclly DX Maraton from CQ is "Starting January 1 of each year and running until the end of December, the DX Marathon is the perfect answer for the DX-er who needs that extra incentive to get on the air every day! Simply work as many countries and CQ Zones as you can in each calendar year, regardless of the band or mode. Each country and zone counts only once, so you can concentrate on working new ones, rather than working the same ones on multiple bands and modes."
Maybe in the future, we could have a filter for the current year to help the tracking of worked countries e CQ Zones.
Thanks a lot for your effort in updating our beloved LogBook app, if you need any help don't exitate to ask.
All the best, 73 from Eleandro PY5XT
A slight oddity... unless I'm missing a setting to reverse this:
In the Frequency Display window, using the left and right mouse buttons to change the digits...
Вложение 348416
Intuitively, i would expect the left mouse click to adjust the digit downwards, and the right mouse click to adjust the digit upwards.
But here, it's the other way round.
Is there a setting to reverse this, or could it be reversed as it's not (to me, anyway! ) logical?
In new version will be here -
Вложение 348417
great - thanks. Look forward to new version.
Quick question about maps...
When we use the maps in the WWLOc windows.. and zoom into each large grid (e.g. JN) the map becomes highly pixellated and "blocky". I know that is a limitation of the JPG file used to generate the map.
Is anyone else using a much higher resolution map successfully? Is it a case of simply copying another map file in?
Yes, found a much higher res map (it's about 10MB) and it works just fine in the WWLoc window, and looks good.
Yes correct,
the problem is that it doesn't verify the match of the call, and inserts any selected manager to any call... even if different.
There should be a check here, if the call doesn't match, don't enter the manager.
Thanks for the attention.
73 de IK2XDE Andrea
The problem also persists in version 141
insert any manager to any call even if they don't match.
Another small problem, when I insert the call in the log window,
in the managers window it automatically positions itself on the first manager found ,
instead it should position itself on the last, most recent one.
73 de IK2XDE Andrea.
Hey Alexey,
Hope you're starting the year off well. I've got a little tech puzzle on my hands. Running LogHX version 3.0 build 742, and I'm noticing a quirk—stations I've worked in FT8 are showing up as gray dupes when I'm in FT4, and vice versa. Strange, right?
I've attached a test run with PY5EJ to give you a visual. The red arrows should point you to the head-scratcher. I don't have PY5EJ's station logged in 17M+FT4, but the system thinks otherwise. This happens with other stations as well.
Вложение 349400
Any insights on what I might be missing? Would appreciate your wizardry to unravel this mystery.
Cheers,
PY5XT - Eleandro
Вложение 349402
Mode - MFSK, not FT4! All right!
There are two things here:
1. This highlighed QSO you shown in the picture is mode MFSK and submode FST4 not FT4
- FST4 = FST4 do not require the strict, independent time synchronization and phase locking of modes like EbNaut.
- FT4 = FT4 uses 4-GFSK modulation, transmission takes 4.48s with a 7.5s timing window.
2. by the ADIF standards (https://adif.org/314/ADIF_314.htm) for FT4 mode we should use mode MFSK submod FT4, as we can read in the chapter "III.B.9 Mode Enumeration"
Вложение 349414
I have this as standard for my log, do you think this is the issue I facing? I should use FT4 instead of MFSK? I didn't get how to fix.
Sorry
Well,
now when I type the DXCall in the "QSO Entry" window,
in the manager window the cursor is positioned correctly on the last and most recent manager found.
But the INSERT button, that inserted the manager selected,
in the QSO entry window, in the Manager field, has disappeared
Now please
explain to us how works the new mask ......DXCALL - MANAGER - INSERT MANAGER...??
It doesn't seem to work...?
Previously, to insert a new manager it was enough to press the "INS" button,
a new row was created, and the new data was inserted.
(and I see that this one still works)
I take this opportunity to wish you and your family a good end and a good start to the year.
Happy New Year
As always, thank you for your continued commitment to log development, on behalf of all users.
Thank you.
ok, testing
v 743 31/12/23 09.26
INSERT MANAGER from the "manager windows" seem work,
bur I must type manually "manager" in the filed,
best solution is that take it automaticaly from database.
(the last and most recent).
Another problem is do not overwrite the manager field in the "QSO entry" window,
if for example there is already other information coming from qrz.com
Thanks.
73 de IK2XDE Andrea
Try now -
http://rx4hx.qrz.ru/files/loghx/prer..._build_743.exe
Happy New Year! :)
Great,
now the manager field is automatically populated with the correct manager.
Now if I do "Insert manager" it inserts the manager into the "qso entry" window
only if the field is empty, it does not overwrite the information coming from qrz.com
(keep in mind that in general setup, I put "replace info" in the callbook management).
I think at this point you will have to give priorities,
first check on qrz.com and overwrite all the information, (if replace info is cheked)
then, if the user type "insert manager" , force his choice, an replace field with the manager chosen from the local database.
I hope I explained myself correctly.
Thank you.
73 de IK2XDE Andrea
Wonderful,
with v.3.0 buid 744 dated 31/12/2023 20.31
the database manager seems to work fine.
All insert and update functions seem to work.
I will do more tests in the next few days.
Thanks Alex.
Happy New Year to all users
and Good DX
73 de IK2XDE Andrea
I warmly thank Alex for his efforts in the development of LogHX.
Finally, the management of the offline manager database work fine and allows various import solutions by users.
Personally, I have kept my database updated for years, and I thought I would make it available to all LogHX users.
I normally update it a couple of times a month.
You can find the file at the following address: http://www.xdenews.net/managers
There are also complete instructions to update your log.
The database can certainly be improved,
so if anyone would like to send me updates or corrections they are welcome.
73 de IK2XDE Andrea
ALARMED SPOT GRID ...problem....I think.....!!
When i select some call for alarms spot,
and in "country status for selected call" i chose Highlight color,
backgroud spot was colored also if I just work the call on same band and mode.
It does not take into account whether the station has already been worked.
I think correct solution will be
BACKGROUND COLOR only if station will be new one on the same band and mode.
If station just worked....NOT BACKGROUND COLOR....spot grid background will be white.
But many people think differently!
Therefore, there is a setting here -
Вложение 349744
change priority here! Set "Dupes" - UP, "Selected call" - DOWN.
Hello, just a simple question...
In the Cluster window I lost the red bracket (when I am on the given frequency).
How can I switch it back again?
Вложение 349824
(This picture is NOT my Cluster window)
The "Highlight spots on freq" is checked.
Thank you for help! :s7:
73 Egon
I mean "red frame", not "red bracket"
Two other question:
- How can I select a QSO in the log window in the new version of LogHX (b748). The SPACE button does not work.
- What is the function of the "Call" (underlined) in Radio1 window.
Thank you for help!
73 Egon
Hi Egon
SPACE works for me
If Call is not underlined and you have entered other data (QTH, Name, Loc...) and then you change the letter in the call, this data will be lost.
If Call is underlined and you have entered other data (QTH, Name, Loc...) and then you change the letter in the call, this data will not be lost.
Vlado OM3BY
Hello Alexei,
Thank you for the help!
- Yes, CAT is OK in Radio1 window.
- Help / Hot keys / is OK, SPACE 111
I reloaded an older View, now SPACE is OK but the red frame is not showing in the Cluster window!
In MY newest View if I click in the log window anywhere, the log is goes to EDIT mode in the clicked row, so in EDIT mode the SPACE is not functioning as Select/Unselect because the cursor is blinking in the row.
So I investigate ... But I think, it is time to reinstall the beloved LogHX from the begining.
I wait a few days, maybe somebody has better idea before I reinstall all again. :)
Thank you again!
73 Egon
- - - Updated - - -
Thank you Vlado!!
Yes I had problem with the disappearing datas in Radio1 window but thank you for you, it will be just bad memories! :)
73 Egon
Hi Alexei.
How to config the CAT-Interface to use the RIG-2 of Omni-Rig
Good day!
