Hello Alexei,
Using build 631
In the "QSO MANUALLY ENTRY" now you add e drop down menu for "Print Queue" field.....welll....work fine.
But you are missing "N" QSL NOT NEED please add it....
Вложение 302827
Thanks.
73 de IK2XDE Andrea.
Hello Alexei,
Using build 631
Вложение 302827
Thanks.
Many thanks Andrea! This is a big help for me! In new version I'll make here new functional.
How about variant - checkbox "Send manually" in upload window?
About LoTW: here create ADIF or tq8 file for manually upload?
Look new prerelease 632 for new work of Print Queue here:
https://forum.qrz.ru/355-loghx-appar...ml#post1792469
Yes, for EQSL and CLUBLOG
checkbox "CREATE ADIF TO SEND MANUALLY"
if checked, loghx only create an adif file, to be send manually via
web interface.
Same checkbox here.
Create ADIF file to be send manually with TQSL,
then users sign file with TQSL and send to lotw server.
Thanks.
Ok, using build 632
Вложение 302840
Please here add this choice "QSL NOT NEED" = PritQueue field = "N"
Thanks in advance.
73 de IK2XDE Andrea
A simple solution would be to create a TXT file similar to NotFoundRecord_Lotw
containing:
"New COUNTRY CONFIRMED" and
"NEW QSO CONFIRMED"
so after synchronization we can see the result.
OK....try build 633
works perfectly .... thanks .... !!
With build 633 works perfectly .... thanks .... !!
Well all work fine for me with build 633
In this section it remains for you to fix HRDLOG.
Without upsetting the program, it is enough that it puts UPLOAD
with these possibilities:
ALL QSO
SELECTED QSO
NOT SEND QSO
manually upload to server (only create ADIF)
To do this I think it is necessary to add in the log the field "HrdlogS" (Yes or No)
to know which qso's have already been sent or not to the server.
Thanks for the excellent work you are doing, and the constant commitment.
In the next few days I will ask you again for the management of the local database of managers.
73 of IK2XDE Andrea
I seem to be getting this error a lot recently in 631 Вложение 303021
What decimal separator do you use? What skin do you use (may be "broken" skin)?
About new fields in log: i'm waiting "Russian Lotw" - http://Hamlog.online :) for add fields for this QSL. I hope it will be soon. :)
Вложение 303032 and black box.asz
To M0CGF: what decimal separator here:
Вложение 303103
The same as your photo shows.
Using build 634
I try to setup "Digital Mode Windows" using RTTY.
Radio was IC-7600 mode RTTY (not USB or LSB) using FSK
So I will configure MTTY to TX with EXTFSK64.
Problem was that when I start "Digital Mode Windows" Radio go on SSB....
How can I configure to stay on RTTY....??
I find that if I disable CAT (setting NO RADIO) all work fine.
SO I think that HXCATinterface when find DIGI MODE change tu USB (using AFSK)
but I whant to stay in RTTY using FSK.
Two variants -
Вложение 303425
Uncheck Use SSB or check Not change TRX mode.
Well, everything works perfectly.....!!
Sorry but there are still some configurations / settings that I don't know.
Have you thought about how to update the management
of the managers on the local database ... ??
In the "SET FILTER WINDOW"
"Use Costum Filed" section,
Freq field was missed....please ad it....
I know that there is band filter,
but is different search for 20m qsl or for 14,260 qso.
Please add all log field here.....hi...
Thanks in advance.
