Страница 49 из 68 ПерваяПервая ... 3942434445464748495051525354555659 ... ПоследняяПоследняя
Показано с 721 по 735 из 1017
Like Tree167Спасибо
Тема: LogHX: English version
  1. #721
  2. #722
    26.07.2023
    41
    4
    Quick question about maps...
    When we use the maps in the WWLOc windows.. and zoom into each large grid (e.g. JN) the map becomes highly pixellated and "blocky". I know that is a limitation of the JPG file used to generate the map.
    Is anyone else using a much higher resolution map successfully? Is it a case of simply copying another map file in?
  3. #723
    03.02.2006
    20,753
    10225
    5491
    That's right. An image is used for WW-locator window. Of course, I can use here "Map" window. But it's more difficult.
  4. #724
    26.07.2023
    41
    4
    Yes, found a much higher res map (it's about 10MB) and it works just fine in the WWLoc window, and looks good.
  5. #725
    03.02.2006
    20,753
    10225
    5491
    Цитата Сообщение от IK2XDE Посмотреть сообщение
    Problem with manual enter from MANAGER local database
    persist also in ver. 739 dated 08/12 unfortunately I see that it is not yet correct.
    It's finally time for manager base)))
    This is how it should work. This button is for inserting current manager from the database into log window. Not for find manager for current station!
  6. #726
    03.01.2021
    196
    18
    Yes correct,
    the problem is that it doesn't verify the match of the call, and inserts any selected manager to any call... even if different.
    There should be a check here, if the call doesn't match, don't enter the manager.
    Thanks for the attention.
    73 de IK2XDE Andrea
    IK2XDE Andrea - WWLoc. JN45MQ
    https://www.xdenews.net/ik2xde/logonline/
    RADIO Setup (update 30/08/2025)
    ICOM IC-7600 - (HF - 50MHz.)
    SunSDR2DX - (HF - 50MHz. - 144 MHz.)
    OM Power - OM2000A+ (1.8-50 MHz. Amplifier)
    OB11-3 (11 element - 3 band - 10m-15m-20m)
    OB9-3 WARC (9 element - 3 band - 12m-17m-30m)
    SkyWire Loop (40-60-80-160 m.)
    LogHX Managers Database (update for free)
    https://www.xdenews.net/managers/
  7. #727
    03.01.2021
    196
    18
    Yes correct,
    73 de IK2XDE Andrea
    The problem also persists in version 141
    insert any manager to any call even if they don't match.
    Another small problem, when I insert the call in the log window,
    in the managers window it automatically positions itself on the first manager found ,
    instead it should position itself on the last, most recent one.
    73 de IK2XDE Andrea.
  8. #728
    07.07.2023
    16
    3
    3
    [ISSUE REPORT] Problem with JT/FT-modes Active Calls Window
    Hey Alexey,
    Hope you're starting the year off well. I've got a little tech puzzle on my hands. Running LogHX version 3.0 build 742, and I'm noticing a quirk—stations I've worked in FT8 are showing up as gray dupes when I'm in FT4, and vice versa. Strange, right?
    I've attached a test run with PY5EJ to give you a visual. The red arrows should point you to the head-scratcher. I don't have PY5EJ's station logged in 17M+FT4, but the system thinks otherwise. This happens with other stations as well.
    Any insights on what I might be missing? Would appreciate your wizardry to unravel this mystery.
    Cheers,
    PY5XT - Eleandro
  9. #729
    03.02.2006
    20,753
    10225
    5491
    Mode - MFSK, not FT4! All right!
  10. #730
    07.07.2023
    16
    3
    3
    There are two things here:
    1. This highlighed QSO you shown in the picture is mode MFSK and submode FST4 not FT4
    • FST4 = FST4 do not require the strict, independent time synchronization and phase locking of modes like EbNaut.
    • FT4 = FT4 uses 4-GFSK modulation, transmission takes 4.48s with a 7.5s timing window.
    2. by the ADIF standards (https://adif.org/314/ADIF_314.htm) for FT4 mode we should use mode MFSK submod FT4, as we can read in the chapter "III.B.9 Mode Enumeration"
    I have this as standard for my log, do you think this is the issue I facing? I should use FT4 instead of MFSK? I didn't get how to fix.
    Sorry
  11. #731
    03.02.2006
    20,753
    10225
    5491
    Check new 743 prerelease.
  12. #732
    03.01.2021
    196
    18
    Well,
    now when I type the DXCall in the "QSO Entry" window,
    in the manager window the cursor is positioned correctly on the last and most recent manager found.
    But the INSERT button, that inserted the manager selected,
    in the QSO entry window, in the Manager field, has disappeared
    Now please
    explain to us how works the new mask ......DXCALL - MANAGER - INSERT MANAGER...??
    It doesn't seem to work...?
    Previously, to insert a new manager it was enough to press the "INS" button,
    a new row was created, and the new data was inserted.
    (and I see that this one still works)
    I take this opportunity to wish you and your family a good end and a good start to the year.
    Happy New Year
    As always, thank you for your continued commitment to log development, on behalf of all users.
    Thank you.
  13. #733
    03.01.2021
    196
    18
    Well,
    Now please
    ok, testing
    v 743 31/12/23 09.26
    INSERT MANAGER from the "manager windows" seem work,
    bur I must type manually "manager" in the filed,
    best solution is that take it automaticaly from database.
    (the last and most recent).
    Another problem is do not overwrite the manager field in the "QSO entry" window,
    if for example there is already other information coming from qrz.com
    Thanks.
    73 de IK2XDE Andrea
  14. #734
    03.02.2006
    20,753
    10225
    5491
    Try now -
    http://rx4hx.qrz.ru/files/loghx/prer..._build_743.exe
    Happy New Year!
  15. #735
    03.01.2021
    196
    18
    Great,
    now the manager field is automatically populated with the correct manager.
    Now if I do "Insert manager" it inserts the manager into the "qso entry" window
    only if the field is empty, it does not overwrite the information coming from qrz.com
    (keep in mind that in general setup, I put "replace info" in the callbook management).
    I think at this point you will have to give priorities,
    first check on qrz.com and overwrite all the information, (if replace info is cheked)
    then, if the user type "insert manager" , force his choice, an replace field with the manager chosen from the local database.
    I hope I explained myself correctly.
    Thank you.
    73 de IK2XDE Andrea
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