Here - Вложение 350152
Thank you for everyone for the helps!
Unfortunately, my PC broke down, so I am now working with a laptop. :(
I reinstalled all of LogHX, everything works fine now!
Thank you again!
73 Egon
- - - Updated - - -
Hello Vlado,
Thank you for this info! I did not know it!
You told me a new thing again! :)
Thank you for your help Vlado!
73 Egon
Hi LogHX3 friends from Steve G0UIH
From V745 onwards.
Вложение 350310
Changing database [I have 12 current good databases] – error as below.
Database[s] won’t open from within the app.
Fix is to quit the program and then re-open.
Program then requests you to pick a log from the database you have just tried to open.
This works [as a workaround] and the d/base opens.
Databases are all ‘Good’ and open fine in MS Access without issues.
No anti-virus or protection enabled
All was good on versions before V745
Error message = “Open ADO Connection Error”.
I was looking to see if this is ODBC related but LogHX3 does not seem to use any ODBC entries.
Running now V750 and error still exists.
Any thoughts
Very 73 – Steve G0UIH
It's strange. Send base to rx4hx@mail.ru - I'm check it!
CAT problem with build 750
With this version CAt not work.
CATHX + IC7600v2
Return to build 749 all work fine.
Thanks for attention.
73 de IK2XDE Andrea
Fixed -
http://rx4hx.qrz.ru/files/loghx/LogH..._build_751.exe
Pse QRX! Looking for a problem!
Fixed:
OK confirm.
With build 751
CAT work fine (like before)
Thanks.
73 de IK2XDE Andrea
Managers update ....!!
Available to all users
https://www.xdenews.net/managers
Вложение 350389
73 de IK2XDE Andrea
Alexey, it is ok to use this picture on my QRZ.com page?
Вложение 350407
Do you see any problem?
ops
Вложение 350418
sorry
This is the least we can do to contribute to the best development
of the software you have made available to us for free.
A small clarification, which you can correct in future versions,
in the whatsnew.txt file indicate the version of the program as Ver. 3.1 build 751 (17 January 2023 y.)
but in reality in the program, both in the logo and in the info, everywhere it says v 3.0 and not v3.1.
It's a small nitpick, but it's worth fixing.
Thanks again for the great work you are doing.
73 de IK2XDE Andrea
>Hello Andrea,
>I tried to save your website for the update instructions but right-click does not work.
>I used a online converter to do it.
>73 Egon
Here pdf file.
Вложение 350450
73 de IK2XDE Andrea
As I said, I downloaded the website with a online converter.
That is same as yours!
Thank you for your helping Andrea!
73 Egon
PS: I do not use the QSL manager database but I help to others to get the best within LogHX! :)
I recommended and helped to install the LogHX* to others. QSL Manager system makes it better.
* (the Best of bests) :)
Hi Alexei,
One oddity with all recent versions since at least 732 - keep meaning to mention this.
The Awards window... I set the fonts to optimum for my display. I close down the software and restart, and on restarting, the fonts are much larger. Shut down and restart again, and the fonts come back bigger still. Both the General (typo "Genegal" in the menu ) Table fonts and the Title/worked/confirmed. Very strange. I have to adjust them back each time I restart.
I guess it's something to do with the user-set fonts, (I was the one who asked for the size to be made variable) maybe everyone else has the default size and are unaffected.
- - - Updated - - -
Just to add that the Band Review windows are similarly affected, exacerabted by the need that one has to reset each column individually......
Now all good Alexei with V751 - tnx for the fix! ::p-up:
Very 73 - Steve G0UIH
Hi Alexei - tnx for the fix.
All good now in V751 :p-up:
Hello,
Since version 749, I have the followings problems:
- Very long statistics calculating time (10s max before, now 2 minutes)
- Synchronisation with lotw, eqsl or clublog is freezing
Same problems with 750 or 751
Hello,
With 752 version: no more long calculation of statistics!
Thanks
More on the issue I covered in my post in post #765.
I have prepared some screenshots to show the issue...
First, the Awards window with the desired font settings: font size set to 16
Вложение 350734
Then I close LogHX down, and restart it:Now you see all font sizes in that window have approximately doubled...
Вложение 350735
So I go through and reset the fonts to how they were, save the view, close and restart, fonts doubled again.
A similar thing is happening with the Band review window - this screenshot is with the desired font settings...
Вложение 350736
And then, after a closedown/restart - note the column header and the row size has increased, and I cant see a way to adjust those, so they carry on getting bigger with each restart...
Solution is to open a new Band Review window, configure it and close the other one down....
Вложение 350737
- - - Updated - - -
One more thing.. (sorry!!)
WW Locators window:
Selecting a time period returns no data despite there being data to show:
In this screenshot, 1/1/23 to 31/12/23 are selected, but the map is blank:
Вложение 350742
... but the data is there, because using the same pair of dates in the Awards window does return data:
Вложение 350743
Yes, it's bug! Thanks!
Fixed -
https://forum.qrz.ru/355-loghx-appar...ml#post2006303
What skin (name) do you use?
Hello,
I have just migrated my log to LOGHX. I have a problem.
I just made a QSO in FT8 and when WSJT-X UDP the QSO in LOGHX this strange
thing happened...
4348 QSOs were registered and the software froze! Can anyone help me to solve this problem?
Thanks,
73, Pierre VA2CZ
See the screen shot of my problem
https://u.pcloud.link/publink/show?c...eaiipIsyTU2Bck
Check in log - setup for WSJT-X - here -
Вложение 351082
may be here same ports for UDP and Rebroadcast UDP?
Also check setup for Net.
LOGHX v 3.0 build 754
HXCAT --> IC 7600v2
When LOGHX start send to transceiver command CI-V TRANSCEIVE OFF
also when I enter and exit from Radio setup.
I'm sure it didn't happen before, if we go back a few versions.
This is a problem for me that I have connect PC+AMPLIFIER+Externat SDR Receiver+SDR CONSOLE....all need CAT
CI-V Transceive
Each Icom radio can operate in one of two modes concerning the CI-V interface: CI-V Transceive on or off. What is this?
With CI-V Transceive set to on, two things happen:
the rigs transmits data automatically over the bus, whenever frequency or mode changes
the rig reacts to data sent over the bus which is adressed not only to it’s own adress but also to a special adress meaning “all rigs connected”
With CI-V Transceive set to off, the behaviour changes:
the rig does not send data automatically, when turning the dial or changing mode, the connected computer must request (poll) data
the rig reacts only to data sent to it’s specific adress, data sent to “ALL” is ignored.
The default setting is CI-V Transceive set to On.
This is useful when connecting a rig to an accessory like an amplifier which can read the CI-V data (and switch bands accordingly).
Also this mode is used to synchronize two radios all the time, maybe in a contest setup.
Another little problem,
I usually use tu set FREQ A from CAT,
Now not read freq A when I am in spit, but read Freq B
Thanks.
73 de IK2XDE Andrea
Hello Alexei;
I encountered a problem installing version 754, see below:
Вложение 351161
Thanks for your attention, 73 from py5ej.
Is here path to Flrig.exe OK?
Вложение 351184
Hello Alexei,
I found this situation on filtering QSOs with date(s) and a custom field.
Вложение 351210
73 Egon
Thanks! Yes, it's mistake! Will be fixed!
Fixed -
http://rx4hx.qrz.ru/files/loghx/LogH..._build_754.exe
Hello Alexei,
Sorry but I forgot to say in my last message, I use 754!
What do I do wrong?
Вложение 351213
73 Egon
- - - Updated - - -
Вложение 351216
But this is OK!
DateQSO>=#01/01/2024# and DateQSO<=#02/02/2024# and Country="UA"
or
DateQSO>=#01/01/2024# and DateQSO<=#02/02/2024# and Country LIKE "UA"
73 Egon
Hello Alexei,
Thank you for the info, YES it works now!
But I had to reinstall v754 again. My 754 was updated by
the automatic update but it does not work! Hmmm...
