Must be
[TX]cfm {599} tu[RX]
Operation after contest.
After contest I usualy import ADIF from contest (N1MM+) to LOGHX.
I hope to have this function useful to many other users soon.
>> UTILITY <<
Update data of selected qso from qrz.com
With this function, all QSOs imported after the contest can be updated with all the data (fields)
downloaded from qrz.com ..... obviously with paid access.
Thanks in advance.
Using build 627 .....and find this utility:
UTILITY --> FIND INFO --> FOROM INTERNET -->QRZ.COM
This is what i am looking for.......great...!!
......but.... NOT update LOCATOR ...and NOT update QTH (only partial) ONLY ADDR1 field and not ADDR2 field.
Please correct it.
Thanks in advance.
73 de IK2XDE Andrea.
IMPORT ADIF....!!
FILE --> Import Adif
Can you please add date filter (from date - to date)
Thanks.
You can make it via filter:
Вложение 301527
... Hmmm, but it is for export, not for import. Do you need time filter for _IMPORT_?
Ok!
External programs for LogHX
In the new version of the log, the ability to get / insert data into the log from / to an external program will be added. Will be able to make external utilities for the log. If any want to write your own utility for the log , you are welcome! :)
Yes thanks....need date and time filter (FROM DATE <TO> DATE) and (FROM DATE and TIME <TO> DATE and TIME)
In the file menu,
we can find LOTW - EQSL and CLUBLOG,
HRDLOG is missing....!!
Please add also HRDLOG for (upload, download and synchronize).
In the clublog when we upload our log ..... please add the choice
MERGE into EXISTING LOG.....or......CLEAR LOG before UPDATE (CLEAR OPTION)
Вложение 301594
For all online log, LOTW, EQSL, CLUGLOG and HRDLOG,
please add the choice for UPLOAD
CREATE FILE TO SEND MANUALLY via web interface.
(Create file but not send automatically via LogHX)
Thanks in advance.
Andrea,
you can manually upload QSO to HRDLOG using this
Вложение 301596
Click right mouse key, in menu use "Send QSO to hRDLOg.net"
YES....but work only for single qso (only single selected qso)
I ask a full procedure like eqsl or clublog
(UPLOAD-DOWNLOAD and SYNCHRONIZE)
I think the problem comes from the fact that in the log we do not find the HrdS and HrdR field
Thanks for attentions.
@IK2XDE HRDLOg was optional functionality as I know.
Let's see what Alexey replies
I have verified and confirm that the HRDLOG fields are missing in the log.
I therefore ask Alexei to add these fields to better manage the sending of QSOs on HRDLOG,
as he has done for EQSL, CLUBLOG and LOTW.
Another request is to add the PRINTQUEUE field in the QSO manually entry / edit windows.
This field is missing.
I have my view for using WSJTX set up using the normal colours but I want to run the dark mode using the "wsjtx --stylesheet :/qdarkstyle/style.qss" on a desktop short but, when I point the wsjtx location at the shortcut it doesn't work. Any ideas how to auto run the dark mode from the view?
It is a window appeared when QSO uploading to HRDLog.net
like this
1) Selecting the QSO (for example KC1LAG)
Вложение 301624
2) See the proof of uploading
Вложение 301625
Look here:
Вложение 301669
write here:
This is for live use, when you send a qso, you see the confirmation message.
But not when maintaining and checking the log.
There is no way to see if a qso has already been sent in the past.
Thanks.
Problem with LOTW and EQSL and clublog synchronize.
Using build 627 (start log (/D=IK2XDE) because I have a lot of log.
When I select sinchronize download log and chose the file that will be /LOGHX/IK2XDE/DOWNLOAD directory....
and pres GO.....whean I press GO ......everything crashes, even windows ... and I'm forced to restart the pc.
Nessun messaggio di errore.
