OK...try IT
- Work fine for BAND/MODE STATISTIC (UTILITY->STATISTIC)
- NOT WORK for all AWARD STATISTIC
No problem, of course thanks for your effort..!!
73 de IK2XDE Andrea
I try with build 618 to setup a contest.....but NO result.
Вложение 299062
Menu SETUP CONTEST --> CONTEST
No possible to select any listed contest
ONLY GENERAL CONTEST
Вложение 299063
Menu CONTEST
Open Contest
> EMPTY <
Only General Contest in the list
Вложение 299064
File menu - NOT OPEN (not work)
73 de IK2XDE Andrea
OK with buil 619 I try to setup a contest (ARRL-INT-DX-CW)
first view I have some observation.
Вложение 299130
EXCH received (STATE) ....was NOT SAVE IN THE LOG (OK in "ContestNRreceive" field)
MULTIPLIER Windows, show only worked multipliers, my opinion is better view ALL multipliers,
probabily in RED color (NOT WORKED) - BLUE color (WORKED).
In the SCORE windows, please add also DUPE count.
And also please not write "AREA" but I think is better "MULTI"
Some other observation...next days....I will continue my test.
73 de IK2XDE Andrea
Contest mode - universal for all contests. Log do not know, that in this contest Exch is State.
Yes, it will be done.
It is ok!
It is mult-name: exapmle for CQWW:
Вложение 299220
Try CW PADDLE with TCI and my SunSDR2DX (today build 619)
Sending macros in cw ....ok.....but seem that "speed" "letter delay" and other
they don't work, they have no effect on speed.
To change speed work only BreakIn menu (EESDR version 1.3.1 update 8)
Also SET NUMBER STYLE (T12345678NT)....NOT work.
73 de IK2XDE Andrea
Running today build 619.
I have setup
RADIO1 - ICOM IC-7600 - (HXCat Interface)
RADIO2 - SunSDR2DX - TCI
BandMap work perfect with radio1 (ICOM) but when I change to Radio2 (SunSDR - TCI)
BandMap not change, stay on Radio1 and NOT WORK.
All other CAT - PTT ecc... work fine.
- Button Panels (band Map).
If I change band cick on button panels, all ok....radio change band.
If I change band from radio, BandMap change correct, but YELOW button NOT change.
73 de IK2XDE Andrea.
For apply number style - use {}:
09{09}
will send
09TN
Select SunSDR2 receiver here:
Вложение 299249
May be problem with Bandmap setup (Setup-Bandmap - do you making any changes here?)
@IK2XDE
Andrea, I am highly recommending to use special Contest Software for contesting instead of contest module in LOG.
Вложение 299318
THIS FUNCTION DO NOT WORK WITH TCI (SunSDR2DX)
But work perfectly with ICOM IC-7600 via (HXCAT Interface)
Вложение 299321
THIS FUNCTION DO NOT WORK WITH TCI (SunSDR2DX) and also with IC7600 via HXCAT
Вложение 299325
Radio 2 - SunSDR2DX was configured correct
Вложение 299326
QSO Entry windows work with no problem with TCI CAT
Вложение 299324
But BandMap DO NOT change beetwen Radio1 (Icom) and Radio2 (SunSDR)
Bandmap stay loked on radio1 and NOT change on radio 2
73 de IK2XDE Andrea
Log have two bandmaps window - for Radio1 and Radio2:
Вложение 299334
What is macros text? This function works only for macros.
OK, I will try it tomorrow evening,
I think that 2 Bandmap was for SO2R (2 VFO)
but when I am as SO1R (1 VFO), only one Bandmap work and switch radio1/radio2
.....OK....I will try.....
Thanks.
[TX]cfm 599 tu[RX]
Speed cpm / Letter Delay / Dash/Dot Delay (NOT WORK with TCI)
But work with HXCAT with ICOM IC-7600.
Thanks for attention.
73 de IK2XDE Andrea