I downloaded LogHX3Setup_build_754.exe from your website
and reinstalled it and NOW it works!
Thanks again!
73 Egon
Hello Alex,
tell me something about it,
every time I start loghx, it sends TRANSCEIVE OFF via CAT, and I have to manually go into the radio menu and re-enable TRANSCEIVE ON.
It's inconvenient to have to change it all the time.
Now not read freq A when I am in split, but read Freq B
Thanks.
73 de IK2XDE Andrea
I'm use INI-files for Radio from OmniRig.
Now I check file IC-7600v2.ini for you Radio and found this:
; Icom IC-7600 ver. 2.00 firmware command set
; IC-7600v2 File created by Bob Wilson, N6TV, n6tv@arrl.net
; Tested by: N6TV @ KE1B & HRO Sunnyvale, CA
; Updated by N6TV 2019-03-23:
; - Comment out compound CI-V commands under pmVfoAA, pmVfoAB, pmVfoBA, and
; pmVfoBB because Icom firmware doesn't handle them consistently.
; - Removed pmFreq as recommended when both pmFreqA and pmFreqB are available.
; initialize
[INIT1]
;Turn CI-V transceive OFF
Command=FEFE7AE0.1A050097.00.FD
ReplyLength=16
Validate=FEFE7AE01A05009700FD.FEFEE07AFBFD
[INIT2]
;disable RS-232C decode, use CI-V
Command=FEFE7AE0.1A050098.00.FD
ReplyLength=16
Validate=FEFE7AE01A05009800FD.FEFEE07AFBFD
[INIT3]
;set CW normal to lower sideband
Command=FEFE7AE0.1A050089.00.FD
ReplyLength=16
Validate=FEFE7AE01A05008900FD.FEFEE07AFBFD
Try delete section [INIT1] from file IC-7600v2.ini (LogHX\Rigs\IC-7600v2.ini)
I think this should help.
Do you use CatHX? If yes then in log - Setup - Test CAT window- then set split ON/Off, close Test CAT window and send file with CAT info to me.
Yes this is the problem,
now problem solved I just put ; before
So initialize ignore/skip this line.
[INIT1]
;Command=FEFE7AE0.1A050097.00.FD
;ReplyLength=16
;Validate=FEFE7AE01A05009700FD.FEFEE07AFBFD
OK I send you personl mail with file.
73 de IK2XDE Andrea
Hi Alex,
I no longer remember how to disable auto reconnection to the cluster.
After sending "bye" to the cluster, loghx automatically reconnects.
I would like to disable the function.
Thank you.
Ok, I tried your solution, but something is wrong.
with ALT+D disconnect telnet correctly.
But if I send the command via telnet
[DISCONNECT] - disconnect from telnet (command provided in the telnet macros)
loghx freezes. and blocks the system.
On the contrary, if I send the manual command "bye" via telnet,
telnet disconnects from the cluster and then reconnects automatically.
So I think you will have to adjust the macro command
[DISCONNECT] = ALT+D
so we can create the macro button in the telnet window to disconnect from the cluster.
73 of IK2XDE Andrea
Quick question and apologies if I am missing something - is there a QSO timer built in? I am working towards various CW awards that require QSO's over a certain length and I want to be able to start and stop a timer and for this to log the start and end time of a QSO.
I have tried doing this manually and when I set the start time the end time mirrors the start time and greys out so I cannot edit it. Plus I sometimes forget to note the start and end time so a timer would be useful.
Many thanks and vy 73 Danny M0SDB
Hello,
in the QSO manually enter windows,
press right button of the mouse, near "Date and Time (on/Off)"
a little menu will open with "Auto Set TimeEnd"
73 de IK2XDE Andrea
Цитата:
I usually use tu set FREQ A from CATHX,
This probem persist also in the buid 756 dated 21/02/2024
Thanks for your attention.
73 de IK2XDE Andrea
Hi Alexey,
I wanted to bring to your attention an issue I've encountered with LogHX, specifically in the recent version Build 755. When I click on the DOWNLOAD and SYNCHRONIZE option for LoTW in the File menu, the program reports that the downloads were successful, and all the new QSOs were flagged as LOTW Received.
However, I've noticed that in some cases, it changes the county field values even if they are already filled. As shown in the figure below, it seems to corrupt the data from countries like Japan by deleting the left digit, leaving only the right digit. Additionally, I've observed instances where it capitalizes (UPPER CASE) the US counties, causing discrepancies in the AWARD statistics.
Вложение 352308
In the figure above, there's an example of a QSO with JA0FLL where I manually changed the county number to 27 (Myoko) before clicking on LoTW download and synchronize. However, after confirming the QSO, it changed to 7, which isn't a valid county. This issue is consistent across multiple QSOs with Japanese stations, where only one digit is retained. Additionally, I've noticed that the county for W7PJS appears in UPPER CASE, despite selecting it from the PRIMARY AND SECONDARY ADMINISTRATIVE AREAS menu.
I didn't encounter such problems in previous builds, although I acknowledge that they may have existed without my notice.
In my opinion, if the fields are already filled or have been manually input by the user, a sync with an online service shouldn't alter any existing data.
As a background, me PY5XT meticulously check the data for each QSO, including STATE, COUNTY, IOTA, WFF, VIA and GRID, as it greatly aids me in tracking various awards programs. And now I have to check my whole logbook hunting for changes that this sync have messed :s9: it will be a pain.
Please let me know if you require further clarification or if I've overlooked anything.
Thank you for your attention to this matter.
Try uncheck this
Вложение 352344
Hi Alexei, I hope this message finds you well.
I'm reaching out regarding a feature request for LogHX. Currently, we have a menu under UTILITIES>FIND RDA for tracking Russian Districts, primarily for participation in the international award program at RDAward.org.
Building on this functionality, I would like to request a similar feature for tracking Japan Prefectures. In LogHX, when checking the administrative Primary and Secondary Areas, Japanese Prefectures (JCC/JCG and AJA) are listed correctly [see attached screenshot].
Вложение 352788
In my opinion, it would be beneficial to have a "table" associating callsigns with their corresponding State/County values. For this purpose, I suggest utilizing the well-maintained website of JJ1WTL, which provides CSV files containing information for almost all Japanese callsigns and their respective States/Counties or JCC/JCG values.
I envision this feature being accessible through the Setup menu, similar to how RDA tracking is currently implemented, where users can upload data as needed.
Could you please confirm receipt of my request and let me know if further clarification is required?
Thank you for considering my suggestion.
Related links:
- RDAAwards.org = rdaward.org
- JJ1WTL = motobayashi.net/callsign/licensesearch.html
Can anyone help?
Having added a new screen and changed orientation of 2 of my screens, all the LOGHX windows have disappeared and I cant seem to retrieve them.
I restarted LogHX, no windows appear apart from the Update one, and I cant access the main menu or anything.
I tried renaming the last known view INI< but that's not made any difference.
Short of deleting all INI windows and starting afresh, what do I do to get at least the main window back?
You can try deleting the INI files, but perhaps the main window is outside of your visible area.
In similar situations, I've tried reducing the screen resolution to the lowest possible value. This sometimes causes the edges of the LogHX main menu to appear, allowing you to move the window to an accessible position.
That's pretty much what I did in the end - had to delete (move) INI files and start display options again from scratch. Even Windows-TAB didnt show the main window - just a blank white square that I could not access or move.
I also found that I had problems making window positions "stick" even after saving them. Part of the issue is that when the monitors are turned off, Windows 11 rearranges some window positions automatically (very annoying!) and I start losing the main LogHX menu window and I'm back to square 1. I have found that NOT using skins and styles greatly reduced these problems.
Hello Alexey,
problem with buid 757 persist.
- IC7600 - CATHX (SET FreqA)- in Split operation read wrong freq. from FreqB (VfoB).
Just send you an email with all test.
- I think you will have to adjust the macro command for telnet [DISCONNECT] = ALT+D
- SunSDR2DX with ESDR 1.0.7
CW Macros from LOGHX work ok With TCI
Problem with SSB Macros from LOGHX - do NOT send audio via TCI
(work correct with IC-7600+COM PTT and Audio from PC)
The "save to TXT file" function of the file manager has some problems.
