Have you changed eQSL data in LOG settings - callsign/QTH/password ?
Вложение 324699
each time you wanna get data from eQSL for certain of your callsigns, you have to change settings, then take data from service.
Вложение 324699
OK got it, does this information save between different logs, as I a ton of /p locations at EQSL and each has its own location and profile?
Hello,
I have a questions about the CreateBackup utility :
1. Is there a way to memorize the default destination folder. It's always C:/ and I would like to set D:/LogHX-backup/ ?
2. Is it possible to specify the destination folder from CLI ? I would like to schedule an automatic "Backup-Task" with the Windows Task scheduler ?
Вложение 324862
73 Christian F8GHE
Hello,
I would like to know if someone has already noticed a loss of synchronization of the frequency
between equipment and softwares of a setup like describe on the picture ?
This observation is only true when using FLDIGI by making rapid frequency changes.
I never observe this issue when using :
- WSJT-X
- FLDIGI with a slow variation of frequency (On IC-7300 or LogHX or Win4Icom or FLDIGI)
Note : The 7300.xml file for FLDIGI is the up2date version.Вложение 324961
73s Christian F8GHE
How get freq LogHX?
Pse print screen of Radio setup in log.
Hello Alexei,
Thank you for supporting us with new features!
I had a strange issue with LoTW download a long time ago. The "QSL QSO after"'s date is constant since 09.20.2021, I have to modify it at every LoTW downloding. See picture.
Вложение 324972
Build 689 :
I have problems with the new telnet section. b688 handle it perfectly but I realized malfunctions with the same setup in b689:
- Telnet1: I use dx.hu for Telnet1, it is not asking from me any password, just a login name. In b688 it is OK but b689 is inserting my password from the "Script for Telnet" window and it is causes an error, dx.hu says "Invalid command". It is not a big problem, just I noticed it for you.
- Telnet2: I use HamAlert. In b688 it is handle login/password from "Scripts for Telnet" window but b689 can not handle it just asking login and password again and again. I tried it with and without auto login but no success.
- Telnet3: I inserted in "Telnet server setup" window the "Localhost 127.0.0.1" but it does not work because it is using the Telnet2's HamAlert telnet setup (!!!) which is NOT checked in the list of "Telnet server setup" window at all.
I missing Localhost because I intesively using SDC.
What could be wrong in my setup? HELP PSE! :)
Thank you in advance, Egon / HA3MN
PS: Really enjoyed to meet you "personaly" for the first time on 10m/FT8! :)
Yes, it's mistake! Autologin is not turn off! Will be fixed!
Is here port set right? Did I understand correctly that telnet 1 and telnet 2 use localhost?
I was wrong! Autologin turn off correctly:
Вложение 324975
Please, reload picture.
Alexei,
Autologin turn off is working for Telnet1, your picture is clearly shows the solution.
Investigating my other problems, I will write again.
73 Egon / HA3MN
Alexei,
I sent an email to your qrz.com address.
73 Egon
Any idea, please?
73 Egon / HA3MN
Вложение 325021
I know what the problem is. Is here checked?
Вложение 325025
I think - yes, here is checked!
And you use "View" - therefore, the date is not saved.
Uncheck here or not use "View" when upload QSO.
Thank you Alexei!
It was checked!
I unchecked and now it is remember the downloading date!
I wouldn't have thought of that... :)
73 Egon
- - - Updated - - -
Hello Alexei,
I can't tell you more clearly, sorry.
Build 689 :
- Telnet1: NOW OK!
*** I tried it with and without auto login but no success. ***
Вложение 325027
- Telnet3:
- I inserted in "Telnet server setup" window the "Localhost 127.0.0.1 port 7373" for SDC but it does not work.
Вложение 325028 Вложение 325029
*** It is using the Telnet2's HamAlert telnet setup! ***
HamAlert's setup is NOT exist in the list of "Telnet server setup" window at all when I setup for Telnet3.
