Страница 43 из 68 ПерваяПервая ... 3336373839404142434445464748495053 ... ПоследняяПоследняя
Показано с 631 по 645 из 1017
Like Tree167Спасибо
Тема: LogHX: English version
  1. #631
    03.01.2021
    196
    18
    LOGHX v. 3.0 build 723
    startin log with ....\LogHX\LogHX3.exe /D=IK2XDE
    Do NOT read last view template.
    I must select my view template that I save and load it.
    LOG NOT save LAST view template as default.
    73 de IK2XDE Andrea
    IK2XDE Andrea - WWLoc. JN45MQ
    https://www.xdenews.net/ik2xde/logonline/
    RADIO Setup (update 30/08/2025)
    ICOM IC-7600 - (HF - 50MHz.)
    SunSDR2DX - (HF - 50MHz. - 144 MHz.)
    OM Power - OM2000A+ (1.8-50 MHz. Amplifier)
    OB11-3 (11 element - 3 band - 10m-15m-20m)
    OB9-3 WARC (9 element - 3 band - 12m-17m-30m)
    SkyWire Loop (40-60-80-160 m.)
    LogHX Managers Database (update for free)
    https://www.xdenews.net/managers/
  2. #632
    03.02.2006
    20,753
    10225
    5491
    Yes, it's new function: if "View" selected in profile or here
    open selected "View", else - last opened "View".
  3. #633
    Low Power
    19.11.2019
    Nyirabrany
    11
    43
    Hello Alexei,
    Updated to 723 and I got a error message when I click in Award:RDA window. 722 is OK.
    Can't close any windows, I have to kill the process and restart the program.
    TU 73 Egon / HA3MN
    PS: I tried AwardXCC, same error.
  4. #634
    03.02.2006
    20,753
    10225
    5491
  5. #635
  6. #636
    14.03.2022
    Oud-Turnhout
    59
    13
    4
    Is there a solution? I am using EESDR V3 with 2 RX open.
    I use RX1 for SSB and RX2 for JTDX.
    Problem when I start JTDX, RX1 also goes into DIGU.
    I use both RX1 and RX2 over TCI, see photo setup.
    73 Pat
Название:	Schermafbeelding 2023-03-21 195432.png
  7. #637
    15.04.2021
    80
    12
    3
    Problem with views vers. 725
    Hello,
    from vers. 725 I have serious problems with views. F.e. my main view is FT8 where should be No Radio and external program is MSHV (Freq and Mode are marked as from MSHV). If I save this view and open again, the Hamlib is marked as ON (why?) together with No Radio, the mode on radio is changed from USB-D to RTTY-R (why??) and MSHV is started up (it is not wanted in settings). If I want to stop MSHV temporarily, no matter if from LogHX panel or from MSHV directly (f.e. I need to make quick CW QSO) both programs are stopped and started again with the same problems (loop?).
    No problem with previous versions.
    Any idea?
    Josef OK2WOНазвание: logHX_2.jpg
  8. #638
    15.04.2021
    80
    12
    3
    Solved.
    I had to change the views setting and restart several times - now it is OK. Sorry for the note. 73 Josef OK2WO
  9. #639
    03.02.2006
    20,753
    10225
    5491
    Fixed:
    https://forum.qrz.ru/355-loghx-appar...ml#post1952906
  10. #640
    15.04.2021
    80
    12
    3
    MMVARI - Macros panel missed
    Sri boys, with the testing of MMVARI functions I accidentally closed Macros panel. What it can be added back? Thanks for help. Josef OK2WO
  11. #641
    03.02.2006
    20,753
    10225
    5491
    Цитата Сообщение от Josef OK2WO Посмотреть сообщение
    added back?
    You can not 100% сlose macros panel.
    Look at here:
    Pull mouse here.
    Or -
    LogHX\INI\loghx_view.ini - section [DigitalForm] -
    MacrosPanel_Height=100 - set here 100.
  12. #642
  13. #643
    15.04.2021
    80
    12
    3
    New (nonstandard) contest setup - how to?
    Hello,
    does exist some help (how-to) for the setting of the new contest (if DLL does not exists) ?
    For example VHF Reg. 1 CW/SSB contests, or local activity contests, where are QSO nr, WW loc and special exchange (QTH, name) are sent...
    I tried to make macros but [myloc], [myqth] etc. do not work...
    73 Josef OK2WO
  14. #644
    03.02.2006
    20,753
    10225
    5491
    This is in the plans. I hope I'll do it soon.
  15. #645
    07.04.2002
    г.Москва, г.Троицк
    49
    9,498
    2570
    7707
    Have you heard that there're contest software available to work with in each contest?
  1. LogHX: Актуальные релизы и история изменений.
    Ответов: 971
    Последнее сообщение: 08.01.2026, 00:04
  2. DIY UW3DI (for English OPs)
    от UU2JET в разделе КВ: UW3DI
    Последнее сообщение: 18.01.2013, 12:04
  3. KENWOOD TS-2000 (Black Version)
    от UA3IRS в разделе TS-2000
    Последнее сообщение: 16.11.2009, 20:16
  4. Navitel 2.0 Pocket PC Version
    от RX3AOE в разделе APRS
    Последнее сообщение: 26.09.2006, 03:39
  5. windows 64 bit version не ставится
    от UR4LZW в разделе Программное обеспечение
    Последнее сообщение: 12.09.2005, 23:58