With build 745 about 30 seconds to save 58000 managers in txt.
With build 757 it takes 1 hour to save the 58000 managers in txt.
The import however works correctly with both builds, about 30 seconds to import 58000 managers
Installed Ver 357 this morning.
Still having an issue wuth WW Loc map - viewing logged WWLoc within a pair of dates (in this case 1/1/23 to 31/12/23 - the map does not match the log, there are a lot of WW-Locs missing.
Using the Awards window and selecting WW Loc does give the correct list, the map is still incorrect.
In the screenshot, I have laid the WW Loc window on top of the Awards window.. the time periods for both windows is set the same, but as you can see on the WWLoc map, half of the LOcs listed on the left are missing.
Also not sure why I cant get the window titles to show properly, it may be that using 4 display screens (This is from Screen 3, which is a 4K monitor) may have something to do with it, don't know. Only happens with LogHX, other software windows show correctly.
Вложение 353789
I foud problem - try this version (reload 757 version):
http://rx4hx.qrz.ru/files/loghx/LogH..._build_757.exe
About "lost windows" - if main window is visible, use Shift+menu for window: window will be in 1,1 position.
If main wondow is not visible - edit loghx_view.ini file. For each "view" edit self loghx_view.ini file.
Section
[MainForm]
Edit
Top=...
Left=...
Pse wait! I'll check this problem.
Alexei - Thanks for that. issue is indeed fixed.
Noted on the loghx_view.ini info.. will remember that for future.
- - - Updated - - -
While I'm here.. any news on the up/down/left/right buttons for the WW Loc screen to navigate round the displayed 20°x10° LOCs instead of having to go back to the world view each time?
- - - Updated - - -
Disregard that last one - I see the keyboard arrow keys do the job.
Save managers 1 hour - it's tooooooooo slow! :)
The reason for this may be an antivirus.
But I have made corrections in 757 version - please, reload again and try save to txt:
Now time to save 50000 managers about 1 sec!
OK Alexey,Цитата:
- The "save to TXT file" function of the file manager has some problems.
Tested latest build 757
- Disconnect telnet command (SOLVED)
- Managers Save in TXT (SOLVED)....fast....super fast.....!
Wait your info for
- IC-7600 CATHX problem if (SETFreqA)
- TCI problem with SSB Macro (SSB TCI macro from Expert work fine)
If you need some or others tests I am at your disposal
Thanks in advance.
73 de IK2XDE Andrea
OK we will wait....for now we will use "RadioMacros" from ExpertSDR
OK, here you can find my two videos
First video with SunSDR2DX via TCI al work fine, split operation and frequency correct in the log.
https://www.xdenews.net/managers/files/1.mp4
Second video with ICOM IC-7600 + CatHX Interface (WRONG FREQUENCY in split operation)
https://www.xdenews.net/managers/files/2.mp4
I hope this video help you for understand the problem.
73 de IK2XDE Andrea
No....IC-7600v2.ini NOT work correct.
Yes, I just delete INIT1, this is old problem.
No I investigate....try also IC7600 and IC7600-DATA,
but all the tree file have the same problem.
I will make some modify, but I don not understand about CAT command in the INI file.
Anyway correct file was IC-7600v2 because I have v2 firmware in the radio.
73 de IK2XDE Andrea
Well, I find a solution.
after some test and mods on the original file ini, I have solved the problem deleting
[STATUS 10] from the file.
; - Removed pmVfoA and pmVfoB when both pmFreqA and pmFreqB are available.
;[STATUS10]
;Command=FEFE7AE0.07D2.FD
;ReplyLength=15
;Validate=FEFE7AE007D2FD.FEFEE07A.07D2.00.FD
;Flag1=00000000000000.00000000.0000.01.00|pmVfoB
;Flag2=00000000000000.00000000.0000.0F.00|00000000000000.00000000.0000 .00.00|pmVfoA
Now all work correct, ISO qso and SPLIT qso will be stored in the log,
with the correct RX Freq. and also correct TX Freq.
This is my personal file.
http://www.xdenews.net/managers/files/IC-7600v2-XDE.ini
If anyone else owns an IC-7600 please test it, and report any malfunctions to me.
For me everything seems to be working fine now.
73 de IK2XDE Andrea
Changing radio
Hi Alexei,
How easy would it be to place a button on the log input screen to change radio from Radio 1 to radio 2? Perhaps a Button that says R1 or R2 that can be toggled?
It would be much quicker and easier to change radios on the fly with a simple click instead of having to go into the menu to do it.
Thanks.
Hi Jim, to do this I found it convenient to use a HotKey (IdKeys900 - Change Active Radio),
but it would actually be useful to have a button, and perhaps also add the change of the relevant BandMap
Then Switch between Radio 1 and Radio 2 and Switch between BandMap1 and BandMap2.
We hope that Alexey finds this request useful and easy to apply.
73 of IK2XDE Andrea
Thank you Andrea, I will look into that. Need to work out how I make that work.
Do I literally put "IdKeys900" in the window next to the hotkey that I want to use?
- - - Updated - - -
it's OK, I've sussed it now! Better than navigating to a button to be honest, now using Numpad and .
Any way to increase the "capacity" or store of DX spots?
During busy contests, spots are disappearing from the list in less than 10 minutes, even if the life has been set to 120 minutes.
Been looking for a setting to change but can't find it.
Use SpotMachine filter -
for country
Вложение 354114
Вложение 354115
or another filter.
Here's a little request for future changes
Send spot via telnet --> Insert macros in info
Please add [submode] field
Thank you.
In this regard, I think that in a very busy contest like a CQ WW the time limit to use is 20 minutes,
no more, 120 minutes is too much...we're talking about thousands of spots per minute.
But anyway what is the real limit set in loghx...??
Is there a maximum number or not..??
73 de IK2XDE Andrea
I updated the log today and now I cannot open anything says open ADO connection error, log is bad, if I say no dont load it says autorisation failed. any ideas as cannot use my log at the moment as it won't open.
it has opened my older log from a few days ago, so I am missing QSO's is there a way to fault find the broken log?
Вложение 354454
I tried the renaming steps below, still the same error from the bkp file
Hello Dear Alexei.
Issues about configuration to use the MSHV with LogHX :
1) - How to add: Command line option, (--inst-name=) to use the MSHV in multi-instance ?
2) - How to set up: LogHX JT (JT/FT - modes actives calls -> Setup auto Call) to MSHV when in FT8 mode ?
Thanks for your attentions,
73 de PY5EJ.
Send file to me rx4hx@mail.ru
It's will be in 759 version of LogHX.
Thanks Alexei, sent a dropbox link to your email.
oh damn! not good. OK let me place the whole of the log folder in there incase I missed one, the one that should be the latest shows 12mb filesize here.
There is a folder called Log that is uploading and contains 54 files.
Alex, thank you for the tremendous work you give to the amateur radio community with your LogHX3 programme. :p-up:
Maybe it would not be a bad idea to remove the "Skimmer" option from the Spot machine window because switching this option on leads to a range of problems. As a dx cluster administrator I notice problems when connecting to the cluster in my case the "market leader" DXSpider which allows to receive spots also from the RBN network. The LogHX3 user mistakenly thinks that by turning on the "Skimmer" checkbox he will also receive skimmer spots. Enabling this option leads to a huge number of telnet retries (unknown command) and a headache for dx cluster administrators who consequently block the user from entering the dx cluster. Enabling RBN skimmer spots is done on the dx cluster itself. I am adding an S50CLX example which could be sensibly included in the LogHX3 instructions.
