Страница 15 из 68 ПерваяПервая ... 589101112131415161718192021222565 ... ПоследняяПоследняя
Показано с 211 по 225 из 1015
Like Tree167Спасибо
Тема: LogHX: English version
  1. #211
    03.02.2006
    20,312
    9974
    5354
    Цитата Сообщение от IK2XDE Посмотреть сообщение
    does NOT connect the cluster via telnet.
    Fixed:
    http://rx4hx.qrz.ru/files/loghx/LogH..._build_610.exe
  2. #212
    03.01.2021
    196
    18
    Hello,
    there is something wrong in the cluster windows.
    In example you can view differece beetwen telnet windows and cluster windows.
    I think problem was when find caracter < > in the spot comment.
    73 de IK2XDE Andrea
  3. #213
    03.02.2006
    20,312
    9974
    5354
    Yes, you are right. I'll fix it today.
  4. #214
    03.01.2021
    196
    18
    Check for dupe qso (in General setup)
    In the log I would like to find this function very convenient.
    Do not send the qsl for the same call/band/mode (QSO DUPE).
    Field PrintQueue "N"
    So in the qso entry windows, if I type a call already contact in the same band and mode,
    the flag "N" is automatically put in the "PrintQueue" field.
    Of course I can change the field before saving the qso,
    but automatically "N" is set.
    "check for dupe qso" function could also be activated when I import an adif,
    perhaps after a contest, where I import in my log many stations already contact
    several times in previous contests.
    When I import the qso from an adif after contest,
    if the qso is already present in my log (same call/band/mode),
    "N" is automatically put in the PrintQueue field.
    Of course this function is a personal choice,
    which everyone can activate or deactivate in the general setup.
    Thanks for reading.
    73 de IK2XDE Andrea.
  5. #215
    Low Power
    16.04.2020
    88
    3
    Strange, been running fine for 1 year.
    LogHX + Gridtracker + WSJT-X
    Nothing changed but now it will not log into LogHX
    The only way I can get it to work is if I use the main udp server value in LogHX but then gridtracker doesn't work.
    I used to have it set up like
    WSJT >>>> main UDP to Gridtracker
    WSJT >>>> 2nd UDP to LogHX
    If I type in the wsjt callsign box it would appear in the log entry box in loghx, now nothing. Many reboots. I even updated to 611 loghx and 2.30 wsjt but still the same issue.
    Wonder why my system doesn't work
  6. #216
    03.02.2006
    20,312
    9974
    5354
    Try this version
    http://rx4hx.qrz.ru/files/loghx/prer..._build_611.exe
    All settings is right...
  7. #217
    03.01.2021
    196
    18
    First, I have configured
    "Setup LogHX" -> "Callbook" -> "Internet Database" -> "Insert data from QRZ.COM".
    This works well and correctly with new QSOs for stations never worked.
    But if I insert a QSO with a station already worked,
    the old data from the log are taken by default,
    those inserted in the previous QSO.
    Personally I prefer to always have updated and new data, taken from qrz.com,
    the correspondent may have changed qth in the meantime.
    So the ideal would be to add the possibility to choose ....
    whether to keep the old data or to force and always update with new data.
    This is chosen by the user by putting a small flag "always update data".
    I hope this option is easy ... and of interest to all users.
    - In the "Correct log data" menu I would like to have the function for
    update all the data (complete) by downloading them directly from QRZ.COM
    (obviously only for the selected QSOs and not for the entire log).
    This could be useful after converting a contest log,
    therefore without the corresponding data,
    or during the log maintenance phase, only for some selected QSOs.
    Thanks for attention.
    73 de IK2XDE Andrea
    Continue my tests with LogHX v 3.0 buid 612
    with good results.
    Can you please add this function in the next version.....THANKS....!!
    73 de IK2XDE Andrea
  8. #218
    04.01.2021
    59
    11
    3
    Hello Andrea,
    Where can I download build 612 ?
    73 Pat
  9. #219
    07.04.2002
    г.Москва, г.Троицк
    48
    9,466
    2556
    7664
    Цитата Сообщение от ON3CQ Посмотреть сообщение
    Hello Andrea,
    73 Pat
    try this
    http://rx4hx.qrz.ru/files/loghx/prer..._build_612.exe
  10. #220
    03.02.2006
    20,312
    9974
    5354
    Now you can choose:
  11. #221
    Low Power
    16.04.2020
    88
    3
    I cannot find it but is there a field I can export to Excel that shows the CONTINENT of the station (ie Europe, NA, SA,OC,AF). Just need a field I can do some calculations on.
  12. #222
    03.01.2021
    196
    18
    Great news.....thanks...!!
  13. #223
    03.01.2021
    196
    18
    I find a little problem with BANDMAP
  14. #224
    04.01.2021
    59
    11
    3
    Hello,
    Displays the information in the Radio 1 screen from qrz but not in the QRZ.COM screen from the LogHX use now buid 612.
  15. #225
    03.02.2006
    20,312
    9974
    5354
    Thanks! I will look for the reason!
    QRZ.COM
    On QRZ.COM changed folder for pictires. It will be fixed!
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
