Страница 61 из 68 ПерваяПервая ... 1151545556575859606162636465666768 ПоследняяПоследняя
Показано с 901 по 915 из 1017
Like Tree167Спасибо
Тема: LogHX: English version
  1. #901
    03.02.2006
    20,616
    10148
    5452
    Цитата Сообщение от IK2XDE Посмотреть сообщение
    However, I confirm that the V 767 from today 06/09/2024 works correctly with my IC-7600,
    correctly manages the split frequency, both vfa and vfob, correctly records the qso in log rxfreq and txfreq,
    on the band map the red and blue arrows are correctly displayed.
    This is very good news. It's very difficult to work with a radio that you don't have.
  2. #902
    QRPP
    05.01.2024
    41
    6
    Where can I download V758 ?TKS
    - - - Updated - - -
    V767 is still has issues:
  3. #903
    03.02.2006
    20,616
    10148
    5452
    Try this test version - http://rx4hx.qrz.ru/files/loghx/test..._build_768.exe
  4. #904
    26.10.2019
    46
    17
    9
    Addition of a comma in the County field.
    Hello Alexei,
    When importing an adif file, created by LogHX (build 768),
    I noticed the inclusion or addition of a comma in the County field of some countries.
    See the result after exports/imports in the LogHX 768 environment.
Название:	County field with comma.png
    If necessary, I can send you an .adi file with the problem described above.
    I ask for guidance to avoid the proliferation of this error.
    Thank you in advance for any help,
    73 from py5ej,
    Pavanatti.
  5. #905
    03.02.2006
    20,616
    10148
    5452
    Look here -
    https://adif.org/314/ADIF_314.htm#Se...ve_Subdivision
    Problem here:
    For JA-stations - <Two-digit prefecture code><Two-digit or four-digit city code> without comma!
    For VE-stations - there are no secondary areas and their identification!
  6. #906
    07.07.2023
    16
    3
    3
    Alexei,
    I totally agree that the county fields are been not used in the ADIF 314 standard. However, it seems that when he exported an ADIF file from LOGHX with these let say “unsupported” counties and then imported the same ADIF back in other computer, a comma (,) was added to those counties. I tested this and found that if we continuously keep exporting and reimporting the log in ADIF format, it keeps adding commas to forehead of the counties. This happens mainly because LOGHX exports counties as <CNTY:X>State,County. For supported counties, LOGHX aparently suppresses the comma, but for unsupported ones, it keeps the comma as the first character.
    From my point of view, the user should be able to write whatever they want in those fields, and export/importing shouldn’t change the values. What am I misunderstanding?
  7. #907
    03.02.2006
    20,616
    10148
    5452
    Yes! You're right! There is an error in LogHX! For export county JA-stations!
  8. #908
    Low Power
    16.04.2020
    89
    3
    All, I have just swapped PC's in the shack and trying to get everything back to how it was.
    I am having trouble with the CAT, I used to use CATHx with no issues.
    Now I get errors that the radio cannot open CatHX.
    If I try wsjtx v2.6.1 with CAThx selected with this I get
    Hamlib error: 1:icom.c(4943):icom_set_conf entered
    1:icom.c(4973):icom_set_conf returning(0)
    1:rig.c(817):rig_open entered
    rig_settings_get_path: path=.hamlib_settings
    rig_settings_load_all: settings_file (.hamlib_settings): No such file or directory
    rig_open: cwd=C:\LogHX
    rig_open: C:\LogHX/hamlib_settings does not exist
    rig_open: async_data_enable=0, async_data_supported=1
    serial_open: COM4
    serial_open(229): open failed#1
    serial_open(229): open failed#2
    serial_open(229): open failed#3
    serial_open(229): open failed#4
    serial_open: Unable to open COM4 - No such file or directory
    port_open: serial_open(COM4) status=-6, err=No such file or directory
    rig_open: rs->comm_state==0?=0
    1:rig.c(1023):rig_open returning(-6) IO error
    IO error
    IO error
    while opening connection to rig
    Timestamp: 2024-10-17T13:10:19.894Z
    However if I goto hamlib it works OK in my FT8 "View".
    In my SSB "view" modes and freqs are all different.
    How can I get back woking with CATHx?
  9. #909
    03.02.2006
    20,616
    10148
    5452
    First: you can copy folder with log to ahother PC without installation. Or install log and copy folder INI to new log path.
    Problem here - Hamlib can't open COM4. May be it's busy by WSJT-X?
  10. #910
    21.07.2022
    80
    20
    CW AutoCQ problem
    In the last version 769 there is not AUTOCQ repeated (CQ on button is red). Also Alt+R does not work, I have to click on ESC everytime.
    What I am doing bad?
    73 Josef OK2WO
  11. #911
    03.02.2006
    20,616
    10148
    5452
    Check this version -
    http://rx4hx.qrz.ru/files/loghx/test..._build_770.exe
  12. #912
    Low Power
    16.04.2020
    89
    3
    Any idea on a socket error?
    C:\LogHX\LogHX3.exe
    Socket Error:
    A Socket operation was attempted to an unreachable host.
    When loading my FT8 view, not sure if its a radio setting or a WSJTX setting? Is there an error log to give more details?
  13. #913
    03.02.2006
    20,616
    10148
    5452
    May be wrong UDP IP for WSJT-X. Look Setup for External programs -> WSJT-X -> check all IP settings here.
  14. #914
    Low Power
    16.04.2020
    89
    3
    ah looks like I had multicast ticked in error. Thanks!
  15. #915
    Low Power
    16.04.2020
    89
    3
    question on the worked confirmed window. I know you can configure the dates, however what I am trying to do is the following.
    1. Show all time status
    plus at the same time
    2. Show status for only this month, as I have a club contest to work as many dxcc each month.
    Is it possible to have both on display?
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