Server Name: S50CLX
Address: s50clx.infrax.si
Port: 41112
S50CLX DXSpider Skimmer Usage. Use command line in Telnet window to Send a command to the dx cluster
SET/SKIMMER (Enabling for ALL MODES)
SET/SKIMMER CW (Enabling for CW only)
SET/SKIMMER RTTY PSK (Enabling for RTTY, PSK/FSK)
SET/SKIMMER FT (Enabling for FT4/8 only)
SET/SEEME (Turn on RBN spots for own call)
UNSET/SKIMMER (Disabling for ALL MODES)
HELP RBN and HELP SET/SKIMMER for a full set of instructions on how to use a feature.
In case of problems connecting to S50CLX I am available via emial address, see qrz.com.
Thanks & 73 Dan S50U sysop S50CLX
https://s50clx.infrax.si
FT4 Wise, is this setup right? Do you have any improvement to suggest?
Вложение 354806
PS. Mode: MFSK SubMode: FT4 is what is in https://adif.org/314/ADIF_314.htm - III.B.9 Mode Enumeration
- - - Updated - - -
Вложение 354806
PS. Mode: MFSK with SubMode: FT4 is what is in https://adif.org/314/ADIF_314.htm - III.B.9 Mode Enumeration
Dan is actually right.
Many users don't know the correct commands
to use the cluster and skimmer function.
Currently DXSPIDER and CC-Cluster (by VE7CC) are the two most popular cluster software
For example, these are the commands to use with a my CC-Cluster:
Server Name: IK2XDE-6
Address: ik2xde.ddns.net
Port: 8000
command----> SET/SKIMMER (skimmer CW & RTTY spots enabled)
command----> UNSET/SKIMMER (skimmer CW & RTTY spots disabled)
command--> SET/CW - SET/NOCW (Turn on/off CW spots)
command--> SET/RTTY - SET/NORTTY (Turn on/off RTTY spots)
command--> SET/FT8 - SET/NOFT8 (Turn on/off FT8 spots)
command--> SET/FT4 - SET/NOFT4 (Turn on/off FT4 spots)
command--> SET/BEACON - SET/NOBEACON (Turn on/off BEACON spots)
command--> SET/OWN - SET/NOOWN (Turn on/off spots for your own call)
73 de IK2XDE Andrea
Not, you setup ADIF mode -> Log mode is wrong.
If you want use FT4 as Mode in log, you must:
- setup Log mode -> ADIF mode - is Ok!
- setup ADIF mode -> Log mode must be
Вложение 354824
Hi Alexei, hi all, I've enabled UDP Adif broadcast but nothing happens, I don't see packets in wireshark when a QSO is entered.
Is UDP ADIF broadcast working?
Basically what I want to do, use a UDP listener to automatically upload QSOs to cloudlog.
Or Alexei, would you be interested in implementing an automatic QSO upload for cloudlog aka Clublog etc. ?
https://github.com/magicbug/Cloudlog/wiki/API
Thank you
Frank
Hello Alexei.
In Windows 10, up to Test version 759 of 2024-April-24 the Sleep Screen function worked properly, but now with Prerelease build_759 of 2024-May-13 it no longer works.
Is there any configuration to be done?
Thanks for any guidance,
73 from py5ej.
Pavanatti.
Hello Alexei;
Thank you for your attention.
The on/off functionality would be great, thanks for implementing it.
Sleep mode is useful for monitoring reception on the VHF bands (e.g. 2m, 6m), or on HF (e.g. 60m, 80m or 160m).
Thank you for your dedication to the fine work of developing LogHX.
73 from py5ej,
Pavanatti.
Done - Setup->Default->add "Disable computer sleep mode" checkbox
Reload -
http://rx4hx.qrz.ru/files/loghx/prer..._build_759.exe
Hello,
I still have a very long process of synchronisation with eqsl, clublog... ending with an error in "reading adif" And sometimes it's very quick without error. QSO numbers is not important. It can freeze at the first as at the 600th
73, Thierry.
Dear Alexi,
I have noticed a strange behavior with my micro KEYER III. At startup, I receive the following errors regarding the internal CW Keyer WinKey2 (see attached files). I have to press OK twice, and then the WinKey2 is recognized.
I suspect that some routines are checking for the presence of the WinKey2.
Just an FYI, and I hope you can provide a fix in the near future.
73,
HB9DHG Fulvio
That's a good tip, Alexei.
I'm using two radios. How I can disable the winKey on one radio and use it only on the second one?
Thanks, Fulvio
UPDATED: never mind Alexei,
You pointed out to the right direction. I had to select RADIO 1 first, then disable WinKey.
Everything is fine now and I do appreciate your help with my issue.
Much appreciated!!!
HB9DHG Fulvio
Is the problem fixed in the latest 761 as I don't see it written in the "Change log"? I only ask enough to inform the DXSpider sysop community. Alex keep up the good work. :p-up:
Вложение 356670
Dan S50U sys S50CLX
In the new version of the log (build 762), this setting will be "hidden" so that it cannot be accidentally enabled.
Hello,
in the last version of LogHX I am noticed the problem:
QSO from MSHV is written to log with ?????? as callsign, sometimes. Previous versions were OK, no ??????...
73 de Josef, OK2WO
SunSDR2DX with ESDR 1.0.8 with LogHX build 762
CW Macros from LOGHX work great with TCI
How we can config it.....??
NO TCI in the Output option.
(Work correct with IC-7600+COM PTT and Audio from PC)
Normally I keep only one band map open, the one relating to the radio I am using.
Normally
Radio 1 - ICOM IC-7600 - Band Maps 1
Radio 2 - SunSDR2DX - Band Maps 2
It would be nice if when I change the radio, the band maps would also change automatically,
so if I am with radio 1 and switch to radio 2, it should automatically close band maps 1 and open band maps 2
I don't know if it's possible and easy to implement, but it would be a nice utility
Hi Alex, I understand that this is not easy to implement.
The solution could be to bypass the problem,
using "RADIO MACROS" supplied with Esdr3 v 1.0.8 and working perfectly.
At this point, as for the bandmap 1 and 2,
when you switch FROM radio1 (es. ICOM)
to RADIO 2 SunSDR2 radio via TCI,
"CW paddle windows" and "Voice windows" are automatically closed,
and the external program "RADIO MACROS" opens.
Perhaps it is useless to waste time implementing it,
since the original RADIO MACROS program powered by Expert works perfectly.
Thanks for your efforts
I worry about adding awards where the first and only criterion is the district (County, Okres in Czech). But the program needs State - but we have no states, only Counties (Okresy). Many OK/OM stations indicate on servers (eg Hamqth) County character code - mine is GBL. What with it? Can County be added as the first criterion? And would it be possible to import a database of OK/OM callsigns with County codes?
Thank you for the info.
73 Josef OK2WO
It's wrong! Look here - https://adif.org/314/ADIF_314.htm
Enumeration for Country Code 503 (Czech Republic)
Code Primary Administrative Subdivision
Southern Moravia (Jihomoravský kraj)
GBL Blansko
By ADIF standart - GBL is Primary Administrative Subdivision - for log - State.
Oh yes - ADIF specifications - I did not know it, sorry. Thank you for clearing. I was looking in LogHX (live example):
Вложение 358199
Next I was looking to Hamqth XML (example on web) - there is <district> as our OKRES (STATE by ADIF) code:
Вложение 358200
That is a referred problem, probably.
73 all the best, Josef OK2WO
I do not see ? ? ? as Mode, but now (since I changed to vers. 762) the Mode is not taken from MSHV. It is a big issue, FT8, MSK, FSK, Q65 QSOs are RTTY or SSB by the band !
Returned to 758.
Pse QRX! Will be fixed in new release.
Hi,
Upgraded to 762 and changed "Call" font size and type at "Find" search.
Wher can I set these parameters? TU
73 Steve HA9PP
Вложение 358482
Now you can not change font for field Call (Find call), but if need - I can make it.
Today I test MSHV with log (I use JTDX for FT8). I can not found problem.
Explain - where ??? In QSOEntry window?
Pse printsrceen!
[QUOTE=RX4HX;2041645]Now you can not change font for field Call (Find call), but if need - I can make it.
