Страница 32 из 68 ПерваяПервая ... 2225262728293031323334353637383942 ... ПоследняяПоследняя
Показано с 466 по 480 из 1017
Like Tree167Спасибо
Тема: LogHX: English version
  1. #466
    High Power Аватар для UI4F
    26.04.2016
    539
    200
    518
    У меня hamalert работает только если в ручную логин и пароль вводить
  2. #467
    Low Power
    02.05.2021
    6
    How get freq LogHX?
    Pse print screen of Radio setup in log.
    How get freq LogHX => Good question, and I don't know exactly but for me (Not sure) it is the same way that WSJT-X . It work perfectly with WSJT-X but with FLDIGI frequencey must be modify slowly. I tried to increased VSP speed from 19200 to 38400 and it is the same.
    Here is the setup
    73s Christian F8GHE
  3. #468
    Low Power
    19.11.2019
    Nyirabrany
    11
    43
    b692:
    Такая же ситуация
    Same situation.
    Hamalert works fine ONLY in Telnet1.
    Telnet2, Telnet2 ONLY manually, without Scripts. (EMPTY Scripts)
    I'm back to b688. It is perfect in Telnets.
  4. #469
    03.02.2006
    20,616
    10148
    5452
    How about version 693? Is problem fixed?
  5. #470
    Low Power
    19.11.2019
    Nyirabrany
    11
    43
    b693 = b692 on Telnets.
  6. #471
    Low Power
    19.11.2019
    Nyirabrany
    11
    43
    b694 = b693 = b692 on Telnets.
    Telnet1: All OK! dx.hu/9000, hamalert.org/7300, 127.0.0.1/7373 works fine WITH scripts.
    Telnet2: With scripts do nothing. Without scripts (empty scripts) I can login manually.
    Telnet3: same as Telnet2
  7. #472
    Low Power
    19.11.2019
    Nyirabrany
    11
    43
    b695 on Telnets is same as before.
  8. #473
    03.02.2006
    20,616
    10148
    5452
    Telnets
    Fixed:
    https://forum.qrz.ru/355-loghx-appar...ml#post1888344
  9. #474
    Low Power
    19.11.2019
    Nyirabrany
    11
    43
    Fixed:
    Alexei,
    Thank you!
    b696 is OK.
    Telnet windows are perfect.
    PS: You did not say anything about "Copy" button in "QSO manually entry/edit" window. Is it possible? TU!
  10. #475
    03.02.2006
    20,616
    10148
    5452
    It's not problem. This is the first time I have received such an offer. Ok, it will be done!
  11. #476
    Low Power
    02.05.2021
    6
    Hi Alexei, Have you looked to code a macro or other method able of adjusting the CW speed to that of a CW spot from a cluster ? Another setting could be a default CW speed.
    73s Christian F8GHE
    - - - Updated - - -
    Alexei,
    Thank you!
    b696 is OK.
    Hello, for me there is an issue with the Telnet1 Script with these error messages 1 and 2Нажмите на изображение для увеличения.
  12. #477
    03.02.2006
    20,616
    10148
    5452
    Delete file <Log folder>\DATA\TelnetScripts.hx
    and run log. Now will be Ok!
    I remember this request. But there's a lot to do. I haven't done it yet. But there are plans.
  13. #478
    Low Power
    19.11.2019
    Nyirabrany
    11
    43
    Alexei,
    Thank you in advance!
    It is would be very useful when a /P or /M station works from 2-3-4 rayons (RDAs).
    No any option to logging all RDA at once, must be line by line for correct info in Award window.
    I would just click on the "Copy" button and reedit just the next RDA in State/Country fields.
    The "Insert" button is helps a bit but missing datas.
    PS: Telnets are OK, thank you for your effort!
    At me Telnet1, Telnet2 with script(s), Telnet3 without script(s).
  14. #479
    Low Power
    02.05.2021
    6
    Yes, Now it works perfectly !
    LogHx is an amazing project with no limits and no end
  15. #480
    Low Power
    19.11.2019
    Nyirabrany
    11
    43
    Alexei,
    Is it possibele when I logging a QSO with split, then logging the RX frequency not the TX frequency?
    For me, more important to see/know/remember where I HEARD the other station.
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
