Hi Alexei,
As you are working on CW, I hope you remember my request :s7:
It was about a way (Macro or button, ..?) to set the CW speed identical as our contact .
73s and have a nice day
Christian F8GHE
Hi Alexei,
Christian F8GHE
I have just installed the ERC rotator control in my yaesu 450DC. All works using the Easy rotor control software. Com 6, Yaesu GS232A 9600,. I have tried using the Yaesu option and the universalcom port in Loghx and tick auto rotation to spot, but nothing turn when using HX. It certainly opens COM6 as when I try to open ERC while I have HX openwith a rotor connected it says COM6 in use. So I am not sure what is missing?
Вложение 328627
Вложение 328628
Doesn't work either way if I click the auto to spot
Вложение 328629
Logger32 it works with these settings
; Created at 22/09/2022 19:10:30
[RotorSetup]
AutoRotation=True
BaudRate=5
ByteSize=3
COMPort=COM6
COMPort_Command=
Correction=0
DTRControl=False
Parity=0
RTSControl=False
RotorType=1
StopBits=0
To M0CGF:
I remember about you problem, pse QRX! I will deal with your problem in the very near future.
Try this version:
http://rx4hx.qrz.ru/files/loghx/prer..._build_705.exe
Check "Auto rotation to spot" or click here:
Вложение 329092
deleted
Hi Alexei
I had the ERC guy remote into my set up today to check a few things, he found the following, I made the change to 14400 and it works OK.
"I tested the rotor function in LogHX.
The command-syntax for GS232 is correct but I found the bug in LogHX: The Baudrate chosen in SETUP – ROTOR SETUP is wrong.
If you choose 9600 Baud the real Baudrate is 4800
If you choose 14400 Baud the real Baudrate is 9600
If you choose 19200 Baud the real Baudrate is 14400"
Hi Alexei,
Do you think that it could be possible to add MULTIPSK from F6CTE (index) as an LogHX external program ?
73s Christian F8GHE
Thank you for help! Yes, problem is here - fixed. Try now:
http://rx4hx.qrz.ru/files/loghx/prer..._build_706.exe
I can't promise that it will be fast. But I will try to do it.
Hi,
Who can explain to me how FLDIGI communicates with LogHX?
Here is the diagram of my system
73s Christian F8GHE
Вложение 330196