I have returned to 761, so PSE check this part of program and make correction if possible. TU
73 Steve HA9PP
Alexei,
Not recognized any difference. 763 still smaller.
73 Steve HA9PP
Вложение 358504
Вложение 358505
Strange! Here -
Вложение 358516
older and new version - same font now!
What skin do you use?
Log from MSHV:
Вложение 358527
Log window:
Вложение 358528
My skin setting is
Вложение 358699
Still UDP Multicast working on this new version build 765?
Fixed problem with UDP Multicast -
http://rx4hx.qrz.ru/files/loghx/LogH..._build_766.exe
Hello,
starting with version 765, and later 766 and 767, there are problems opening the local file managers.
versions 763 and 764 work correctly.
Thanks.
73 de IK2XDE Andrea
Fixed - try this:
http://rx4hx.qrz.ru/files/loghx/test..._build_767.exe
ICOM IC-7600
With version 767 [ something changed in the management of the cat when transmitting in split.
Now, even if I set FREQA, it always reads the frequency FREQB, the one where I transmit in split.
Instead it should remain FRQA where I receive the dx station.
V763 work fine with cat.
73 de IK2XDE Andrea
Fixed, please test -
If you select FREQA or FREQB - Вложение 360119
you can not use second VFO for split mode.
Hi Alexey,
ICOM IC-7600 does not have two separate vfos.
when in split mode,
the VFOA (FreqA) is fixed on the receive frequency, (red arrow on the bandmap) (in the log as RX FREQ)
the VFOB (FreqB) you move it to the desired transmit frequency.
(blue arrow on the bandmap) (in the log as TX FREQ)
Please check, until version 763 everything worked fine.
73 de IK2XDE Andrea
... but here is problem with Yaesu TRX....
Well, try this version:
Need printscreen this two windows from version 763, where all work well -
Вложение 360176
for IC-7600.
I found problem - try again:
Another version for testing:
With the latest version 767 (the one from today 06/09)
Everything works correctly.
However, I discovered that the changes were made between 759 and 761
(I have never tried 760) and since then all the subsequent ones do not work.
However, I confirm that the V 767 from today 06/09/2024 works correctly with my IC-7600,
correctly manages the split frequency, both vfa and vfob, correctly records the qso in log rxfreq and txfreq,
on the band map the red and blue arrows are correctly displayed.
In the qso entry window, the call of the station positioned on VfoaA (RxFreq) is correctly displayed.
Thank you.
73 de IK2XDE Andrea
Where can I download V758 ?TKS
- - - Updated - - -
V767 is still has issues:
Вложение 360986
Вложение 360985
Try this test version - http://rx4hx.qrz.ru/files/loghx/test..._build_768.exe
Hello Alexei,
When importing an adif file, created by LogHX (build 768),
I noticed the inclusion or addition of a comma in the County field of some countries.
See the result after exports/imports in the LogHX 768 environment.
Вложение 361373
If necessary, I can send you an .adi file with the problem described above.
I ask for guidance to avoid the proliferation of this error.
Thank you in advance for any help,
73 from py5ej,
Pavanatti.
Look here -
https://adif.org/314/ADIF_314.htm#Se...ve_Subdivision
Problem here:
For JA-stations - <Two-digit prefecture code><Two-digit or four-digit city code> without comma!
For VE-stations - there are no secondary areas and their identification!
Alexei,
I totally agree that the county fields are been not used in the ADIF 314 standard. However, it seems that when he exported an ADIF file from LOGHX with these let say “unsupported” counties and then imported the same ADIF back in other computer, a comma (,) was added to those counties. I tested this and found that if we continuously keep exporting and reimporting the log in ADIF format, it keeps adding commas to forehead of the counties. This happens mainly because LOGHX exports counties as <CNTY:X>State,County. For supported counties, LOGHX aparently suppresses the comma, but for unsupported ones, it keeps the comma as the first character.
From my point of view, the user should be able to write whatever they want in those fields, and export/importing shouldn’t change the values. What am I misunderstanding?
All, I have just swapped PC's in the shack and trying to get everything back to how it was.
I am having trouble with the CAT, I used to use CATHx with no issues.
Now I get errors that the radio cannot open CatHX.
If I try wsjtx v2.6.1 with CAThx selected with this I get
Hamlib error: 1:icom.c(4943):icom_set_conf entered
1:icom.c(4973):icom_set_conf returning(0)
1:rig.c(817):rig_open entered
rig_settings_get_path: path=.hamlib_settings
rig_settings_load_all: settings_file (.hamlib_settings): No such file or directory
rig_open: cwd=C:\LogHX
rig_open: C:\LogHX/hamlib_settings does not exist
rig_open: async_data_enable=0, async_data_supported=1
serial_open: COM4
serial_open(229): open failed#1
serial_open(229): open failed#2
serial_open(229): open failed#3
serial_open(229): open failed#4
serial_open: Unable to open COM4 - No such file or directory
port_open: serial_open(COM4) status=-6, err=No such file or directory
rig_open: rs->comm_state==0?=0
1:rig.c(1023):rig_open returning(-6) IO error
IO error
IO error
while opening connection to rig
Timestamp: 2024-10-17T13:10:19.894Z
However if I goto hamlib it works OK in my FT8 "View".
In my SSB "view" modes and freqs are all different.
How can I get back woking with CATHx?
In the last version 769 there is not AUTOCQ repeated (CQ on button is red). Also Alt+R does not work, I have to click on ESC everytime.
What I am doing bad?
73 Josef OK2WO
Check this version -
http://rx4hx.qrz.ru/files/loghx/test..._build_770.exe
Any idea on a socket error?
C:\LogHX\LogHX3.exe
Socket Error:
A Socket operation was attempted to an unreachable host.
When loading my FT8 view, not sure if its a radio setting or a WSJTX setting? Is there an error log to give more details?
ah looks like I had multicast ticked in error. Thanks!
question on the worked confirmed window. I know you can configure the dates, however what I am trying to do is the following.
1. Show all time status
plus at the same time
2. Show status for only this month, as I have a club contest to work as many dxcc each month.
Is it possible to have both on display?
I can do that but can you have 2 windows? one showing this month and one showing all time - both showing at the same time??
Now - not. Only one window. But I need to think about it. Maybe is good idea - to make a separate window for each statistic.
Hi Alexei,
Couple of things now I've fixed my login problems on here.
I posted in the past about the fonts in the Awards window doubling in size after restarting the program, when using a theme or skin for the main program.
i have found that it actually happens if the Awards window is actually closed and re-opened, and not just when the program is closed down and restarted.
I was also thinking as a suggestion, that the configuration of the Awards window could be loaded/saved in a similar manner to that of the Band Review windows.
Finally (for now!) I am finding the sound output selection on the DX spots alarm (Setup.. General Setup.. Color setup for Country Status) is changed if another sound device is connected or reconnected. For example, I plug in a Midi device I use to control my SDR software, and LogHX changes the output device to the Midi device I just plugged in (undesired behaviour)
Any way of making the selected sound output device "stick" ?
Any idea what httpgeterror - error code 87, error message : The parameter is incorrect. its from the spotmachineserver.exe
Log version?
768
sorry been away with work, says 404 error on the download
Now download last release 770 -
http://rx4hx.qrz.ru/files/loghx/LogH..._build_770.exe
Hello all,
today morning my friend CT1EHK Carlos did upgrade of logHX3 to 770 version.
He is facing the following situation:
Вложение 362936
He is able to run logHX3 when he chooses OK but he is afraid that something is not going well, Alex can you check what's wrong here ?
Best 73 all.
CT1DRB/OK8RB
David Quental
Hello Dear Alexei.
I need help sorting the QSLR(S)_Date columns after removing (30-12-1899).
Вложение 362945
Thanks in advance for any guidance, 73 from py5ej.
Hi Alexei,
Just a heads up that Windows Defender flagged a threat after I installed build 771 this evening, clearly it's a false positive - details in the screengrab image below in case it's of any help:
Вложение 363258
I am also getting the error below when I click on a DX spot - everything happens normally as it should but I also get this pop up box:
Вложение 363261
I clear the box down and all is fine.
