Страница 64 из 68 ПерваяПервая ... 1454575859606162636465666768 ПоследняяПоследняя
Показано с 946 по 960 из 1017
Like Tree167Спасибо
Тема: LogHX: English version
  1. #946
    03.02.2006
    20,621
    10150
    5452
    Цитата Сообщение от Jim Smith Посмотреть сообщение
    Telnet kept disconnecting
    Yes, here is some proplem! Pse QRX!
  2. #947
    Low Power
    16.04.2020
    89
    3
    Hi had the vhfstpete dll flagged today and also telnet disconnects.
    However I have an issue with the bandmap, its just not showing even though its ticked.
    I have recently changed to a new win11 PC from win10, and I am not sure if my install copied across OK as each time i load it I have various different things happening. It doesn't seen to save the views and associated radios.
    Question for everyone incase there is a better way.
    I have a view for SSB where I have a radio selected for control.
    For FT8 I have a view with wsjtx loaded, in Loghx no radio is selected and its controlled via wsjtx.
    Best way to manage it? Issue is if I want to quickly nip to ssb then its a reload of view as the reports are still +- etc.
    ignore this I managed to fix the view by copying over the ini for the bandmap from a different view.
  3. #948
    26.07.2023
    41
    4
    I'm still getting the telnet disconnects as well.. only to localhost - external ones are fine.
    Also sone UI issues..
    Firstly, on loading LogHX, I get the following 2 error windows:
    Название: Screenshot 2025-02-17 094421.png
    Название: Screenshot 2025-02-17 094401.png
    After loading, there are 2 windows that don't come up properly...
    First the Awards window - all font sizes increase by approx 35% each time the window is reopened.
    Secondly, the Frequency window. I have set it to look like this:
Название:	Screenshot 2025-02-17 094817.png
    but after reloading the software, it comes up like this:
Название:	Screenshot 2025-02-17 094740.png
    I have to re-set it each time.
    Even though I have saved the setup under "Select View" once I have it as I want, the issues still persist.
    It's worth pointing out that I have a multi-screen setup here, I don't know if that is part of the problem.
  4. #949
    03.02.2006
    20,621
    10150
    5452
    Log version?
    It's not good. I'll check it out.
  5. #950
    26.07.2023
    41
    4
    [QUOTE=RX4HX;2075109]Log version?
    Oh sorry ! Should have said.... Build 776
  6. #951
    Low Power
    16.04.2020
    89
    3
    since updating my gfx card all the views open but they seem to all appear off the screen and I cannot view the windows. REally weird.
    Is there anything I can reset in the view ini to fix this?
  7. #952
    26.07.2023
    41
    4
    While we wait and see if Alexei comes up with a solution....
    I don't have a definitive answer, but the file you're looking for is likely to be in LogHX/INI/Vews/GeneralViews then select the folder of the name of the view you are currently using. Make a copy of the loghx_view.ini, so that if this doesnt work, you still have a copy of the original.
    Change all lines starting "left" or "top" to 0 and see if that repositions your windows to where you can see them on restarting LogHX.
    I THINK that worked for me in the past.
  8. #953
    03.02.2006
    20,621
    10150
    5452
    Do you use 2 monitors? If yes, change in Windows setup main monitor.
    Or - Shift+menu for window = open window in Left=0, Top=0.
    Or -
  9. #954
    Low Power
    16.04.2020
    89
    3
    Thanks will try it.
    One more question.
    I have view for SSB and a view for FT8. I am sure before this reinstall that the SSB allowed a radio in CATHX and in FT8 view the radio was disabled. I've tried resaving the views with these settings but the radio still remains on and clashes with wsjtx for control and the radio ends up in rtty-r mode.
  10. #955
    03.02.2006
    20,621
    10150
    5452
    Do you want link CAT to View? If yes, check here -
  11. #956
    Low Power
    16.04.2020
    89
    3
    Been off the air for a while since the last rotator question.
    I have the rototar connected, it says click left SP etc on the QSO entry window. When I click the SP it just sends the Rotator to 0 deg, LP does nothing.
    Any ideas how to troubleshoot?
  12. #957
  13. #958
    Модератор
    10.12.2011
    Белоозёрский
    8,461
    5845
    7825
    Hello Ian!
  14. #959
    QRPP
    29.01.2024
    I'm new to LOG XH, and I find it great. I managed to set it up easily. However, while using it, the LOG
    window suddenly shrank for no apparent reason. Now, I can’t resize it back to its original size.
    Can someone help me? Thanks, 73 Pierre VA2CZ
  15. #960
    03.02.2006
    20,621
    10150
    5452
    Can't you stretch the window with the mouse? Show printscreen, please!
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
