Fixed:
http://rx4hx.qrz.ru/files/loghx/LogH..._build_610.exe
Hello,
there is something wrong in the cluster windows.
Вложение 295323
Вложение 295324
In example you can view differece beetwen telnet windows and cluster windows.
I think problem was when find caracter < > in the spot comment.
73 de IK2XDE Andrea
Check for dupe qso (in General setup)
In the log I would like to find this function very convenient.
Do not send the qsl for the same call/band/mode (QSO DUPE).
Field PrintQueue "N"
So in the qso entry windows, if I type a call already contact in the same band and mode,
the flag "N" is automatically put in the "PrintQueue" field.
Of course I can change the field before saving the qso,
but automatically "N" is set.
"check for dupe qso" function could also be activated when I import an adif,
perhaps after a contest, where I import in my log many stations already contact
several times in previous contests.
When I import the qso from an adif after contest,
if the qso is already present in my log (same call/band/mode),
"N" is automatically put in the PrintQueue field.
Of course this function is a personal choice,
which everyone can activate or deactivate in the general setup.
Вложение 295538
Thanks for reading.
73 de IK2XDE Andrea.
Вложение 296891
Strange, been running fine for 1 year.
LogHX + Gridtracker + WSJT-X
Nothing changed but now it will not log into LogHX
The only way I can get it to work is if I use the main udp server value in LogHX but then gridtracker doesn't work.
I used to have it set up like
WSJT >>>> main UDP to Gridtracker
WSJT >>>> 2nd UDP to LogHX
If I type in the wsjt callsign box it would appear in the log entry box in loghx, now nothing. Many reboots. I even updated to 611 loghx and 2.30 wsjt but still the same issue.
Wonder why my system doesn't work
Try this version
http://rx4hx.qrz.ru/files/loghx/prer..._build_611.exe
All settings is right...
Hello Andrea,
Where can I download build 612 ?
73 Pat
Now you can choose:
Вложение 297649
http://rx4hx.qrz.ru/files/loghx/prer..._build_612.exe
I cannot find it but is there a field I can export to Excel that shows the CONTINENT of the station (ie Europe, NA, SA,OC,AF). Just need a field I can do some calculations on.
I find a little problem with BANDMAP
Вложение 297680
Вложение 297681
Hello,
Displays the information in the Radio 1 screen from qrz but not in the QRZ.COM screen from the LogHX use now buid 612.