Yes, CreateBauckup.exe create zip-archive, and it's look like virus.
Fixed -
http://rx4hx.qrz.ru/files/loghx/test..._build_772.exe
Hello Alexey,
with new buid 774 - 08/01/2025
whean I use OFFLINE MANAGERS DATABASE
function LOAD from *.TXT file
I receive this error:
Вложение 364405
Вложение 364406
LogHX run as administrator.
Hope you will find this bug.
Thanks.
here some example.
3A/IZ8EGM,IZ8EGM,01-01-2015,31-12-2015
3A/MM0NDX,EB7DX,01-01-2021,31-12-2024,WEB OQRS - https://www.eb7dx.com - ONLY DIRECT - NO BUREAU
3A/MM0SAJ,EB7DX,16-01-2024,31-12-2024
3A/N0FW/P,W8QID,01-01-2005,31-12-2005
3A/N9NS/P,W8QID,01-01-2005,31-12-2005
3A/OJ0Y,EB7DX,01-01-2019,31-12-2019,WEB OQRS - https://www.eb7dx.com - ONLY DIRECT - NO BUREAU
3A/OK1CZ,OK1CZ,01-01-2000,31-12-2000
3A/ON4LUC/P,ON6DP,01-01-2007,31-12-2007
3A/ON5NT/P,ON5NT,01-01-2007,31-12-2007
3A/ON5UR,M0URX,01-01-2012,31-12-2014,WEB OQRS - https://www.m0urx.com
3A/ON8AK,M0URX,01-01-2012,31-12-2012,WEB OQRS - https://www.m0urx.com
3A/PB8DX,OQRS,01-01-2022,31-12-2022,CLUBLOG OQRS - LOTW
3A/RA9USU,UA3DX,01-01-2021,31-12-2021
3A/SP2FAX/P,SP2PI,01-01-2005,31-12-2005
3A/SP2JMB/P,SP2PI,01-01-2005,31-12-2005
This file never change
File CREATE with "SAVE TO TXT FILE"
73 de IK2XDE Andrea
Hello Alexey,
now all work fine.
Thanks.
Last version:
Wrong CONNECT_SERVER!
on any server. What is new, where is a problem?
73 Josef OK2WO
Solved - all my data, including the callsign, disappeared from the setup, I don't know why, after upgrade...
73 Josef OK2WO
Ignore my previous, I solved it.
It looks like recent Windows Defender updates is generating false positives for trojan viruses in LogHX files.
This morning, Spottercollector.exe was eaten by Defender.
I updated LogHX to 776 and this time Defender ate LogHX.exe as well as SpotterCollector.
I have put an exception on the LogHX folder, reinstalled and all is ok now.
Haha, yes thats hat I meant. Not enough coffee consumed at that point.
On another note - I was using 775, but I had to roll back to an earlier build becasue Telnet kept disconnecting and was not re-connecting automatically. I find it strange that it should disconnect at all, as it's a localhost / 127.0.0.1 connection to VE7CC cluster client running on the same machine.....
The disconnection happens due to "Timeout get gata from server [127.0.0.1]" ( assume gata = data ). Another program I use doesn't get these disconnections, so I wonder how long a timeout has to be before LogHX assumes a timeout and disconnects.
Anyway, I rolled back to 771 (the last I'd downloaded) and all is well again, the disconnects still happen but HX connects again straight away.
Hi had the vhfstpete dll flagged today and also telnet disconnects.
However I have an issue with the bandmap, its just not showing even though its ticked.
I have recently changed to a new win11 PC from win10, and I am not sure if my install copied across OK as each time i load it I have various different things happening. It doesn't seen to save the views and associated radios.
Question for everyone incase there is a better way.
I have a view for SSB where I have a radio selected for control.
For FT8 I have a view with wsjtx loaded, in Loghx no radio is selected and its controlled via wsjtx.
Best way to manage it? Issue is if I want to quickly nip to ssb then its a reload of view as the reports are still +- etc.
ignore this I managed to fix the view by copying over the ini for the bandmap from a different view.
I'm still getting the telnet disconnects as well.. only to localhost - external ones are fine.
Also sone UI issues..
Firstly, on loading LogHX, I get the following 2 error windows:
Вложение 365968
Вложение 365969
After loading, there are 2 windows that don't come up properly...
First the Awards window - all font sizes increase by approx 35% each time the window is reopened.
Secondly, the Frequency window. I have set it to look like this:
Вложение 365971
but after reloading the software, it comes up like this:
Вложение 365970
I have to re-set it each time.
Even though I have saved the setup under "Select View" once I have it as I want, the issues still persist.
It's worth pointing out that I have a multi-screen setup here, I don't know if that is part of the problem.
[QUOTE=RX4HX;2075109]Log version?
Oh sorry ! Should have said.... Build 776
since updating my gfx card all the views open but they seem to all appear off the screen and I cannot view the windows. REally weird.
Is there anything I can reset in the view ini to fix this?
While we wait and see if Alexei comes up with a solution....
I don't have a definitive answer, but the file you're looking for is likely to be in LogHX/INI/Vews/GeneralViews then select the folder of the name of the view you are currently using. Make a copy of the loghx_view.ini, so that if this doesnt work, you still have a copy of the original.
Change all lines starting "left" or "top" to 0 and see if that repositions your windows to where you can see them on restarting LogHX.
I THINK that worked for me in the past.
Thanks will try it.
One more question.
I have view for SSB and a view for FT8. I am sure before this reinstall that the SSB allowed a radio in CATHX and in FT8 view the radio was disabled. I've tried resaving the views with these settings but the radio still remains on and clashes with wsjtx for control and the radio ends up in rtty-r mode.
Do you want link CAT to View? If yes, check here -
Вложение 366476
Been off the air for a while since the last rotator question.
I have the rototar connected, it says click left SP etc on the QSO entry window. When I click the SP it just sends the Rotator to 0 deg, LP does nothing.
Any ideas how to troubleshoot?
Test quuestion
Hello Ian!
I'm new to LOG XH, and I find it great. I managed to set it up easily. However, while using it, the LOG
window suddenly shrank for no apparent reason. Now, I can’t resize it back to its original size.
Can someone help me? Thanks, 73 Pierre VA2CZ
Can't you stretch the window with the mouse? Show printscreen, please!
I am still struggling with this rotator issue, any help please?
Alex hi
Maybe it would be interesting for users of your programme to improve the reception of telnet DXCluster spots for interested group of users of POTA and SOTA programme. On the S50CLX DXCluster I have implemented the integration of spots that are not part of the classical telnet DXCluster network. More in my note below. The user of your programme would thus have the possibility to select in the programme the reception of specific spots via a button, with predefined commands to be sent to the S50CLX DXCluster after a successful connection. Sorting, searching by reference ... etc is a matter of implementing of LogHX. The idea for the button is:
1. POTA ONLY spots -> command executed: ACC/SPOTS INFO -POTA-
2. SOTA ONLY spots -> command executed: ACC/SPOTS INFO -SOTA-
3. BOTH POTA&SOTA spots -> command executed: ACC/SPOTS INFO -POTA- OR INFO -SOTA-
4. S50CLX CLUSTER DEFAULT (all spots) -> command executed: CLEAR/SPOTS ALL
A connection via telnet protocol to S50CLX s50clx.infrax.si:41112 which is a completely free service is required to receive POTA/SOTA spots.
Good luck, Dan S50U
POTA and SOTA enthusiasts!
POTA (Parks On The Air) and SOTA (Summits On The Air) are internationally renowned programmes. They encourage licensed radio amateurs to operate outdoors in nature parks or on mountain peaks. Operators making contacts in parks or on summits are called activators, and the other operators who contact them are hunters.
