Страница 23 из 68 ПерваяПервая ... 1316171819202122232425262728293033 ... ПоследняяПоследняя
Показано с 331 по 345 из 1017
Like Tree167Спасибо
Тема: LogHX: English version
  1. #331
    03.01.2021
    196
    18
    Now you can use different port for CW and PTT
    Thanks, now with buil 645 work great.....PTT and CW on different port.......thanks....!!
    Alse add ADIF fields for export QSO to LoTW, eQSL, Clublog
    Sorry, with buil 645 I NOT found DXCC field in the clublog/eqsl/hrdlog adif file.
    SORRY THIS MOD NOT WORK
    << NEW >>
    Now orange band button change band correctly in the bandmap.....thanks....!!
    << NEW >>
    The VOICE WINDOWS not resize the button key (NOT ENLARGE the button)
    Thanks.
    73 de IK2XDE Andrea.
  2. #332
    03.02.2006
    20,625
    10150
    5452
    Thank you very much Andrea!
    Your comments are very helpful in working on log!
    I'll fix it soon!
  3. #333
    03.02.2006
    20,625
    10150
    5452
    Done:
    https://forum.qrz.ru/355-loghx-appar...ml#post1808106
  4. #334
    03.01.2021
    196
    18
    Yes.....with build 647 VOICE WINDOWS resize button key....now work fine.
    With build 647 I NOT find DXCC adif field in the clublog upload file, please remember to do this.
    Please remember also my post N. 329 about Telnet cluster.
    I noticed that in the telnet window, many lines are cut / deleted especially
    at the beginning of the connection, all the lines sent by the cluster are not displayed.
    In my opinion this is a mistake, often in that part there are important warnings for users,
    or instructions for use, for filters, for skimmers or other.
    Thanks for your good job.
  5. #335
    03.01.2021
    196
    18
    About EQSL image.
    I just download from eqsl all my 65000 qsl image,
    all image are stored in a directory, C:\Users\LOG\Pictures\IK2XDE-EQSL
    As you can see in the example, all immage,
    All qsl use this format file name: CALL_DATE_TIME_BAND_MODE.png
    I try to import a single file image in the PHOTO field of the log, and all work fine,
    but, import manualy 65000 file take a long time.
    Can you please add and automatic integration of the file....??
    For example, if I push show photo (on selected qso)
    automatic verify if file exist in the declared directory, and show it.
    No importing all immage, no importing link or other, only verifiy the file ...and if exist show it.
    Thanks for your attention,
    I hope this change is possible....!!
  6. #336
    03.02.2006
    20,625
    10150
    5452
    From the third time - it will be!
    Yes! I found mistake! Not all strings showed! Will be fixed!
  7. #337
    03.02.2006
    20,625
    10150
    5452
    Try now:
    https://forum.qrz.ru/355-loghx-appar...ml#post1808561
  8. #338
    03.01.2021
    196
    18
    Well, thanks you for your work.
    - With build 648 in the cluster telnet windows, all the string are showed, all seem to work correct now....thanks...!!
    - With build 648 in the cluglog adif, was added DXCC adif field, well....tested, and all work fine.......thanks...!!
    - With build 648 we have now a problem with separete COM configuratio of PTT and CW
    with buil 647 work great, but now if i setup a different port, CW work on the same port of PTT.
    I think you will have to verify something here....!!
    Thanks for your effort.
  9. #339
    03.02.2006
    20,625
    10150
    5452
    Please, printscreen of CAT setup 647 version.
  10. #340
    03.01.2021
    196
    18
    Made some other test,
    with build 648 .....PTT/CW separate COM port work fine.....!!
    This is my config "RADIO 1" SETUP ( 2 x IC-7600 )
    IC-7600 N.1
    PTT for Voice Key on COM7
    MMVARI for AFSK digi like PSK31/63 on COM3
    IC-7600 N.2
    CW for CW KEY on COM5
    MMTTY for FSK RTTY with EXTFSK64 on COM4
    SunSDR2DX
    On "Radio 2" I have setup TCI with SunSDR2DX
    no problem with TCI....no problem with SDC.....!!
    73 de IK2XDE Andrea
  11. #341
    03.01.2021
    196
    18
    With build 649
    there is a small problem with the CW macro window.
    When I press "TUNE" there is no way to stop the transmission,
    if I press "ESC" it doesn't work, I have to send a macro and then it stops.
    Before (buil 647) it was turned off by pressing "ESC" or again press "TUNE"
    Thanks.
    Последний раз редактировалось IK2XDE; 09.06.2021 в 22:50.
    IK2XDE Andrea - WWLoc. JN45MQ
    https://www.xdenews.net/ik2xde/logonline/
    RADIO Setup (update 30/08/2025)
    ICOM IC-7600 - (HF - 50MHz.)
    SunSDR2DX - (HF - 50MHz. - 144 MHz.)
    OM Power - OM2000A+ (1.8-50 MHz. Amplifier)
    OB11-3 (11 element - 3 band - 10m-15m-20m)
    OB9-3 WARC (9 element - 3 band - 12m-17m-30m)
    SkyWire Loop (40-60-80-160 m.)
    LogHX Managers Database (update for free)
    https://www.xdenews.net/managers/
  12. #342
    03.02.2006
    20,625
    10150
    5452
    "TUNE"
    Try this version:
    http://rx4hx.qrz.ru/files/loghx/prer..._build_650.exe
    Is now ok?
  13. #343
    03.01.2021
    196
    18
    YES.....!!
    from my side, i have done some tests,
    and everything seems to work correctly now.
    73 de IK2XDE Andrea
  14. #344
    03.02.2006
    20,625
    10150
    5452
    Andrea!
    Test also this version:
    http://rx4hx.qrz.ru/files/loghx/test..._build_651.exe
    Is Ok?
  15. #345
    03.01.2021
    196
    18
    Andrea!
    Is Ok?
    With this version (build 651)
    RADIO1
    HXCAT with IC-7600 work fine... !!
    Separate COM port.....work fine...!!
    PTT on COM 7....work fine....!!
    CW on COM 5.....work fine....!!
    CW macros.....work fine....!!
    Voice key switch radio in tx (PTT) and play the selected file......work fine....!!
    RADIO2
    TCI with SunSDR2dx
    CAT via TCI work fne....!!
    CW macro via TCI work fine.....!!
    .....but....
    Voice key with TCI.....NOT WORK...... (TCI does not switch the radio in TX)
    All others like cluster, statistic, award, ecc.... seems to work fine.
    Последний раз редактировалось IK2XDE; 13.06.2021 в 00:52.
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
