Страница 51 из 68 ПерваяПервая ... 4144454647484950515253545556575861 ... ПоследняяПоследняя
Показано с 751 по 765 из 1017
Like Tree167Спасибо
Тема: LogHX: English version
  1. #751
    Low Power
    19.11.2019
    Nyirabrany
    11
    43
    Цитата Сообщение от HA3MN Посмотреть сообщение
    Hello, just a simple question...
    In the Cluster window I lost the red bracket (when I am on the given frequency).
    How can I switch it back again?
    Вложение 349824
    (This picture is NOT my Cluster window)
    The "Highlight spots on freq" is checked.
    Thank you for help!
    73 Egon
    Thank you for everyone for the helps!
    Unfortunately, my PC broke down, so I am now working with a laptop.
    I reinstalled all of LogHX, everything works fine now!
    Thank you again!
    73 Egon
    - - - Updated - - -
    Цитата Сообщение от Vlado Посмотреть сообщение
    Hi Egon
    Ctrl+E
    Vlado OM3BY
    Hello Vlado,
    Thank you for this info! I did not know it!
    You told me a new thing again!
    Thank you for your help Vlado!
    73 Egon
  2. #752
    QRPP
    16.01.2024
    3
    Hi LogHX3 friends from Steve G0UIH
    From V745 onwards.
    Changing database [I have 12 current good databases] – error as below.
    Database[s] won’t open from within the app.
    Fix is to quit the program and then re-open.
    Program then requests you to pick a log from the database you have just tried to open.
    This works [as a workaround] and the d/base opens.
    Databases are all ‘Good’ and open fine in MS Access without issues.
    No anti-virus or protection enabled
    All was good on versions before V745
    Error message = “Open ADO Connection Error”.
    I was looking to see if this is ODBC related but LogHX3 does not seem to use any ODBC entries.
    Running now V750 and error still exists.
    Any thoughts
    Very 73 – Steve G0UIH
  3. #753
    03.02.2006
    20,616
    10148
    5452
    It's strange. Send base to rx4hx@mail.ru - I'm check it!
  4. #754
    03.01.2021
    196
    18
    CAT problem with build 750
    With this version CAt not work.
    CATHX + IC7600v2
    Return to build 749 all work fine.
    Thanks for attention.
    73 de IK2XDE Andrea
    IK2XDE Andrea - WWLoc. JN45MQ
    https://www.xdenews.net/ik2xde/logonline/
    RADIO Setup (update 30/08/2025)
    ICOM IC-7600 - (HF - 50MHz.)
    SunSDR2DX - (HF - 50MHz. - 144 MHz.)
    OM Power - OM2000A+ (1.8-50 MHz. Amplifier)
    OB11-3 (11 element - 3 band - 10m-15m-20m)
    OB9-3 WARC (9 element - 3 band - 12m-17m-30m)
    SkyWire Loop (40-60-80-160 m.)
    LogHX Managers Database (update for free)
    https://www.xdenews.net/managers/
  5. #755
    03.02.2006
    20,616
    10148
    5452
    Fixed -
    http://rx4hx.qrz.ru/files/loghx/LogH..._build_751.exe
    Pse QRX! Looking for a problem!
    Fixed:
  6. #756
    03.01.2021
    196
    18
    OK confirm.
    With build 751
    CAT work fine (like before)
    Thanks.
    73 de IK2XDE Andrea
    Managers update ....!!
    Available to all users
    73 de IK2XDE Andrea
  7. #757
    07.07.2023
    16
    3
    3
    [OFF-TOPIC] Icon for my QRZ.com page
    Alexey, it is ok to use this picture on my QRZ.com page?
    Do you see any problem?
  8. #758
    Very High Power Аватар для RX3APM
    26.09.2007
    4,979
    6984
    1616
    Should be rx4hx.qrz.ru
    Not rx4rx
  9. #759
  10. #760
    03.02.2006
    20,616
    10148
    5452
    Managers update
    Today is a very pleasant day for me! Thank you very much!!!
  11. #761
    03.01.2021
    196
    18
    This is the least we can do to contribute to the best development
    of the software you have made available to us for free.
    A small clarification, which you can correct in future versions,
    in the whatsnew.txt file indicate the version of the program as Ver. 3.1 build 751 (17 January 2023 y.)
    but in reality in the program, both in the logo and in the info, everywhere it says v 3.0 and not v3.1.
    It's a small nitpick, but it's worth fixing.
    Thanks again for the great work you are doing.
    73 de IK2XDE Andrea
  12. #762
    Low Power
    19.11.2019
    Nyirabrany
    11
    43
    73 de IK2XDE Andrea
    Hello Andrea,
    I tried to save your website for the update instructions but right-click does not work.
    I used a online converter to do it.
    73 Egon
  13. #763
    03.01.2021
    196
    18
    >Hello Andrea,
    >73 Egon
    Here pdf file.
    LogHX - Managers database by IK2XDE & IK2XDF.pdf
    73 de IK2XDE Andrea
  14. #764
    Low Power
    19.11.2019
    Nyirabrany
    11
    43
    >Hello Andrea,
    >73 Egon
    Here pdf file.
    73 de IK2XDE Andrea
    As I said, I downloaded the website with a online converter.
    That is same as yours!
    Thank you for your helping Andrea!
    73 Egon
    PS: I do not use the QSL manager database but I help to others to get the best within LogHX!
    I recommended and helped to install the LogHX* to others. QSL Manager system makes it better.
    * (the Best of bests)
  15. #765
    26.07.2023
    41
    4
    Hi Alexei,
    One oddity with all recent versions since at least 732 - keep meaning to mention this.
    The Awards window... I set the fonts to optimum for my display. I close down the software and restart, and on restarting, the fonts are much larger. Shut down and restart again, and the fonts come back bigger still. Both the General (typo "Genegal" in the menu ) Table fonts and the Title/worked/confirmed. Very strange. I have to adjust them back each time I restart.
    I guess it's something to do with the user-set fonts, (I was the one who asked for the size to be made variable) maybe everyone else has the default size and are unaffected.
    - - - Updated - - -
    Just to add that the Band Review windows are similarly affected, exacerabted by the need that one has to reset each column individually......
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
