Yes, it's wrong! I'll check this!
Hello Josef!
What to do:
- run only LogHX and select as CAT - CatHX. Setup CAT for you Trx. Set "PTT via CAT"
- Menu Setup->Test CAT window.
- CW window -> press RX/TX button for TX, wait 3 sec and press RX/TX button for RX.
- close Test CAT window. When window coluses, will be created txt-file with command from TRX.
Save this file and sen to me. Tnx!
All are arranged by you, but the TX switch on CW windows works for a very short time only. I tried the TUNE switch ON / 3 sec / OFF, file is here: Вложение 335649
Hi Alexei, Do you plan to add this Hotkey Ctrl+ESC (or Ctrl+Alt+ESC) in your next build720 ?
(I would like to validate it with the EA4TX ARS-USB of my old friend because for his simplification I prefer not to installed PstRotator for him. With one less software, it will be easier for him :s7:)
73s Christian F8GHE
Unckeck here -
Вложение 335664
But now it 's enough -
all is Ok!
Question - when you Trx set to TX, LogHX show freq from Trx?
Yes, everything is ready for this.
New file here with RX/TX working ((renamed to .txt):Вложение 335673
Frequency indicator is OK if TX (all digits).
73 Josef
I found problem - please, test this version:
http://rx4hx.qrz.ru/files/loghx/test..._build_720.exe
The build tested - CW via hamlib works OK. There are some limitations (IC-7100 specific):
- it can send up to 29 chars only (incl. spaces)
- speed and CW chars settings must be controlled in radio
AutoCQ in LogHX works OK.
Anyway, the best solution for IC-7100 CW is to use the additional USB port with USB/RS232 convertor.
Thank you Alex for your perfect work. 73 GL Josef
Hi,
Here is a small Howto to setup LogHX with a rotor controler ARS-USB from EA4TX with and without PstRotatorAz. It wrote in French but if you think that coukd be usefull for community, I can translate it in English.
73s Christian F8GHE
Hello,
I just installed LogHX 7.19 on a new PC with Win11 and I'm not able to modify the font size of the "setup menu", the icons and the clock size. My font size is so small, that I can't read menu :s9: After multiples tests, I don't know if it is a Window11 or a LogHX parameter.
Who can help me ?
Вложение 336637
73s Christian F8GHE
For change clock size - replace files in folder Skins\Default\0.jpg...9.jpg and R.jpg to another. You can find these files on the internet.
The rest cannot be changed yet.
Thanks very much Alexei.
Ok for the clock size and about the unchangeable font size of the "General Setup" menu but here are some remarks about it:
- I never met this type of tiny font size with Win7 or Win10 and my friend F1DJY who use Win11 doesn't meet this type of problem.
- When I try to change the default font size of Win11, the font size of the "Genral Setup" menu always stays the same.
Questions:
- Is it the default font size of Win11 that used for this menu of LogHX or is it a setting in an .ini file?
- May be, I have to reset and create new .ini files ?
73s Christian F8GHE
Hello,
I find this little problem,
all CW spot from skimmer EA8/DF4UE-#
carry a letter C in the bandmap
I think it is due to the very long call.
If possible, check the alignment correction
Вложение 337090Вложение 337091
Thanks for your work
73 de IK2XDE Andrea
