Search in Google: fldigi xml-rpc
Example:
Fldigi Users Manual: Xmlrpc Control
Example:
Is it possible to listen an UDP broadcast with LogHX (For example QSOs broadcasted by DXLOG on the UDP port 12060 of the localhost) ?
I think that it should be possible with the Spot-machine but I'm not able to configure it :s9:
73s Christian F8GHE
I would like to know if it is possible to connect LogHX to the UDP Broadcast QSOs or SPOTs Output from DXLOG ?
DXLOG is able to Broadcast QSO or SPOTs to UDP. It is possible to select N1MM format for QSO.
I was able to connect this UDP output to Log4OM with the Inbound Communicator of Log4OM and I would like to do the same with LogHX.
Вложение 330425
It's here:
Вложение 330462
After setup DXLOG.NET for Broadcasting, it works with Log4OM but not with LogHX.
Maybe my LogHX setup is not correct ? I checked on TAB Broadcast data /Received (N1MM format) / Radio, Contact and Spots on port 12060 (Same as on your ScreenShot)
And now when I close LogHX, I received this UDP error message.
Вложение 330566
Here are my setup for DXLOG and LogHX
Вложение 330601
Вложение 330602
I progress very slowly like a cat :s7:
Now my "radio UDP" setup between LogHX and DXLOG is working :p-up:
But spot and contacts need more investigation
Here is the status of my UDP setup
- Radio is OK
- Contacts and Spot are KO
Вложение 330650
Here are print screens of DXLOG and LogHX
Вложение 330652
73s Christian F8GHE
Hello Christian!
Thank you so much for the very detailed information! I found the error and corrected it. Try this test version -
... deleted!
Re-setup ports for Broadcast!
Update: new release
https://forum.qrz.ru/355-loghx-appar...ml#post1912284
Alexei, the pleasure is mine. I really like LogHX and it's me who thanks you for all your work and the time spent for LogHX.
I'm sorry but it seems the same for me with the new build_707 except the disappearance of the UDP error :p-up:
After re-setup of UDP port 13063
=> Everything is OK with Radio (Same on previous version 706)
=> But Contacts and Spots from DXLOG not seen on LogHX (Same on previous version 706)
Please confirm that Contacts or Spots could be seen in the QSO-Entry window ?
73s Christian F8GHE
Setup of DXLOG and LogHX right? Look at print screen:
Now use one port for radio, spots and contacts!
After a good night everything is working :s10:
(Check setup and Restart DXLOG and LogHX)
Thanks very much and have a nice sunday !
73s Christian F8GHE
Вложение 330724
