Hello everyone,
Who can explain this setup ? I don't understand it :s9:
Вложение 324047
73s Christian F8GHE
Hello everyone,
Вложение 324047
73s Christian F8GHE
If you want get spots from WW DX cluster, you can self sets parsing for this ww-page or use two ww dx cluster (OH2AQ or DXSCAPE), parsing of which is already in the log:
Вложение 324103
For select OH2AQ or DXScape - double-click on red line.
Hi Alexei,
"parsing of which is already in the log:" : You mean that the parsing is applied on all new spots and also those that are already in the LogHX log ?
73s Christian F8GHE
- - - Updated - - -
Hi Alexei, now it's ok in LogHX V3.0 build 688. Thanks very much !
73s Christian F8GHE
- - - Updated - - -
Hello,
Here are 3 questions about Spot-Machine setup and 2 minor syntax errors :
1. What is the use of the Login suffix for the Telnet setup ?
2. How is the assignment of automatic login scripts 1 or 2 to each telnet sessions done ?
3. It seems that only adress IP 127.0.0.1 is recognized in the Localhost setup ? Not possible to set IP 192.168.xx.yy !
Вложение 324311
To connect to the same telnet-server from several logs use suffix. You will be connecting as F8GHE-1, F8GHE-2, etc.
You can't do that now. But this is the right remark. Will do.
It is possible to use IP 192.168.xx.yy. Is here problem?
Hello,
Is it possible to open a log screen for Radio 2 also.
73 Pat
Yes it seems not working with the local IP
Вложение 324441
Ask for a confirmation about Spot-Machine connection.
Do you want to mean Disconnect/Reconnect instead Connect/Reconnect ?
Вложение 324442
I would like to have these screens for radio 1 & 2 that you shouldn't switch.
Вложение 324467
73 Pat
Hi Alexei, we'll test that thanks for the info.
Hi Alexey,
after two years and 120000 qso, I still have some observations to make.
Of course, only for the purpose of improving this beautiful software for all users.
Only you can tell us if these improvements can be made and for that we thank you in advance.
UTILITIES -> STATISTICS -> BAND/MODE STATISTIC
In this statistic it would be nice to add the ability to analyze the complete log
or filter it by date (FULL LOG or From date -> To date)
I would like to see the same possibility in the award statistics, such as DXCC etc ....
Complete management of HRDlog field <HRDLOGS> and <HRDLOGR> fields currently not managed.
Some automatisms would be convenient in the manual entry window of the QSOs.
For example when I type the QSO start date, it should automatically change the end QSO date as well,
and the same thing for the QSO start and end time.
The same thing when I enter the RX frequency,
it should automatically propose the same TX frequency.
However, always leaving the possibility to modify them .... obviously
Last question, if I start the program with this command:
LOGHX3.EXE / D = IK2XDE
can I open a second instance of the software
LOGHX3.EXE / D = IK2XDF
And use two logs at the same time .... Multi Operators station.... ??
Of course with different radio....different CAT and CW COM PORT setup....MULTI TX??
As you know, we are two brothers.
In order not to be pointed out as the one who always asks and does nothing,
I remind you of my availability to help you manage, maintain and update the local file manager
and the cty.dat file, making them always available to all users.
Question on EQSL uploads, for this month I operate as MQ0CGF. I have set up EQSL and created a new log in LogHX. I cannot seem to get the MQ0 log to sync with EQSL. Anything I have missed in the set up?
