02.05.2021, 21:26 #316Координатор темы
- 03.02.2006
- 53
- 20,616
- 10148
- 5452
First about CatHX INI-Files:
CatHX use INI-files from OmniRig - you can copy to /Rigs folder INI-file from OmniRig.
Second - about IC-705: you can self create INI-file for 705, if you have documentation for CAT of 705. Or send to me documentation for 705, and I'll make INI-file.
Yes Andrea, You're right! I'll fix it.73 de RX4HX, Alexei, http://rx4hx.qrz.ru
Ant.: UW4HW, Pwr.: ~500 Wtts
03.05.2021, 09:04 #317Low Power
- 02.05.2021
- 53
- 6
Alexei,
First about CatHX INI-Files: Thanks for the advise. I did it and more than 130 files was updated and added on release 634 and my problem solved
Second - about IC-705: The INI-file for IC-705 is included in this last Omnirig INI-file Updated 2021-04-15. It could be a good idea to update rigs in your release of your GREAT software
Thanks very much for your help and your work
73s Christian F8GHE
04.05.2021, 00:45 #318Standart Power
- 03.01.2021
- 196
- 18
In the adif file sent to clublog, the DXCC field is missing.
This field is not mandatory, but it is essential to avoid reporting errors in the log,
especially for ambiguous calls for example with special calls like GB5xxx
which have various exceptions for ENGLAND-SCOTLAND and WALES ..... just for example.
I think it is appropriate to put this field in the file to be uploaded to Clublog, Eqsl and Lotw.
Thanks.
73 de IK2XDE Andrea
05.05.2021, 15:27 #319Координатор темы
- 03.02.2006
- 53
- 20,616
- 10148
- 5452
Problem with folders fixed - please check:
https://forum.qrz.ru/355-loghx-appar...ml#post1801176
Fixed also.73 de RX4HX, Alexei, http://rx4hx.qrz.ru
14.05.2021, 20:37 #320Standart Power
- 03.01.2021
- 196
- 18
This problem persists even with the latest version 641.
The yellow background does not follow the band, as does the bold lettering.
The cat and the band map work correctly both
with CATHX than with TCI without problems.
Thanks.
73 de IK2XDE Andrea.
Surely other colleagues will appreciate this possibility
Also ... for example.... in N1MM +,
I can configure CW on one port and PTT on another different port.
Thanks.
73 de IK2XDE Andrea.Последний раз редактировалось IK2XDE; 14.05.2021 в 20:27.
14.05.2021, 22:33 #321Координатор темы
- 03.02.2006
- 53
- 20,616
- 10148
- 5452
14.05.2021, 23:03 #322Standart Power
- 03.01.2021
- 196
- 18
The problem occurs on any band, both with CATHX and IC-7600 and with TCI and SUNSDR2Dx.
When I change bands, the yellow button stays on the initial band,
but the bold text follows the cat correctly, the bandmap also changes bands correctly.
The problem is only the yellow background color.
Thanks.
16.05.2021, 00:00 #323Координатор темы
- 03.02.2006
- 53
- 20,616
- 10148
- 5452
17.05.2021, 22:59 #324Standart Power
- 03.01.2021
- 196
- 18
Try also with build 644,
of course same problem.
Test with clublog, without DXCC field, a lot of ambiguous calls like GB5xxx
create an error report because the country is not recognized.
(This call was used for England-Scotland-Wales)
Test also send adif to HRDLOG without DXCC field,
qso added to log without flag, because country was not recognized.
Please fix this (add DXCC field in the adif)
Thanks.
73 de IK2XDE Andrea
ONLY FOR REPORT.
In the build 644 yellow background now is orange,
yes follow the band with cat, but not delete (clear) previus band.
I think you will work again on it.
Thanks.
18.05.2021, 11:39 #325Координатор темы
- 03.02.2006
- 53
- 20,616
- 10148
- 5452
18.05.2021, 12:59 #326Standart Power
- 03.01.2021
- 196
- 18
But in my log was registered correct.
Thanks.
19.05.2021, 09:33 #327Standart Power
- 03.01.2021
- 196
- 18
https://clublog.freshdesk.com/suppor...-club-log-use-
Here is a list of the ADIF fields Club Log uses:
QSO_DATE
TIME_ON
TIME_OFF (this is stored independently and used for log matching as well as ADIF exports)
QSLRDATE
QSLSDATE
CALL
OPERATOR
MODE
BAND
BAND_RX
FREQ
QSL_RCVD
LOTW_QSL_RCVD
QSL_SENT
DXCC
PROP_MODE
CREDIT_GRANTED
RST_SENT
RST_RCVD
NOTES
GRIDSQUARE [note that this is only set if the Club Log user sets a locator on Settings > Locators, and it is not stored per QSO]
How does Club Log determine DXCC status?
Identifying DXCC entities correctly is an important feature of Club Log, so let's take a moment to explain the philosophy.
Club Log primarily uses details of allocated prefixes dating back to 1945 to map callsigns in uploaded logs to the corresponding DXCC entities. Maintaining the prefix data, plus a number of changes and known exceptions within defined date ranges, is a painstaking task undertaken voluntarily by Alan, 5B4AHJ.
If you upload an ADIF log that claims a particular DXCC entity for a QSO (in the ADIF COUNTRY or DXCC field) but Club Log maps the call to a different entity, an error will be generated when the log is imported into the database. Other problems, such as unknown prefixes, also generate errors. At the end of the log import process, an error report will be emailed to you and copied to Alan.
It is not unusual to discover from the Club Log error reports that you have worked new countries or filled additional band-slots, and most of us find it immensely satisfying to know that our logs and DXCC records are accurate. We hope that you will go through any error reports you receive, fixing busted calls and obvious country errors in your log and then re-upload your corrected log to Club Log.Последний раз редактировалось IK2XDE; 19.05.2021 в 09:37.
19.05.2021, 22:21 #328Координатор темы
- 03.02.2006
- 53
- 20,616
- 10148
- 5452
21.05.2021, 20:44 #329Standart Power
- 03.01.2021
- 196
- 18
I am using build 644 with satisfaction,
surely there are still some things to improve, in my opinion, but we are getting closer .... hi ...
My tests this week focused on the cluster.
The cluster I use is: ik2xde.ddns.net:8000
To check the differences I used PUTTY for the telnet connection.
For example, I noticed that in the telnet window, many lines are cut / deleted especially
at the beginning of the connection, all the lines sent by the cluster are not displayed.
In my opinion this is a mistake, often in that part there are important warnings for users,
or instructions for use, for filters, for skimmers or other.
In my opinion all lines should be displayed.
For example, if I send the SH/U command (to view the users connected to the cluster),
only the first line is shown, the others are cut off.
- The ALARMS window, once the call to be monitored has been set,
show only the latest spots, one line only for each mode or band.
In my opinion it would be better to see all the spots of that call,
to have a better situation.
Or in any case being able to choose whether to see only one line, or all.
- Favorite Spots.
This function is not clear to me, I did not understand what it is for, and how it can be configured.
Thanks for your attention, I hope that my observations will help everyone to improve this software.
28.05.2021, 09:35 #330Координатор темы
- 03.02.2006
- 53
- 20,616
- 10148
- 5452
Now you can use different port for CW and PTT:
https://forum.qrz.ru/355-loghx-appar...ml#post1806384
Alse add ADIF fields for export QSO to LoTW, eQSL, Clublog
167Спасибо
