Страница 16 из 68 ПерваяПервая ... 6910111213141516171819202122232666 ... ПоследняяПоследняя
Показано с 226 по 240 из 1017
Like Tree167Спасибо
Тема: LogHX: English version
  1. #226
    03.01.2021
    196
    18
    We all know that 340 countries are currently valid for DXCC purposes.
    Many of us, however, will probably log some QSOs with deleted entities,
    made in the past, and therefore valid.
    Qso that maybe we have regularly accredited for the award,
    and rightly we want to keep track and visibility.
    For this I ask if it is possible to integrate the DXCC statistics with these deleted entities,
    of course with a choice flag, where I can select WITH or WITHOUT "DELETED ENTITIES".
    Full list with all info here: http://www.arrl.org/files/file/DXCC/...nt_Deleted.txt
    I personally have qso with these deleted entities:
    Netherlands Antilles Is.
    St. Marte-Saba & St. Eustatius Is.
    Malyj Visosotsky Is.
    All qso made in the past, when they are valid,
    and regularly accredited for the DXCC.
    Thanks for attention.
    73 de IK2XDE Andrea.
  2. #227
    07.04.2002
    г.Москва, г.Троицк
    49
    9,498
    2570
    7707
    I am not sure I can help in this case , if Alexey could understand your request
    But
    1) Menu - Utilities - Non standard Calls
    2) Non standard calls window
    3) Press "Insert" and Add needed prefix with dates of its availability
    Second way, I am thinking, is
    1) add deleted territories to country_user.dat file
    2) When log started , Press Ctrl-C
    3) Select deleted prefix for needed QSO
    @RX4HX , your turn
  3. #228
    03.02.2006
    20,753
    10225
    5491
    I created a file with all deleted countries, but no time to add it to log.
    I'm trying do it soon.
  4. #229
    Low Power
    16.04.2020
    89
    3
    Any ideas? I haveset USER3 to CONT but it doesn't seem to pull in any data. I cannot see continent as a standard grid header to add? Just want to display AF,AS,EU,OC,NA,SA etc in a field.
  5. #230
    03.02.2006
    20,753
    10225
    5491
    New fields will be added in log soon. Pse QRX!
  6. #231
    03.02.2006
    20,753
    10225
    5491
    Done:
    https://forum.qrz.ru/355-loghx-appar...ml#post1776838
  7. #232
    03.01.2021
    196
    18
    Hello,
    With build 614, on START, I receive this error...!!
    I return back with build 613....all is ok.
    Thanks.
    73 de IK2XDE Andrea
  8. #233
    03.02.2006
    20,753
    10225
    5491
    error
    Setup->Backup->Make archiv and send me.
  9. #234
    03.02.2006
    20,753
    10225
    5491
    I’m not sure, but I found and fix same error. Please, check it:
    http://rx4hx.qrz.ru/files/loghx/prer..._build_614.exe
  10. #235
    03.01.2021
    196
    18
    Thanks....all work fine now....!!
    No error on start and
    also deleted countries in DXCC Award work very well and easy to setup.
  11. #236
    03.01.2021
    196
    18
    Now I am using build 615
    everything seems to work .... but I will continue my tests.
    Now that we can count deleted countries in DXCC,
    the graphic part should be improved,
    highlighted those deleted,
    and putting the selection Count deleted countries YES or NOT.
    About the Band / Mode Statistic
    Currently showing two values (qso worked) + (qso confirmed)
    You could please evaluate the possibility of putting the choice of single view
    (only qso worked) or the double one (worked + confirmed).
    To be able to change the sort of "mode" columns.
    Thanks.
    IK2XDE Andrea.
  12. #237
    03.02.2006
    20,753
    10225
    5491
    If I right understand, it's this:
    Uncheck "DXCC mode"?
  13. #238
    03.01.2021
    196
    18
    Menu UTILITY - STATISTIC - BAND MODE STATISTIC
    ONLY WORKED
    ONLY CONFIRMED
    ALL
    73 de IK2XDE Andrea
  14. #239
    03.01.2021
    196
    18
    ONLY WORKED
    ONLY CONFIRMED (Paper+Lotw+Eqsl selection)
    ALL (Worked / Confirmed)
    Change column position.
    Change font dimensione.
    Thanks.
  15. #240
    03.02.2006
    20,753
    10225
    5491
    About modes position: set mode position here - replace row with modes in Setup->Mode setup
    About wkd/cfm - please wait
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
