Hello Alexey,
Any news about my message #387.......??
Thanks in advance.
Are these fields in the SW as I don't see where they are but they are in the adif from my tablet log
for example
<QSO_DATE:8:d>20211029<TIME_ON:4>1435<TIME_OFF:4>1436<CALL:6>YO6FNF<NA ME:5>David<RST_RCVD:2>59<RST_SENT:2>59<BAND:3>20m<FREQ:6>14.272<MODE:3 >SSB<SUBMODE:3>USB<MY_GRIDSQUARE:6>JO00dr<COMMENT:0><OPERATOR:7>M0CG F/M<STATION_CALLSIGN:7>M0CGF/M<MY_SIG:4>WWFF<MY_SIG_INFO:8>GFF-0018<SIG_INFO:9>yoff-0125<STX:2>15<eor>
Вложение 315157
For import from you tablet log WFF field, use this settings:
Вложение 315163
Pse QRX new version!
Hello,
I can't get it to work I have this message ORZ.COM.
My subscription for QRZ.COM is still ok until 03/04/2022.
73 Pat – ON3CQ
Вложение 315966
Hi,
I am using two instances of LogHX (678) to achieve independent operation of ESDR RX1 and RX2, enabling me to use JTDX on RX2 while chasing CW DX on RX1.
This setup works well, but with one annoyance. When klicking on spots in the ESDR panorama on RX1, it also changes the QRG on RX2 (et vice versa). This only happens when klicking on a spot in panorama. Changing from ESDR2 to ESDR3 does not matter.
I use the Net Setup in LogHX.
Вложение 317657
Anyone?
73 de LB2EG Richard
Need prinscreen setup of TCI in log. Here:
Вложение 317686
Do you use Radio 1 for ESDR RX1 and Radio 2 for ESDR RX2? I think problem is here.
Hi Alexei,
Yesterday i put the latest ESDR3 0.11.0 (v.28.12.21) in use with LogHX. Using the spot function LogHX populates ESDR3 panorama with spots as usual, but clicking on spots did not result in change of QRG or an entry in LogHX QSO window.
The same problem with SDC even in Linux.
Reporting this on EESDR Github bugtracker, the EE programmer closed the report as no EESDR bug, stating this was a LogHX or SDC problem. https://github.com/ExpertSDR3/Expert...KER/issues/189
Testing again today, clicking on the FIRST spot from either SDC or LOGHX changes the QRG, but not when clikcing on the subsequent spots.
73 de LB2EG Richard
- - - Updated - - -
EE programmer has reconsidered and accepted this as a ESDR3 bug...
73 de LB2EG Richard
anyone having issues uploading logs to EQSL and LOTW in 2022? I am getting No Match on eqsl_user/eqsl_pswd for date 20220102 00:01.
i checked my eqsl and the call is valid from march 2020 to 2035.
Ian
BANDMAP dont show all spot receiving from telnet.
Show only not worked call.
I forgot where is function to set/unset this.
Thanks
It's here:
Вложение 321684
P.S. I'm very sorry for not answer of you e-mail. Please wait - i'm work of manager base!
Alexei,
I recently started using LogHX together with the SunSDR2 DX and V3 0.12.1 via TCI.
He always takes my RX 1 TCI for my Log entry can I open a 2nd log entry for RX 2.
How can I have my RX2 tracked via TCI to also be able to log via RX2.
Is there is a way tu use double RX and double log entry.
73 Pat
Yes - it's here:
Вложение 322027
