14.09.2022, 15:46 #526Low Power
- 02.05.2021
- 53
- 6
Hi Alexei,
As you are working on CW, I hope you remember my request
It was about a way (Macro or button, ..?) to set the CW speed identical as our contact .
73s and have a nice day
Christian F8GHE
18.09.2022, 02:35 #527Low Power
- 16.04.2020
- 89
I have just installed the ERC rotator control in my yaesu 450DC. All works using the Easy rotor control software. Com 6, Yaesu GS232A 9600,. I have tried using the Yaesu option and the universalcom port in Loghx and tick auto rotation to spot, but nothing turn when using HX. It certainly opens COM6 as when I try to open ERC while I have HX openwith a rotor connected it says COM6 in use. So I am not sure what is missing?
18.09.2022, 11:07 #528Координатор темы
- 03.02.2006
- 53
- 20,753
- 10225
- 5491
Ant.: UW4HW, Pwr.: ~500 Wtts
19.09.2022, 00:03 #529Low Power
- 16.04.2020
- 89
19.09.2022, 01:06 #530Low Power
- 16.04.2020
- 89
22.09.2022, 23:47 #531Low Power
- 16.04.2020
- 89
; Created at 22/09/2022 19:10:30
[RotorSetup]
AutoRotation=True
BaudRate=5
ByteSize=3
COMPort=COM6
COMPort_Command=
Correction=0
DTRControl=False
Parity=0
RTSControl=False
RotorType=1
StopBits=0
01.10.2022, 08:48 #532Координатор темы
- 03.02.2006
- 53
- 20,753
- 10225
- 5491
To M0CGF:
I remember about you problem, pse QRX! I will deal with your problem in the very near future.73 de RX4HX, Alexei, http://rx4hx.qrz.ru
04.10.2022, 10:38 #533Координатор темы
- 03.02.2006
- 53
- 20,753
- 10225
- 5491
Try this version:
http://rx4hx.qrz.ru/files/loghx/prer..._build_705.exe
Check "Auto rotation to spot" or click here:
04.10.2022, 14:12 #534Low Power
- 16.04.2020
- 89
06.10.2022, 10:51 #535Low Power
- 16.04.2020
- 89
deleted
Последний раз редактировалось M0CGF; 06.10.2022 в 10:56.
06.10.2022, 12:23 #536Координатор темы
- 03.02.2006
- 53
- 20,753
- 10225
- 5491
06.10.2022, 15:07 #537Low Power
- 16.04.2020
- 89
Hi Alexei
I had the ERC guy remote into my set up today to check a few things, he found the following, I made the change to 14400 and it works OK.
"I tested the rotor function in LogHX.
The command-syntax for GS232 is correct but I found the bug in LogHX: The Baudrate chosen in SETUP – ROTOR SETUP is wrong.
If you choose 9600 Baud the real Baudrate is 4800
If you choose 14400 Baud the real Baudrate is 9600
If you choose 19200 Baud the real Baudrate is 14400"
08.10.2022, 12:49 #538Low Power
- 02.05.2021
- 53
- 6
Hi Alexei,
Do you think that it could be possible to add MULTIPSK from F6CTE (index) as an LogHX external program ?
73s Christian F8GHE
19.10.2022, 13:42 #539Координатор темы
- 03.02.2006
- 53
- 20,753
- 10225
- 5491
Thank you for help! Yes, problem is here - fixed. Try now:
http://rx4hx.qrz.ru/files/loghx/prer..._build_706.exe
I can't promise that it will be fast. But I will try to do it.73 de RX4HX, Alexei, http://rx4hx.qrz.ru
26.10.2022, 01:27 #540Low Power
- 02.05.2021
- 53
- 6
167Спасибо