On the S50CLX telnet DXCluster I implemented the collection of spots from POTA and SOTA that are not part of the classical telnet DXCluster network (potaapp and sotawatch). Such spots are tagged with [-POTA-] and [-SOTA-] respectively. In the comment field a spot tagged as such carries:
POTA:
- International POTA reference number, example: SI-0831
- Mode of operation, example: CW
- POTA reference name, example: Preval Vrh Ravni
SOTA:
- International SOTA peak reference number; example: S5/CP-002
- Mode of operation; example: SSB
- SOTA summit name, altitude, points; example: Porezen, 1630m, 8 points
With the right settings, the exact DX spots you want can be received and this is achieved using the filters below. To change an existing filter, simply overwrite it with a new command. Each command (BOLD formatted text) must be entered on a new line, confirm the entry by pressing ENTER.
- for receiving only POTA spots, command: ACC/SPOTS INFO -POTA-
- for receive only SOTA spots, command: ACC/SPOTS INFO -SOTA-
- for receiving POTA and SOTA spots, command: ACC/SPOTS INFO -POTA- OR INFO -SOTA-
The CLEAR/SPOTS ALL command removes all set filters and the S50CLX passes us all SOTA, POTA, DXCluster and optionally RBN (SET/SKIMMER <mode>) spots.
In cases where you do not want to receive POTA and SOTA spots e.g. in a contests, use the command as the first filter before all others REJ/SPOTS 1 INFO -POTA- OR INFO -SOTA-
Spot forwarding is based on the DXSpider DXCluster software validation and normalisation algorithm, rejecting duplicates spots and ensuring quality spots in the face of increasingly frequent malicious attacks on global amateur radio DXCluster network.
The S50CLX DXCluster can be reached via telnet at: s50clx.infrax.si port 41112
My small contribution to the promotion of outdoor activities in POTA and SOTA hamradio programmes. :-)
Spread the news, thanks
73 Danilo S50U sys S50CLX DXCluster
p.s. The information is also published on the Radioklub Cerkno S50E website https://s50e.si/pota-sota-dxcluster/
Is there a way I can send each QSO automatically to an SQL database?
I want to create my own local SQL database and run some stats for my club contest. Also I want to learn more about SQL, this would be a good way. I'd only want to send date,time on, mode,band,P150C,locator
I guess. I used to run the English Castle Awards (WCA) database for all the UK hunters so I had manual log uploads working. That scheme closed but it got me interested to see if I could generate my club monthly contest stats automatically. As now I export to excel then manually(with a few macros) sort the data.
Hello,
I am sorry, but version 777 does not work for me - CAT is faulty, does not read radio, does not control radio (Omnirig and FT991A or IC-7100). Installed back 776 and all is OK.
73 Josef OK2WO
Fixed in build 778!
I can confirm - build 778 works well! Thanks and 73 Josef OK2WO
- - - Updated - - -
A little problem: Autocq does not repeated. The same from macro [AUTOCQ] as from Alt+R. Button CQ is red, delay is 5 sec. What is wrong? Josef OK2WO
Here -
Вложение 370121
change RX/TX? AutoCQ is not work if log not receive RX/TX signals for TRX.
Since v777:
- Network error : messageclient exeption UDP server 127.0.0.1: 2237
- Drop.Win32.ScoreSelfDel.915434 inside the exe (F-secure), not before V777
73, Thierry.
Thank you for the help. Now worked with FT991A. I have to set RTS handshake ON in Omnirig and radio. 73 GL Josef OK2WO
Hi Alexei.
An error message is displayed when LogHX (builds 777 or 778) is used with JTDX v2.2.160-rc3 in ‘JT/FT-modes active calls’. The message ‘Network error: MessageClient exception: Invalid message format UDP server 244.0.01:2237’.
JT/FT-modes active calls' also does not work correctly with MSHV 276_rc2 (UDP Multicast 224.0.0.1 port 2237), but no error message is displayed.
I've reverted to the previous version 776.
I hope this information can help you debug the new build.
Thank you for your tireless work with the LogHX.
73 of py5ej,
Pavanatti.
AutoCQ works with FT991, not with FT991 DATA... 73 OK2WO
Does anyone use their rotator at all with this software? I cannot get mine to goto a heading when the callsign is entered. It just goes to North no matter the contact.
I try again to download and install the 778 version. No virus inside: everything is working. No more error in the tcp tansmission.
@M0CGF I'm using PstRotator and it works!
Can you share PSTROTATOR settings please.
I found my calibration was wrong, recalibrated and it worked but I want the USB COM connection to PSTrotator then I need a connection via TCP,IP,UDP or which ever works to LogHX. Right now I can work either programme standalone but not both, I like to see the direction of the antenna in pst.
Ah I got it working now!!
By default, I use "N" in the PrintQueue field.
With version 779 of 05/08/2025, if I manually save a QSO, everything works correctly.
However, if I connect WSJT-X and the QSO in FT8 is automatically saved, the PrintQueue field is not saved
and the field in the log, remains empty.
Вложение 372608
ik2xde@gmail.com
This problem is present in versions 777-778-779, in the old version 776 everything works correctly.
When I close the log and exit permanently, version 779 doesn't seem to close SpotMachineServer.exe and CWServerHX.exe properly.
I have to close them manually from Task Manager.
73 de IK2XDE Andrea.
I try with v 779 dated 05-08-2025 (not today release)
Problem also with 777-778
Now I use version 776 without problem.
With version 779 dated 05-08-2025
Thanks.
Now I try
v 779 dated 14/08
v 780 dated 19/08 (test version)
problem persist.
When WSJT-X save qso , LOGHX save qso with PRINTQUEUE field "EMPTY"
Not save "N" that I put in the "QSO ENTRY" windows.
All ok with version 776
Thanks in advance.
Yes Andrea! Today I found problem! Pse QRX! I will fix the problem as soon as possible.
Fixed, please try:
http://rx4hx.qrz.ru/files/loghx/test..._build_780.exe
Unfortunately, even with this version the problem persists.
It also does not save other fields from qrz.com lije Name, qth, mail..ecc...
73 de IK2XDE Andrea
In practice, it doesn't take into account what's displayed in the QSO entry window,
it doesn't save data from QRZ Name, locator, QTH, mail, etc., and it doesn't save the PrintQueue field.
It only saves data from wsjt-x
Here
https://forum.qrz.ru/355-loghx-appar...ml#post2107085
is same problem as you problem. And today's 780 version has solved it.
Hello Andrea!
Try this test version:
Version at 25 august.
Hi, thanks for your attention.
You probably have the solution right in front of you, but you can't see it...hey...
Let's start with something that's certain: version 776 works correctly.
So you need to look at what you changed afterward; the problem persists from 777 to 780.
I use WSJT-X as always and obviously haven't changed any configurations (which I checked, however).
When the callsign of the correspondent is in the call field of wsjt-x,
the callsign field in the "log entry" window is filled with the same callsign.
Loghx searches for the data on qrz.com and completes the other fields.
Then I put "N" in the Print Queue field because I don't want a QSL (QSL NOT NEED).
Here's where it ends: when WSJT-X saves the QSO, LogHX also saves the QSO,
but without the pre-populated qrz.com fields and also leaves the PrintQueue field blank, where I manually entered the "N."
Check carefully: the solution is in version 776, which works correctly.
Thanks in advance for your efforts in finding the solution.
Try this version -
at 27.08.2025
Что то не пойму что делаю не так, прошу помощи гуру, задача из журнала выбрать связи в FT8, FT4 и все это сохранить в adif. Что делал, в журнале выбрал фильтр-установить фильтр Вложение 373109 , настроил дату старта и окончания, настроил мод и диапазоны, выбрал все континенты, тыкаю установить фильтр, по идее в журнале должны все связи выделится, но я не вижу выделения как при выделении клавишей пробел, где покопать??
It was difficult, but I did it!)))
Now all is Ok!
OK , Now I test v 780 date 28/08/2025 - 15.50
all fields was saved correctly......thanks....!!
But we have another problem
Вложение 373151
Duble Error on start, v 780 28/08 15.50
Вложение 373152Вложение 373153
