Страница 25 из 68 ПерваяПервая ... 1518192021222324252627282930313235 ... ПоследняяПоследняя
Показано с 361 по 375 из 1017
Like Tree167Спасибо
Тема: LogHX: English version
  1. #361
    03.01.2021
    196
    18
    I use eQSL Show by IZ0ROQ
    You can find it here: https://www.iz0roq.com/i-miei-programmi/
    Others info about file format in my msg #335
    We need HRDLOGS to know if qso was upload to hrdlog server.
    For HRDLOGR i do not know if we can download an adif with all confirmed qso like eqsl or clublog.
    73 de IK2XDE Andrea
    IK2XDE Andrea - WWLoc. JN45MQ
    https://www.xdenews.net/ik2xde/logonline/
    RADIO Setup (update 30/08/2025)
    ICOM IC-7600 - (HF - 50MHz.)
    SunSDR2DX - (HF - 50MHz. - 144 MHz.)
    OM Power - OM2000A+ (1.8-50 MHz. Amplifier)
    OB11-3 (11 element - 3 band - 10m-15m-20m)
    OB9-3 WARC (9 element - 3 band - 12m-17m-30m)
    SkyWire Loop (40-60-80-160 m.)
    LogHX Managers Database (update for free)
    https://www.xdenews.net/managers/
  2. #362
    03.02.2006
    20,753
    10225
    5491
    Цитата Сообщение от IK2XDE Посмотреть сообщение
    HRDLOGS
    About field for HRDLog - I don't want to make a field specifically for HRDLog. I will do User11...User20 boolen fields for use with any online logs.
    Well, about file format: do you want show self image for each QSO?
  3. #363
    03.01.2021
    196
    18
    Yes....thanks.
  4. #364
    25.03.2020
    30
    3
    20
    Hi Alexei,
    I am using LogHX (build 660) with JTDX and Gridtracker.
    To keep control over Gridtracker (memory/prosessor usage) i have Gridtracker on a Rasperry PI on the same LAN as my shack PC. As the UDP forward function in LogHX (setup for external programs) does not allow portforwarding to another PC (am i wrong?), I have enabled multicast in JTDX. UDP packets from JTDX are now received by Gridtracker on the Raspberry pi, and forwarded by Gridtracker to the listening port on LogHX on shack PC. This works Ok, but it is a one way stream that does not allow any action to JTDX coming from LogHX.
    Is it a big task for you to expand the UDP forward function in LogHX "setup for external programs" to allow portforwarding to another pc/ip-adress (or to expand LogHX to send and receive UDP using Multicast)?
    73 de LB2EG Richard
  5. #365
    03.02.2006
    20,753
    10225
    5491
    Ok! Not problem! It's will be done in new version.
  6. #366
    Low Power
    19.11.2019
    Nyirabrany
    11
    43
    RDA synchronization
    Hello Alexei,
    Are you planning to built in any kind of RDA synchronization (or just check/uncheck fields), as like LoTW, eQSL, Clublog, etc? I can't control what I uploaded and downloaded as worked/confirmed QSO/QSL.
    Thank you,
    73 Egon
  7. #367
    03.02.2006
    20,753
    10225
    5491
    Цитата Сообщение от HA3MN Посмотреть сообщение
    RDA synchronization
    I don't know any server, wich log can make synchronization by RDA.
    May be Hamlog.online, when it will be ready for synchronization...
  8. #368
    03.02.2006
    20,753
    10225
    5491
    ip-adress
    Done:
    https://forum.qrz.ru/355-loghx-appar...ml#post1824035
  9. #369
  10. #370
    03.02.2006
    20,753
    10225
    5491
    not work
    Correct - check settings for rebroadcast and try again:
    http://rx4hx.qrz.ru/files/loghx/prer..._build_662.exe
  11. #371
    Low Power
    19.11.2019
    Nyirabrany
    11
    43
    Alexei,
    I would be great if you would prepare just two fields into database for future use, like for LoTW, eQSL, etc. I would use it for "hand" synchronisation with any source from Hamlog, mydx.eu, cfmrda. I have confirmed QSOs now only from the LoTW in my log, which is just less than half of my confirmed QSOs. And in the future, when will be any server, LogHX can "continue" the synchronisation.
    73 Egon
  12. #372
    25.03.2020
    30
    3
    20
    Now it works!. Thank you!
    73 de LB2EG Richard
  13. #373
    03.02.2006
    20,753
    10225
    5491
    Yes, it's will be done! I plan to add 10 boolean fields User11-20 for future use.
    Hamlog
    Hope that auto synchronization with Hamlog (like with LoTW or eQSL) will be soon!
  14. #374
    Low Power
    19.11.2019
    Nyirabrany
    11
    43
    Alexei,
    Thank you for answer!
    Just an idea: Put a "Last" button in the Log window, beside of "Unselect" and "Find", please!
    When I working in the log, hard/slow to go to the last QSO's rekord!
    Thank you again, 73 Egon
  15. #375
    03.02.2006
    20,753
    10225
    5491
    "Last" button
    It's not problem, but why do you not use keys "Home"-"End" for go to first-last QSO?
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
